中兴ZX279100A+GN25L95+RTL8192ER+Le9641做的千兆光猫 路由器PCB 原理
设计挺牛逼的 2层板。NamePCB DecalPart TypeValueANT1RF-CABLE-CON2RCA_JACK_1U.FL-R-SMTANT2RF-CABLE-CON2RCA_JACK_1U.FL-R-SMTANT3ANT-TEMPRCA_JACK_1U.FL-R-SMTANT4ANT-TEMPRCA_JACK_1U.FL-R-SMTBS1BOSA_APATAB2481-564-20-SU-4C-12_5AB2481-564-20-SU-4C-12CON1CON20VP2R54-1X3TMCON5X1_MALE_CONSOLE_SIP_7CON5X1,Male,Console,SIPCON2CON20VP2R54-1X2TMCON5X1_MALE_CONSOLE_SIP_5CON5X1,Male,Console,SIPCON4CON20VP2R54-1X5TMCON5X1_MALE_CONSOLE_SIP_8CON5X1,Male,Console,SIPCON6DIP/2.0-1X4CON5X1_MALE_CONSOLE_SIP_11CON5X1,Male,Console,SIPCON7DIP/2.0-1X4CON5X1_MALE_CONSOLE_SIP_11CON5X1,Male,Console,SIPD3SOD-123BAT46WSS10100FLD5SOT-23DIODE_SOT23_SINGLEBAV99D6SOT-23DIODE_SOT23_SINGLEBAV99D8LL34DIODE_SCHOTTKY_0LUDZS5/0.5W/5.1V/NCDSW3SOT23DIODE_SOT23_SINGLE_4SOT23_SINGLEDSW4SMADIODE_0_2ES1DECP1ECAP-5.0-10X12CAPACITOR_POL470uF/25VECP2ECAP-5.0-10X12CAPACITOR_POL470uF/25VJ1DC-JACK-180POWER_JACK_2DC电源插座J2CON90RS2R00-4TMCON_USB-A_RAV_AMP1734775CON/USB/A/RAVJ5RJ11-1PORT-180RJ11_0_2RJ11/6P4CJ6RJ45-4PORT-180PHJ8X4_0P64/13Z/0AG9K1SW2PSW_PUSHBUTTON_0轻触开关L1FCD754R7MINDUCTOR_FERRITE4.7uH/3AL2FCD754R7MINDUCTOR_FERRITE4.7uH/3AL3IND2SM-4R0X4R5INDUCTOR_FERRITE2.2uH/2.6A/NCL4FCD754R7MINDUCTOR_FERRITE4.7uH/3AL5L0402INDUCTORLQG15HS4N7S02/4.7nHL6L0402INDUCTORLQG15HS4N7S02/4.7nHL12L0402INDUCTOR600R/100MHz/300mA/DCRL13LS-SNR4030INDUCTOR_FERRITE6.8uH ±20%/4*4*1.8mmL23L/IND/SMD/LQM2MP_G0/1008INDUCTOR_FERRITE0RL25SWPA4030SINDUCTOR_04.7uHQ3SOT23C23012305 PEMOSFET/NCRVR2CAP-A-5MMVARISTORPPL09500MA0C0YN1/NCRVR3CAP-A-5MMVARISTORPPL09500MA0C0YN1/NCRVS1RES0805RESISTOR_21M/1%RVS2RES0805RESISTOR_20RRVS3RES0805RESISTOR_20RSW1POWER-SWITCH-180POWER_SWITCH_5电源开关SW3SW2PSW_PUSHBUTTON_0_2SW,PushButton,RA,DIP4T2TR20-H2001DGH2001DG_0H2001DGT3TFM18-1P78X4P8MT0864G1801DGT6DIP-12H2001DG_0_2FE/DIP/12U1SOP6-0280-0950-1MP1583_1SY113BADC/RT7294CU2SOP6-0280-0950-1MP1583_1SY113BADC/RT7294CU3SOT23-5-BURT8059GJSU4SOP6-0280-0950-1MP1583_1SY113BADC/RT7294CU5TSSOP8AT24C08-10TC-1_2.8AT24C08-10TC-1.8U6GN25L95GN25L95_6GN25L95U7TQFN16MP3430_8MAX15059AETE+U8TSOP12X18R4-48TMP_0NAND,Flash,x8,TSOP48U11PBGA19X19F0325-0R80-NZX279100AZX279100AU12R-PBGA9R0X15R5-96-0R80-2H5PS1G83KFR-S6C_19H5PS1G83KFR-S6CU14SO-8P-127TISP61089_BD/HDTISP61089BDU15QFN48ZLMISLIC_56_ABS_5Le9641U16SOT-223-GOIAME1117_4AME1117-1V5WANT1JACK-COAXIAL-3PJACK-COAXIAL-3P_0NI/911-001-0006RLFWANT2JACK-COAXIAL-3PJACK-COAXIAL-3P_0NI/911-001-0006RLFWANT3RJ45R_275R/5%WANT4RJ45R_275R/5%WANT5RJ45R_275R/5%WANT6RJ45R_275R/5%WU1QFN7X7-56-G4R6X4R6-BRL5760_0RTL8192ERWX1XTAL/D1BCRYSTAL25.000M/10ppm/13pFX1TRAN48SM-12R2X27R8/21000BASE-T_DUALPORT_XFORMER_0H5014X2TRAN48SM-12R2X27R8/21000BASE-T_DUALPORT_XFORMER_0H5014X3SSOT-6FDV301N_NCHL_25V_220MA_ROHS_0FDC86244Y1XTAL/D1BTSX-3225_125.000M/10ppm/13pF PCB 原理图,GERBER 。生产工艺要求。贴片坐标等整套资料
原理图ORCAD格式。
5个RMB 。没需要的,看看图片就好。
支持 谢谢分享
