[Allegro16.6以下] 老外的 INTEL ATOM E3825  MinnowMax PCB和原理图开源共享
查看19208 | 回复82 | 2018-1-14 20:03:01 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
BH1BATTERY_2_BATT3_190X610_BATTHOBATT HOLDER,BS-1225-PCBATT3_190X610
CHOKE1COM_CHOKE_90_OHM_CHOKE4_0805_ACACM2012-900CHOKE4_0805
CHOKE2COM_CHOKE_90_OHM_CHOKE4_0805_ACACM2012-900CHOKE4_0805
CHOKE3COM_CHOKE_90_OHM_CHOKE4_0805_ACACM2012-900CHOKE4_0805
CHOKE4COM_CHOKE_90_OHM_CHOKE4_0805_ACACM2012-900CHOKE4_0805
CPU1INTEL_ATOM_E3825_5_FCBGA-1170_BBAYTRAIL_IFCBGA-1170
D1LED_LTST-C150GKT_1_LED_0603_DISLTST-C191TBKTLED_0603
D2LED_LTST-C150GKT_1_LED_0603_DISLTST-C191TBKTLED_0603
D3BAT54A_2_BAT54_132_2_BAT54A-SBAT54A-SBAT54_132_2
D4BAT54A_2_BAT54_132_2_BAT54A-SBAT54A-SBAT54_132_2
D5DIODE_DUAL_BAT54C-S_BAT54_132_2BAT54C-SBAT54_132_2
D6BAT54A_2_BAT54_132_2_BAT54A-SBAT54A-SBAT54_132_2
D7ESD-SOD-XFDFN_P_2-XFDFN_D5V0L1BD5V0L1B2LP-7B2-XFDFN
D8DIODE_DUAL_BAT54C-S_BAT54_132_2BAT54C-SBAT54_132_2
D9ESD-SOD-XFDFN_P_2-XFDFN_D5V0L1BD5V0L1B2LP-7B2-XFDFN
D10DIODE_DUAL_BAT54C-S_BAT54_132_2BAT54C-SBAT54_132_2
D11BAT54A_2_BAT54_132_2_BAT54A-SBAT54A-SBAT54_132_2
D12BAT54A_2_BAT54_132_2_BAT54A-SBAT54A-SBAT54_132_2
F1FUSE_0_FUSE_0805_FUSE-2A-08-LR-FUSE-2A-08-LR-XFUSE_0805
FB1FB0805_FB0603_FB_120R_3AFB_120R_3AFB0603
FB2FB0805_FB0603_FB_120R_3AFB_120R_3AFB0603
FB3INDUCTOR_2_FB0603_FB_600R_1.3AFB_600R_1.3AFB0603
FB4FB0805_FB0603_FB_120R_3AFB_120R_3AFB0603
FB5FB0805_FB0603_FB_120R_3AFB_120R_3AFB0603
FB6BEAD_0_FB0603_FB_120R_3AFB_120R_3AFB0603
FB7TB321611U520_1_R0603_0R000R00R0603
FB8BEAD_2_R0603_0R000R00R0603
FB9TB321611U520_1_R0603_0R000R00R0603
FB10TB321611U520_1_R0603_0R000R00R0603
FB11FB0805_FB0603_FB_120R_3AFB_120R_3AFB0603
FB12TB321611U520_1_R0402_0R00R0R0402
H1MHOLE_MTGH250C156D_PL_MHOLEMHOLEMTGH250C156D_PL
H2MHOLE_MTGH250C156D_PL_MHOLEMHOLEMTGH250C156D_PL
H3MHOLE_MTGH250C156D_PL_MHOLEMHOLEMTGH250C156D_PL
H4MHOLE_MTGH250C156D_PL_MHOLEMHOLEMTGH250C156D_PL
J1HEADER4X2_1_HDR2X4_HEADER 4X2HEADER 4x2HDR2X4
J2FAN_JUMPER1X2_WALL2_100LS_SIP2_SIP2_FANWALL2_100LS
J3SATA_HEADER_RA_0_SATA_RA_047080470804005SATA_RA
J4SIP6_RA_SIP6_SIP6_RASIP6_RASIP6
J5JUMPER1X2_0_SIP2_JUMPERJUMPERSIP2
J6JUMPER1X2_0_SIP2_JUMPERJUMPERSIP2
J7JUMPER1X2_0_SIP2_JUMPERJUMPERSIP2
J8CONN_RJ45_MAGJACK_GIGABIT_66058RJ-45 Gigabit6605814-6
J9CONN_PWRJACK_RAPC712_0_RAPC712_RAPC712RAPC712
J10CONN_5177985-2_SMT-5177985-2_515177985-2SMT-5177985-2
JP1HDR13X2_0P1_HDR2X13_HDR-26HDR-26HDR2X13
L1FB_220OHMS_2A_0805_FB0805_BKP21BKP2125HS221-TFB0805
