[Allegro16.6以下] 工业主板XCV6LX240T_FF1156+TMS320C6657+XCF128X+FX3_121_BUMP+TFP410+UCD7242
查看28703 | 回复188 | 2017-5-21 20:57:58 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
板子有以下元件
B11212_FILTER_NFW31SP106X1E4L_3_L2200pFL_3P_70_63X35
B21212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35
B31212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35
B41212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35
B51212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35
B61212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35
B71212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35
B81212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35
B91212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35
B101212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35
B111212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35
B121212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35
B131212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35
B141212_FILTER_NFW31SP106X1E4L_2_L2200pFL_3P_70_63X35
B26L0805_120_100MHZ120_120MHZL0805
B271212_BEAD_0_L0603_120_100MHZ120_100MHzL0603
B281212_BEAD_0_L0603_120_100MHZ120_100MHzL0603
B291212_BEAD_0_L0805_120_100MHZ120_100MHzL0805
B301212_BEAD_0_L0603_120_100MHZ120_100MHzL0603
B311212_BEAD_0_L0603_120_100MHZ120_100MHzL0603
B321212_BEAD_0_L0603_DISCRETE_120_120_100MHzL0603
CLK1141_TI_CDCE62005RGZT_0_QFN_48P_TI_CDCE62005RGZTQFN_48P_20_276X276_TP220V25
CP1CAP POL_C1210_100UF100uFC1210
CRY150MHZ_SMD_0507_25MHZ25MHZSMD_0507
D1LED_LED0603_LEDLEDLED0603
D2LED_0_LED0603_LEDLEDLED0603
D3LED_LED0603_LEDLEDLED0603
D4LED_0_LED0603_LEDLEDLED0603
D5LED_LED0603_LEDLEDLED0603
D6130_SCHOTTKY_SMA-1_0_DIODE_2P_1B340ADIODE_2P_158_197X110
D7LED_LED0603_LEDLEDLED0603
D8130_ESD_D0603_0_ESD_2P_65_63X31PGB1010603ESD_2P_65_63X31
D9130_ESD_D0603_0_ESD_2P_65_63X31PGB1010603ESD_2P_65_63X31
D10LED_0_LED0603_LEDLEDLED0603
DVI1DVI_INTERFACE_0 DVI_D_24PIN_NEW
EEPROM1141_ST_M24M01-HRMN6TP_0_SOIC_8PST_M24M01-HRMN6TPSOIC_8P_50_193X236
FB1INDUCTOR_FB0805_MPZ2012S601A_MPZ2012S601AFB0805
FB2INDUCTOR_FB0805_MPZ2012S601A_MPZ2012S601AFB0805
FB3INDUCTOR_FB0805_MPZ2012S601A_MPZ2012S601AFB0805
FB4INDUCTOR_FB0805_MPZ2012S601A_MPZ2012S601AFB0805
