没画完的14层 服务器主板PCB文件共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEATX_PSU1ATX_2X10P_4D2MM_H12D833502-Power,20PIN,180D,ATX_2X10P_4D2MM_H12D8B1FB0603600ohm_1AFB0603BT1BATCON3P_5MM_H21-KST3PIN,180D,BATCON3P_5MM_H21-KSTBZ1BZ_2P_12_6D5MM_H9BUZZER-5VBZ_2P_12_6D5MM_H9CN3SFP_2X10P_53D5X16D06X14D933614-OpticalFiber,20PIN,90D,SFP_2X10P_53D5X16D06X14D9CN4SFP_2X10P_53D5X16D06X14D933614-OpticalFiber,20PIN,90D,SFP_2X10P_53D5X16D06X14D9CON5H3P_2D54MM_H8D63PIN,180D,P:2.54mmH3P_2D54MM_H8D6CON6HSMD2X4P_1D27MM_H5D9733503-Header,8PIN,180D,P:1.27MMHSMD2X4P_1D27MM_H5D97CON7H2X5P_2D54MM_H8D6-K109PIN,180D,P:2.54mmH2X5P_2D54MM_H8D6-K10CON8WAFER_4P_2MM_H6D133505-WiretoBoard,4PIN,180D,P=2.0mmWAFER_4P_2MM_H6D1CON9HB2X5P_2MM_H5D733503-Header,10PIN,180D,P=2.0mmHB2X5P_2MM_H5D7CON10FPC20P_D5MM-IMSA-9637S-20Y90520PIN,90D,P:0.5mmFPC20P_D5MM-IMSA-9637S-20Y905CON11HSMD2X10P_1D27MM_H733503-Header,20PIN,180D,P=1.27mmHSMD2X10P_1D27MM_H7CON12HSMD2X4P_2D54MM_H10D48PIN,180D,P:2.54mmHSMD2X4P_2D54MM_H10D4CON13HSMD2X4P_2D54MM_H10D48PIN,180D,P:2.54mmHSMD2X4P_2D54MM_H10D4CPLD_PS_ON1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6CX6_P1V2_1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6CX6_P1V8_1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6CX6_VCORE1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6D1SOT23_ACABAT54CSOT23_ACAD4D_SOD-523_ROHMRB520SM-30T2RD_SOD-523_ROHMD7D_SOD-523_ROHMRB520S-30-TE61D_SOD-523_ROHMD8D_SOD-323_PANJIT1N4148WSD_SOD-323_PANJITD9D_SOD-523_ROHMRB520S-30-TE61D_SOD-523_ROHMD12D_SK36ARB051L-40_40V_3AD_SK36AD13D_SOD-323_PANJIT1N4148WSD_SOD-323_PANJITD14D_SOD-323_PANJIT1N4148WSD_SOD-323_PANJITD15D_SOD-323_PANJIT1N4148WSD_SOD-323_PANJITD24D_SOD-323_MCCSCS501VD_SOD-323_MCCD25D_SOD-523_ROHMRB520S-30-TE61D_SOD-523_ROHMD37D_SLP2510P8_SEMTECHAZ1045-04F.R7GD_SLP2510P8_SEMTECHD38D_SLP2510P8_SEMTECHAZ1045-04F.R7GD_SLP2510P8_SEMTECHD39D_SLP2510P8_SEMTECHAZ1045-04F.R7GD_SLP2510P8_SEMTECHD40D_SLP2510P8_SEMTECHAZ1045-04F.R7GD_SLP2510P8_SEMTECHD41D_SOD-323_PANJIT1N4148WSD_SOD-323_PANJITD42D_SOD-323_PANJIT1N4148WSD_SOD-323_PANJITEC21EC_SMD_6D3MM_H7D7560.0UF_6.3VEC_SMD_6D3MM_H7D7EC23DCASE_7343680.0UF_2.5VDCASE_7343EC24DCASE_7343680.0UF_2.5VDCASE_7343EC26DCASE_7343680.0UF_2.5VDCASE_7343EC29DCASE_7343680.0UF_2.5VDCASE_7343EC31DCASE_7343680.0UF_2.5VDCASE_7343EC33DCASE_7343680.0UF_2.5VDCASE_7343EC34DCASE_7343680.0UF_2.5VDCASE_7343