在*.brd文件中导入网络表的时候netrev.lst 提示有如下错误:; D. Z' N$ P; i5 _% {5 e' h- W+ c) \
#1 WARNING(SPMHNI-192): Device/Symbol check warning detected.; H2 h# _( s# ~. S( X
ERROR(SPMHNI-196): Symbol 'HDR1X8' for device '8 HEADER_HDR1X8_8 HEADER' has extra pin '9'.) E8 rZ/ K% ?: u6 F& {& ?3 ~. x
#1 ERROR(SPMHNI-191): Device/Symbol check error detected.
ERROR(SPMHNI-193): Error finding symbol 'DIP8' for device 'OP-27_DIP8_OP-27': 'ERROR(SPMHDB-181): Database revision 14.x is too old ... must run dbdoctor.'.% H. b% x4 b3 m& Y0 G1 E5 P* y
#2 ERROR(SPMHNI-191): Device/Symbol check error detected.
ERROR(SPMHNI-193): Error finding symbol 'DIP8' for device 'OP-07_DIP8_OP-07': 'ERROR(SPMHDB-181): Database revision 14.x is too old ... must run dbdoctor.'.
#2 WARNING(SPMHNI-192): Device/Symbol check warning detected.h" t* B! _/ p! mC- m
WARNING(SPMHNI-194): Symbol 'TO99' for device 'OPA128/BB_TO99_OPA128/BB' not found in PSMPATH or must be "dbdoctor"ed.
对于warning 1: 在design entry cis 中,我对header8 用“Edit part” 命令看过了,只有8个脚,封装我也打开看过可,只放了8个焊盘,这个“extra pin 9“是什么意思啊?该如何解决呢?
对于”must' run dbdoctor“的错误和警告,该如何运行dbdoctor 啊?。我只知道可以用PCB utility 中的dbdoctor 从外部运行和从pcb Editor 中 运行data base check。。
# a, M& c9 D( E7 ?0 u& S
谢谢了。。。 |
