车载机子YGV629+EPM7032+PVI-1004D+AD7843+LT1940 PCB和原理图
NamePart TypePCB DecalValueDU16LM7805CT_5_2TO-252AIC1085CEFU1FUSESMR12061812L260H9HEADER_3_0CON-5P\2.0PH2.0X2.0H12HEADER_3_1CON-5P\2.0PH2.0X2.0J1HEADER_30_0_2ZIFF30L-0.5MMZIFF30-0.5MM-UPJ2HEADER_5X2CON-SQT-2X5-2.0HEADER5X2J3CONN_PCB_2SM034.0BSM03(4.0)B-BHS-1-TBJ4HEADER_4_1ZIFF4-1.0-LFPC1.0S-6S-4PWB-UPJ5HEADER_4_0CON3P-2.54CON3P-2.54(NC)J6CONN_SOCKET_48_0CON-48P\DIN41612CONNSOCKET16X3J7HEADER_5X2_2CON-10P\2X5\2.54HEADER5X2-2.54-FEMALE(NC)L1INDUCTOR_2L-0805BEAD-0805L2INDUCTOR_2L-0805BEAD-0805(NC)L3XC6383A501PR_2L/5.5UHK5S-4.8UH+->12%(3L)L4INDUCTOR_2L-0805BEAD-0805L5INDUCTOR_2L-0805BEAD-0805L6INDUCTOR_2L-0805BEAD-0805L7CAP_NPSMC06031UF-1206L8INDUCTOR_2L-SMTDRS073210UH-1.5A/SMTDRS0732-100ML9INDUCTOR_2SMR08050-0805L10INDUCTOR_2L-080547UH-0805/SMI-201212-470KL11INDUCTOR_2L-0805SMD-322522-151KPD1DIODE_SCHOTTKY_1D-SMT58191N5819-SMTPD2DIODE_0_21N4148-SMT1N4148-SMTPD3DIODE_SCHOTTKY_1D-SMT58191N5819-SMTPD4DIODE_0_21N4148-SMT1N4148-SMTPL1INDUCTOR_2L-SMTDRRI040222UH/SMTDRRI0402-220MPL2INDUCTORL1206BEAD-1206PL3INDUCTOR_2L-SMTDRRI040247-2010PL4INDUCTORL1206BEAD-1206PU1LT1940IC-LT1940LT1940Q1NPN_0_22N39042N3904-SMTQ2XC62AP5002PR_4AIC1720-33CXAIC1721D-33CX(NC)Q3NPN_0_22N39042N3904-SMTQ4LM7805CT_0_2SOT223LM2936MP-3.3Q5NPN_0_22N39042N3904-SMTQ7XC62AP5002PR_3AIC1720-33CXAIC1721D-33CXQ8NPN_0_22N39042N3904-SMTQ9NPN_0_22N39042N3904-SMTSW3CON3_0_2EN11-2EC11P20L13.2F5.2M5V1STX1TRANSFORMER_POWER_3F0512AF0512AU114053_174HC4053-SOP74HC4053-SOPU2QFP-64_0PVI-1004/PQFPPVI-1004D/PQFPU3XC6383A501PR_4BU4S81-SOT23BU4S81-SOT23U4ELM9827AA_0LM3480IM3-3.3LM3480IM3-3.3U5LM833LM8272-MSOPLM8272-MSOPU6P8DIP8\SO-45324532U7BIT3105_0BIT3107BIT3105-SSOP20U8P8DIP8\SO-45324532U9PCF8575_SSOP24_0AD7843-TSSOP/QSOPAD7843-TSSOPU10DS1307ZNDS1307DS1307ZNU11MTV230M-PQFPIC-MTV230MTV230M-PQFPU12AN2546FH-A_0AN2546FH-AAN2546FH-AU1414053_074HC4053-SOP74HC4053-SOPU15LM358NIC-AD8092AR\SOP8AD8092ARU17EPM7032_3IC-EPM7032\TQFP44EPM7032ATI44-10+softU18TL2932IIC-TLC2932TLC2932IPWELEU23LM7805CT_0_2SOT223LM2936MP-3.3U2428F800CV_T_0SMT-SOP2-56E28F128JA-150U25CAT1161/2_2TRTQ1446GV629A70U2614053_174HC4053-SOP74HC4053-SOPVA4JUMPER1_0JUMPER1VR1RESISTOR_VAR_3VR-MVR2210K-VR1VR2RESISTOR_VAR_3VR-MVR2210K-VR1VR3RESISTOR_VAR_3VR-MVR2233K-VR1X1CRYSTAL_032768KHZ32.768KHZX274HC4051_29DIP-CRYSTAL9.6M crystalY1CRYSTALCRY-02\SMD211.0592MHZ-1-U3BY2CRYSTAL_2CRY-02\SMD23.579545MHz-1-U3BY3CRYSTAL_2CRY-02\SMD24.433619MHz-1-U3BZIR1HEADER_3IRM-3438IRM-3438ZR1R_4SMR0603200K-0603ZR2R_4PHOTOPHOTORESISTER 10lux-3k-12k
bc 看了确实挺有用啊 自己的功力还不够,看别人的板子就特别好看,自己画的很烂 谢谢老吴 谢谢吴老师分享 好资料,看看。 不错
