我刚用EE2007.3,下了个破解的,中心库的设计能用,但DxDesigner中原理图等的save保存按钮怎么是灰的,无法保存,那位高手给我指点一下啊,是我破解过程中那块有问题?我用的破解文件见附件,谢谢了" O5 l# M) y" WE" n. @, M+ a
% w% I) x8 j1 {( |$ E
破解的说明为:
Mentor EE/PADS20007.4 license keygen and path" ~3 p% k6 c# x4 n: n; Y4 U6 T
1, use myMGLS.DLL to replace the origin one which is 1,564,672 (1.49M) bytes sizes9 K- \/ D& }- K
other MGLS.DLL which version is not 2008.056 is not need to replace.
2, use my keygen to make licensefile.:; U9 q- M4 dj) |$ b% a
- q0 y* a8 F1 x+ R- O
note p) ^/ |8 t6 T8 O8 xH
must make license file which has SIGN2 key. so you can run my MakeLic.bat to gen a valid license file.g2 Q0 J& a7 z7 h) f9 }# ^! O9 q
. A+ K' O9 I: A! T
3, not use for sale and commerce.2 v% h/ J. N' S% d
4, this file only test in win32 OS.
( o( B8 k8 O9 ?% Y% A. j9 }. `
LONG
2007.08.063 ^u' o* B+ T" g; M
8 z* K) w) {. A
A,先完整的安装程序在C目录下,安装过程中要指向license file,可以先指向文件夹中的license.txt。
B,安装EE运行EE2007.4安装在C盘完成后直接运行.bat% b8 _7 K; {. zf/ `/ H7 P1 r
或者安装的是PADS,运行pads2007.4安装在C盘完成后直接运行.bat
若没有成功请手动设置环境变量和license Server.
注:安装在D:\或者其它目录,请自行修改BAT。
( d: B* \' l$ y! ?$ QS
WANG+ l6 z; q4 Q4 J* R
2008 .10 .12
破解PADS 2007.3和EE2007.3.zip
2008-11-4 15:26 上传
点击文件名下载附件
859.74 KB, 下载次数: 2341 |
