Name | PCB Decal | Value | Part Type | ANT1 | PADBAAABAAAAAAAAABABAA | | PAD | AUX-L1 | OAAAAAA | TX | O | AUX-R1 | OAAABB | TX | O | CON1 | FCC24-H | | FCC30P-H | CON2 | 12P-1.0BA | | 12PSMT | CON3 | CN16AA | | CN16A | CON4 | DIP12PIN-4.2MM | 12P4.25 | ZZF-OUTSOCKET-12P | CON5 | SMT-18P-2.5MM | | SMT-18P-2.5MM | CON6 | CON22PIN-1.5DIPSOCKETA | | CON22PIN1.0 | D1 | SCHOTTKY.DN | IN5822 | S.DIODE | D2 | DIO/DO-214AC | IN5822 | DIO | D3 | DIO/DO-214AC | 1N4001 | DIO | D4 | DIO/DO-214AC | 1N4001 | DIO | EC1 | DIP-10MM | 2200uF/25V | CAP | H1 | O | | O | IC1 | SI4730 | SI4702/30/31 | SI4730/31 | IC2 | QN8035 | QN8035 | TUNER | IC3 | TDA7381 | TDA7388/TB2929 | TDA7383 | J1 | CON-02PA | MIC | CON-02P | J2 | RCA4 | | RCA4-8.4-13 | J4 | RCA4-8.4-13B | | RCA4-8.4-13 | L1 | 603 | FB | INDUCTOR | L2 | L0805 | FB | IND | L3 | L-0603 | 1UH | IND | L4 | L-0603 | FB | IND | L5 | L-0805 | FB | IND | L6 | L0805 | 10UH | IND | L7 | L0805 | FB | IND | L8 | L0805 | 10UH | IND | L9 | L6MM_8 | 22UH3A | L8MM | L10 | L-0603 | FB310 | IND | L11 | L/TC-28HBB | 90UH/15A | INDUCTOR | L12 | L-0603 | NC/3.3UH | IND | Q1 | SOT-89 | 2SB1132 | PNP/BCE | Q2 | SOT-89 | 2SB1132 | PNP/BCE | Q3 | SOT23 | 2N3904S | 9014C | Q4 | SOT23 | 2SK3018 | 9014C | Q5 | SOT23 | 9014 | 9015C | Q6 | SOT23 | 2N3904S | 9014C | Q7 | SOT23 | 9014 | 9014C | Q8 | SOT23 | 2N3904S | 9014C | Q9 | SOT23 | 2N3904S | 9014C | Q10 | SOT-23 | AM3407 | MOS | Q19 | SOT-23E | 9015 | SOT-23 | Q20 | SOT-23D | 2n3904 | SOT-23 | Q21 | SOT23B | 9014 | NPN | RX1 | O | RX | O | S1 | DIP-S-4P | 4p/dip | DIP-S-4P | SD1 | SD_2IN1_PUSH | SD/MMC-2IN1 | SD_2IN1 | TP1 | TEST_POINT | | TEST | TX1 | O | TX | O | U1 | AMS1117 | AMS1117-ADJ | AMS1117 | U2 | AMS1117 | AMS1117-3V3 | AMS1117 | U3 | TSOP-28M | TDA7313 | 7313 | U4 | SPHE8104LW-128P | SPHE8202T-128 | SPCA760-128_2A | U5 | TSOP54-2 | ELIEMT M12L64164A-5T/SDRAM 16Mx4 | 4MX16 | U6 | DIP28\SSOPH1 | AM5888S | AM5888 | U7 | TO-252(DPAK) | 78M05 | 7805 | U8 | TO-252(DPAK) | 78M09 | 7805 | U9 | IC8 | SPIFLASF25T80 | SPI25T80 | U10 | SOP-32 | 80F0308AD32 | PT2312 | U11 | SOP8 | 24C02 | 24C02 | U12 | TL431 | TL431 | TL431 | U13 | DIP8-SOP | BA4558 | KIA4558 | U14 | SOP8P | TD1410 | SOP8P | V1 | O | | O | X1 | X'TAL | 10M | CRYSTAL | XT1 | XTALK3 | 27.00MHZ | X | XT2 | XTAL3AA | 32.768MHZ | XTDIP | XT3 | XTAL3AA | 32.768KHz | XTDIP | ZD1 | ZD/LL-34 | 3.9V | DIODE/ZENER-5.1V | ZD2 | ZD/LL-34 | 7.5V | DIODE/ZENER-5.1V |
