TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 27087
重要提示:PCB作品文件展下载说明
REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | BL3 | BEAD0603 | BLM18PG181SN1 | BEAD0603 | BL4 | BEAD0603 | BLM18PG181SN1 | BEAD0603 | CR7010 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR7011 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR7012 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR8202 | SOD-123A | B5819W | SOD-123A | CR9400 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9401 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9403 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9405 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9406 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9500 | SMCR_SC79A | BAP63-02 | SMCR_SC79A | CR9501 | SMCR_P6X1P0_P40HA | ESD9N5BM-2/TR | SMCR_P6X1P0_P40HA | CR9502 | SMCR_P6X1P0_P40HA | ESD9N5BM-2/TR | SMCR_P6X1P0_P40HA | CR9503 | SMCR_P6X1P0_P40HA | ESD9N5BM-2/TR | SMCR_P6X1P0_P40HA | CR9504 | SMCR_P6X1P0_P40HA | ESD9N5BM-2/TR | SMCR_P6X1P0_P40HA | CR9505 | LCC10_NS_2P5X1P0_P65HA | ESD5304D | LCC10_NS_2P5X1P0_P65HA | CR9506 | LCC10_NS_2P5X1P0_P65HA | ESD5304D | LCC10_NS_2P5X1P0_P65HA | CR9507 | SMCR_SC79A | BAP63-02 | SMCR_SC79A | CR9508 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9509 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9510 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9511 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9512 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9513 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9514 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9515 | SMCR_SC79A | BAP63-02 | SMCR_SC79A | CR9517 | SOD-123A | B5819W | SOD-123A | CR9518 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9519 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9520 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9521 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9522 | ESD0402A | SDV1005H140C100NPTF | ESD0402A | CR9523 | SOD-123A | B5819W | SOD-123A | D1 | LED0603A | Green-LED | LED0603A | D2 | LED0603A | Green-LED | LED0603A | D3 | LED0603A | Green-LED | LED0603A | D4 | LED0603 | RED_LED | LED0603 | D6 | LED0603A | Green-LED | LED0603A | D7 | LED0603A | Green-LED | LED0603A | D8 | LED0603A | Green-LED | LED0603A | D1218 | SMCR_SC79A | BAP63-02 | SMCR_SC79A | D2000 | SOD523_P7HA | LM5Z6V2T1G | SOD523_P7HA | EC1 | C0603A | 10uF | C0603A | FB7011 | SMF0402_1P15XP65_P65HA | 120OHM | SMF0402_1P15XP65_P65HA | FB7012 | SMF0402_1P15XP65_P65HA | 120OHM | SMF0402_1P15XP65_P65HA | FB7013 | SMF0402_1P15XP65_P65HA | 120OHM | SMF0402_1P15XP65_P65HA | GND1 | TP_2 | TP_2.0 | TP_2 | GND2 | TP_2 | TP_2.0 | TP_2 | J9500 | CON19_MICRO_HDMI_SD80085_051A | CON19_P4MM_MICROHDMI | CON19_MICRO_HDMI_SD80085_051A | J9705 | HXS_USB_004_B | USBA-A | HXS_USB_004_B | J9707 | CON_08_W_5A_JJXA | SPK_08_W_5A_JJX | CON_08_W_5A_JJXA | J9708 | FPC28_1MM_BA | CON28 | FPC28_1MM_BA | J9710 | DC-058A | DC_JACK | DC-058A | J9711 | FPC30P_05A | FPC05_30PIN | FPC30P_05A | J9712 | A1201WN-S-7PA | A1201WN-S-7P | A1201WN-S-7PA | J9713 | FPC30P_05A | FPC05_30PIN | FPC30P_05A | J9714 | FPC10P_05BA | FPC05_10PIN | FPC10P_05BA | J9715 | CON_08_W_5A_JJXA | SPK_08_W_5A_JJX | CON_08_W_5A_JJXA | J9717 | WF13-051G1RA | WF13-051G1R | WF13-051G1RA | J9718 | CSTU-21391347F-B | CSTU-21391347F-1 | CSTU-21391347F-B | L2000 | SML2520_1P2H | 1.0UH | SML2520_1P2H | L2001 | SML2520_1P2H | 1.0UH | SML2520_1P2H | L2002 | SML2520_1P2H | 1.0UH | SML2520_1P2H | L2003 | SML2520_1P2H | 1.0UH | SML2520_1P2H | L2004 | SML2520_1P2H | 1.0UH | SML2520_1P2H | L2005 | SML2520_1P2H | 1.0UH | SML2520_1P2H | L2006 | SML2520_1P2H | 1.0UH | SML2520_1P2H | L2007 | SPN4040A | 1.0UH | SPN4040A | L2008 | SML2520_1P2H | 1.0UH | SML2520_1P2H | L7011 | HIL0603A | 0 | HIL0603A | L8206 | SPN5050 | 10uH | SPN5050 | L8214 | HIL0603A | 0 | HIL0603A | L8215 | HIL0603A | 0 | HIL0603A | L9506 | SML_4P_43X53_CM_P35HA | 80OHM_100MHZ | SML_4P_43X53_CM_P35HA | L9507 | SML_4P_43X53_CM_P35HA | 80OHM_100MHZ | SML_4P_43X53_CM_P35HA | L9508 | SML_4P_43X53_CM_P35HA | 80OHM_100MHZ | SML_4P_43X53_CM_P35HA | L9509 | SML_4P_43X53_CM_P35HA | 80OHM_100MHZ | SML_4P_43X53_CM_P35HA | L9510 | SPN4040A | 1.0UH | SPN4040A | L9511 | HIL0603A | 0 | HIL0603A | L9515 | ACFT4A2G900E1 | ACFT4A2G900E | ACFT4A2G900E1 | MT12 | HOLE150D100 | MOUNT_C158P59 | HOLE150D100 | MT13 | HOLE228D178 | MOUNT_C158P59 | HOLE228D178 | MT14 | HOLE228D178 | MOUNT_C158P59 | HOLE228D178 | Q8 | SOT-23A | SI2305 | SOT-23A | Q10 | SOT-23A | SI2305 | SOT-23A | Q54 | SOT-723A | WNM2030 | SOT-723A | Q2000 | LCC6_P65MM_SQ2P1MM_NSA | MOSFETP_8PIN | LCC6_P65MM_SQ2P1MM_NSA | Q3500 | SOT-723A | WNM2030 | SOT-723A | Q9504 | SOT-723A | WNM2030 | SOT-723A | Q9505 | SOT-723A | WNM2030 | SOT-723A | Q9506 | SOT-723A | WNM2030 | SOT-723A | Q9507 | SOT-723A | WNM2030 | SOT-723A | Q9508 | SOT-723A | WNM2030 | SOT-723A | Q9509 | SOT-723A | WNM2030 | SOT-723A | Q9510 | SOT-23A | SI2305 | SOT-23A | Q9511 | SOT-23A | SI2305 | SOT-23A | Q9512 | SOT-23A | SI2305 | SOT-23A | Q9513 | SOT-23A | SI2305 | SOT-23A | Q9514 | LCC6_P65MM_SQ2P1MM_NSA | MOSFETP_8PIN | LCC6_P65MM_SQ2P1MM_NSA | Q9516 | SOT-523 | MMBT3906T | SOT-523 | Q9517 | SOT-23A | SI2305 | SOT-23A | Q9518 | SOT-23A | SI2305 | SOT-23A | Q9519 | SOT-723A | WNM2030 | SOT-723A | R2003 | CAP0402A | 1UF | CAP0402A | R2007 | SMR0402A | NC/0R | SMR0402A | R2008 | SMR0402A | NC/0R | SMR0402A | R2009 | RES0805_4PINA | 0.01 | RES0805_4PINA | RT2000 | SMRT0402_27X47A | 10K | SMRT0402_27X47A | RT2001 | RES0402A | 100 | RES0402A | RT2003 | RES0402A | 100 | RES0402A | U1 | SSOP28-0_65AA | GL850AUSB | SSOP28-0_65AA | U2 | LQFP48_7X7A | SH68F83L2 | LQFP48_7X7A | U3 | CSP9_15X15A | AW8010CSR | CSP9_15X15A | U5 | SOT23-6A | TCS9608-F | SOT23-6A | U11 | SOT23-5A | TCS9607 | SOT23-5A | U13 | QFN32_4X4A | ES8316 | QFN32_4X4A | U19 | SOT23-5A | TCS9607 | SOT23-5A | U1000 | BGA592B_P65MM_17X17 | SOC_CHV_CR_REV1P0_DDR | BGA592B_P65MM_17X17 | U2003 | LCC76_P4MM_SQ9P1MM_P9HA | AXP288_1P07 | LCC76_P4MM_SQ9P1MM_P9HA | U2004 | LCC8_P5MM_3MMX2MM_EP1P4X1P5_P9 | SY7088 | LCC8_P5MM_3MMX2MM_EP1P4X1P5_P9 | U3000 | FBGA216-15X15 | LPDDR3_SS_0 | FBGA216-15X15 | U3500 | SOL8PIN_55X8X22A | W25Q16DWZPIG | SOL8PIN_55X8X22A | U3501 | BGA153_11P5X13_12MILPAD | KLM8G1WEMB_B031 | BGA153_11P5X13_12MILPAD | U6100 | AP6330A | AP6335 | AP6330A | U9011 | CSP9_15X15A | AW8010CSR | CSP9_15X15A | U9012 | SOT23-5A | TCS9607 | SOT23-5A | U9013 | SOT23-5A | TCS9607 | SOT23-5A | W15 | CONN_COAX_SMT_2X2 | CON4_COAX_2X2_MM4829_2702 | CONN_COAX_SMT_2X2 | W17 | FPC40P_05 | NC | FPC40P_05 | Y1 | OSC3225A | 12.0MHZ | OSC3225A | Y1000 | OSC3225A | 12.0MHZ | OSC3225A | Y1001 | MC_146A | 32.768KHZ | MC_146A | Y1002 | OSC3225A | 12.0MHZ | OSC3225A |
重要提示:PCB作品文件展下载说明
