Intel Atom x5-Z8350 掌上电脑 PCB原理图共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEBL3BEAD0603BLM18PG181SN1BEAD0603BL4BEAD0603BLM18PG181SN1BEAD0603CR7010ESD0402ASDV1005H140C100NPTFESD0402ACR7011ESD0402ASDV1005H140C100NPTFESD0402ACR7012ESD0402ASDV1005H140C100NPTFESD0402ACR8202SOD-123AB5819WSOD-123ACR9400ESD0402ASDV1005H140C100NPTFESD0402ACR9401ESD0402ASDV1005H140C100NPTFESD0402ACR9403ESD0402ASDV1005H140C100NPTFESD0402ACR9405ESD0402ASDV1005H140C100NPTFESD0402ACR9406ESD0402ASDV1005H140C100NPTFESD0402ACR9500SMCR_SC79ABAP63-02SMCR_SC79ACR9501SMCR_P6X1P0_P40HAESD9N5BM-2/TRSMCR_P6X1P0_P40HACR9502SMCR_P6X1P0_P40HAESD9N5BM-2/TRSMCR_P6X1P0_P40HACR9503SMCR_P6X1P0_P40HAESD9N5BM-2/TRSMCR_P6X1P0_P40HACR9504SMCR_P6X1P0_P40HAESD9N5BM-2/TRSMCR_P6X1P0_P40HACR9505LCC10_NS_2P5X1P0_P65HAESD5304DLCC10_NS_2P5X1P0_P65HACR9506LCC10_NS_2P5X1P0_P65HAESD5304DLCC10_NS_2P5X1P0_P65HACR9507SMCR_SC79ABAP63-02SMCR_SC79ACR9508ESD0402ASDV1005H140C100NPTFESD0402ACR9509ESD0402ASDV1005H140C100NPTFESD0402ACR9510ESD0402ASDV1005H140C100NPTFESD0402ACR9511ESD0402ASDV1005H140C100NPTFESD0402ACR9512ESD0402ASDV1005H140C100NPTFESD0402ACR9513ESD0402ASDV1005H140C100NPTFESD0402ACR9514ESD0402ASDV1005H140C100NPTFESD0402ACR9515SMCR_SC79ABAP63-02SMCR_SC79ACR9517SOD-123AB5819WSOD-123ACR9518ESD0402ASDV1005H140C100NPTFESD0402ACR9519ESD0402ASDV1005H140C100NPTFESD0402ACR9520ESD0402ASDV1005H140C100NPTFESD0402ACR9521ESD0402ASDV1005H140C100NPTFESD0402ACR9522ESD0402ASDV1005H140C100NPTFESD0402ACR9523SOD-123AB5819WSOD-123AD1LED0603AGreen-LEDLED0603AD2LED0603AGreen-LEDLED0603AD3LED0603AGreen-LEDLED0603AD4LED0603RED_LEDLED0603D6LED0603AGreen-LEDLED0603AD7LED0603AGreen-LEDLED0603AD8LED0603AGreen-LEDLED0603AD1218SMCR_SC79ABAP63-02SMCR_SC79AD2000SOD523_P7HALM5Z6V2T1GSOD523_P7HAEC1C0603A10uFC0603AFB7011SMF0402_1P15XP65_P65HA120OHMSMF0402_1P15XP65_P65HAFB7012SMF0402_1P15XP65_P65HA120OHMSMF0402_1P15XP65_P65HAFB7013SMF0402_1P15XP65_P65HA120OHMSMF0402_1P15XP65_P65HAGND1TP_2TP_2.0TP_2GND2TP_2TP_2.0TP_2J9500CON19_MICRO_HDMI_SD80085_051ACON19_P4MM_MICROHDMICON19_MICRO_HDMI_SD80085_051AJ9705HXS_USB_004_BUSBA-AHXS_USB_004_BJ9707CON_08_W_5A_JJXASPK_08_W_5A_JJXCON_08_W_5A_JJXAJ9708FPC28_1MM_BACON28FPC28_1MM_BAJ9710DC-058ADC_JACKDC-058AJ9711FPC30P_05AFPC05_30PINFPC30P_05AJ9712A1201WN-S-7PAA1201WN-S-7PA1201WN-S-7PAJ9713FPC30P_05AFPC05_30PINFPC30P_05AJ9714FPC10P_05BAFPC05_10PINFPC10P_05BAJ9715CON_08_W_5A_JJXASPK_08_W_5A_JJXCON_08_W_5A_JJXAJ9717WF13-051G1RAWF13-051G1RWF13-051G1RAJ9718CSTU-21391347F-BCSTU-21391347F-1CSTU-21391347F-BL2000SML2520_1P2