TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 27352
重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | ANT1 | ANT3216120A5T_V02B_AN9520 | | ANT3216120A5T_V02B_AN9520 | BAT1 | PAD2 | BattPad | BATTERY_PAD | BAT_GND | PAD1.2 | | TEST_2 | BE1 | SPEKER_BUZZ-10MM | beep | BELL | CON1 | SIP-7P-2MM | Test Sock | SIP-7P-2MM | CS_A | PAD1.2 | | TEST_2 | CTRL | PAD1.2 | | TEST_2 | D5 | EMD2 | RB521S-30FJTE61 | 1SS400G | D6 | SOD-323-B | XBS104S15 | DIODE_SCHOTTKY | D7 | EMD2 | RB521S-30FJTE61 | 1SS400G | D8 | EMD2 | RB521S-30FJTE61 | 1SS400G | D9 | EMD2 | RB521S-30FJTE61 | 1SS400G | D10 | LED-0603A | RED Led | LED-0603A | D11 | LED-0603DUAL | LED0605-2-COLOR | LED-0603DUAL | D12 | LED-0603DUAL | LED0605-2-COLOR | LED-0603DUAL | D13 | EMD2 | RB521S-30FJTE61/nc | 1SS400G | F12 | HOLE1.6C | | FIDUCIAL_1MM | F13 | HOLE1.6C | | FIDUCIAL_1MM | F14 | HOLE1.6C | | FIDUCIAL_1MM | F15 | FIDUCIAL_1MM | | FIDUCIAL_1MM | F16 | HOLE1.6C | | FIDUCIAL_1MM | F22 | HOLE1.6BAAA | | FIDUCIAL_1MM | FA1 | PAD2 | FA | BATTERY_PAD | FB1 | 402 | BK1005LL470-T/47ohm | BEAD-47OHM-100MHZ-0402 | GND | PAD1.2 | | TEST_2 | HOP_R | PAD1.2 | | TEST_2 | HPO_L | PAD1.2 | | TEST_2 | INT | PAD1.2 | | TEST_2 | J1 | CON4/1.25MM/SMT | HEAD4PIN-80 | SIP4P | J2 | PIN2SOP0.8MM | conn3pin | PIN2SOP0.8MM | J9 | CON2-1.25-V | Batt_Connector | CON2_0 | J20 | CON-USB-UAF95-05254-S105 | UAF95-05254-S105 | CON-USB-UAF95-05254-S105 | JUPLINE1 | CT-1 | | JUPLINE | JUPLINE2 | CT-1 | | JUPLINE | L251 | 402 | 2.0nH | IND-2.2NH-0402 | L252 | 402 | 1.0nH | IND-1.2NH-0402 | L253 | 402 | 3.0nH | IND-3.3NH-0402 | L261 | 402 | 2.0nH | IND-2.2NH-0402 | MIC1 | PAD2 | EM4015L-42BC10&33-G | AUDIO-MIC-EM4015L-42BC10&33 | MOT1 | NC-MOTOR-ZT40S01A | Motor;DC;3V;90mA;8.4x11.8 | NC-MOTOR-ZT40S01A | MOT2 | PAD2 | nc | NC-MOTOR-ZT40S01A | P2_1 | PAD1.2 | | TEST_2 | P2_2 | PAD1.2 | | TEST_2 | PUMP1 | PAD2 | Motor Servo | BATTERY_PAD | Q1 | SOT-416B | DTE143ZE-T2L | DTE143ZE-T2L | Q2 | SC70/SC75-3L | SBT4102AWT1G/MMST2907A | TRX-MMST2907A-PNP | Q3 | SOT-416B | DTE143ZE-T2L | DTE143ZE-T2L | Q4 | SOT363-6 | WNMD2154/UP04878/nc | UP08478 | Q6 | DFN2X2-6-P0.65 | WPM2006-6/TR | FET-P-WPM2006-6/TR | Q7 | SOT363-6 | WNMD2154/UP04878 | UP08478 | REF | PAD1.2 | | TEST | RU55 | 402 | 4.7K | RES-4.7K-0402 | RX | PAD1.2 | | TEST_2 | SPK | PAD2 | Speaker | BUZZER1 | SW18 | SMT-KEY2.3X4.5 | PWRON | SW_TACT_SPST/SM_34GND | T20 | CT-1 | | JUPLINE | T21 | CT-1 | | JUPLINE | U1 | SOT23_6PIN_1.3 | TP4057/BL4054-42TCRN | IC_PWR_TP4057_BL4054 | U2 | QFN32P_5X5MM | ALC5633Q-GRT | AUDIO-CODEC-ALC5633Q-GRT | U3 | QFN40/0.5A | CC2540 | QFN40/0.5 | U4 | SOT23_5PIN_1.3 | WL2805E30-5/TR | LDO_3.0V_SOT23-5 | U5 | MSOP8 | PCF8563 | PCF8563 | U6 | BLUE-HM-11 | Blue-HM-11 | BLUE-HM-11 | U7 | LGA-28-4X5X1.1MM | LSM330DLC | LSM330DLC | U8 | QFP64-0.5-12MM | STM3232F103RET6 | QFP64-0.5-12MM | U9 | DIP14\SO | LMV324MTX | LM324 | U10 | IC-US-9111 | PreSnsor | PRESSURE_SENSOR | U11 | SOT23_5PIN_1.3 | WL2805E33-5/TR | LDO_3.3V_SOT23-5 | U12 | SOT23_5PIN_1.3 | WL2805E33-5/TR | LDO_3.3V_SOT23-5 | U13 | CC48B | EM78P510NAQ | EM78P510NAQ | U14 | SOIC-8 | 24C02 | 24C02 | U15 | DIP14\SO | LMV324MTX | LM324 | U16 | SOIC-8 | FDS9926A | IC_ME9926 | U17 | SOP8/SMD/EN25Q64/S | W25Q32F | EN25Q64 | U18 | QFN8/SMD/P1.27/EN25Q64/S-HZG | Serial Flash | EN25Q64_0 | U19 | IC-AXDL345 | AXDL345 | IC-ADXL345 | Y1 | SSP-T7-F | Q13MC1461000200/32.768kHz | SSP-T7-F | Y2 | XTAL-CRYSTAL-3215 | 32.768KHz | XTAL-CRYSTAL-32K768-12.5PF-Q13FC1350 | Y3 | TCXO3225 | 7M32000035/32MHz | CRYSTAL_26M_3G | Y5 | TCXO3225 | 7V12000005/12MHz | CRYSTAL_26M_3G | Y6 | SSP-T7-F | Q13MC1461000200/32.768kHz | SSP-T7-F |
重要提示:PCB作品文件展下载说明
