工业主板XCV6LX240T_FF1156+TMS320C6657+XCF128X+FX3_121_BUMP+TFP410+UCD7242
板子有以下元件
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEB11212_FILTER_NFW31SP106X1E4L_3_L2200pFL_3P_70_63X35B21212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35B31212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35B41212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35B51212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35B61212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35B71212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35B81212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35B91212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35B101212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35B111212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35B121212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35B131212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35B141212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35B26L0805_120_100MHZ120_120MHZL0805B271212_BEAD_0_L0603_120_100MHZ120_100MHzL0603B281212_BEAD_0_L0603_120_100MHZ120_100MHzL0603B291212_BEAD_0_L0805_120_100MHZ120_100MHzL0805B301212_BEAD_0_L0603_120_100MHZ120_100MHzL0603B311212_BEAD_0_L0603_120_100MHZ120_100MHzL0603B321212_BEAD_0_L0603_DISCRETE_120_120_100MHzL0603CLK1141_TI_CDCE62005RGZT_0_QFN_48P_TI_CDCE62005RGZTQFN_48P_20_276X276_TP220V25CP1CAP POL_C1210_100UF100uFC1210CRY150MHZ_SMD_0507_25MHZ25MHZSMD_0507D1LED_LED0603_LEDLEDLED0603D2LED_0_LED0603_LEDLEDLED0603D3LED_LED0603_LEDLEDLED0603D4LED_0_LED0603_LEDLEDLED0603D5LED_LED0603_LEDLEDLED0603D6130_SCHOTTKY_SMA-1_0_DIODE_2P_1B340ADIODE_2P_158_197X110D7LED_LED0603_LEDLEDLED0603D8130_ESD_D0603_0_ESD_2P_65_63X31PGB1010603ESD_2P_65_63X31D9130_ESD_D0603_0_ESD_2P_65_63X31PGB1010603ESD_2P_65_63X31D10LED_0_LED0603_LEDLEDLED0603DVI1DVI_INTERFACE_0 DVI_D_24PIN_NEWEEPROM1141_ST_M24M01-HRMN6TP_0_SOIC_8PST_M24M01-HRMN6TPSOIC_8P_50_193X236FB1INDUCTOR_FB0805_MPZ2012S601A_MPZ2012S601AFB0805FB2INDUCTOR_FB0805_MPZ2012S601A_MPZ2012S601AFB0805FB3INDUCTOR_FB0805_MPZ2012S601A_MPZ2012S601AFB0805FB4INDUCTOR_FB0805_MPZ2012S601A_MPZ2012S601AFB0805FB5FERRITE_120OHM_2000MA_0_EMIFIL120EEMIFIL_BLM18P_0603FB6INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805FB7INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805FB8INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805FB9INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805FB10INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805FB11INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805FB12INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