FB5FERRITE_120OHM_2000MA_0_EMIFIL120EEMIFIL_BLM18P_0603
FB6INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805
FB7INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805
FB8INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805
FB9INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805
FB10INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805
FB11INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805
FB12INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805
FB13INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805
FB14INDUCTOR_FB0805_MPZ2012S601A_MPMPZ2012S601AFB0805
HOLE1MEC_PINMEC_PINHOLE_MECH
HOLE2MEC_PINMEC_PINHOLE_MECH
HOLE3MEC_PINMEC_PINHOLE_MECH
HOLE4MEC_PINMEC_PINHOLE_MECH
IC1DS30EA101_DS30EA101_13PINS_DS30DS30EA101DS30EA101_13PINS
IC2DS32ELX0124_DS32ELX0124_49PINS_DS32ELX0124DS32ELX0124_49PINS
J1FPGA_JTAG_0_FPGA_JTAG_10PINS_FPFPGA_JTAG_10PINSFPGA_JTAG_10PINS
J2XILINX_FPGA_JTAG_2_CON8_2_54_COCON8CON8_2_54
J3CONN PWR3-H_CON3_2_54_CONN 2.5CONN 2.54MM 3-HCON3_2_54
J4CON5_SMA_CON5CON5SMA
J5POWERJACK_12V_12V_POWER_JACK_POPOWER_JACK_12V12V_POWER_JACK
J6POWER_ON_BOTTOM_12V_POWER_ON_BO12V_POWER_ON_BOTTOM12V_POWER_ON_BOTTOM
J7CONN SOCKET40X2_2_CON3_2_54_COCONN3_2.54mmCON3_2_54
J8CONN SOCKET40X2_2_CON3_2_54_COCONN3_2.54mmCON3_2_54
J9CONNECTOR - 2 X1_TE_825433-2_9961102-6404-ARTE_825433-2
J11TI_14PIN_JTAG_DSP_JTAG_14PINS_TTI_JTAG_14PINSDSP_JTAG_14PINS
J12GSB3211311WEU_0_UEB1112C-2AK1-4UEB1112C-2AK1-4HUEB1112C-2AK1-4H
J13HEADER_1X2_TE_825433-2_961102-6961102-6404-ARTE_825433-2
J14HEADER_1X2_TE_825433-2_825433-2825433-2TE_825433-2
J15DX4R005J91R1500_DX4R005J91R1500DX4R005J91R1500DX4R005J91R1500
J163M_SATA_5607_7PIN_3M_SATA_5607_3M_SATA_5607_7PINS3M_SATA_5607_7PINS
J173M_SATA_5607_7PIN_3M_SATA_5607_3M_SATA_5607_7PINS3M_SATA_5607_7PINS
J183M_SATA_5607_7PIN_3M_SATA_5607_3M_SATA_5607_7PINS3M_SATA_5607_7PINS
J193M_SATA_5607_7PIN_3M_SATA_5607_3M_SATA_5607_7PINS3M_SATA_5607_7PINS
J20HRS-FPC-FH12-CL586-0564-3_HRS_FHRS-FPC-FH0564-3HRS_FPC_30PINS
J21HRS-FPC-FH12-CL586-0564-3_HRS_FHRS-FPC-FH0564-3HRS_FPC_30PINS
J22PAL_5PINS_PAL_5PIN_PAL_5PINPAL_5PINPAL_5PIN
J23PAL_5PINS_PAL_5PIN_PAL_5PINPAL_5PINPAL_5PIN
J24ONE_PIN_CON_ONE_PIN_CON_ONE_PINONE_PIN_CONONE_PIN_CON
