电子小跑腿 发表于 2017-7-22 14:11:53
车载PCB 和原理图共享
NamePCB DecalValuePart TypeBLUETOOTHFLC-BTMDC705-I2U-DPFLC-BTMDC705-I2UCXN1450CON1FPC-1.0K-A-NPB(30P)_2FPC30P_1.0CON30_FFC_GMCON2FPC10P_1.0FPC10P-1.0CON10CON4FFC10_0.5/SMD_PFPC10P-0.5CON10D1DIODE_DIP_ASSK34DIODED2IN4148-0805IN4148DIODED3DO-214IN4007DIODED4SOT-23BAV99BAV99D5SOT-23BAV99BAV99D6SMD5819B230ADIODED7IN4148-0805IN4148/NCDIODED8IN4148-0805IN4148DIODED9DO-214IN4007DIODED15IN4148-08054148DIODED16DO-214IN4007DIODED22IN4148-08054148DIODED24SOT-23BAV99BAV99D28IN4148-0805IN4148DIODED29SOT-23BAV99BAV99D31IN4148-08054148 NCDIODED32IN4148-08054148 NCDIODED33IN4148-0805IN4148DIODED34SOT-23BAV99BAV99D35SOT-23BAV99BAV99D37IN4148-0805IN4148DIODED39SOT-23BAV99BAV99D40SOT-23BAV99BAV99D41SOT-23BAV99BAV99D46IN4148-0805IN4148DIODED47IN4148-0805IN4148DIODEF112100.5A /0RFUSEF212100.5A /0RFUSEF412100.5A /0RFUSEIPODIPOD_GMMDJ-105AIPOD_8PJ1CON8-2.0CON8P_2.0_CMMBCMMB8P_2.0J2ANT_2PSIP2P-2.0/NCCON2J316P-CON-GM16P-CON16P-CON-GMJ4SIP6P-1.27CON6P_1.27CON6P_1.27J5CON4P-2.0SIP4P_2.0CON4P_2.0J7SIP12-2.0TDA6621TUNER_BOARDJ18FFC45_0.5UPFFC45PIN_0.5MMFYT9023_TFT_45P_1J29SIP4P-1.271.27*4PIN/NCSIP4P-1.27JP1SPH20_2.0_90SPH20P_2.0SPH20_2.0JP2SPH18_2.0_90SPH18P_2.0SPH18_2.0L4SMDL7MM47UH/2AINDUCTOR_IRON_0L6L_13_26380uHL_13_26L8SMDL7MM33UH/3AINDUCTOR_IRONL9SMDL4.8X4.8.1.8100UH/200mAINDUCTORL12SMDL4.8X4.8.1.84.7UH/200mA/NCINDUCTORQ1SOT-23AO3401AP2301NQ2SOT-233904NPN_BCEQ3SOT-23AO3401AP2301NQ4SOT-233906PNP_3Q5SOT-233904NPN_BCEQ6SOT-23AO3401AP2301NQ7SOT-428_32SD1803NPN_BCEQ8SOT-233904NPN_BCEQ9SOT-23AO3401AP2301NQ10SOT-23AO3401AP2301NQ12SOT-233906PNP_3Q13SOT-233904NPN_BEC_2Q14SOT-233904NPN_BCEQ15SOT-233904NPN_BCEQ17SOT-233904NPN_BEC_7Q18SOT-23AO3401AP2301NQ19SOT-233904NPN_BCEQ20SOT-233904NPN_BEC_7Q21SOT-238550PNP_BCEQ22SOT-233906PNP_3Q23SOT-233904NPN_BEC_2Q25SOT-23AO3401AP2301NQ28SOT-239014NPN_0Q30SOT-233904NPN_BCEQ31SOT-233904NPN_BEC_7Q33SOT-233906PNP_3Q34SOT-233904NPN_BCEQ37SOT-23AO3401AP2301NQ39SOT-233904NPN_0RADIO1ST7540AF1QSD_RT_L89QST_7540U1SOT-42878D0578D05U2LQFP64STM8_64PINU3SOT-42878D0578D05U4SOT-42878D0978D05U5SOT-42878D0978D05U6TSSOP24-0.65FUS6502FMS6502U7BD3702FVBD3702FVBD3702FVU8SSOP16TDA7478TDA7478U9MSOP8/9MP2303MP2303DN_9U11MSOP8NJM4558/TLC2272C4558U13MSOP8NJM45584558U14TSSOP16-0.6574HC4052IC-SMD-SOP16U16MSOP8NJM45584558U21HZIP25TDA7386/TDA7384TDA7386U24SOT8978L1878L05U27SOT8978L1878L05Y2HC-49SM4.332MOSCY3CRY-49S-B16MHZCRY-2ZD1IN4148-08059.1VDZZD3IN4148-08057.5VDZ_0ZD4IN4148-080516VDZ_0ZD5IN4148-08057V5DZZD6IN4148-08056.8VDZZD26IN4148-08053.9VDZ_0ZD27IN4148-08053.9VDZ_0
irumei 发表于 2017-7-22 14:21:52
wcjcn 发表于 2017-7-22 14:30:31
感觉像是自动布线。。。。使用有没有问题哟??
lichengpcb 发表于 2017-7-22 14:50:38
很多过孔连在一起是软件自动加的?
tianghao520 发表于 2017-7-22 16:34:14
bidezhi7777 发表于 2017-7-22 17:41:56
学习一下,是什么方案的
walucky 发表于 2017-7-22 19:27:27
到处走看 发表于 2017-7-22 20:03:34
corecouter 发表于 2017-7-22 20:46:39
南亭好远 发表于 2017-7-23 08:01:23
不错啊
查看完整版本: 车载PCB 和原理图共享
