SD102 BGA324+DS90UB926QSQE/NOPB+DRV8889-Q1+RTL9010AA+MAX96706GTJ+T PCB文件
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEB17020020-001-000002BLM18KG121TBLM18KG121TCN10010027-001-000087FH52-50S-0.5SHFH52-50S-05SHCN10020027-001-000086FH52-30S-0.5SHFH52-30S-05SHCON1601FAKRA_FA1-NCRP-PCB-8_FKPPRNZD02FKPPRNZD02TFA1-NCRP-PCB-8D401SS10PH10-M3/87A_TO-277A-3_SS10PSS10PH10-M3/87ATO-277A-3D402DIODE_0_TPSMC27CA_TPSMC27CATPSMC27CATPSMC27CAD4030026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603D4040026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603D4050026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603D5010016-001-000011MBR0540T1GSOD_123D5050022-001-000012PESD3V3S1BLDFN1006-2D8010026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603D9010022-001-000017RCLAMP0512TQTCTRCLAMP0512D9020022-001-000017RCLAMP0512TQTCTRCLAMP0512D10010016-001-000003RB160L-40TE25RB160LD10020016-001-000013RBR2VWM60ATFRBR2VWM60ATFD10030016-001-0000141N4148WQ-7-F1N4148WQ-7-FD15010022-001-000008PESD2CAN.215SOT-23-3D15020022-001-000008PESD2CAN.215SOT-23-3D16010026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603D17010026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603D19010022-001-000017RCLAMP0512TQTCTRCLAMP0512D19020026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603D19030026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603D19040026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603J401DCPOWER JACK_PJ-202B_IO_PJ-202PJ-202AHPJ-202BJ4020027-001-000085UK-G0701-ZS-YUK-G0701-ZS-YJ501JTAG20PIN_1_JTAG20PIN_300S-20P300S-20PJTAG20PINJ5020027-001-000057TS-3025-A-A-BTS_3025J5030027-001-000057TS-3025-A-A-BTS_3025J5040027-001-000057TS-3025-A-A-BTS_3025J7010027-001-000019TFCardTFCARD_CDJ8010027-001-0000992304372-1C-2304372-1J9010027-001-000025ZX62D-B-5PA8MICROUSBBJ14010102-001-000001KPB3642SP10-1SIP_2J14020034-001-000009SIP_2SIP_2J15010034-001-000009SIP_2SIP_2J15020027-001-000063EK500V-05PWIRINGCON5J15030034-001-000009SIP_2SIP_2J1702HSPPRNZS11T_HSPPRNZS11T_HSPPRNZHSPPRNZS11T/DESRHSPPRNZS11TJ18010027-001-000058HAD-04HWAG-2HAD-04HWAGJ18020027-001-000065EK500V-04PWIRINGCON4J18050034-001-000009SIP_2SIP_2J18060034-001-000009SIP_2SIP_2J18070027-001-000063EK500V-05PWIRINGCON5J19010027-001-000025ZX62D-B-5PA8MICROUSBBL4020003-001-0000333.3uHSMD5D6X5D4X3L4030003-001-00003722uHSMD7D4X6D9X4D5L4040003-001-0000383.3uHIND252012L4050003-001-0000361uHSMD5D6X5D4X3L406INDUCTOR_P2_SMD7D1X6D5X3_5.6UH@5.6uH@5.4ASMD7D1X6D5X3L4070003-001-0000361uHSMD5D6X5D4X3L8010003-001-0000383.3uHIND252012L8020039-001-000006DLW32MH101XT2DLW32MH101XT2L10010003-001-00003722uHSMD7D4X6D9X4D5L15010019-001-000002ACT45B-510-2P-TL003SMD1812_P4L15020019-001-000002ACT45B-510-2P-TL003SMD1812_P4L1601INDUCTOR_VLS3015CX_VLS3015CX-10VLS3015CX-101M-HVLS3015CXL1602INDUCTANCE_0_VLS3015CX_VLS3015CVLS3015CX-6R8M-HVLS3015CXL1603INDUCTOR_NLV25X_NLV25T-R33J-EFDNLV25T-R33J-EFDNLV25XL1701COMMON_INDUCTANCE_0_L4-2_2X1_4-90R@100MHzL4-2_2X1_4-H1_4L1702INDUCTOR_P2_SMD7D1X6D5X3_5.6UH@5.6uH@5.4ASMD7D1X6D5X3M3MHOLE_HOLE_C7R00D3R20_MHOLE_