J25ONE_PIN_CON_ONE_PIN_CON_ONE_PINONE_PIN_CONONE_PIN_CON
J26ONE_PIN_CON_ONE_PIN_CON_ONE_PINONE_PIN_CONONE_PIN_CON
J27ONE_PIN_CON_ONE_PIN_CON_ONE_PINONE_PIN_CONONE_PIN_CON
J28ONE_PIN_CON_ONE_PIN_CON_ONE_PINONE_PIN_CONONE_PIN_CON
J29ONE_PIN_CON_ONE_PIN_CON_ONE_PINONE_PIN_CONONE_PIN_CON
J30ONE_PIN_CON_ONE_PIN_CON_ONE_PINONE_PIN_CONONE_PIN_CON
J33SWAP_POWER_5VSWAPTE_825433-2
L1INDUCTOR_L0603_NCNCL0603
L2INDUCTOR_L0603_BLM18PG181SN1BLM18PG181SN1L0603
L3INDUCTOR_L0603_BLM18PG181SN1BLM18PG181SN1L0603
L4INDUCTOR_L0603_NCNCL0603
L51211_CHOKE_0_L0805_DISCRETE_1UH1uHL0805
L6INDUCTOR_L0603_BLM18PG181SN1BLM18PG181SN1L0603
L71211_CHOKE_0_CHOKE_2P_238_287_10.47uHCHOKE_2P_238_287X260
L81211_CHOKE_0_CHOKE_2P_238_287_10.47uHCHOKE_2P_238_287X260
L9INDUCTORFERRITE_L0603_4.7UH4.7uHL0603
L10INDUCTORFERRITE_L0603_4.7UH4.7uHL0603
L11INDUCTORFERRITE_L0603_4.7UH4.7uHL0603
L12FERRITE_L0805_4.7UH4.7UHL0805
L131211_CHOKE_0_CHOKE_2P_238_287X23.3uHCHOKE_2P_238_287X260
L141211_L_0_INDUCTOR_2P_267_270X2622uHINDUCTOR_2P_267_270X265
L151211_CHOKE_0_CHOKE_2P_238_287X23.3uHCHOKE_2P_238_287X260
L161211_CHOKE_0_CHOKE_2P_238_287X23.3uHCHOKE_2P_238_287X260
L17INDUCTOR_L0805_BLM41PG600SN1BLM41PG600SN1L0805
L18INDUCTORFERRITE_L0603_4.7UH4.7uHL0603
L19INDUCTORFERRITE_L0603_4.7UH4.7uHL0603
L20INDUCTOR_BLM21PG221SN1D_BLM21PGBLM21PG221SN1DBLM21PG221SN1D
L21INDUCTOR_BLM21PG221SN1D_BLM21PGBLM21PG221SN1DBLM21PG221SN1D
L22INDUCTOR_NLCV32T-2R2M-PFR_2.2UH2.2uHNLCV32T-2R2M-PFR
L23INDUCTOR_BLM21PG221SN1D_BLM21PGBLM21PG221SN1DBLM21PG221SN1D
LED1LED_LED_0603_LED_GREEN_LED_GREENLED_0603
NAND1NAND512R3A2DZA6E_2_VFBGA80P_10PMT29F1G08ABCHCVFBGA80P_10P5X15_63_EINF
PMBUS11653_JH5X1V_0_HD_5X1P_100_D_IO_PH_5x1V_2.54mmHD_5X1P_100_D
Q1141_MICROCHIP_MCP9700AT-E-LT_0_MICROCHIP_MCP9700AT-E/LTSC-70_5P
Q2141_TI_TPS73701DRBT_3_QFN_20_TITI_TPS74401QFN_20
Q3141_TI_TPS73701DRBT_0_QFN_8P_26TI_TPS73701DRBTQFN_8P_26_118X118
Q4141_TI_TPS73701DRBT_3_QFN_20_TITI_TPS74401QFN_20
RP1RP_1K_RP_3PINS_SMD_1K1KRP_3PINS_SMD
SPI1141_NUMONYX_N25Q128A21BSF40F_0_NUMONYX_N25Q128A21BSF40FSOIC_16P_50_406X406
SW1PUSHBUTTON_SW_PB_PUSHBUTTONPUSHBUTTONSW_PB
SW2EVQ-PE105K_EVQ-PE105K_434123 0434 123 050 816EVQ-PE105K
SW3EVQ-PE105K_EVQ-PE105K_434123 0434 123 050 816EVQ-PE105K
