armclub 发表于 2017-6-21 12:00:16
再发一个安卓系统车载主板 PCB和原理图共享下载
PCB和原理图都是PADS9.5格式
NamePart TypePCB DecalValueANT96ANT2ANT-CANTCN1CON-SMD22P-0.5MMCON-SMD22PIN-0.5MM20P 0.5mmCN2CON4_54P/1.25MMCON4CN3CON-SMD22P-0.5MMCON-SMD22PIN-0.5MM20P 0.5mmCN4CON4_54P/1.25MMCON4CN5CON4_54P/1.25MMCON4CN6CON4_6FPC-4P-1.0MMFPC4-1.0DCN9CON2_0CCFL-LAMPLED-PANELCON1CON-SMT-60PIN-HANNSTARFPC-60PIN-0.5MMCON2C200_LVDS_CON_4PC200_LVD_CON_4PCON3CON94CON94CON4CON74CON74D1DIODEDIODE_DO201AD_7MMIN5401D2TVSSTVS0603ESDD3TVSSTVS0603NCD4DSSD2010SS14D5DIODESD0805IN4148WD6DIODESD0805IN4148WD7TVSSTVS0603ESDD8DSSD2010SS14D9BAT54CSOT23-BAT54BAT54CD10TVSSTVS06030603ESDA-LPD11TVSSTVS06030603ESDA-LCD12DIODESD0805IN4148WD13TVSSTVS06030603ESDA-LPD14TVSSTVS0603ESDD15BAT54CSOT23-BAT54BAT54CD21TVSSTVS06030603ESDA-LCD23TVSSTVS06030603ESDA-LCD24TVSSTVS06030603ESDA-LCD26DIODE_DIACESD0603ESDD27TVSSTVS0603ESDD28DIODE_DIACESD0603ESDD30DIODESD08051N4148D31DIODESD08051N4148F1FUSESF1308500MAF3FUSESF1308500MAF4FUSESF1308200MAFB1INDUCTOR_0_2RES0805600RFB2INDUCTOR_0L0603600RFB3FBL0805SZ2012K421TFFB4FBSLB0805SZ2012K601TFFB5FBL0805FB310FB8FBSLB0805SZ2012K601TFFB9INDUCTOR_0L0603600RFB11INDUCTOR_0_2RES0805600RFB12INDUCTOR_0L0603600RFB13FBL0805SZ2012K421TFJ1SIP32AMCON32P-A1.0MM32P-1.0MM下接J2DDTAPJ3DDTAPJ4DDTAPJ5RCA_54PINRCA-54PINJ6CON-4PIN-IPODSIP4-78D74-32DUSB_JK CONJ7DDTAPJ8DDTAPJ9DDTAPJ1032PIN32PINAAAAAAAAAAAJ11DDTAPJ12DDTAPJ13DDTAPJ14IS0-54PINHD54J15GPSANTGPSANTACON5J16GPSANTGPSANTACON5J17FM-4750DIP-10PIN-FMTDQ-30FMV-001J18FCC-10P-1.25MMCON-10P-1.25MMFCC-10P-1.25MML1FBSL08051.8uHL2INDL-5X510uH/1.6AL3FBSL08051.8uHL4IND_18X25MML-13/2535mH非晶呃流线圈L5INDL-5X510uH/1.6AL6FBSL08051.8uHL7INDUCTOR/CHIPCF25223.3UHL15CD74IND-SMT-CD7522UHL21INDUCTOR/CHIPIND-SMD-CDH8B28/38/43/582.2MHL51FBSL08051.8uHQ1NPNSOT239014Q2NPNSOT239014Q3NPNSOT239014Q4PNPSOT238550Q5NPNSOT239014Q6PNPSOT238550Q7PMOSSOT23-MOSDMP3098LQ8NPNSOT898050Q9NPNSOT239014Q10PMOSSOT23-MOSDMP3098LQ11PMOSSOT23-MOSDMP3098LQ12NPNSOT239014Q13NPNSOT239014Q14NPNSOT233904Q15PNPSOT23MMBT3906Q16PNPSOT238550Q17NPNSOT239014Q18NPNSOT239014Q19NPNSOT239014Q20NPNSOT23MMBT3904Q21NPNSOT233904Q23PMOSSOT23-MOSDMP3098LQ24NPNSOT233904Q25PNPSOT238550Q26PNPSOT238550Q27PMOSSOT23-MOSDMP3098LQ28NPNSOT239014SC1SCREW-2.6-3.0MMSCREW-2.6MM-4SC2SCREW-2.6-3.0MMSCREW-2.6MM-4SC3SCREW-2.6-3.0MMSCREW-2.6MM-4SC4SCREW-2.6-3.0MMSCREW-2.6MM-4SC5SCREW-2.6-3.0MMSCREW-2.6MM-4SC6SCREW-2.6-3.0MMSCREW-2.6MM-4U1MN101EF51A_1QFP44-31D5-472MN101EF51AU2RT9164-33CG//AIC1117-33CY_0SOT2231117/3.3VU3MTK_CON126_1.27MMMTK_CON126_1.27MMU4SGM9119SOP8-25D59-197SGM9119U6MP3302SOT23-5MP3302U7MP1541SOT23-5MP1541U11TDA7381_0TDA7386ATDA7388U16HT7133SOT89-1HT7533Z1DZSD0805-15.6VZ2DZSD0805-15.6VZ3DZSD0805-15.6VZ4DZSD0805-1BZT52C9V1Z5DIODESD0805IN4148WZ6DZSD0805-1BZT52C15VZ7DZSD0805-1BZT52C6V8Z10DZSD0805-13V9ZD4BAV99SOT23-BAV99BAT54SZD5BAV99SOT23-BAV99BAT54S
armclub 发表于 2017-6-21 12:00:53
跟刚刚发的那个有进行小修改。
单枪舞九州 发表于 2017-6-21 13:36:21
pcb1314520 发表于 2017-6-21 13:40:52
steven7 发表于 2017-6-21 18:28:52
谢谢楼主分享。
为自己带盐 发表于 2017-6-21 22:41:38
什么方案的呀
木子清风 发表于 2017-6-27 09:19:18
woshizhengjie89 发表于 2017-12-15 15:36:42
已阅,顶一下
wst2016 发表于 2017-12-16 09:03:14
肥猫 发表于 2024-4-21 22:32:08
回 armclub 的帖子
armclub:
跟刚刚发的那个有进行小修改。 (2017-06-21 12:00) images/back.gif
查看完整版本: 再发一个安卓系统车载主板 PCB和原理图共享下载
