汇川MD500E变频器开发方案 PCB原理图 源码等资料
NamePart TypePCB DecalValue
BAR_CODEBAR_CODE(42\27X6)BARCODE-27X6
CN115020003-CON3-5MM-10A-300VCON-3-5MMJTB552-04-1-03-3-M6
CN215020004-CON6-DL-5.08MM-10ACON-6-5.08MMJTB870-05-2-03-3-M3
CN315020004-CON6-DL-5.08MM-10ACON-6-5.08MMJTB870-05-2-03-3-M3
CN415020004-CON6-DL-5.08MM-10ACON-6-5.08MMJTB870-05-2-03-3-M3
D106013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
D206013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
D310021004-LED-DIO-RED-0805SAWLED-SD08050805SAW
D406013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
D506013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
D606013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
D706013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
D806013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
D906013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
D1010021003-LED-DIO-GREEN-0805HGWLED-SD08050805HGW
D2306012002-SW-DIO-100V-200MA-MMBD7000LT1GSOT23MMBD7000LT1G
D2406012002-SW-DIO-100V-200MA-MMBD7000LT1GSOT23MMBD7000LT1G
D2506016002-BTS-DIO-7V-7V-SMBJ5.0CASMB--2215SMBJ5.0CA
D2606016002-BTS-DIO-7V-7V-SMBJ5.0CASMB--2215SMBJ5.0CA
D2706016002-BTS-DIO-7V-7V-SMBJ5.0CASMB--2215SMBJ5.0CA
D2806016002-BTS-DIO-7V-7V-SMBJ5.0CASMB--2215SMBJ5.0CA
D2906013002-S-DIO-40V-100MA-BAS40-06LT1GSOT23BAS40-06LT1G
D3006013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
D3106013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
D3206013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
D3306013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
D3406013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
D3506013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
D3606012002-SW-DIO-100V-200MA-MMBD7000LT1GSOT23MMBD7000LT1G
D3706012002-SW-DIO-100V-200MA-MMBD7000LT1GSOT23MMBD7000LT1G
D3806013001-S-DIO-40V-100MA-BAS40-04LT1GSOT23BAS40-04LT1G
D3906013001-S-DIO-40V-100MA-BAS40-04LT1GSOT23BAS40-04LT1G
D4006013001-S-DIO-40V-100MA-BAS40-04LT1GSOT23BAS40-04LT1G
D4106013001-S-DIO-40V-100MA-BAS40-04LT1GSOT23BAS40-04LT1G
D4206016002-BTS-DIO-7V-7V-SMBJ5.0CASMB--221533V
D4306016002-BTS-DIO-7V-7V-SMBJ5.0CASMB--221533V
J115013003-SIP8-2.5MM-P2500J-08CON-8-100P2500J-08
J215010039-CON2X5-2.54CON10-100CON10
J315010028-SSED18-1MM-W-EFC-PM24-SD18H3-3ZSED20-23.8X6.65EFC-PM24-SD18H3-3Z
J415011003-SIP3-2.54MM-3A-201K0300SIP-3-100201K0300
J515011003-SIP-3-100-3A-201K0300SIP-3-100201K0300
J615011001-SIP2-2.54MM-3A-201K0200SIP-2-100201K0200
J715050001-CON8-RJ45-9030800004CON8-15X13-RJ45(KZ)9030800004
J815011003-SIP-3-100-3A-201K0300SIP-3-100201K0300
J915011003-SIP-3-100-3A-201K0300SIP-3-100201K0300
J1015011003-SIP-3-100-3A-201K0300SIP-3-100201K0300
J1115010024-DIP34-2.54MM-2313411001CON-34-1001236-341-121-1
J1215015001-DSED28-2MM-263K2821CON-28-SMT263K2821
J1315011003-SIP-3-100-3A-201K0300SIP-3-100201K0300
K112010003-RLY5-892-1CC-C/24VRLY5-7.62MM-20.5X10.224V-125VAC-10A(NO)-125VAC-3A(NC)
L111011002-L-100UH-SMTSPL100μH±10%
L211011001-L-100MHZ-PBY201209T-101Y-NSL0805PBY201209T-101Y-N
