重要提示:PCB作品文件展下载说明
主板型号是 :YK86VQ-MCP-8931 V1.0
Name | PCB Decal | Value | Part Type | D1 | SOD323 | 1N4148 | SOD323 | D4 | SOD123 | 1N5819 | SOD123 | D7 | SOT23 | BAT54S | SOT23 | D8 | D1206 | 7V | D1206 | D9 | D1206 | 18V | D1206 | D10 | SOT23 | BAT54S | SOT23 | D11 | SOD123 | 1N5819 | SOD123 | D12 | SOD123 | 1N5819 | SOD123 | D13 | SOD323 | 1N4148 | SOD323 | D14 | SOT23 | BAT54C | SOT23 | D26 | SMA | DC/SS32 | SMA | D28 | SMA | DC/SS32 | SMA | D29 | SOD123 | 1N5819 | SOD123 | D30 | SOD123 | 1N5819 | SOD123 | D32 | SOD123 | AZ3005-01G | SOD123 | ED3 | E0402N | ESD9B5V | E0402N | ED31 | E0402N | ESD5Z3.3T1 | E0402N | ED49 | E0402N | ESD9B5V | E0402N | FB1 | L0603 | 0R | L0603 | J1 | 757DC-B | DC5V | 757DC-B | J2 | MICRO_USB_NJ2 | USB | MICRO_USB_NJ2 | J3 | 757TF | TF_SD_SOCKET | 757TF | J6 | PJ-311A | AJ324F-6-S | PJ-311A | J7 | SPKPAD | CON2 | SPKPAD | J8 | FPC40-R-0.5A | AT070TNA2 | FPC40-R-0.5 | J9 | FPC24-0.5 | OV2659 | FPC24-0.5 | J15 | RS7M1609013-A | 30P0.5TOP | RS7M1609013-A | J27 | WIFIANT | ANT1 | WIFIANT | J29 | WIFIANT | ANT1 | WIFIANT | L1 | IND_4X4&3X3 | 4.7UH/1.5A | IND_4X4&3X3 | L5 | IND_4X4&3X3 | 10UH/2A | IND_4X4&3X3 | L6 | IND_4X4&3X3 | 10UH/2A | IND_4X4&3X3 | L15 | L0402 | NC | L0402 | L21 | IND_4X4&3X3 | 2.2UH/1.5A | IND_4X4&3X3 | L22 | IND_4X4 | 3.3UH/2A | IND_4X4 | L37 | R0402 | FB600R | R0402 | MARK2 | MARK | MARK | MARK | MARK4 | MARK | MARK | MARK | MARK5 | MARK | MARK | MARK | MARK6 | MARK | MARK | MARK | MIC1 | MIC_4020 | MIC | MIC_4020 | P1 | PAD2X2.5 | BATT+ | PAD2X2.5 | Q1 | SOT23 | DC/8050 | SOT23 | Q2 | SOT23 | 2SK3018 | SOT23 | Q8 | SOT23 | 8050 | SOT23 | Q9 | SOT23 | DC/AO3423 | SOT23 | Q10 | SOT23 | 8050 | SOT23 | Q14 | SOT23 | AO3423 | SOT23 | Q15 | SOT23 | WPM2026 | SOT23 | Q19 | SOT23 | 8050 | SOT23 | Q27 | SOT23 | 8050 | SOT23 | Q30 | SOT23 | IPS/8050 | SOT23 | Q32 | SOT23 | IPS/AO3423 | SOT23 | Q33 | SOT23 | AO3423 | SOT23 | RP4 | RES-ARRAY0402 | 0R | RESX4 | SHIELD1 | SHIELD-3P | CON5 | SHIELD-3P | SW1 | SW8 | VOL+ | SW8 | SW4 | SW8 | VOL- | SW8 | SW6 | SW8 | PWR | SW8 | SW7 | SW-PB3 | RESET | SW-PB3 | U1 | BGA453-19X19 | RK3188 | BGA453-19X19 | U2 | MCP193 | CI_MCP | MCP193 | U3 | SOT25 | PT5108E23E-18 | SOT25 | U7 | SOT26 | SY7152ABC | SOT26 | U8 | MSOP8 | HYM8563 | MSOP8 | U9 | SOT23 | DC/CE8808C33M | SOT23 | U12 | SOT25 | RT9013-12PB | SOT25 | U13 | WM8988 | ES8323 | WM8988 | U14 | TSOP1-48 | NAND_FLASH | TSOP1-48 | U15 | SOT25 | RT9013-18PB | SOT25 | U16 | SOT25 | DC/LPW5206H | SOT25 | U20 | TSOP56 | SN75LVDS83A | TSOP56 | U21 | MSOP8 | NS4150B | MSOP8 | U23 | SOT26 | TCS3354 | SOT26 | U24 | SOT26 | AP3127B | SOT26 | U25 | QFN40L | ACT8931A | QFN40L | U28 | CON50P_0D5MMA | LC070LF02CWXXLA | CON50P_0D5MM | U37 | SOT25 | SY8009B | SOT25 | U40 | MMA7660FC | STK8312 | MMA7660FC | U45 | QFN5X5-40PIN | GSL1680/8 | QFN5X5-40PIN | U80 | WIFI_8723AS | NC/WIFI+BT | WIFI_8723AS | U90 | QFN32 | ESP8089 | ESP8080_7 | X1 | M49S-SMD | 24MHZ | M49S-SMD | X2 | M49S-SMD | 26MHZ | M49S-SMD | Y5 | CRY_MC146 | NC/32.768KHZ-20PPM | CRY_MC146 | Y7 | CRY_2X6 | 32.768KHZ-20PPM | CRY_2X6 |
重要提示:PCB作品文件展下载说明