EC36DCASE_7343150.0UF_16VDCASE_7343EC37DCASE_7343150.0UF_16VDCASE_7343EC38DCASE_7343150.0UF_16VDCASE_7343EC39DCASE_7343150.0UF_16VDCASE_7343EC73XCASE_7343470.0UF_6.3VXCASE_7343EC119EC_SMD_6D3MM_H7D7270.0UF_16VEC_SMD_6D3MM_H7D7EC120EC_SMD_6D3MM_H7D7270.0UF_16VEC_SMD_6D3MM_H7D7EC121EC_SMD_6D3MM_H7D7_N560.0UF_6.3VEC_SMD_6D3MM_H7D7_NEC122EC_SMD_6D3MM_H7D7_N270.0UF_16VEC_SMD_6D3MM_H7D7_NEC130DCASE_7343150.0UF_16VDCASE_7343EC159DCASE_7343150.0UF_16VDCASE_7343EC160DCASE_7343150.0UF_16VDCASE_7343EC161DCASE_7343150.0UF_16VDCASE_7343EC163DCASE_7343150.0UF_16VDCASE_7343EC164DCASE_7343150.0UF_16VDCASE_7343EC165EC_SMD_6D3MM_H7D7270.0UF_16VEC_SMD_6D3MM_H7D7EC166EC_SMD_6D3MM_H7D7270.0UF_16VEC_SMD_6D3MM_H7D7EC167EC_SMD_6D3MM_H7D7270.0UF_16VEC_SMD_6D3MM_H7D7EC168EC_SMD_6D3MM_H7D7270.0UF_16VEC_SMD_6D3MM_H7D7EC170EC_SMD_6D3MM_H7D7270.0UF_16VEC_SMD_6D3MM_H7D7EC171EC_SMD_6D3MM_H7D7270.0UF_16VEC_SMD_6D3MM_H7D7EC173DCASE_7343680.0UF_2.5VDCASE_7343F1FUSE_1D8X3D5_H1D6RESETTABLE-PTC,2A,6VFUSE_1D8X3D5_H1D6F4FUSE_1D8X3D4_HD7RESETTABLE-PTC,1.1A,6VFUSE_1D8X3D4_HD7FAN1WAFER_4P_2D54MM_11D54PIN,180D,P:2.54mmWAFER_4P_2D54MM_11D5FAN2WAFER_4P_2D54MM_11D54PIN,180D,P:2.54mmWAFER_4P_2D54MM_11D5FAN3WAFER_4P_2D54MM_11D54PIN,180D,P:2.54mmWAFER_4P_2D54MM_11D5FAN4WAFER_4P_2D54MM_11D54PIN,180D,P:2.54mmWAFER_4P_2D54MM_11D5FAN5WAFER_4P_2D54MM_11D54PIN,180D,P:2.54mmWAFER_4P_2D54MM_11D5FB1FB060380ohm/600mAFB0603FB2FB060380ohm/600mAFB0603FB3FB060380ohm/600mAFB0603FB7L080530ohm/3AL0805FB8L080530ohm/3AL0805FB10L080530ohm/3AL0805FB11L080530ohm/3AL0805FB12L080530ohm/3AL0805FB16FB0805120ohm_300mAFB0805FB83FB0603120ohm_3AFB0603H25HOLE-OB7X19D4_2X16_2OB7X19D4HOLE-OB7X19D4_2X16_2H26HOLE-OB7X19D4_2X16_2OB7X19D4HOLE-OB7X19D4_2X16_2HS4HEATSINK_28X28X3028X28X30MMHEATSINK_28X28X30J1PJACK_5P_9D2X14_H533604-AudioJack,5PIN,90D,PJACK_5P_9D2X14_H5JDIMM1DDR4_288P_1D7_H21D333401-MemoryConnectors,288PIN,180D,P=0.85MMDDR4_288P_1D7_H21D3JDIMM3DDR4_288P_1D7_H21D333401-MemoryConnectors,288PIN,180D,P=0.85MMDDR4_288P_1D7_H21D3JDIMM4DDR4_288P_1D7_H21D333401-MemoryConnectors,288PIN,180D,DDR4_288P_1D7_H21D3JDIMM5DDR4_288P_1D7_H21D333401-MemoryConnectors,288PIN,180D,P=0.85MMDDR4_288P_1D7_H21D3JDIMM7DDR4_288P_1D7_H21D333401-MemoryConnectors,288PIN,180D,P=0.85MMDDR4_288P_1D7_H21D3JDIMM8DDR4_288P_1D7_H21D333401-MemoryConnectors,288PIN,180D,DDR4_288P_1D7_H21D3JDIMM9DDR4_288P_1D7_H21D333401-MemoryConnectors,288PIN,180D,P=0.85MMDDR4_288P_1D7_H21D3JDIMM10DDR4_288P_1D7_H21D333401-MemoryConnectors,288PIN,180D,DDR4_288P_1D7_H21D3JDIMM11DDR4_288P_1D7_H21D333401-MemoryConnectors,288PIN,180D,P=0.85MMDDR4_288P_1D7_H21D3JDIMM13DDR4_288P_1D7_H21D333401-MemoryConnectors,288PIN,180D,P=0.85MMDDR4_288P_1D7_H21D3JDIMM14DDR4_288P_1D7_H21D333401-MemoryConnectors,288PIN,180D,DDR4_288P_1D7_H21D3JDIMM15DDR4_288P_1D7_H21D333401-MemoryConnectors,288PIN,180D,P=0.85MMDDR4_288P_1D7_H21D3JP4H3P_2D54MM_H8D63PIN,180D,P:2.54mmH3P_2D54MM_H8D6JP11H8P_2D54MM_H8D68PIN,180D,P:2.54MMH8P_2D54MM_H8D6JP13H2X4P_2D54MM_H6D58PIN,180D,2.54MMH2X4P_2D54MM_H6D5JP15HSMD2X4P_1D27MM_H5D9733503-Header,8PIN,180D,P:1.27MMHSMD2X4P_1D27MM_H5D97JP21H3P_2D54MM_H8D63PIN,180D,P:2.54mmH3P_2D54MM_H8D6L10L_4D15X4_H1D83.3uH_2.5AL_4D15X4_H1D8L54L_10D7X8_H8D30.15uH_55AL_10D7X8_H8D3L55L_4D2X4_H465nH_19AL_4D2X4_H4L56L_4D2X4_H465nH_19AL_4D2X4_H4L57L_4D2X4_H465nH_19AL_4D2X4_H4L98L_10D7X8_H8D30.15uH_55AL_10D7X8_H8D3L101L_10D7X8_H8D30.15uH_55AL_10D7X8_H8D3L102L_4D5X4_H20.22uH_9AL_4D5X4_H2L103L_10D7X8_H8D30.15uH_55AL_10D7X8_H8D3L104L_7D3X6D6_H33.3uH_6AL_7D3X6D6_H3L105L_11D5X10_H3D81uH_18AL_11D5X10_H3D8L106L_6D95X6D6_H2D82.2uH_8AL_6D95X6D6_H2D8LAN1RJ45X2_LED-M1-ZZ-007333603-RJ,28PIN,90D,RJ45X2_LED-M1-ZZ-0073LED3LED0603YELLOWLED0603LED4LED4P_SMD1D1_2X1D25XD8GREEN+YELLOWLED4P_SMD1D1_2X1D25XD8LED5LED0603YELLOWLED0603LED6LED4P_SMD1D1_2X1D25XD8GREEN+YELLOWLED4P_SMD1D1_2X1D25XD8LED12LED7X2_20P_1D5MM_14D6X12X4D05ORANGELED7X2_20P_1D5MM_14D6X12X4D05LED14LED0603GREENLED0603LED20LED4P_SMD1D9_1D9X1D6XD8RED+GREENLED4P_SMD1D9_1D9X1D6XD8M2GBX_100P_1D8MM_H13D5-9033611-HighFrequency,100PIN,90D,GBX_100P_1D8MM_H13D5-90M3GBX_100P_1D8MM_H13D5-9033611-HighFrequency,100PIN,90D,GBX_100P_1D8MM_H13D5-90M5GBX_100P_1D8MM_H13D5-9033611-HighFrequency,100PIN,90D,GBX_100P_1D8MM_H13D5-90M9GBX_54P_2MM_H11D45-90AIRMAX,VS2,54PIN,90D,P=1.4MMGBX_54P_2MM_H11D45-90P1V8_1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6P1V8_AUX1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6P3V3_1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6P3V3_AUX1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6P5V_1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6P5V_AUX1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6P12V1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6P12V_AUX1