805FB13INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805FB14INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805HOLE1MEC_PINMEC_PINHOLE_MECHHOLE2MEC_PINMEC_PINHOLE_MECHHOLE3MEC_PINMEC_PINHOLE_MECHHOLE4MEC_PINMEC_PINHOLE_MECHIC1DS30EA101_DS30EA101_13PINS_DS30DS30EA101DS30EA101_13PINSIC2DS32ELX0124_DS32ELX0124_49PINS_DS32ELX0124DS32ELX0124_49PINSJ1FPGA_JTAG_0_FPGA_JTAG_10PINS_FPFPGA_JTAG_10PINSFPGA_JTAG_10PINSJ2XILINX_FPGA_JTAG_2_CON8_2_54_COCON8CON8_2_54J3CONN PWR3-H_CON3_2_54_CONN 2.5CONN 2.54MM 3-HCON3_2_54J4CON5_SMA_CON5CON5SMAJ5POWERJACK_12V_12V_POWER_JACK_POPOWER_JACK_12V12V_POWER_JACKJ6POWER_ON_BOTTOM_12V_POWER_ON_BO12V_POWER_ON_BOTTOM12V_POWER_ON_BOTTOMJ7CONN SOCKET40X2_2_CON3_2_54_COCONN3_2.54mmCON3_2_54J8CONN SOCKET40X2_2_CON3_2_54_COCONN3_2.54mmCON3_2_54J9CONNECTOR - 2 X1_TE_825433-2_9961102-6404-ARTE_825433-2J11TI_14PIN_JTAG_DSP_JTAG_14PINS_TTI_JTAG_14PINSDSP_JTAG_14PINSJ12GSB3211311WEU_0_UEB1112C-2AK1-4UEB1112C-2AK1-4HUEB1112C-2AK1-4HJ13HEADER_1X2_TE_825433-2_961102-6961102-6404-ARTE_825433-2J14HEADER_1X2_TE_825433-2_825433-2825433-2TE_825433-2J15DX4R005J91R1500_DX4R005J91R1500DX4R005J91R1500DX4R005J91R1500J163M_SATA_5607_7PIN_3M_SATA_5607_3M_SATA_5607_7PINS3M_SATA_5607_7PINSJ173M_SATA_5607_7PIN_3M_SATA_5607_3M_SATA_5607_7PINS3M_SATA_5607_7PINSJ183M_SATA_5607_7PIN_3M_SATA_5607_3M_SATA_5607_7PINS3M_SATA_5607_7PINSJ193M_SATA_5607_7PIN_3M_SATA_5607_3M_SATA_5607_7PINS3M_SATA_5607_7PINSJ20HRS-FPC-FH12-CL586-0564-3_HRS_FHRS-FPC-FH0564-3HRS_FPC_30PINSJ21HRS-FPC-FH12-CL586-0564-3_HRS_FHRS-FPC-FH0564-3HRS_FPC_30PINSJ22PAL_5PINS_PAL_5PIN_PAL_5PINPAL_5PINPAL_5PINJ23PAL_5PINS_PAL_5PIN_PAL_5PINPAL_5PINPAL_5PINJ24ONE_PIN_CON_ONE_PIN_CON_ONE_PINONE_PIN_CONONE_PIN_CONJ25ONE_PIN_CON_ONE_PIN_CON_ONE_PINONE_PIN_CONONE_PIN_CONJ26ONE_PIN_CON_ONE_PIN_CON_ONE_PINONE_PIN_CONONE_PIN_CONJ27ONE_PIN_CON_ONE_PIN_CON_ONE_PINONE_PIN_CONONE_PIN_CONJ28ONE_PIN_CON_ONE_PIN_CON_ONE_PINONE_PIN_CONONE_PIN_CONJ29ONE_PIN_CON_ONE_PIN_CON_ONE_PINONE_PIN_CONONE_PIN_CONJ30ONE_PIN_CON_ONE_PIN_CON_ONE_PINONE_PIN_CONONE_PIN_CONJ33SWAP_POWER_5VSWAPTE_825433-2L1INDUCTOR_L0603_NCNCL0603L2INDUCTOR_L0603_BLM18PG181SN1BLM18PG181SN1L0603L3INDUCTOR_L0603_BLM18PG181SN1BLM18PG181SN1L0603L4INDUCTOR_L0603_NCNCL0603L51211_CHOKE_0_L0805_DISCRETE_1UH1uHL0805L6INDUCTOR_L0603_BLM18PG181SN1BLM18PG181SN1L0603L71211_CHOKE_0_CHOKE_2P_238_287_10.47uHCHOKE_2P_238_287X260L81211_CHOKE_0_CHOKE_2P_238_287_10.47uHCHOKE_2P_238_287X260L9INDUCTORFERRITE_L0603_4.7UH4.7uHL0603L10INDUCTORFERRITE_L0603_4.7UH4.7uHL0603L11INDUCTORFERRITE_L0603_4.7UH4.7uHL0603L12FERRITE_L0805_4.7UH4.7UHL0805L131211_CHOKE_0_CHOKE_2