复杂的安装说明,不过搞定。完美破解!!& Kh/ a$ G1 z* N( w" W. O
CADENCE SPB V15.2 好软件,再安装一次也值得。:)
#* Install notes follow, License info are below *, f; f: Y/ X6 K4 S' e
#************************************************/ _7 X# j3 M) C* J0 ^! {# _
# - Edit this license file and replace the "hostname" field below with your computer hostname" J! ~9 r6 d# {[7 d8 v* I) ^
# - Create 2 environment variables: a) LM_LICENSE_FILE. G& b9 H4 n# p6 e
# b) CDS_LIC_FILE5 f, _# N. e: H3 L% G
# assign to both variable this value => [email=5280@{your]5280@{your[/email] host name}
# note under win9x, use autoexec.bat (SET [email=LM_LICENSE_FILE=5280@{your]LM_LICENSE_FILE=5280@{your[/email] host name})/ b; |' X# h$ w5 Ln2 QL
#/ k) B' z* Ma- |+ A1 t( b
# - Install any Cadence Licence Manager from any cadence cdroms (ie LDV, PSD)3 L& W7 Z6 Q& s- C
# all the next operations suit the SPB 15.2 installation.}/ f" j9 H3 Y1 X+ ?a. ?3 ~
#. I; E2 e9 I( c. N7 |" |
#. \4 \* P4 a8 X. e|; {: C2 b
# - Feed the CD1, run setup.exe if your autorun feature is disabled
## d6 x& \5 y" L
# - Select "Set-Up Licensing" and point this license file when prompted about a license file4 x4 Y% Q) e& L9 k. ]/ `
# - Ignore the msg about the license can't be parsed if ther's any, this msg is fake , the license manager is already
# running perfectly ( poor cadence coders ;D )8 D+ n% W! g/ Q, h# e, X2 E- ?; I; P
#1 U" z+ FA: y# \9 R
# - Once this License Manager installation is done, just select Install Products
#6 L6 b3 F3 r, x$ f: G' K8 ^
# - when prompted about controlfile.txt just makes the text box empty, and select items manualy...
#3 d1 \" j( s3 }# J$ r
# - Insert the cd2 when prompted
# - If you installed ConceptHDL schemtic entry editor, u may install the librairies from the cd3) ~1 h( _5 q! K" P7 V
# and if u don't wanna use concept HDL at all, u just burnt a cd for nothing, , isn't that funny!; H8 X6 Z2 X, |# o1 m
# Last step, if the software ask you about a reboot, u should really reboot! |