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6P12V_DUALH1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6P1SOCKET_LGA409433404-CPUSocket,,180D,SOCKET_LGA4094PCIE1PCIEX16_SMD164P_1MM_H11D133403-EdgecardCard,164PIN,180D,PCIEX16_SMD164P_1MM_H11D1PCIE2PCIEX16_SMD164P_1MM_H11D133403-EdgecardCard,164PIN,180D,PCIEX16_SMD164P_1MM_H11D1PSU1_PWRGOODH1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6PSU2_PWRGOODH1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6PVDDCR_CPU1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6PVDDCR_SOC1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6PVDDCR_SOC_AUX1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6PVDDIO_ABCD1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6PVDDIO_EFGH1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6PVPP_ABCD1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6PVPP_EFGH1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6PVTT_ABCD1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6PVTT_EFGH1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6PWROK_3V3_1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6PWROK_3V3_2H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6PWROK_3V3_3H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6PWR_BTN_N1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6PWR_GOOD1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6PWR_GOOD2H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6Q9SOT23_GDS2N7002SOT23_GDSQ10SOT23_BCEPMBS3904SOT23_BCEQ11SOT23_BCEPMBS3904SOT23_BCEQ12SOT23_GDS2N7002SOT23_GDSQ16SOT23_GDS2N7002SOT23_GDSQ24SOT363_6NX7002AKSSOT363_6Q25SOT363_6NX7002AKSSOT363_6Q28SOT23_6SM2601PSCC-TRGSOT23_6Q29SOT23_GDS2N7002SOT23_GDSQ34SOT23_GDS2N7002SOT23_GDSQ45SOT23_GDS2N7002SOT23_GDSQ46SOT23_GDS2N7002SOT23_GDSQ50SOT23_GDS2N7002SOT23_GDSQ70SOT23_GDS2N7002SOT23_GDSQ71SOT23_GDS2N7002SOT23_GDSQ94SOT23_GDS2N7002SOT23_GDSQ95SOT23_GDS2N7002SOT23_GDSQ117SOT23_GDSSM2416NSANSOT23_GDSQ123SOT23_GDSNX7002AKSOT23_GDSQ124SOT363_6SM1660DSCSSOT363_6Q125SOT363_6SM1660DSCSSOT363_6Q126SO8_PWRPAK_5PSM4311PSKPC-TRGSO8_PWRPAK_5PQ127SOT363_6NX7002AKSSOT363_6Q128SOT23_GDSSM2416NSANSOT23_GDSQ130SOT23_GDS2N7002SOT23_GDSQ131SOT23_GDS2N7002SOT23_GDSRSMRST_N1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6RT8THR2P_DIP_2D54_4X3D5X4D510.0KohmTHR2P_DIP_2D54_4X3D5X4D5RT9THR2P_DIP_2D54_4X3D5X4D510.0KohmTHR2P_DIP