P_238_287X23.3uHCHOKE_2P_238_287X260L141211_L_0_INDUCTOR_2P_267_270X2622uHINDUCTOR_2P_267_270X265L151211_CHOKE_0_CHOKE_2P_238_287X23.3uHCHOKE_2P_238_287X260L161211_CHOKE_0_CHOKE_2P_238_287X23.3uHCHOKE_2P_238_287X260L17INDUCTOR_L0805_BLM41PG600SN1BLM41PG600SN1L0805L18INDUCTORFERRITE_L0603_4.7UH4.7uHL0603L19INDUCTORFERRITE_L0603_4.7UH4.7uHL0603L20INDUCTOR_BLM21PG221SN1D_BLM21PGBLM21PG221SN1DBLM21PG221SN1DL21INDUCTOR_BLM21PG221SN1D_BLM21PGBLM21PG221SN1DBLM21PG221SN1DL22INDUCTOR_NLCV32T-2R2M-PFR_2.2UH2.2uHNLCV32T-2R2M-PFRL23INDUCTOR_BLM21PG221SN1D_BLM21PGBLM21PG221SN1DBLM21PG221SN1DLED1LED_LED_0603_LED_GREEN_LED_GREENLED_0603NAND1NAND512R3A2DZA6E_2_VFBGA80P_10PMT29F1G08ABCHCVFBGA80P_10P5X15_63_EINFPMBUS11653_JH5X1V_0_HD_5X1P_100_D_IO_PH_5x1V_2.54mmHD_5X1P_100_DQ1141_MICROCHIP_MCP9700AT-E-LT_0_MICROCHIP_MCP9700AT-E/LTSC-70_5PQ2141_TI_TPS73701DRBT_3_QFN_20_TITI_TPS74401QFN_20Q3141_TI_TPS73701DRBT_0_QFN_8P_26TI_TPS73701DRBTQFN_8P_26_118X118Q4141_TI_TPS73701DRBT_3_QFN_20_TITI_TPS74401QFN_20RP1RP_1K_RP_3PINS_SMD_1K1KRP_3PINS_SMDSPI1141_NUMONYX_N25Q128A21BSF40F_0_NUMONYX_N25Q128A21BSF40FSOIC_16P_50_406X406SW1PUSHBUTTON_SW_PB_PUSHBUTTONPUSHBUTTONSW_PBSW2EVQ-PE105K_EVQ-PE105K_434123 0434 123 050 816EVQ-PE105KSW3EVQ-PE105K_EVQ-PE105K_434123 0434 123 050 816EVQ-PE105KTP1T POINT R_PAD_TEST_TPOINT RT POINT RPAD_TESTTP2T POINT R_PAD_TEST_TPOINT RT POINT RPAD_TESTTP400_TP-S40_0_TP-S40_TP-S40TP-S40TP-S40TP500_TP-S50X2-SHORT_0_TP-S50X2-SHTP-S50X2-SHORTTP-S50X2-SHORTU1XCV6LX240T_2_FF1156_(S1+S2+S3+SXCV6LX240TFF1156U250MHZ_SMD_0507_40MHZ40MHZSMD_0507U3AD9288_2_XCF128X_FGT64C_XCF128XXCF128X_FGT64CXCF128X_FGT64CU4MT47H64M16HR_84-FBGA_MT47H64M16MT47H64M16HR84-FBGAU5MT47H64M16HR_84-FBGA_MT47H64M16MT47H64M16HR84-FBGAU6LP2997_PSOP-8_LP2997LP2997PSOP-8U7TMS320C6657_BGA80P_38X38_625_SKTMS320C6657BGA80P_38X38_625_SKT_EINFU10141_TI_SN74ALVC125PWR_0_SOIC_14TI_SN74ALVC125PWRSOIC_14P_26_197X252U11141_TI_SN74AVC4T245PWR_0_SOIC_1TI_SN74AVC4T245PWRSOIC_16P_26_197X252U12141_TI_MAX3221E_0_SOIC_16P_26_1TI_MAX3221ECPWRSOIC_16P_26_197X252U13SY58608U_3_SY89832_SY89832USY89832USY89832U14141_TI_SN74AVC4T245PWR_2_SOIC_1TI_SN74AVC4T245PWRSOIC_16P_26_197X252U15141_SAMSUNG_K4B1G1646G-BCH9_0_BSAMSUNG_K4B1G1646G-BCH9BGA_96P_31_524X295_C14U16141_SAMSUNG_K4B1G1646G-BCH9_0_BSAMSUNG_K4B1G1646G-BCH9BGA_96P_31_524X295_C14U17141_SAMSUNG_K4B1G1646G-BCH9_0_BSAMSUNG_K4B1G1646G-BCH9BGA_96P_31_524X295_C14U18141_TI_SN74AVC4T245PWR_1_UQFN10SN74AVC2T245RSWRUQFN10U19141_TI_UCD9222RGZR_0_QFN_48P_20TI_UCD9222RGZRQFN_48P_20_276X276_TP202V25U20141_TI_UCD7242RSJT_0_QFN_32P_20TI_UCD7242RSJTQFN_32P_20_236X236_UDC7242U21PTH04070_