3.2MHOLE_3.2MMHOLE_C7R00D3R20M4MHOLE_HOLE_C7R00D3R20_MHOLE_3.2MHOLE_3.2MMHOLE_C7R00D3R20M5MHOLE_HOLE_C7R00D3R20_MHOLE_3.2MHOLE_3.2MMHOLE_C7R00D3R20M6MHOLE_HOLE_C7R00D3R20_MHOLE_3.2MHOLE_3.2MMHOLE_C7R00D3R20Q401DMC4029SSDQ-13_SOP8-1_27-4_95X3DMC4029SSDQ-13SOP8-1_27-4_95X3_95-H1_75Q4030015-001-000011SQ2315ES-T1_GE3SQ2315ESQ4040015-001-000012SQ2310ES-T1_GE3SQ2310ESQ4050015-001-000050AP30P30QAP30P30QQ5010015-001-000012SQ2310ES-T1_GE3SQ2310ESQ7010015-001-000011SQ2315ES-T1_GE3SQ2315ESQ7020015-001-000013LBSS139WT1GLBSS139WTQ7030015-001-000012SQ2310ES-T1_GE3SQ2310ESQ7040015-001-000011SQ2315ES-T1_GE3SQ2315ESQ7050015-001-000012SQ2310ES-T1_GE3SQ2310ESQ8010015-001-000012SQ2310ES-T1_GE3SQ2310ESQ8020015-001-000012SQ2310ES-T1_GE3SQ2310ESQ8030015-001-000012SQ2310ES-T1_GE3SQ2310ESQ8040015-001-000012SQ2310ES-T1_GE3SQ2310ESQ10010015-001-000011SQ2315ES-T1_GE3SQ2315ESQ11010015-001-000012SQ2310ES-T1_GE3SQ2310ESQ16010015-001-000012SQ2310ES-T1_GE3SQ2310ESQ16020015-001-000012SQ2310ES-T1_GE3SQ2310ESQ16030015-001-000012SQ2310ES-T1_GE3SQ2310ESQ16040015-001-000012SQ2310ES-T1_GE3SQ2310ESQ16050015-001-000011SQ2315ES-T1_GE3SQ2315ESQ16060015-001-000012SQ2310ES-T1_GE3SQ2310ESQ18010062-001-000013MMBT3904LC-SOT-23_SOT-23-3_Q18020015-001-000012SQ2310ES-T1_GE3SQ2310ESQ18030015-001-000012SQ2310ES-T1_GE3SQ2310ESQ18040015-001-000012SQ2310ES-T1_GE3SQ2310ESQ18050015-001-000012SQ2310ES-T1_GE3SQ2310ESQ19010015-001-000012SQ2310ES-T1_GE3SQ2310ESQ19020015-001-000012SQ2310ES-T1_GE3SQ2310ESQ19030015-001-000012SQ2310ES-T1_GE3SQ2310ESQ19040015-001-000012SQ2310ES-T1_GE3SQ2310ESTVS8010022-001-000019AVRH10C101KT141NE8AVRH10C101KT141NE8TVS8020022-001-000019AVRH10C101KT141NE8AVRH10C101KT141NE8TVS19010022-001-000013PESD5V0S1BLDDFN1006D-2U4030011-001-000020NM/MPQ2179AGQHE-AEC1-ZMPQ217XU4040010-001-000031BD00IC0MEFJ-ME2HTSOP-J8U4051011-001-000019NM/MPQ2167AGQE_AEC1_C07V_ZQFN-14U407MPQ4313GRE-AEC1_MPQ4313GRE-AEC1MPQ4313GRE-AEC1MPQ4313GRE-AEC1U4080011-001-000019MPQ2167AGQE_AEC1_C07V_ZQFN-14U5010061-001-000005SD_E3E3Q_BGA324U5020152-001-000004NM/TPS3823-25QDBVRQ1TPS382XU6020077-001-000003IS45S32160F-7BLA2TFBGA90U7021010-001-000031NM/BD00IC0MEFJ-ME2HTSOP-J8U8020064-001-000004RTL9010AAQFN-48-EP-RTL9010AAU10020047-001-000006MPQ3364MPQ3364U11020057-001-000004IS25LP064D-JBLA3SOIC8_SPIFLASHU14020036-001-000003TAS2505-Q1TAS2505TRGERQ1U14030066-001-000003AK4619AK4619U14040083-001-000002SA2718T421-WT01SA2718T421-WT01U14050083-001-000002SA2718T421-WT01SA2718T421-WT01U15010059-001-000003TJA1043TTJA1043TU15020059-001-000002TLE9251VSJPG-DSO-8U16020024-001-000006TPS1H000AQDGNRQ1TPS1H000_VSSOP8U16030101-001-000001MAX96706GTJ+TTQFN32-EPU17020092-001-000003DS90UB926QSQE/NOPBDS90UB926QSQEU18020080-001-000002DRV8889-Q1HTSSOP24-PWPU1901CP2105-F01-GM_QFN24_CP2105-F01-CP2105-F01-GMQFN24U1902MPQ4313GRE-AEC1_MPQ4313GRE-AEC1MPQ4313GRE-AEC1MPQ4313GRE-AEC1X5010025-001-000018CX2016SA24000D0HSSCCXTAL2016X50232768_NX3215SA_NX3215SA-32.768KNX3215SA-32.768KHZ(STD-MUS-2)NX3215SAX8011025-001-000018CX2016SA25000D0HSSCCXTAL2016 PCB文件。回复可见下载
**** Hidden Message ***** 给力的老吴!!!