_2D54_4X3D5X4D5RT10THR2P_DIP_2D54_4X3D5X4D510.0KohmTHR2P_DIP_2D54_4X3D5X4D5RT11THR2P_DIP_2D54_4X3D5X4D510.0KohmTHR2P_DIP_2D54_4X3D5X4D5SFP1SFP_20P_11X8D52X5D4533614-OpticalFiber,20PIN,90D,P=0.8MMSFP_20P_11X8D52X5D45SFP2SFP_20P_11X8D52X5D4533614-OpticalFiber,20PIN,90D,P=0.8MMSFP_20P_11X8D52X5D45SLP_S3_N1H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6SLP_S5H1P_2D54MM_H8D633503-Header,1PIN,180D,P=2.54MMH1P_2D54MM_H8D6SW1SW_DTSML-32Y-V-TRTACTSWITCH,2PINSW_DTSML-32Y-V-TRSW2SW_BTS-1102VB-1-B-ST46TACTSWITCH,2PINSW_BTS-1102VB-1-B-ST46TPM1HSMD2X10P_1D27MM_H6D6-F-L233503-Header,19PIN,180D,P=1.27mmHSMD2X10P_1D27MM_H6D6-F-L2U3SOT89_GIOS-1206B15-U3T1USOT89_GIOU8SC70_5PSN74LVC1G08DCKRSC70_5PU11SON6_D65_TH1D6X1TPS2553DRVTSON6_D65_TH1D6X1U12SON6_D65_TH1D6X1TPS2553DRVTSON6_D65_TH1D6X1U21SOT23_5SN74LVC1G07DBVRSOT23_5U22SSOP16_D635LTC2629CGN-1#TRPBFSSOP16_D635U23SSOP24_D635LTC4306CGN#TRPBFSSOP24_D635U24SSOP16_D635LTC2629CGN-1#TRPBFSSOP16_D635U28SO8_W5D2MX25L25645GM2I-08GSO8_W5D2U31SC70_5PSN74LVC1G07DCKRSC70_5PU36BGA256_1MM_17X17LCMXO2-1200UHC-4FTG256CBGA256_1MM_17X17U39TSSOP16_D65SN74AVC4T245PWRTSSOP16_D65U48SC70_6PNC7WV07P6XSC70_6PU50SOT23_5SN74LVC1G17DBVRSOT23_5U51TSOT-238_D65MP1475DJ-LF-ZTSOT-238_D65U64QFN29_D5_5X4MPQ8632GVE-15-ZQFN29_D5_5X4U65QFN16_D5-T2D55X2D05-V6SN74AVC4T774RGYRQFN16_D5-T2D55X2D05-V6U66SC70_5PSN74LVC1G07DCKRSC70_5PU75LQFP128_D4IT8528E/FXLQFP128_D4U76SOT23_GVRTLV809K33DBVRSOT23_GVRU85QFN21_D4-MPQ8633AGLEMPQ8633AGLE-ZQFN21_D4-MPQ8633AGLEU93QFN16_D5_3X4MPQ8636GLE-10-ZQFN16_D5_3X4U120QFN21_D4-MPQ8633AGLEMPQ8633AGLE-ZQFN21_D4-MPQ8633AGLEU122TSOT-238_D65MP1475DJ-LF-ZTSOT-238_D65U124SO8_W5D2MX25L25645GM2I-08GSO8_W5D2U126FCBGA320_D8MM_15X15MT28942A0-NCCF-AEFCBGA320_D8MM_15X15U139SO8W25Q16JVSNIQSO8U141SO8W25Q16JVSNIQSO8U142QFN56_D4-T5D2X5D2KTI225VSLMNGQFN56_D4-T5D2X5D2U143QFN56_D4-T5D2X5D2KTI225VSLMNGQFN56_D4-T5D2X5D2U144QFN24_D5-T2D9X2D9TUSB522PRGERQFN24_D5-T2D9X2D9U145QFN24_D5-T2D9X2D9TUSB522PRGERQFN24_D5-T2D9X2D9U146SSOP16_D65MAX3232ECDBRG4SSOP16_D65U149QFN48_D4-T4D2X4D29ZXL0851EKILFTQFN48_D4-T4D2X4D2U154TSOT-238_D65MP1475DJ-LF-ZTSOT-238_D65U155VQFN18_D5-D65TPS56C215RNNRVQFN18_D5-D65U156HTSSOP14_D65-T2D31X2D46TPS54426PWPRHTSSOP14_D65-T2D31X2D46U158SO8MX25L512EMI-10GSO8U159SO824LC04BT-I/SNGSO8U161QFN52_D4-T4D7X4D7ISL69247IRAZ-TQFN52_D4-T4D7X4D7U162QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RU163QