这是我把 IBS文件转换成 DML文件 的messages!
; G0 D- d6 ?+ U! E) ]/ e
Argument 'and' ignored" h. u% j+ k& `Z% K
Argument 'Settings\Administrator\桌面\9263\hy57v561620ft_full.ibs' ignored
Argument 'Settings\Administrator\桌面\9263\hy57v561620ft_full.dml' ignored
RUNNING IBISCHK COMMAND: ibischk4 C:\Documents
IBISCHK4 V4.0.1
ERROR - Unable To Open File 'C:\Documents.ibs'
END OF IBISCHK COMMAND OUTPUT
READING IBIS FILE C:\Documents$ u/ t2 ^5 K5 w, G' L
ERROR @line 1: Keyword expected, but not recognized: <("C:\Documents")>. Skipping this line.
ERROR @line 0: Syntax error after parsing the token <> :
The previous token began on line 0 and was <>
RUNNING DMLCHECK for C:\Documents7 ~6 z: V$ x: v6 V: v7 n6 b+ [
5 Q+ W5 Y& V) C4 h4 ?
Translation failed due to IBIS2DML errors.6 s! {! }& b+ d# b6 q; f% R
Output saved as C:\Documents.txt for examination. |
