RK3288挂两个LPDDR3 双MIPI PCB和原理图共享ALC5640
NamePart TypePCB DecalValue6CON1JP_USB-0400ASMTMICRO-USB-TM-MC-02Micro USB PortANT1CON2ANT_2PWI-FI ANTD1DIODE_PINTVS0603TVSD14DIODE_PINTVS0603TVSD15DIODE_PINTVS0603TVSD5004DIODE_0D0805B5819WD5005DIODE_SCHOTTKYSOD1233.0VD5006DIODE_0D0805B5819WD5007DIODE_PINTVS0603TVSD5008DIODE_PINTVS0603TVSD5009DIODE_PINTVS0603TVSD5010DIODE_SCHOTTKYSOD1233.0VD5012DIODE_PINTVS0603TVSD5030DIODE_PINTVS0603TVSD5031DIODE_PINTVS0603TVSD5032DIODE_PINTVS0603TVSD5033DIODE_PINTVS0603TVSD5034DIODE_PINTVS0603TVSD5035DIODE_PINTVS0603TVSD5036DIODE_PINTVS0603TVSD5037DIODE_PINTVS0603TVSD5038DIODE_PINTVS0603TVSD5039DIODE_PINTVS0603TVSED2000DIODE_BI-DIR_TRIGE0402ESD5451NFB10COM_CHOKE_0CHOKE_4PDLW21HN900SQ2LFB7105INDUCTOR_2L0402600R/100MHzFB7106INDUCTOR_2L0402600R/100MHzFB7107INDUCTOR_2L0402600R/100MHzFB7108INDUCTOR_2L0402600R/100MHzFB7109INDUCTOR_2L0402600R/100MHzFB7200INDUCTORR06030RFB7201INDUCTORL0603BLM18EG601SN1FB7202INDUCTORL0603BLM18EG601SN1FB7203INDUCTORL0603BLM18EG601SN1FB7204INDUCTORL0603BLM18EG601SN1J4HEADER_4_0KEY3X5H9_VLOJ5HEADER_4_1FPC6P_0.5MMH9_VLOJ11PHONEJACK_STEREO_SW_3PJK-311S-CPHONEJACKJ19TOUCH-10PIN_0FPC6P_0.5MM8PIN-0.5mmJ20TOUCH-10PIN_0FPC6P_0.5MM8PIN-0.5mmJ22LCM0200CE1A0_12FH26-39S-0-339PJ23CON2CON2AbatterJ24LCM0200CE1A0_12FH26-39S-0-339PJ1800CON3UART-DEBUGCON3J7201CON2_0WIRELCON2J7202CON2_0WIRELCON2L1INDUCTORS_OF_FERRITEIND-3X3SWPA3015S1R0NT/1.5AL10INDUCTORS_OF_FERRITEIND-3X3SWPA3015S1R0NT/1.5AL11INDUCTORS_OF_FERRITEIND-3X3SWPA3015S1R0NT/1.5AL12INDUCTORS_OF_FERRITEIND-4X4SWPA4020S1R0NT/3AL13INDUCTORS_OF_FERRITEIND-3X3SWPA3015S1R0NT/1.5AL14INDUCTORS_OF_FERRITEIND-3X3SWPA3015S1R0NT/1.5AL32INDUCTOR_3IND-4X44.7uHL2109INDUCTOR_1CD434.7uH/2AL2110INDUCTOR_1CD434.7uH/2AL2205INDUCTORS_OF_FERRITEINDC2520X220L0.22uH/5AL2207INDUCTORS_OF_FERRITEINDC2520X220L0.22uH/5ALA60INDUCTOR_1L25202.2uHLA61INDUCTOR_1L25202.2uHP2102TESTPOINT1T-0.7TESTP2104TESTPOINT1T-0.7TESTQ3600FET_N_MOSSOT23WNM2016Q3601NPN4SOT238050TPRTEST-1_4.0TPTEST-1.0TPR1TEST-1_4.0TPTEST-1.0TPRGTEST-1_4.0TPTEST-1.0TVOL+TEST-1_4.0TPTEST-1.0TVOL-TEST-1_4.0TPTEST-1.0TVOL-1TEST-1_4.0TPTEST-1.0TVOL-2TEST-1_4.0TPTEST-1.0U295T619_2CSP0608-80RC5T620-1017U37MT6628_1LGA44_12_12MMM500U1000MCU_RK3288BGA636_19X19MCU_RK3288U2000ESDX2SOT23ESD5302FU2205BB27_0WLCSP-20SYR827U2206BB27_0WLCSP-20SYR828U3600LPDDR3-32BIT-178PINFBGA178-13X11.5LPDDR3-32_178U3601LPDDR3-32BIT-178PINFBGA178-13X11.5LPDDR3-32_178U4000INAND_0INAND_169eMMCU4001LDO-PT5108/RT9013SOT25TG1803-18U7100CODEC-ALC3224QFN48-6X6ALC5640U7201LDO-PT5108/RT9013SOT25TG1803-18U8004G5121SOT26SY7200AU8005G5121SOT26SY7200AUA66G5121_3TQFN-16TPS65135UA67G5121_3TQFN-16TPS65135Y2CRYSTALCRY-MC14632.768KY5CRYSTAL-4CRY-D322526M-20ppmY1100CRYSTAL-4_1CRY-D322524M-30ppm 避免大范围扩散。有需要的下载。 所以RMB 。 没需要的就看看图片好了。
支持 哇! 老酷,看图,有币需要在下载 很好的资料 老师又出猛料了
