layout 发表于 2017-4-27 19:11:12
FC500+SI4730+PT2348+STM8A 车载主板 PCB文件共享
NamePCB DecalValuePart Type3V3TESTTESTANT2CON2/2.02PIN 2.0mmCN2BACKTP_1.5MMTP_1.2MMBRAKETP_1.5MMTP_1.2MMCN1FFC50/0.5BFFC50P 0.5mmAT070TN92D1SOD-323IN4148IN4001(DIP)D2DO-214ABAAAAA1N4001IN4001(DIP)D3D_1206IN4148IN4001(DIP)D4DIO/DO-214AAIN5822IN4001(DIP)D5DIO/DO-214AAIN4001IN4001(DIP)D6DO-214ABRB050LA-401N4003G_1D7D_1206IN4148IN4001(DIP)D8DIO/DO-214AAIN4001IN4001(DIP)D9DIO/DO-214AAIN4001IN4001(DIP)D10SMD_40070603ESDA-LPIN4001(DIP)D12SOD-323IN4148IN4001(DIP)D13SOD-323IN4148IN4001(DIP)D14FY/D-MI06-CA-1N5401D-101D16SOT-23BAV99BA99D19SOT-23BAV99BA99D20SOD-323IN4148IN4001(DIP)D21SMD_4007IN4001IN4001(DIP)D23SOT-23BAV99BA99D24SOD-323IN4148IN4001(DIP)D25SOT-23BAV70BA70D27SMD_40070RIN4001(DIP)D28SOD-323IN4148IN4001(DIP)D29SOD-323IN4148IN4001(DIP)D31SOD-323IN4148IN4001(DIP)D32SOD-323IN4148IN4001(DIP)D33SOD-323IN4148IN4001(DIP)D34SOD-323IN4148IN4001(DIP)D35SOD-323IN4148IN4001(DIP)D37SOD-323IN4148IN4001(DIP)D38SOD-323IN4148IN4001(DIP)D39SOD-323IN4148IN4001(DIP)EC1EC_8X5470UF/16VECEC24EC_8X5470UF/16VECEC25EC_8X5470UF/16VECESD10603LESDPGB1010603ESD20603LESDPGB1010603ESD30603LESDPGB1010603ESD40603LESDPGB1010603ESD50603LESDPGB1010603ESD60603LESDPGB1010603ESD70603LESDPGB1010603ESD80603LESDPGB1010603ESD120603LESDPGB1010603ESD130603LESDPGB1010603ESD140603LESDPGB1010603ESD150603LESDPGB1010603ESD160603LESDPGB1010603F31812_FUSE0.35AFUSE/0.035AGNDTESTTESTIC1SOT252BL1117-3.3VLD1117IC3PT2348PT2348ZZF-PT2348IC4SO8-OPT24C02AT24C02J1LINE_OUT16PLINE_OUT_16PINJ2TFT6765-TUN_AAJ_18PINJ3RAC3X4RCA24PJ4NEW-ISO-16PJACK18PINJ5TV-S77-1ATV_13PINJ6FFC60/0.5B60PCON_60P_0.5MMJ7OUTPUT2PHVPJ8CN40(0.5)-B40PIN_0.5MMJ9CN2(3.0)CON2J13CN4(1.0)4PIN 1.0mmCON4_TOUCHL1L0603600R@100MLL2L1206B600R@100MLL3L/TC-28H200uH(LGJ)IND-CDRH74L4L12X1222UHINDL5SDSL0603F1.5uHINDL6L1206B600R@100MLL70603L600R@100MLL80603L600R@100MLL9IND-CDH2B18-HP2.2uHIND-2.2UH/1.65AN-CDH2B18-XAL10L08052.7uHLL11IND/10MM50R/100ML4L120603R10UHL-1L13IND-SMT-CD4310UHINDL140805R270nHL-1L15IND-CDH2B18-HP2.2uHIND-2.2UH/1.65AN-CDH2B18-XAL160603R600R@100MLL17L0603600R@100MLL18IND-0805-BAFBL2L190805R220nHL-1L200603L600R@100MLL21IND-SMT-CD4322uHINDL220603L600R@100MLL230603L600R@100MLL240603L600R@100MLL250603R600R@100MLL26L0603600R@100MLL