TP1T POINT R_PAD_TEST_TPOINT RT POINT RPAD_TEST
TP2T POINT R_PAD_TEST_TPOINT RT POINT RPAD_TEST
TP400_TP-S40_0_TP-S40_TP-S40TP-S40TP-S40
TP500_TP-S50X2-SHORT_0_TP-S50X2-SHTP-S50X2-SHORTTP-S50X2-SHORT
U1XCV6LX240T_2_FF1156_(S1+S2+S3+SXCV6LX240TFF1156
U250MHZ_SMD_0507_40MHZ40MHZSMD_0507
U3AD9288_2_XCF128X_FGT64C_XCF128XXCF128X_FGT64CXCF128X_FGT64C
U4MT47H64M16HR_84-FBGA_MT47H64M16MT47H64M16HR84-FBGA
U5MT47H64M16HR_84-FBGA_MT47H64M16MT47H64M16HR84-FBGA
U6LP2997_PSOP-8_LP2997LP2997PSOP-8
U7TMS320C6657_BGA80P_38X38_625_SKTMS320C6657BGA80P_38X38_625_SKT_EINF
U10141_TI_SN74ALVC125PWR_0_SOIC_14TI_SN74ALVC125PWRSOIC_14P_26_197X252
U11141_TI_SN74AVC4T245PWR_0_SOIC_1TI_SN74AVC4T245PWRSOIC_16P_26_197X252
U12141_TI_MAX3221E_0_SOIC_16P_26_1TI_MAX3221ECPWRSOIC_16P_26_197X252
U13SY58608U_3_SY89832_SY89832USY89832USY89832
U14141_TI_SN74AVC4T245PWR_2_SOIC_1TI_SN74AVC4T245PWRSOIC_16P_26_197X252
U15141_SAMSUNG_K4B1G1646G-BCH9_0_BSAMSUNG_K4B1G1646G-BCH9BGA_96P_31_524X295_C14
U16141_SAMSUNG_K4B1G1646G-BCH9_0_BSAMSUNG_K4B1G1646G-BCH9BGA_96P_31_524X295_C14
U17141_SAMSUNG_K4B1G1646G-BCH9_0_BSAMSUNG_K4B1G1646G-BCH9BGA_96P_31_524X295_C14
U18141_TI_SN74AVC4T245PWR_1_UQFN10SN74AVC2T245RSWRUQFN10
U19141_TI_UCD9222RGZR_0_QFN_48P_20TI_UCD9222RGZRQFN_48P_20_276X276_TP202V25
U20141_TI_UCD7242RSJT_0_QFN_32P_20TI_UCD7242RSJTQFN_32P_20_236X236_UDC7242
U21PTH04070_PTH04070_PTH04070PTH04070PTH04070
U22PTH04070_PTH04070_PTH04070PTH04070PTH04070
U23141_TI_TPS51200DRCT_0_QFN10P_20TI_TPS51200DRCTQFN10P_20_118X118_TP94X65V5
U24141_TI_TPS54620RGY_0_QFN_14P_20TI_TPS54620RGYQFN_14P_20_138X138_TP79
U25141_TI_TPS54231D_0_SOIC_8P_50_1TI_TPS54231DSOIC_8P_50_193X236
U2614S_TI_SN74LVC1G07_SOT-23-5_1_STI_SN74LVC1G07DBVRSOT-23_5P
U27141_TI_TPS54620RGY_0_QFN_14P_20TI_TPS54620RGYQFN_14P_20_138X138_TP79
U28141_TI_TPS54620RGY_0_QFN_14P_20TI_TPS54620RGYQFN_14P_20_138X138_TP79
U29PTV05010_1_PTV05010_PTV05010PTV05010PTV05010
U30TPS3823-33_0_TPS3823-33_TPS3823TPS3823-33TPS3823-33
U31141_FTDI_FT2232HL_0_QFP_64P_20_FTDI_FT2232HLQFP_64P_20_472X472
U32141_TI_TXS0108EPWR_0_SOIC_20P_2TI_TXS0108EPWRSOIC_20P_26_256X252
U33141_TI_SN74LVC00APWR_TSSOP14_0_TI_SN74LVC00APWRSOIC_14P_26_197X252
U34141_ATMEL_AT93C46DN-SH-T_0_SOICATMEL_AT93C46DN-SH-TSOIC_8P_50_193X236
