jiangxianjun
发表于 2015-1-19 08:29:11
The Artix-7 FPGA is optimized for high performance logic, and offers more capacity, higher performance, and more resources than earlier designs. Artix-7 100T features include:[li]15,850 logic slices, each with four 6-input LUTs and 8 flip-flops[/li][li]4,860 Kbits of fast block RAM[/li][li]Six clock management tiles, each with phase-locked loop (PLL)[/li][li]240 DSP slices[/li][li]Internal clock speeds exceeding 450MHz[/li][li]On-chip analog-to-digital converter (XADC)[/li] The Nexys4 DDR also offers an improved collection of ports and peripherals, including: |
[li]16 user switches[/li][li]USB-UART Bridge[/li][li]12-bit VGA output[/li][li]3-axis accelerometer[/li][li]128MiB DDR2[/li][li]Pmod for XADC signals[/li] | [li]16 user LEDs[/li][li]Two tri-color LEDs[/li][li]PWM audio output[/li][li]Temperature sensor[/li][li]Serial Flash[/li][li]Digilent USB-JTAG port for FPGA programming and communication[/li] | [li]Two 4-digit 7-segment displays[/li][li]Micro SD card connector[/li][li]PDM microphone[/li][li]10/100 Ethernet PHY[/li][li]Four Pmod ports[/li][li]USB HID Host for mice, keyboards and memory sticks[/li] |
[tr][/tr]
板子实物图:
本主题需向作者支付
2 枚金币 才能浏览
购买主题
jiangxianjun
发表于 2015-1-19 08:29:53
具体信息参考:
http://www.digilentinc.com/Products/Detail.cfm?NavPath=2,719,1337&Prod=NEXYS4DDR
jiangxianjun
发表于 2015-1-19 08:30:13
只有pdf格式的原理图,没有Layout。
yihong
发表于 2015-1-19 09:29:50
randy1022
发表于 2015-1-19 10:38:41
Re:Nexys4 DDR Artix-7 FPGA Board(赛灵思:XC7A100T-1CSG324C)
很给力啊!发帖就是这么规范!
doctor
发表于 2015-7-31 14:32:29
很不错啊,给个赞!
gongping
发表于 2015-10-14 15:09:35
很不错,学习一下,谢谢
danruhai
发表于 2016-6-24 16:09:08
Re:Nexys™4 DDR Artix-7 FPGA Board(赛灵思:XC7A100T-1CSG324C)
不错的东西,学习了,谢谢!
hurry0110
发表于 2016-10-11 10:01:55
可惜没金币!
kang30
发表于 2018-1-29 23:04:06
有没有原理图和layout的工程文件啊,要只是PDF就没意思了。