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RU164QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RU165QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RU166QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RU169QFN32_D4-TH2D7X2D7ISL69243QFN32_D4-TH2D7X2D7U170QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RU171QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RU172QFN52_D4-T4D7X4D7ISL68224IRAZ-TQFN52_D4-T4D7X4D7U173QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RU174QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RU175QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RU176QFN52_D4-T4D7X4D7ISL68224IRAZ-TQFN52_D4-T4D7X4D7U177QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RU178QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RU198QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RU201QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RU202QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RU205QFN24_D5-T2D9X2D9TUSB522PRGERQFN24_D5-T2D9X2D9U207QFN24_D4-G5329BG5329BQU1UQFN24_D4-G5329BU208QFN16_D5_3X4MPQ8636GLE-10-ZQFN16_D5_3X4U209SC70_5PSN74LVC1G08DCKRSC70_5PU210TQFN42_D5-T2D05X7D55-V18PI3EQX16000ZHEXTQFN42_D5-T2D05X7D55-V18U211TQFN42_D5-T2D05X7D55-V18PI3EQX16000ZHEXTQFN42_D5-T2D05X7D55-V18U212TQFN42_D5-T2D05X7D55-V18PI3EQX16000ZHEXTQFN42_D5-T2D05X7D55-V18U213TQFN42_D5-T2D05X7D55-V18PI3EQX16000ZHEXTQFN42_D5-T2D05X7D55-V18U214TQFN42_D5-T2D05X7D55-V18PI3EQX16000ZHEXTQFN42_D5-T2D05X7D55-V18U215TQFN42_D5-T2D05X7D55-V18PI3EQX16000ZHEXTQFN42_D5-T2D05X7D55-V18U216TQFN42_D5-T2D05X7D55-V18PI3EQX16000ZHEXTQFN42_D5-T2D05X7D55-V18U217TQFN42_D5-T2D05X7D55-V18PI3EQX16000ZHEXTQFN42_D5-T2D05X7D55-V18U218QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RU219QFN39_D45-ISL99390RISL99390FRZ-TR5935QFN39_D45-ISL99390RUSB_CON1USB_2_A_2MM_15X17D5X16D433601-USB,18PIN,90D,USB_2_A_2MM_15X17D5X16D4USB_CON2USB_1_A_2MM_14D8X16D5X7D833601-USB,9PIN,90D,USB_1_A_2MM_14D8X16D5X7D8USB_DOM1HBSMD2X4P_2D54MM_H12D3-FKN*PINHEADER2*4,8PIN,180D,P:2.54mmHBSMD2X4P_2D54MM_H12D3-FKNY1CRYSMD3D2X2D5_6P_EPSON156.25MHzCRYSMD3D2X2D5_6P_EPSONY3CRYSMD3D2X2D5_4P_FUJICOM25MHzCRYSMD3D2X2D5_4P_FUJICOMY4CRYSMD6D9X1D4_4P_AKER32.768KHzCRYSMD6D9X1D4_4P_AKERY5CRYSMD3D2X2D5_4P_HARM48MHzCRYSMD3D2X2D5_4P_HARMY7CRYSMD3D2X2D5_4P_FUJICOM25MHzCRYSMD3D2X2D5_4P_FUJICOM PCB文件回复可见下载
**** Hidden Message ***** 谢分享
