Name | PCB Decal | Value | Part Type | BLUETOOTH | FLC-BTMDC705-I2U-DP | FLC-BTMDC705-I2U | CXN1450 | CON1 | FPC-1.0K-A-NPB(30P)_2 | FPC30P_1.0 | CON30_FFC_GM | CON2 | FPC10P_1.0 | FPC10P-1.0 | CON10 | CON4 | FFC10_0.5/SMD_P | FPC10P-0.5 | CON10 | D1 | DIODE_DIP_A | SSK34 | DIODE | D2 | IN4148-0805 | IN4148 | DIODE | D3 | DO-214 | IN4007 | DIODE | D4 | SOT-23 | BAV99 | BAV99 | D5 | SOT-23 | BAV99 | BAV99 | D6 | SMD5819 | B230A | DIODE | D7 | IN4148-0805 | IN4148/NC | DIODE | D8 | IN4148-0805 | IN4148 | DIODE | D9 | DO-214 | IN4007 | DIODE | D15 | IN4148-0805 | 4148 | DIODE | D16 | DO-214 | IN4007 | DIODE | D22 | IN4148-0805 | 4148 | DIODE | D24 | SOT-23 | BAV99 | BAV99 | D28 | IN4148-0805 | IN4148 | DIODE | D29 | SOT-23 | BAV99 | BAV99 | D31 | IN4148-0805 | 4148 NC | DIODE | D32 | IN4148-0805 | 4148 NC | DIODE | D33 | IN4148-0805 | IN4148 | DIODE | D34 | SOT-23 | BAV99 | BAV99 | D35 | SOT-23 | BAV99 | BAV99 | D37 | IN4148-0805 | IN4148 | DIODE | D39 | SOT-23 | BAV99 | BAV99 | D40 | SOT-23 | BAV99 | BAV99 | D41 | SOT-23 | BAV99 | BAV99 | D46 | IN4148-0805 | IN4148 | DIODE | D47 | IN4148-0805 | IN4148 | DIODE | F1 | 1210 | 0.5A /0R | FUSE | F2 | 1210 | 0.5A /0R | FUSE | F4 | 1210 | 0.5A /0R | FUSE | IPOD | IPOD_GM | MDJ-105A | IPOD_8P | J1 | CON8-2.0 | CON8P_2.0_CMMB | CMMB8P_2.0 | J2 | ANT_2P | SIP2P-2.0/NC | CON2 | J3 | 16P-CON-GM | 16P-CON | 16P-CON-GM | J4 | SIP6P-1.27 | CON6P_1.27 | CON6P_1.27 | J5 | CON4P-2.0 | SIP4P_2.0 | CON4P_2.0 | J7 | SIP12-2.0 | TDA6621 | TUNER_BOARD | J18 | FFC45_0.5UP | FFC45PIN_0.5MM | FYT9023_TFT_45P_1 | J29 | SIP4P-1.27 | 1.27*4PIN/NC | SIP4P-1.27 | JP1 | SPH20_2.0_90 | SPH20P_2.0 | SPH20_2.0 | JP2 | SPH18_2.0_90 | SPH18P_2.0 | SPH18_2.0 | L4 | SMDL7MM | 47UH/2A | INDUCTOR_IRON_0 | L6 | L_13_26 | 380uH | L_13_26 | L8 | SMDL7MM | 33UH/3A | INDUCTOR_IRON | L9 | SMDL4.8X4.8.1.8 | 100UH/200mA | INDUCTOR | L12 | SMDL4.8X4.8.1.8 | 4.7UH/200mA/NC | INDUCTOR | Q1 | SOT-23 | AO3401 | AP2301N | Q2 | SOT-23 | 3904 | NPN_BCE | Q3 | SOT-23 | AO3401 | AP2301N | Q4 | SOT-23 | 3906 | PNP_3 | Q5 | SOT-23 | 3904 | NPN_BCE | Q6 | SOT-23 | AO3401 | AP2301N | Q7 | SOT-428_3 | 2SD1803 | NPN_BCE | Q8 | SOT-23 | 3904 | NPN_BCE | Q9 | SOT-23 | AO3401 | AP2301N | Q10 | SOT-23 | AO3401 | AP2301N | Q12 | SOT-23 | 3906 | PNP_3 | Q13 | SOT-23 | 3904 | NPN_BEC_2 | Q14 | SOT-23 | 3904 | NPN_BCE | Q15 | SOT-23 | 3904 | NPN_BCE | Q17 | SOT-23 | 3904 | NPN_BEC_7 | Q18 | SOT-23 | AO3401 | AP2301N | Q19 | SOT-23 | 3904 | NPN_BCE | Q20 | SOT-23 | 3904 | NPN_BEC_7 | Q21 | SOT-23 | 8550 | PNP_BCE | Q22 | SOT-23 | 3906 | PNP_3 | Q23 | SOT-23 | 3904 | NPN_BEC_2 | Q25 | SOT-23 | AO3401 | AP2301N | Q28 | SOT-23 | 9014 | NPN_0 | Q30 | SOT-23 | 3904 | NPN_BCE | Q31 | SOT-23 | 3904 | NPN_BEC_7 | Q33 | SOT-23 | 3906 | PNP_3 | Q34 | SOT-23 | 3904 | NPN_BCE | Q37 | SOT-23 | AO3401 | AP2301N | Q39 | SOT-23 | 3904 | NPN_0 | RADIO1 | ST7540AF1 | QSD_RT_L89 | QST_7540 | U1 | SOT-428 | 78D05 | 78D05 | U2 | LQFP64 | | STM8_64PIN | U3 | SOT-428 | 78D05 | 78D05 | U4 | SOT-428 | 78D09 | 78D05 | U5 | SOT-428 | 78D09 | 78D05 | U6 | TSSOP24-0.65 | FUS6502 | FMS6502 | U7 | BD3702FV | BD3702FV | BD3702FV | U8 | SSOP16 | TDA7478 | TDA7478 | U9 | MSOP8/9 | MP2303 | MP2303DN_9 | U11 | MSOP8 | NJM4558/TLC2272C | 4558 | U13 | MSOP8 | NJM4558 | 4558 | U14 | TSSOP16-0.65 | 74HC4052 | IC-SMD-SOP16 | U16 | MSOP8 | NJM4558 | 4558 | U21 | HZIP25 | TDA7386/TDA7384 | TDA7386 | U24 | SOT89 | 78L18 | 78L05 | U27 | SOT89 | 78L18 | 78L05 | Y2 | HC-49SM | 4.332M | OSC | Y3 | CRY-49S-B | 16MHZ | CRY-2 | ZD1 | IN4148-0805 | 9.1V | DZ | ZD3 | IN4148-0805 | 7.5V | DZ_0 | ZD4 | IN4148-0805 | 16V | DZ_0 | ZD5 | IN4148-0805 | 7V5 | DZ | ZD6 | IN4148-0805 | 6.8V | DZ | ZD26 | IN4148-0805 | 3.9V | DZ_0 | ZD27 | IN4148-0805 | 3.9V | DZ_0 |
STM8.7z
(833 KB, 下载次数: 10)
