armclub 发表于 2021-2-1 19:14:21
4层电脑主板PCB文件共享
REFDESCOMP_DEVICE_TYPESYM_NAMEAUDIO1AUDIO-JACK5PAUDIO-JACK5PAUDIO2A2004WV-2X4PA2004WV-2X4PBATBATBATBZBZ-HY-21B-9MMBZ-HY-21B-9MMCP11SMC8P4C-0402SMC8P4C-0402CPUFANFAN4P-AFAN4P-AD1SD05SD05D2SOD-123-AISOD-123-AID3SOT23SOT23D4SOT23SOT23D5SOT23SOT23D6DO-214ACDO-214ACD7SOD-123-AISOD-123-AID8SOD-123-AISOD-123-AID9SOD-123-AISOD-123-AID18DO-214ACDO-214ACD19DO-214ACDO-214ACD20SOD-123-AISOD-123-AID21SOT23SOT23D22SOT23SOT23D23SOD-123-AISOD-123-AID24SOT23SOT23D25SOT23SOT23D26SOD-323SOD-323D27SOD-323SOD-323D28SOD-123-AISOD-123-AID29SOD-323SOD-323D30SOD-123-AISOD-123-AID31SOT23SOT23D32SOT23SOT23D39SOD-123-AISOD-123-AID40SOT23SOT23D41SD05SD05DC_OUT2DC-00052DC-0005DIOCON2PA_2-54MMCON2PA_2-54MMEC1EC6_3P2_54DIPEC6_3P2_54DIPFS15FUSE-AFUSE-AFS16FUSE-SMD2410FUSE-SMD2410FS17FUSE-AFUSE-AFS18FUSE-AFUSE-AFS19F1206F1206FS20F1206F1206FS21F1206F1206H1MH9A-8D4MMMH9A-8D4MMH2MH9A-8D4MMMH9A-8D4MMH3MH9A-8D4MMMH9A-8D4MMH4MH9A-8D4MMMH9A-8D4MMINVA2501WV-5PA2501WV-5PJCMOSCON3PA_2-54MMCON3PA_2-54MMJCOM2_SELH2N20X-2X12D0-AIH2N20X-2X12D0-AIJCOM1CON2X3PA_2-54MMCON2X3PA_2-54MMJCOM2CON2X3PA_2-54MMCON2X3PA_2-54MMJCOM3CON2X3PA_2-54MMCON2X3PA_2-54MMJCOM4CON2X3PA_2-54MMCON2X3PA_2-54MMJCOM5CON2X3PA_2-54MMCON2X3PA_2-54MMJCOM6CON2X3PA_2-54MMCON2X3PA_2-54MMJFRONTA2004WV-2X5PA2004WV-2X5PJFRONT1CON2X5PA_2-54MMCON2X5PA_2-54MMJLPCHEADER2X5P_2MM-SMD-N10-AIHEADER2X5P_2MM-SMD-N10-AIJLVDSCON3PA_2-54MMCON3PA_2-54MMJLVDS_MODEHEADER2X3P_2MM-SMD-AIHEADER2X3P_2MM-SMD-AIJLVDS_SELHEADER2X4P_2MM-SMD-AIHEADER2X4P_2MM-SMD-AIJPWR_SELCON3PA_2-54MMCON3PA_2-54MMJSPIHEADER2X4P_2MM-SMD-AIHEADER2X4P_2MM-SMD-AIJVFD_SELCON2X3PA_2-54MMCON2X3PA_2-54MMKB_MSPS2-CPS2-CL1L-WSRPG0503L-WSRPG0503L2APL1108P-R60MAPL1108P-R60ML3L-WSRPG0503L-WSRPG0503L4L-WSRPG0503L-WSRPG0503L5L-WSRPG0503L-WSRPG0503L6APL0806P-1R0MAPL0806P-1R0ML7L0603L0603L8L0603L0603L9APL0806P-1R0MAPL0806P-1R0ML10APL0806P-1R0MAPL0806P-1R0ML11L-WSRPG0503L-WSRPG0503L12APL0806P-1R0MAPL0806P-1R0ML13L-WSRPG0503L-WSRPG0503L143D16FS3D16FSLCD1A1001WV-S-F-2X15PA1001WV-S-F-2X15PLCD2A1001WV-S-F-2X15PA1001WV-S-F-2X15PLED1LED0603-AILED0603-AILPTD-SUB25P-FEMALED-SUB25P-FEMALEMCRA2001WV-6PA2001WV-6PMINI-PCIEMPCET-S5201-TP40-CMPCET-S5201-TP40-COSCOSC-DSC1025-5X3-2MMOSC-DSC1025-5X3-2MMPWR1POWER-JACK-4PPOWER-JACK-4PPWR2C4255WV-2X02PC4255WV-2X02PQ1TO252-GDSTO252-GDSQ2TO252-GDSTO252-GDSQ3SOP8A_1-27SOP8A_1-27Q4PQFN08APQFN08AQ5TO252-GDSTO252-GDSQ6SOT23-GDSSOT23-GDSQ7SOT23-GDSSOT23-GDSQ8SOT23-BCESOT23-BCEQ9PQFN08APQFN08AQ10SOT23-GDSSOT23-GDSQ11SOT23-BCESOT23-BCEQ12PQFN08APQFN08AQ13PQFN08APQFN08AQ14SOT23-BCESOT23-BCEQ15PQFN08APQFN08AQ16SOT23-BCESOT23-BCER620SMR2010-B-AISMR2010-B-AIR621SMR0402SMR0402RN1SMR8P4RA-0402SMR8P4RA-0402RN2SMR8P4RA-0402SMR8P4RA-0402RN39SMR8P4RA-0402SMR8P4RA-0402RN404P2R4P2RRN414P2R4P2RRN424P2R4P2RRN434P2R4P2RRN44SMR8P4RA-0402SMR8P4RA-0402RT1SMR0603SMR0603RT2CON2PA_2-54MMCON2PA_2-54MMRT3SMR0603SMR0603RT4SMR0603SMR0603SATA1SATA-7PS-DIP-CMSATA-7PS-DIP-CMSATA2SATA22P-DIP-180D-AISATA22P-DIP-180D-AISATA_PWRA2501WV-4PA2501WV-4PSO-DIMM1ASODIMM3-U2RN-BOTSODIMM3-U2RN-BOTSO-DIMM1SODIMM3-ASOA62-UARNSODIMM3-ASOA62-UARNSP1GND_ISOLATIONGND_ISOLATIONSP2GND_ISOLATIONGND_ISOLATIONSPK_OUTA2001WV-4PA2001WV-4PSYSFANFAN3P-AFAN3P-AU1PSOP8_1-27MMPSOP8_1-27MMU2SOT-89-5PSOT-89-5PU3SOP8A_1-27SOP8A_1-27U4PSOP8_1-27MMPSOP8_1-27MMU5SOT-89-5PSOT-89-5PU6QFN32-5X5MM_0-5QFN32-5X5MM_0-5U7FTG256_1MM-17X17FTG256_1MM-17X17U8PNV22MMR07PNV22MMR07U9PSOP8_1-27MMPSOP8_1-27MMU10SOP8A_1-27SOP8A_1-27U11SOT23-6PSOT23-6PU12FBGA84P_0-8MM-10X12-5FBGA84P_0-8MM-10X12-5U13SSOP28E_0-65SSOP28E_0-65U14SOP8A_1-27SOP8A_1-27U15SC70-5PSC70-5PU16SOT-89-5PSOT-89-5PU17SC70-5PSC70-5PU18SOT23-6PSOT23-6PU19MLF56_0-4-7X7MMMLF56_0-4-7X7MMU20SSOP28E_0-65SSOP28E_0-65U21PSOP8_1-27MMPSOP8_1-27MMU22RCLAMP0524P-BRCLAMP0524P-BU23BGA360_TGPBGA360_TGPU24PSOP8_1-27MMPSOP8_1-27MMU25SC70-5PSC70-5PU26SO-8ASO-8AU27SC70-5PSC70-5PU28SO-8ASO-8AU29PQFP128J_0-5PQFP128J_0-5U30LQFP48B_0-5LQFP48B_0-5U31SOIC8_50-150-200SOIC8_50-150-200U32SOP8A_1-27SOP8A_1-27U33SSOP28E_0-65SSOP28E_0-65U34SSOP28E_0-65SSOP28E_0-65U35SSOP28E_0-65SSOP28E_0-65U36SSOP28E_0-65SSOP28E_0-65U37QFN48_0-5-7X7MMQFN48_0-5-7X7MMU38SO-8ASO-8AU39RCLAMP0524P-BRCLAMP0524P-BU40QFN48-RTL8111EQFN48-RTL8111EU41RCLAMP0524P-BRCLAMP0524P-BU42RCLAMP0524P-BRCLAMP0524P-BU43SOT23-6PSOT23-6PU44RCLAMP0524P-BRCLAMP0524P-BUSB1_COM4USB-COM-24P-UB11123USB-COM-24P-UB11123USB2_LANUSB-LAN-30P-JFM24U1-OUSB-LAN-30P-JFM24U1-OUSB3CON2X5PA_2-54MM-N9CON2X5PA_2-54MM-N9VGA1_COM2COM-VGA-2IN1-301COM-VGA-2IN1-301VGA2A2004WV-2X5PA2004WV-2X5PX1XTAL-FSX-5LXTAL-FSX-5LX2XTAL-MC-146XTAL-MC-146X3XTAL-FSX-5LXTAL-FSX-5L
armclub 发表于 2021-2-1 19:16:42
PCB文件。5金币下载。
yaodaoji 发表于 2021-2-1 19:25:35
nj20044 发表于 2021-2-2 00:40:42
nfsden 发表于 2021-2-2 01:02:24
感谢分享
longxuekai 发表于 2021-2-2 04:13:05
学习了吧
kanxue_nmg 发表于 2021-2-2 07:32:27
yushibin 发表于 2021-2-2 07:33:30
单枪舞九州 发表于 2021-2-2 07:54:42
支持
mirage 发表于 2021-2-2 07:57:23
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 4层电脑主板PCB文件共享