L311011001-L-100MHZ-PBY201209T-101Y-NSL0805PBY201209T-101Y-N
L411011001-L-100MHZ-PBY201209T-101Y-NSL0805PBY201209T-101Y-N
L511011001-L-100MHZ-PBY201209T-101Y-NSL0805PBY201209T-101Y-N
MM1M3_138_NPM3_138NP
MM2M3_138_240M3_138_240
MM3M3_138_NPM3_138NP
Q106021007-NPN-DYN-40V-0.6A-MMBT4401LT1GSOT23MMBT4401LT1G
Q206021007-NPN-DYN-40V-0.6A-MMBT4401LT1GSOT23MMBT4401LT1G
Q306021007-NPN-DYN-40V-0.6A-MMBT4401LT1GSOT23MMBT4401LT1G
Q406021007-NPN-DYN-40V-0.6A-MMBT4401LT1GSOT23MMBT4401LT1G
Q506021007-NPN-DYN-40V-0.6A-MMBT4401LT1GSOT23MMBT4401LT1G
Q606021007-NPN-DYN-40V-0.6A-MMBT4401LT1GSOT23MMBT4401LT1G
Q706021007-NPN-DYN-40V-0.6A-MMBT4401LT1GSOT23MMBT4401LT1G
Q806021007-NPN-DYN-40V-0.6A-MMBT4401LT1GSOT23MMBT4401LT1G
Q906021004-NPN-DYN-40V-1A-PBSS4140TSOT23PBSS4140T
Q1006021004-NPN-DYN-40V-1A-PBSS4140TSOT23PBSS4140T
Q1106021004-NPN-DYN-40V-1A-PBSS4140TSOT23PBSS4140T
Q1206021004-NPN-DYN-40V-1A-PBSS4140TSOT23PBSS4140T
U109030005-COMP-LM393DR2G-SOP8SOP8-50-150LM393DR2G
U209030005-COMP-LM393DR2G-SOP8SOP8-50-150LM393DR2G
U309030005-COMP-LM393DR2G-SOP8SOP8-50-150LM393DR2G
U409030008-AMP-TL082IDR-SOIC8SOP8-50-150TL082IDR
U509030005-COMP-LM393DR2G-SOP8SOP8-50-150LM393DR2G
U609030005-COMP-LM393DR2G-SOP8SOP8-50-150LM393DR2G
U709030005-COMP-LM393DR2G-SOP8SOP8-50-150LM393DR2G
U809030005-COMP-LM393DR2G-SOP8SOP8-50-150LM393DR2G
U908011006-GATE-SN74ACT244-SOP20SOP20-25-17374ACT244
U10TEMP-IC-TMS320F28035-QFP80QFP80-050-1212TMS320F28035
U1109020005-VMON-AMAX708-TG-SOP8SOP8-50-150ADM708-4.4V
U1207030004-IC-AT24C32AN-SOP8SOP8-50-150AT24C32AN_32K
U1308012019-GATE-SN74LVC244APWR-SOP20SOP20-25-173SN74LVC244APWR
U1408011006-GATE-SN74ACT244-SOP20SOP20-25-17374ACT244
U1508011006-GATE-SN74ACT244-SOP20SOP20-25-17374ACT244
U1610010008-GO-HCPL-181-00BE-SOP4PS2701\PHCPL-181-00BE
U1708011006-GATE-SN74ACT244-SOP20SOP20-25-17374ACT244
U1808011006-GATE-SN74ACT244-SOP20SOP20-25-17374ACT244
U1908012019-GATE-SN74LVC244APWR-SOP20SOP20-25-173SN74LVC244APWR
U2010012001-GO-TLP114A-TPR-SDOP5SGO5-50-173TLP114A-TPR
U2110012001-GO-TLP114A-TPR-SDOP5SGO5-50-173TLP114A-TPR
U2210012001-GO-TLP114A-TPR-SDOP5SGO5-50-173TLP114A-TPR
U2310012001-GO-TLP114A-TPR-SDOP5SGO5-50-173TLP114A-TPR
U2409030014-AMP-MC33272ADR2G-SOP8SOP8-50-150MC33272ADR2G
U2507030004-IC-AT24C32AN-SOP8SOP8-50-150AT24C32AN_32K
U2609010004-VREG-TLV1117-33CDCYR-SOT223SOT-223TLV1117-33CDCYR
U2708012010-GATE-SN74ACT14DR-SOIC14SOP14-50-150SN74ACT14DR
U2809030004-AMP-LM324DR-SOP14SOP14-50-150LM324DR
U2910012001-GO-TLP114A-TPR-SDOP5SGO5-50-173TLP114A-TPR
U3010012001-GO-TLP114A-TPR-SDOP5SGO5-50-173TLP114A-TPR
U3110012001-GO-TLP114A-TPR-SDOP5SGO5-50-173TLP114A-TPR
U3209020003-VREG-LM317LDR2G-SOP8SOP8-50-150LM317LDR2G
U3308012016-DCK-SN74LVC1G14DCKRDCKSN74LVC1G14DCKR
U3408012016-DCK-SN74LVC1G14DCKRDCKSN74LVC1G14DCKR
U3508012016-DCK-SN74LVC1G14DCKRDCKSN74LVC1G14DCKR
X114010005-X3-20MHZ-50PPMX3-2.44MM-10.24X4.6520MHz
Z1MARKMARK
Z2MARKMARK_IC
Z3MARKMARK_IC
Z4MARKMARK
Z5MARKMARK
Z6MARKMARK
牛的 谢谢分享,我记得其他地方卖挺贵 :D 学习龙头企业的设计 是目前流行的方案吗? 这个资料真牛啊
