[IC] 一打datasheet 一起打包
查看927 | 回复1 | 2018-1-25 13:58:01 | 显示全部楼层 |阅读模式
一打datasheet 一起打包
有以下规格书。需要的下载。
Device datasheet\3G\UNA Product specification ver1.0_CN.pdf
Device datasheet\3G\UNA-Lite Product specification -V1.3-2013.08.13_SC(密码:UNALITE).pdf
Device datasheet\Buffer\(Buffer)-NL27WZU04DFT2G.PDF
Device datasheet\Buffer\3P5609AL1完全替代安森美NL27WZU04.pdf
Device datasheet\Buffer\sn74lvc2gu04.pdf
Device datasheet\Codec\ALC3224 DataSheet_0.91带消回音.pdf
Device datasheet\Codec\ALC5623_DataSheet_1.2.pdf
Device datasheet\Codec\ES8323 DS.pdf
Device datasheet\Codec\ALC5631Q DataSheet_0.9.pdf
Device datasheet\DCDC\MP1495_r1.04.pdf
Device datasheet\DCDC\SYR827 for Rockchip.pdf
Device datasheet\DCDC\AN_SY7203_powerstar_David.pdf
Device datasheet\DCDC\SYR828 for Rockchip.pdf
Device datasheet\ESD\AZ1045-04F.pdf
Device datasheet\ESD\TPD4E05U06.pdf
Device datasheet\FLASH LED Drive\SGM3140 REV.A.pdf
Device datasheet\FLASH LED Drive\SGM3141B_S_R11_20121017 ROCKCHIP 1A.PDF
Device datasheet\FLASH LED Drive\SKY81290_1.2A Flash LED Driver.pdf
Device datasheet\FLASH LED Drive\AN_SY7803_RK_Lawrence.pdf
Device datasheet\LCM\8.9寸1920X1200 SP_A00_LTL089CL02-W_13012 9_V0 0_V1 (1).pdf
Device datasheet\LCM\Ipad3_LP097QX1-SPA1-8M1_V0 4_110818.ppt
Device datasheet\LCM\MIPI_8.9_2560_1600(MIPI Introduce).pdf
Device datasheet\Memory\K3PE0E000E(A)-XGC1(2).pdf
Device datasheet\Memory\KLMxGxxE4x-x001(MMC4.41 2ynm based e_MMC)_1.1.pdf
Device datasheet\MIPI Camera\OV8825_MODULE.dwg
Device datasheet\Sensor\AK8963_MS1356_E-00_111212.pdf
Device datasheet\Sensor\CM3218.pdf
Device datasheet\Sensor\OCH165_datasheet 1.0_20130318.pdf
Device datasheet\Sensor\LIS3DH.PDF
Device datasheet\Sensor\LSM303D Rev 0 1.pdf
Device datasheet\Sensor\LSM330.pdf
Device datasheet\Sensor\PS-MPU-6050C-00 v1.pdf
Device datasheet\Touch IC\CT363CT365电容式触摸屏控制芯片主控软件编程应用指南V2.0.pdf
Device datasheet\Touch IC\CT363电容式触摸屏控制芯片硬件开发指南V1.0.pdf
Device datasheet\Touch IC\D-FT5506_FT5606_FT5816-1212-V2.0+(FT5506_5606_5816+Datasheet).pdf
Device datasheet\Touch IC\GSL3680_DataSheet_Chinese_RevA1.8.pdf
Device datasheet\WIFI\ampak_roadmap20140119_brcm.pdf
Device datasheet\WIFI\AP6210 datasheet_V1.2_12262012.pdf
Device datasheet\WIFI\AP6335 datasheet_V1.2_08152013.pdf
Device datasheet\WIFI\AP6476 datasheet_V1.1_10222012.pdf
Device datasheet\CHARGE\5T620-1017_PS_Rev11.pdf
Device datasheet\CHARGE\BQ24133.pdf
Device datasheet\Gas Gauge\CW2013 Gas Gauge Datasheet_ver0.1.pdf
Device datasheet.rar (41.58 MB, 下载次数: 7)
mj8abcd | 2018-1-25 15:18:49 | 显示全部楼层