H1.0UHSML2520_1P2HL2001SML2520_1P2H1.0UHSML2520_1P2HL2002SML2520_1P2H1.0UHSML2520_1P2HL2003SML2520_1P2H1.0UHSML2520_1P2HL2004SML2520_1P2H1.0UHSML2520_1P2HL2005SML2520_1P2H1.0UHSML2520_1P2HL2006SML2520_1P2H1.0UHSML2520_1P2HL2007SPN4040A1.0UHSPN4040AL2008SML2520_1P2H1.0UHSML2520_1P2HL7011HIL0603A0HIL0603AL8206SPN505010uHSPN5050L8214HIL0603A0HIL0603AL8215HIL0603A0HIL0603AL9506SML_4P_43X53_CM_P35HA80OHM_100MHZSML_4P_43X53_CM_P35HAL9507SML_4P_43X53_CM_P35HA80OHM_100MHZSML_4P_43X53_CM_P35HAL9508SML_4P_43X53_CM_P35HA80OHM_100MHZSML_4P_43X53_CM_P35HAL9509SML_4P_43X53_CM_P35HA80OHM_100MHZSML_4P_43X53_CM_P35HAL9510SPN4040A1.0UHSPN4040AL9511HIL0603A0HIL0603AL9515ACFT4A2G900E1ACFT4A2G900EACFT4A2G900E1MT12HOLE150D100MOUNT_C158P59HOLE150D100MT13HOLE228D178MOUNT_C158P59HOLE228D178MT14HOLE228D178MOUNT_C158P59HOLE228D178Q8SOT-23ASI2305SOT-23AQ10SOT-23ASI2305SOT-23AQ54SOT-723AWNM2030SOT-723AQ2000LCC6_P65MM_SQ2P1MM_NSAMOSFETP_8PINLCC6_P65MM_SQ2P1MM_NSAQ3500SOT-723AWNM2030SOT-723AQ9504SOT-723AWNM2030SOT-723AQ9505SOT-723AWNM2030SOT-723AQ9506SOT-723AWNM2030SOT-723AQ9507SOT-723AWNM2030SOT-723AQ9508SOT-723AWNM2030SOT-723AQ9509SOT-723AWNM2030SOT-723AQ9510SOT-23ASI2305SOT-23AQ9511SOT-23ASI2305SOT-23AQ9512SOT-23ASI2305SOT-23AQ9513SOT-23ASI2305SOT-23AQ9514LCC6_P65MM_SQ2P1MM_NSAMOSFETP_8PINLCC6_P65MM_SQ2P1MM_NSAQ9516SOT-523MMBT3906TSOT-523Q9517SOT-23ASI2305SOT-23AQ9518SOT-23ASI2305SOT-23AQ9519SOT-723AWNM2030SOT-723AR2003CAP0402A1UFCAP0402AR2007SMR0402ANC/0RSMR0402AR2008SMR0402ANC/0RSMR0402AR2009RES0805_4PINA0.01RES0805_4PINART2000SMRT0402_27X47A10KSMRT0402_27X47ART2001RES0402A100RES0402ART2003RES0402A100RES0402AU1SSOP28-0_65AAGL850AUSBSSOP28-0_65AAU2LQFP48_7X7ASH68F83L2LQFP48_7X7AU3CSP9_15X15AAW8010CSRCSP9_15X15AU5SOT23-6ATCS9608-FSOT23-6AU11SOT23-5ATCS9607SOT23-5AU13QFN32_4X4AES8316QFN32_4X4AU19SOT23-5ATCS9607SOT23-5AU1000BGA592B_P65MM_17X17SOC_CHV_CR_REV1P0_DDRBGA592B_P65MM_17X17U2003LCC76_P4MM_SQ9P1MM_P9HAAXP288_1P07LCC76_P4MM_SQ9P1MM_P9HAU2004LCC8_P5MM_3MMX2MM_EP1P4X1P5_P9SY7088LCC8_P5MM_3MMX2MM_EP1P4X1P5_P9U3000FBGA216-15X15LPDDR3_SS_0FBGA216-15X15U3500SOL8PIN_55X8X22AW25Q16DWZPIGSOL8PIN_55X8X22AU3501BGA153_11P5X13_12MILPADKLM8G1WEMB_B031BGA153_11P5X13_12MILPADU6100AP6330AAP6335AP6330AU9011CSP9_15X15AAW8010CSRCSP9_15X15AU9012SOT23-5ATCS9607SOT23-5AU9013SOT23-5ATCS9607SOT23-5AW15CONN_COAX_SMT_2X2CON4_COAX_2X2_MM4829_2702CONN_COAX_SMT_2X2W17FPC40P_05NCFPC40P_05Y1OSC3225A12.0MHZOSC3225AY1000OSC3225A12.0MHZOSC3225AY1001MC_146A32.768KHZMC_146AY1002OSC3225A12.0MHZOSC3225A PCB文件和原理图一起打包
谢谢分享!