PTH04070_PTH04070PTH04070PTH04070U22PTH04070_PTH04070_PTH04070PTH04070PTH04070U23141_TI_TPS51200DRCT_0_QFN10P_20TI_TPS51200DRCTQFN10P_20_118X118_TP94X65V5U24141_TI_TPS54620RGY_0_QFN_14P_20TI_TPS54620RGYQFN_14P_20_138X138_TP79U25141_TI_TPS54231D_0_SOIC_8P_50_1TI_TPS54231DSOIC_8P_50_193X236U2614S_TI_SN74LVC1G07_SOT-23-5_1_STI_SN74LVC1G07DBVRSOT-23_5PU27141_TI_TPS54620RGY_0_QFN_14P_20TI_TPS54620RGYQFN_14P_20_138X138_TP79U28141_TI_TPS54620RGY_0_QFN_14P_20TI_TPS54620RGYQFN_14P_20_138X138_TP79U29PTV05010_1_PTV05010_PTV05010PTV05010PTV05010U30TPS3823-33_0_TPS3823-33_TPS3823TPS3823-33TPS3823-33U31141_FTDI_FT2232HL_0_QFP_64P_20_FTDI_FT2232HLQFP_64P_20_472X472U32141_TI_TXS0108EPWR_0_SOIC_20P_2TI_TXS0108EPWRSOIC_20P_26_256X252U33141_TI_SN74LVC00APWR_TSSOP14_0_TI_SN74LVC00APWRSOIC_14P_26_197X252U34141_ATMEL_AT93C46DN-SH-T_0_SOICATMEL_AT93C46DN-SH-TSOIC_8P_50_193X236U37SN74LVC1G08DCKR_SC70_5P_SN74LVCSN74LVC1G08DCKRSC70_5PU38TS3L301_SOIC_48P_20_492X319_TS3TS3L301DGGSOIC_48P_20_492X319U39NCP361SNT1G_0_SOT95P275X110-5N_NCP360SNT1GSOT95P275X110-5N_AU40AZ1065-06Q_0_UDFN10_SP3010_ESDESD ProtectorUDFN10_SP3010U41USBLC6-2_0_SOT95P280X145-6N_824824 001 02SOT95P280X145-6NU42LM1117MPX-3_1.3SOT223_DPAK_4PINCP1117DT33RKGDPAK_4PIN_RELU43NCP1117DTARKG_1NCP1117DTARKGDPAK_4PIN_RELU44SC189CSKTRT_SOT95P280X145-5N_SCSC189CSKTRTSOT95P280X145-5NU45FX3_121_BUMP_10_FX3_121_BUMP_FXFX3_121_BUMPFX3_121_BUMPU46M24M02-DR_SOIC127P600X175-8N_A_M24M02-DRMN6TPSOIC127P600X175-8N_AU47CY7C65215_4_CY7C65215-32LTXI_CYCY7C65215CY7C65215-32LTXIU48USBLC6-2_0_SOT95P280X145-6N_824824 001 02SOT95P280X145-6NU49LT1963A_2.3V_LT1963A_3_LT1963A_LT1963A_3.3VLT1963A_3U50TPS72518_1_TPS72518DCQ_SOT223-5TPS72518TPS72518DCQ_SOT223-5U51ADV7180_0_ADV7180_40PIN_LFCSP_AADV7180ADV7180_40PIN_LFCSPU52ADV7123_ADV7123_LQFP_48PINS_ADVADV7123ADV7123_LQFP_48PINSU53SN74AVC16T245_DGG_SN74AVC16T245SN74AVC16T245SN74AVC16T245_SOP48U54LT1963A_2.3V_LT1963A_3_LT1963A_LT1963A_3.3VLT1963A_3U55141_TI_TXS0108EPWR_0_SOIC_20P_2TI_TXS0108EPWRSOIC_20P_26_256X252U56SN74LVC1T45_DCK_SN74LVC1T45_DCKSN74LVC1T45SN74LVC1T45_DCKU57TFP410_PQFP_64PIN_TFP410TFP410TFP410_PQFP_64PIN_1U58LT1963A_2.3V_LT1963A_3_LT1963A_LT1963A_3.3VLT1963A_3U59141_TI_SN74AVC4T245PWR_1_UQFN10SN74AVC2T245RSWRUQFN10USB11654_USB-UH51543_MABTYPE_0_USB-MINIUSB_5HUSB-UH51543Y11231_XTAL_2P_0_XTAL_2P_161_205X25MHz_20pFXTAL_2P_161_205X134_H59Y21231_XTAL_2P_0_XTAL_2P_161_20_112MHz_20pFXTAL_2P_161_205X134_H59Y3CRYSTAL_1_OSCCC200X250X55-4N_CRCRYSTALOSCCC200X250X55-4NY4CRYATAL_28.6363MHZ_CRY_28M_SMD_CRYSTAL_28.6363MHZCRY_28M_SMD PCB文件是ALLEGRO16.6格式。
**** Hidden Message ***** 不错的东西啊 高大上,啧啧 看起来不错哦
