重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | ANT1 | CON_MM9329-2700 | NC | CON_MM9329-2700 | ANT2 | ANT-2P-846 | | CON_14-2500-0001-00 | ANT3 | CON-2017.01.2510.00 | GTA-1.6CF(70) | GPS_ANT | BPZ1 | BPZ | | BPZ | CN3 | B_TO_B_80PIN_MALE | IMSA-9828B-60Y921 | B_TO_B_84PIN | D1 | SDSMC2723BAA | NC | DD | D8 | SMA | SMA_B340A | SMA-SMB | D9 | SD0805 | 1N4148 | DIODE4148 | D10 | SD0805 | 1N4148 | DIODE4148 | D12 | SDSMC2723 | 1-5SMC24AT3 | DD | D13 | SMA | SMA_B340A | SCHOTTKY | D14 | SD0805 | 1N4148 | DIODE4148 | DD1 | TO-252-TAA | STPS15H100CB | PNP_2 | DL5 | DLW21S_SQ | ACM2012-121-2P-T001 | TDKZJYS81 | E23 | AE6_5 | 47UF/25V | CAP_E_3 | ESD1 | ESD | ESD | ESD2 | F1 | SF1206A | SMD1812P260TF/12 | FUSE1206 | F2 | FU0805 | 100MA/12V | FUSE0805 | F3 | SF1206 | 500MA/12V | FUSE1206 | IC1 | IC_TDA7719 | TDA7719 | IC_TDA7719 | IC7 | SOT-23-5 | XC6228D332VR/TLV70233DBVT | XC6209B332MR | IC19 | IC_IVT_BLUESOLEIL_I38EA | IVT_BlueSoleil_i50e | IC_IVT_BLUESOLEIL_I50E | ISO28P1 | ISO28PAAAAAAA | | ISO28P | J1 | DZ60_DEBUG | | HEADER_3X2 | J2 | CN-SMD60P-H-0.5-A | CON-60PIN-0.5-DOWN(HannStar TFT) | CON60 | JP4 | HOLE118-8STAR | CON9 | CON9 | L1 | 0805/L | 1.8UH | INDUCTOR_2 | L2 | 1206/FB | FB121 | INDUCTOR_3 | L3 | 1206/FB | FB121 | INDUCTOR_3 | L4 | NFE31PT | NFE31PT222Z1E9D_6A | CAP_FEED | L8 | L1608-330 | 330UH | INDUCTOR2 | L9 | 1206/FB | 215nH | INDUCTOR | L10 | 0805/FB | 270nH | FB_S_2 | L12 | 1206/FB | 3.3uH | INDUCTOR_3 | L26 | CDR7D28MN | 10uH | L | L30 | 0805/L | 27nH | INDUCTOR_2 | L31 | NFM21C | NFM21CC471R1H3 | EMIFIL | L32 | 0603/L | 15NH | L2 | L34 | CDR7D28MN | 10uH | L_3 | L35 | 0805/FB | FB31R | L_3 | L36 | CDR7D28MN | 10uH | L_3 | MU1 | IC_JN3.B3A2.LR | NEO-6M | IC_JN3.B3A2.LR | Q1 | TO-252-T | _2SA2072TLQ | PNP_2 | Q2 | SOT-23 | PMBT3904 | NPN3 | Q4 | SOT-323 | DTC114EUA | DTC_114 | Q6 | SOT89 | BCX53-16 | PNP | Q8 | TO-252-T | _2SA2072TLQ | PNP_2 | Q12 | SOT-323 | DTC114EUA | DTC_114 | Q21 | SOT-23 | PMBT3904 | NPN3 | U1 | PCM5102AA | S U4 | PCM5102A | U4 | HVQFN32-5X5 | TEF6686 | NXP665X | U5 | SOT1117-223 | TLV1117LV33DLYR-3.3 | VOLTREG | U6 | SO8 | LM9076BMA-3.3 | LM22670 | U7 | SOT1117-223 | TLV1117LV33DLYR-3.3 | VOLTREG | U8 | SO-G14 | TPS54386PWPRQ1 | TPS54386-Q1 | U10 | S-PWQFN-N16A | TPS2543 | TPS2543 | U13 | SQFP10X10-64AA | S9S08DZ60MLH_DZMCU | MC9S08DZ60 | U15 | SOT-143 | TC1270ASVRCTR | MIC811 | U16 | SO-G14 | TPS54386PWPRQ1 | TPS54386-Q1 | U20 | FLEXIWAT25/TDA7386 | TDA7388 | 7388 | U24 | SO14 | BA14741F | BA14741 | U25 | SSOP5 | LT1931ES5 | LT1931 | Y1 | SMHF-49B | 4MHz_SMHF-49B | XTAL | Y2 | SMHF-49B | 4MHz | XTAL_2 |
重要提示:PCB作品文件展下载说明