L2FB_220OHMS_2A_0805_FB0805_BKP21BKP2125HS221-TFB0805
L3CHOKE_2R2M-7D3X6D8-PT6D2-SMD_CHPIND-2.2U-SMD-0603-8A-MAGCHOKE_PT6D2MM_SMD_2P
L4FB0805_FB0603_FB_120R_3AFB_120R_3AFB0603
L5FB0805_FB0603_FB_120R_3AFB_120R_3AFB0603
L6FB0805_FB0603_FB_120R_3AFB_120R_3AFB0603
L7111-1002735_SM-7351-IND-0603_DIFB_220R_2.2ASM-7351-IND-0603
L8INDUCTORIRON_1_CHOKE_NLC252018IND-4.7U-S-XCHOKE_NLC252018_SMD_2P
L9INDUCTOR_0R33M-PT5D1-SMD_CHOKE_0.33uHCHOKE_PT5D1MM_SMD
L10INDUCTOR_0R33M-PT5D1-SMD_CHOKE_0.33uHCHOKE_PT5D1MM_SMD
L11CHOKE_1R0M-7D3X6D8-PT6D2-SMD_CHPIND-1U-SMD-0603-11A-MAG-XCHOKE_PT6D2MM_SMD_2P
L12FB0805_FB0603_FB_120R_3AFB_120R_3AFB0603
L13FB0805_FB0603_FB_120R_3AFB_120R_3AFB0603
LAN1RTL8111GS_0_QFN32_PT04_NCP81102RTL8111GS-CG-XQFN32_PT04_NCP81102
MEM1MICRON_MT41K256M16HA_FBGA96_DDRMICRON MT41K256M16HAFBGA96_DDR3
MEM2MICRON_MT41K256M16HA_FBGA96_DDRMICRON MT41K256M16HAFBGA96_DDR3
MEM3MICRON_MT41K256M16HA_FBGA96_DDRMICRON MT41K256M16HAFBGA96_DDR3
MEM4MICRON_MT41K256M16HA_FBGA96_DDRMICRON MT41K256M16HAFBGA96_DDR3
P1CONN_HDMI_TYPED_TH_CONN19_HDMI-microHDMI_THCONN19_HDMI-1
P2MICROSD_CONN_BOTTOM_SD-MICRO-SCSCHA5B0200SD-MICRO-SCHA5B0300
Q1MBT3904DW1T1G_0_SOT-363_MBT3904MBT3904SOT-363
Q2BAV99_1_SOT23_3L_BAV99-7-F-S-XBAV99-7-F-S-XSOT23_3L
Q3MBT3904DW1T1G_0_SOT-363_MBT3904MBT3904SOT-363
Q4MMBT3904_SOT23_EBC_MMBT3904MMBT3904SOT23_EBC
Q5MOSFET_NCH_30V_3_5A_TSMT3_0_SOTRXR035N03SOT23_GDS_2
Q6MOSFET_NCH_30V_3_5A_TSMT3_0_SOTRXR035N03SOT23_GDS_2
Q72N7002K_SOT23_GSD_2N7002K2N7002KSOT23_GSD
Q8MOSFET_NCHAN_BSS138_SOT23_GSD_BBSS138SOT23_GSD
Q9BAV99_1_SOT23_3L_BAV99-7-F-S-XBAV99-7-F-S-XSOT23_3L
Q102N7002K_SOT23_GSD_2N7002K2N7002KSOT23_GSD
Q112N7002K_SOT23_GSD_2N7002K2N7002KSOT23_GSD
Q122N7002K_SOT23_GSD_2N7002K2N7002KSOT23_GSD
Q13MOSFET_NCH_30V_3_5A_TSMT3_0_SOTRXR035N03SOT23_GDS_2
Q142N7002K_SOT23_GSD_2N7002K2N7002KSOT23_GSD
SP1SHORT-NMNP_SHORT2-NMNP_SHORT-NMSHORT-NMNPSHORT2-NMNP
SP2SHORT-NMNP_SHORT2-NMNP_SHORT-NMSHORT-NMNPSHORT2-NMNP
SP3SHORT-NMNP_SHORT2-NMNP_SHORT-NMSHORT-NMNPSHORT2-NMNP
SP4SHORT-NMNP_SHORT2-NMNP_SHORT-NMSHORT-NMNPSHORT2-NMNP
SW1SW_B3F-1000_SM-SW-SPST-4-4_DISCB3F-1000SM-SW-SPST-4-4
U1SN74AUP1G34_DBV_SOT23-5_SN74AUPSN74AUP1G34SOT23-5
U2TPD12S016_24TSSOP_SSOP24_256P_2TPD12S016PWSSOP24_256P_222LS
U3MICRON_SPI_MEM_N25Q064A_SO8_W20MICRON N25Q064ASO8_W200
U4TS3A27518EZQS_BGA24_E5_P5_3X3_TTS3A27518EZQSBGA24_E5_P5_3X3
U5TXS0102YZP_DSBGA-8_TXS0102YZPTXS0102YZPDSBGA-8
U6TXS0102YZP_DSBGA-8_TXS0102YZPTXS0102YZPDSBGA-8
U7TXS0104EYZT_DSBGA-12_TXS0104EYZTXS0104EYZTDSBGA-12
U8PROT_TPD4S012_3_U_6_DRY_TPD4S01TPD4S012U_6_DRY