U37SN74LVC1G08DCKR_SC70_5P_SN74LVCSN74LVC1G08DCKRSC70_5P
U38TS3L301_SOIC_48P_20_492X319_TS3TS3L301DGGSOIC_48P_20_492X319
U39NCP361SNT1G_0_SOT95P275X110-5N_NCP360SNT1GSOT95P275X110-5N_A
U40AZ1065-06Q_0_UDFN10_SP3010_ESDESD ProtectorUDFN10_SP3010
U41USBLC6-2_0_SOT95P280X145-6N_824824 001 02SOT95P280X145-6N
U42LM1117MPX-3_1.3SOT223_DPAK_4PINCP1117DT33RKGDPAK_4PIN_REL
U43NCP1117DTARKG_1NCP1117DTARKGDPAK_4PIN_REL
U44SC189CSKTRT_SOT95P280X145-5N_SCSC189CSKTRTSOT95P280X145-5N
U45FX3_121_BUMP_10_FX3_121_BUMP_FXFX3_121_BUMPFX3_121_BUMP
U46M24M02-DR_SOIC127P600X175-8N_A_M24M02-DRMN6TPSOIC127P600X175-8N_A
U47CY7C65215_4_CY7C65215-32LTXI_CYCY7C65215CY7C65215-32LTXI
U48USBLC6-2_0_SOT95P280X145-6N_824824 001 02SOT95P280X145-6N
U49LT1963A_2.3V_LT1963A_3_LT1963A_LT1963A_3.3VLT1963A_3
U50TPS72518_1_TPS72518DCQ_SOT223-5TPS72518TPS72518DCQ_SOT223-5
U51ADV7180_0_ADV7180_40PIN_LFCSP_AADV7180ADV7180_40PIN_LFCSP
U52ADV7123_ADV7123_LQFP_48PINS_ADVADV7123ADV7123_LQFP_48PINS
U53SN74AVC16T245_DGG_SN74AVC16T245SN74AVC16T245SN74AVC16T245_SOP48
U54LT1963A_2.3V_LT1963A_3_LT1963A_LT1963A_3.3VLT1963A_3
U55141_TI_TXS0108EPWR_0_SOIC_20P_2TI_TXS0108EPWRSOIC_20P_26_256X252
U56SN74LVC1T45_DCK_SN74LVC1T45_DCKSN74LVC1T45SN74LVC1T45_DCK
U57TFP410_PQFP_64PIN_TFP410TFP410TFP410_PQFP_64PIN_1
U58LT1963A_2.3V_LT1963A_3_LT1963A_LT1963A_3.3VLT1963A_3
U59141_TI_SN74AVC4T245PWR_1_UQFN10SN74AVC2T245RSWRUQFN10
USB11654_USB-UH51543_MABTYPE_0_USB-MINIUSB_5HUSB-UH51543
Y11231_XTAL_2P_0_XTAL_2P_161_205X25MHz_20pFXTAL_2P_161_205X134_H59
Y21231_XTAL_2P_0_XTAL_2P_161_20_112MHz_20pFXTAL_2P_161_205X134_H59
Y3CRYSTAL_1_OSCCC200X250X55-4N_CRCRYSTALOSCCC200X250X55-4N
Y4CRYATAL_28.6363MHZ_CRY_28M_SMD_CRYSTAL_28.6363MHZCRY_28M_SMD
重要提示:PCB作品文件展下载说明
人人为我,我为人人。希望大家下载资料的同时能回帖支持,你们的支持,是我最大的共享动力。不回帖以后不共享了。哈哈
layout | 2017-5-21 20:59:18 | 显示全部楼层
PCB文件是ALLEGRO16.6格式。
游客,如果您要查看本帖隐藏内容请回复
xnima_irumei | 2017-5-21 21:02:30 | 显示全部楼层
lg0556 | 2017-5-21 21:52:26 | 显示全部楼层
zengfanlong | 2017-5-21 22:33:36 | 显示全部楼层
o桃花岛主o | 2017-5-21 22:35:40 | 显示全部楼层
xiaotianshi | 2017-5-21 22:50:35 | 显示全部楼层
chess2006 | 2017-5-21 23:32:07 | 显示全部楼层
shenchengan | 2017-5-22 07:52:56 | 显示全部楼层
神话2013 | 2017-5-22 07:58:38 | 显示全部楼层
人人为我,我为人人。
社区居民最爱沙发宣传大使奖终身成就奖社区明星忠实会员优秀斑竹奖