27L0603NCLL280603L600R@100MLL290805R2.7UHL2L32L08052.7uHLL36L1206BNCLL440603R1K@100ML2L450603R1K@100ML2M1MARKMARKM2MARKMARKM3MARKMARKM4MARKMARKQ1SOT-23S8550PNPQ2SOT-23S8550PNPQ3SOT-23S8050NPNQ4SOT-23S8050NPNQ5SOT-23S8050NPNQ6SOT-23S8050NPNQ7SOT-23S8050NPNQ8SOT-23S8550PNPQ9SOT-23S8050NPNQ10SOT-23S8050NPNQ11SOT-23S8050NPNQ12SOT-23S8550PNPQ13SOT-23S8050NPNQ14SOT-239018NPNQ15SOT-23S8050NPNQ16SOT-23S8050NPNQ17SOT-23S8550PNPQ18TO-89KTC4375NPNQ19Q/SOT-23/SMD-ZRKRC103C103Q20SOT-23M3407SI2323Q21SOT-23S8550PNPQ22SOT-23S8550PNPQ23SOT-23S8050NPNQ24SOT-23KRC103SNPN/ECBQ25SOT-23KRC103C103Q26SOT-23P6403MOS_PQ27SOT-23KRC103C103Q28SOT-23S8550PNPQ29SOT-239018NPNQ32SOT-23S8550PNPQ38SOT-23KRC103SNPN/ECBQ39SOT-23KRC103C103RSTTESTTESTTESTTESTTESTTP01TP_1.5MMTP_1.2MMTP1TP-D2.0-AAPOINTERTP2TP-D2.0-AAPOINTERTP3TP-D2.0-AAPOINTERTP4TP-D2.0-AAPOINTERU1SOT25278M09IC-VOLREG7809_AU2SOP16-3.9-1.27CD4052CD4052U3SOIC8EMP1584PQ1CZ21_0_3U4TA8266HTDA7388TDA7384U5SO8-OPTNJM4558NJM4558U6SOT23-6MP3202ZZF-FSP3305U7LQFP48HK-48PSTM8A_48U8SI4731-TUN_ATDA7786TDA7786/SI4731U9SOT-23-5EML3406-ADJBL3406B-ADJU10TO-89HT7533-1IC-HT7533-1-SOT-89-AAU11SOT-23SGM809_2.93VIMP809U12MSOP-10SGM3005SGM3005XMSU13TO-89HT7550-1IC-HT7533-1-SOT-89-AAU14QFN16-0.5MMTPS2546TPS2546U15SOT-23-5EML3406-ADJBL3406B-ADJU18SOT-23XC6206P302MXC6206P152MU19NJM2107MP1540SOT23-5U21SOIC8_208MILMX25L6406EGD5F4GQ4UAYIG_3U26BC3IVT I159BC3U28SOT252BL1117-3.3VLD1117U29QFP128P0_40B14_00X14_00H1_60FC500APPX-ELQFP128-1118_6U33SOP66PO_65B10K4H511638J-LCCCDDR_SDRAM66PU37SOT-23SGM809_2.93VIMP809U38SSOP24_0.635MMSI4730SI4730_SSOP24X+TP_1.5MMTP_1.2MMX-TP_1.5MMTP_1.2MMXT1CRY/HC-49USM24MHZCRYSTALXT2CRY/HC-49USM8MHZCRYSTALY+TP_1.5MMTP_1.2MMY-TP_1.5MMTP_1.2MMY1XTAL332.768khzXTALZ2ZD_120610VZD_1206Z3ZD_12067.5VZD_1206Z6ZD_120616VZD_1206Z7ZD_12066.8VZD_1206ZD10603R24V2R5SESDZD20603R24V2R5SESDZD30603R24V2R5SESDZD4ZD_12065.1VZD_1206ZD100603R24V2R5SESD
layout 发表于 2017-4-27 19:11:28
地沟油 发表于 2017-4-27 19:33:27
lfc 发表于 2017-4-27 20:07:17
学习一下
lyh0739 发表于 2017-4-27 20:16:05
牛逼呀,,
天天向下 发表于 2017-4-28 08:13:16
kbh2006@163.com 发表于 2017-4-28 08:17:45
佝偻的戒指 发表于 2017-4-28 08:35:39
miaomiao 发表于 2017-4-28 08:38:09
学习一下
bidinghong 发表于 2017-4-28 08:43:40
向大神学习学习
页: [1] 2 3 4 5
查看完整版本: FC500+SI4730+PT2348+STM8A 车载主板 PCB文件共享