U9PROT_TPD4S012_3_U_6_DRY_TPD4S01TPD4S012U_6_DRY
U10TXS0104EYZT_DSBGA-12_TXS0104EYZTXS0104EYZTDSBGA-12
U11MOSFET_NCH_30V_12A_HS08_0_HSO8-SK8603190LHSO8-F4-B
U12MOSFET_NCH_30V_12A_HS08_0_HSO8-SK8603190LHSO8-F4-B
U13NB670_24V_REG_WLDO_QFN16_1_FCQFNB670FCQFN16_RT7290A_NB669
U14TXS0104EYZT_DSBGA-12_TXS0104EYZTXS0104EYZTDSBGA-12
U15TXS0104EYZT_DSBGA-12_TXS0104EYZTXS0104EYZTDSBGA-12
U16TXS0104EYZT_DSBGA-12_TXS0104EYZTXS0104EYZTDSBGA-12
U17TXS0104EYZT_DSBGA-12_TXS0104EYZTXS0104EYZTDSBGA-12
U18TXS0104EYZT_DSBGA-12_TXS0104EYZTXS0104EYZTDSBGA-12
U19TXS0104EYZT_DSBGA-12_TXS0104EYZTXS0104EYZTDSBGA-12
U20NCP606_LDO_500MA_DFN6_DFN6_3X3PNCP606DFN6_3X3P3MM
U21IC-SOP8_APL5933AKAI-TRG_SOP8_W1APL5933SOP8_W150_PT50-104X120
U22TPD6E001RSE_1_U_10_RSE_TPD6E001TPD6E001U_10_RSE
U23TPD2E001DRL_1_U_5_DRL_TPD2E001TPD2E001U_5_DRL
U24IC-SOP8_APL5933AKAI-TRG_SOP8_W1APL5933SOP8_W150_PT50-104X120
U25SN74LVC1G14DBVR_SOT23-5_SN74LVCSN74LVC1G14DBVRSOT23-5
U2674LVC1G08_0_SOT23-5_74LVC1G08DB74LVC1G08DBVRSOT23-5
U27IC-QFN40_ISL95837HRZ_1_QFN40_PTISL95837HRZ-TQFN40_PT04-92HD89C_1
U28SN74LVC1G14DBVR_SOT23-5_SN74LVCSN74LVC1G14DBVRSOT23-5
U29TPD4EUSB30_0_FPC_4P10_R_1_TPD4UTPD4USB30FPC_4P10_R_1
U3074LVC1G08_0_SOT23-5_74LVC1G08DB74LVC1G08DBVRSOT23-5
U31FDMS3660S_DUAL_2_PQFN8_FDMS3660FDMS3660SPQFN8
U32TPS2066DR_SO8-25X75_TPS2066DRTPS2066DRSO8-25X75
U33IC-SOP8_EEPROM_M24C02-WMN6TP_1_M24C02-WMN6TP-XSOP8_W150_PT50
U34FDMS3660S_DUAL_2_PQFN8_FDMS3660FDMS3660SPQFN8
U35NCT3012S_1_ESOP8_W150_PT50-90X9NCT3012S-XESOP8_W150_PT50-90X90
U36IRF9321-FET_P-CH_SOIC8_1_SOP8_WIRF9321SOP8_W150_PT50
U37NB675GL-Z_0_QFN21_NB675_NB675-XNB675-XQFN21_NB675
U38IC-SOP8_APL5912KAC-TRG_1_SOP8_WAPL5912KAC-TRGS-XSOP8_W150_PT50_3X2D5MM
U39SN74LVC1G14DBVR_SOT23-5_SN74LVCSN74LVC1G14DBVRSOT23-5
USB1USB_LPP_LPUSB1013_3_USB13_DUAL_DUAL_USB_2.0_3.0USB13_DUAL
Y1XTAL-2P-32P768KHZ_145-0004789_232.768KHz, ABRACON2-SMD
Y2XTAL-4P-25MHZ_145-0004792_XTAL-25.00MHzXTAL-FSX3M_4P_SMD
Y3XTAL-4P-25MHZ_145-0004792_XTAL-25.00MHzXTAL-FSX3M_4P_SMD
重要提示:PCB作品文件展下载说明
老吴 | 2018-1-14 20:04:26 | 显示全部楼层
两个版本。但是没有比较差异。下载的自己看。
MinnowMax_RevA1_brd.zip (3.05 MB, 下载次数: 17)
经纬 | 2018-1-14 20:41:55 | 显示全部楼层
xiaoxiao | 2018-1-14 21:19:00 | 显示全部楼层
bingo426 | 2018-1-14 22:48:22 | 显示全部楼层
最后成功的人往往不是最有才华的人,而是那些默默付出直到最后一刻也不放弃的那些人!
shenchengan | 2018-1-15 08:11:35 | 显示全部楼层
james_zhangwk | 2018-1-15 08:16:38 | 显示全部楼层
i_333333 | 2018-1-15 08:24:56 | 显示全部楼层
非常非常感谢楼主大神
xuexue | 2018-1-15 08:31:29 | 显示全部楼层
ilpuyi | 2018-1-15 08:31:48 | 显示全部楼层
