我在15.5中是可以出gerber的,现在用16.01出gerber出现这样的提示
---- Photoplot outline rectangle not found ... using drawing extents) o# m& ^( o- @# z
1 l/ y) x' K) q8 x1 |) H9 q
Sat Sep 20 21:01:35 2008 Page 1: d; U% u' h9 y. s
Photoplot log file
Results from parameter file ...- k# P; z8 a, H/ p/ D
DEVICE-TYPE GERBER_RS274X
OUTPUT-UNITS MM
FILM-SIZE 24000 16000' j' F4 b$ @5 A3 o+ u
FORMAT 5.37 |) T8 a8 U) }$ ?
ABORT-ON-ERROR NO& V; V# d" G4 _; v$ c
SCALE 1
SUPPRESS-LEAD-ZEROESYES
SUPPRESS-TRAIL-ZEROES NO
SUPPRESS-EQUAL YES
UNDEF-APT-CONT NO- Z8 U( KQ8 @* u; r
WARNING: for raster artwork formats, artwork accuracy must be
at least one place greater than the database accuracy, up8 |6 f; W" g: _3 l/ Q& v
to the maximum accuracy allowed by the selected output format.
Increase the accuracy by increasing the "Decimal Places" in. Z9 e! d, q( L' B5 p
the FORMAT section of the artwork parameters and then rerun
artwork.0 u* D0 B, z! ]7 `7 Y( A6 Z
The current output is rounding down the data.Failure to change
the format may result in inaccurate arc coordinates in the output6 l6 G7 y; ~$ [$ c. C# [* I
files and possible shape/void plotting failures.
PROCESSING FILM < TOP.art > ...
================================================================3 D9 k! U* J1 c8 \3 y) N7 e
FILM PARAMETERS :
---------------------------------------------------------' C9 d" \1 B9 m7 C
Undefined line width 0.25008 l" A) \5 t, [
Mirror code NONE
Rotate angle NONE
Offset x: 0.0000
Offset y: 0.0000+ ]4 ~% j& I& z$ M7 a* x+ B, D0 l
Plot negative NO: c1 XF9 W9 T" T9 e9 d
Suppress unconnected internal padsNO
WARNING: 0 width line found at (0.5000 0.0000)
... using undefined line width of 0.2500
WARNING: Segment with same start and end points at
(69.7822 34.5562) will be ignored. Increasing output- g9 D- G4 X7 }& Ta
accuracy may allow segment to be generated.
+ u/ _/ K/ E3 p6 E* G0 n- T
APERTURES USED:
---------------------------------------------------------8 @; ]3 E[& z+ yA& ?
TYPE SIZE/NAME ROT MIRROR MODE 4 [9 ~9 j3 g+ U7 E, a$ y
CIRCLE 0.25000 DARK
CIRCLE 0.30000 DARK 1 o5 ~8 z! A/ U) v
CIRCLE 0.40000 DARK
CIRCLE 0.60000 DARK
CIRCLE 0.63500 DARK 6 X+ J) B8 X2 U' W
CIRCLE 0.80000 DARK 5 G, _+ b; Z$ w: {9 f6 k
CIRCLE 1.01600 DARK + b4 `0 m) B1 t( h
CIRCLE 1.27000 DARK
CIRCLE 1.39700 DARK
CIRCLE 1.52400 DARK ( G+ T7 i5 M. p' ~- z; J
CIRCLE 1.65100 DARK 1 z4 F1 k. @4 I8 O8 A" U
CIRCLE 2.30000 DARK * {3 T! g! u/ c+ }
CIRCLE 2.79400 DARK
CIRCLE 3.25120 DARK H4 T/ c, D) q, e, m* f
CIRCLE 5.00000 DARK
SQUARE 0.76200 0.000 NO DARK
SQUARE 0.76200 0.100 NO DARK
SQUARE 1.00000 0.100 NO DARK + J" K1 t$ a7 d3 x
SQUARE 1.27000 0.000 NO DARK
SQUARE 1.39700 0.000 NO DARK
SQUARE 1.65100 0.100 NO DARK : @! [0 C2 L9 B5 ea, j% J" D
RECTANGLE0.30480 x 1.77800 0.000 NO DARK 7 j" }0 ]/ K% t) O) q9 [
RECTANGLE0.30480 x 1.77800 90.000 NO DARK " u6 \/ {i4 ]1 g/ S8 F/ H( F& F
RECTANGLE0.63500 x 2.03200 90.000 NO DARK 3 H0 m' x7 q* Y' P# G) }6 ?
RECTANGLE1.10000 x 3.00000 90.100 NO DARK , o: D' c* U% l+ G+ k
RECTANGLE1.14300 x 1.65100 0.100 NO DARK
RECTANGLE1.14300 x 1.65100 90.000 NO DARK
RECTANGLE1.14300 x 1.65100 90.100 NO DARK . _4 ?7 b& D* l, e" L" X
RECTANGLE1.22000 x 2.20000 0.000 NO DARK
RECTANGLE1.50000 x 0.30000 0.000 NO DARK . N! t7 G5 S/ z7 m) j' E! xe9 g
RECTANGLE1.50000 x 0.30000 0.100 NO DARK & e2 p, @! Z$ ?2 b) I
RECTANGLE1.50000 x 0.30000 90.000 NO DARK 2 O. ?$ Q9 B# f7 q
RECTANGLE1.50000 x 0.30000 90.100 NO DARK
RECTANGLE1.51890 x 1.65100 90.100 NO DARK
RECTANGLE1.60000 x 2.20000 0.100 NO DARK 5 \1 }8 w9 |5 }; ^7 J. X! D
RECTANGLE1.60000 x 2.20000 90.100 NO DARK
RECTANGLE2.20000 x 1.50000 0.100 NO DARK " [8 b1 V, T4 D/ b! m
RECTANGLE2.30000 x 3.80000 0.100 NO DARK
RECTANGLE2.30000 x 3.80000 90.100 NO DARK
RECTANGLE3.00000 x 3.20000 90.100 NO DARK * I/ w# l, L% a' [; f
OBLONG 1.60000 x 3.80000 0.100 NO DARK : N; v, U3 ]" V1 `7 y6 @' N
OBLONG 1.60000 x 3.80000 90.100 NO DARK
TOP created with warnings |
