老吴 发表于 2020-2-18 11:53:03
ITE的IT9852+ALC5616+AW8733 做的楼宇安防对讲主板PCB和原理图共
NamePCB DecalValuePart TypeCM1CHOKE_0805Choke_0805CHOKE_0CM2CHOKE_0805Choke_0805CHOKE_0CON1TU1252WNV-05TU1252WNV-05HEADER_4_5CON2CKS-001FA-A1NWUSB Port AUSB_PORTA_1CON3CON_MINI-USB-0.8-1USB_Mini BUSB_PORT_MINI_BCON4FPC-05-50PAT070TN92_FPC_P0.503._AT070TN92_FPC_P0.5D1SOD323FRB751VDIODE_2D2DO-214ACSS24LDIODE_ZENER_0D6SOT-523NC/Rclamp0502B_SC-75_3LDZ_DUAL_CA_KKJ_3D7SOT-523NC/Rclamp0502B_SC-75_3LDZ_DUAL_CA_KKJ_3D8SOD323FRB751VDIODE_2D9SOD323FRB751VDIODE_2D10SOT-523Rclamp0502B_SC-75_3LDZ_DUAL_CA_KKJ_3D11SOT-523Rclamp0502B_SC-75_3LDZ_DUAL_CA_KKJ_3D12DO-214ACSS24LDIODE_ZENER_0D13D0603LED_RedLED_0D14DO-214ACSS24LDIODE_ZENER_0D15SOT23-3P-1/GSD-1BAS40-04BAS40-04_0D16SOT23-3P-1/GSD-1BAS40-04BAS40-04_0F1F1206MF-NSMF150-2THERMAL_FUSE_0H1MTG3.0HoleTEST_POINT_0H2MTG3.0HoleTEST_POINT_0H3MTG3.0HoleTEST_POINT_0H4MTG3.0HoleTEST_POINT_0J2FPHSI-102T1W000FPHSI-102T1W000HEADER_2_1J3TSH-369PHONEJACK STEREO SWPHONEJACK_STEREO_SW_1J4FPHSI-110T1W000HEADER 10/2.0HEADER_8_3J5HEADER3X1/2.0HEADER3X1/2.0HEADER_5_2J6FPHSI-104T1W000FPHSI-104T1W000HEADER_4_2J7HEADER5X1/2.54HEADER 5X1/2.54HEADER_5J8FPHSI-105T1W000HEADER 5HEADER_5J9FPHSI-103T1W000FPHSI-103T1W000HEADER_3_3J10FPHSI-105T1W000FPHSI-105T1W000HEADER_8_2J11FPHSI-105T1W000FPHSI-105T1W000HEADER_8_2J12HEADER2X1/2.0HD 1x2_2.0mmHEADER_1X2_0J13TU1252WNV-06TU1252WNV-06HEADER_10_1J14HEADER2X1/2.54HEADER 2HEADER_2J15SCD473DC_JACK-5V5V_POWER_SOCKET_0L2ZAD-4030LPC5015FT-2R2M-AINDUCTORL3ZAD-4030LPC5015FT-2R2M-AINDUCTORL4ZAD-4030LPC5015FT-2R2M-AINDUCTORL5ZAD-604510uHL_SMD_15UH_3.2AL6ZAD-604510uHL_SMD_15UH_3.2AQ1SOT23-3P-1/GSDTSM2301MOSFET_P_2Q2SOT23-3P-1/GSD-1MMBT3904NPN_3RN6RP0402X433RRESARR_IS_4/SORST_KEY1PSW_STS-076System_RSTSW_PUSHBUTTON_1U1LQFP-128P-E/0.4/14X14IT9852IT9852_2U2SOT23-3P-1/GSD-1TS3809CXFTS809CXC_1U3TSOT25-5P/0.95/3X3VP3162EUP2584A_0U4TQFN-16P/0.5/3X3G5520-TQFN3X3-16CAT7202_0U7QFN-32P/0.4/4X4ALC5616SP3232EU_4U8QFN-20P/0.4/3X3AW8733SP3232EU_0U10SOP-8P/1.27/5X8MX25L12835FM2I-10GNORFLAH_EN25B16U11SO-8P/1.27/5X6SP485_SOICN803._SP458_SOICNU12FPC-05-6PNC/To_Capacitor TouchTO_TOUCH_0U13TSOT25-5P/0.95/3X3G5728T0105._IT7831TS_TSOT25U14TSOT25-5P/0.95/3X3ETA3409/2A_out05._IT7831TS_TSOT25U15TSOT25-5P/0.95/3X3G5728T0105._IT7831TS_TSOT25U16C2002-C-00Macro SD ConMACRO_SD_CON_2Y1XTAL-HC49USY212MHzCRYSTAL_0_2Y2SF-321532.768kCRYSTAL_2
老吴 发表于 2020-2-18 11:54:48
PCB和原理图一起打包。回复可见下载。
**** Hidden Message *****
ai317 发表于 2020-2-18 11:56:48
好复杂的设计,应该是大厂货了
似水流年 发表于 2020-2-18 12:27:50
ftx1984 发表于 2020-2-18 12:43:08
bingo426 发表于 2020-2-18 12:58:23
cmyldd 发表于 2020-2-18 13:43:12
好好
cityhu 发表于 2020-2-18 17:02:52
yhgwork 发表于 2020-2-18 23:39:59
不错的PCB文件
清心如水 发表于 2020-2-19 08:17:52
页: [1] 2 3 4 5 6 7
查看完整版本: ITE的IT9852+ALC5616+AW8733 做的楼宇安防对讲主板PCB和原理图共
