重要提示:PCB作品文件展下载说明
Comment | Description | Designator | Footprint | LibRef | Quantity | +5V | | +5V | TEST | TP | 1 | 进气 | Electrical Bell | B1 | CON2-4.1MM | Bell | 1 | 放汽 | Electrical Bell | B2 | CON2-4.1MM | Bell | 1 | 锅内进水 | Electrical Bell | B3 | CON2-4.1MM | Bell | 1 | 真空 | Electrical Bell | B4 | CON2-4.1MM | Bell | 1 | 排水 | Electrical Bell | B5 | CON2-4.1MM | Bell | 1 | 104 | Capacitor | C1, C2, C3, C4, C5,C12, C14, C15, C16, C17, C18, C23, C24, C25, C26, C27, C29, C30, C33, C34,C37, C38 | 0805C | CAP | 22 | 103/400V | Capacitor | C6, C7, C9, C13, C19 | C1206-2 | CAP | 5 | 22pF | Capacitor | C8, C10 | 0805C | Cap | 2 | 102 | Capacitor | C11 | 0805C | CAP | 1 | 103 | Capacitor | C21 | 0805C | CAP | 1 | 105 | Capacitor | C22 | 0805C | CAp | 1 | 680uF | Capacitor | C28 | CAP7343 | CAPACITOR POL | 1 | 22uF | Capacitor | C31, C35 | C1210 | CAPACITOR POL | 2 | 220uF | Capacitor | C32 | CAP7343 | CAPACITOR POL | 1 | 2200/50V | | C36 | RB.3/.8 | ELECTRO2 | 1 | SC-70 | | CN1 | ISP-10PIN | SC-70 | 1 | CN | Header, 2-Pin | CN2, CN5 | CON2-4.1MM | Header 2 | 2 | 20PIN-JTAG | | CN3 | HEADER2X10-2.54MM | 20PIN-JTAG | 1 | CON5 | Connector | CN4, CN6 | XH-5-L | CON5 | 2 | 0.1UF X | Capacitor | CX1 | CBB-10MM | CAP0 | 1 | 4007 | Default Diode | D1, D2, D3, D4, D5 | DO-214C | DIODE | 5 | | Typical RED GaAs LED | D6, D7, D8, D9, D10,D11, D13, D16, D18, D19, D20 | 0805LED | LED1 | 11 | DB107 | 桥堆 | D12 | DB207S | Bridge | 1 | 1N4148 | 二极管 | D14, D15 | LL34 | 1N4007 | 2 | M7 | Diode | D17 | DO-214C | 1N4148 | 1 | IN5824 | Zener Diode | D21 | DO-214C | ZENER2 | 1 | RS406 | Diode Bridge | DB1 | BRIDGE1 | BRIDGE | 1 | RS206 | Full Wave DiodeBridge | DB2 | RS206-HY | Bridge1 | 1 | Comment | | Designator105 | DANGER | | 1 | Comment | | Designator106 | NO TOUCH | | 1 | Comment | | Designator107, HIGHVOLTAGE, Solenoid valve | FANGXIANG | | 3 | GND | | GND | TEST | TP | 1 | PC817XI | 4-Pin PhototransistorOptocoupler | IC1 | SOP4 | Optoisolator1 | 1 | UART | | J1 | XH2.54-4P | UART | 1 | USB | | J2 | USB-B | USB | 1 | 继电器 | | K1, K2 | SRU-05VDC-SL-C | 继电器-1 | 2 | 10UH | Resistor | L1 | 0805N | RES2 | 1 | 33uH | | L2 | IND_12X12 | INDUCTOR2 | 1 | U4 | | LM358 | SO8M1 | LM158 | 1 | | Varistor(Voltage-Sensitive Resistor) | NTC1, NTC2, PT1000 | XH-2-L | Res Varistor | 3 | 铜插片 | | P1, P2, P3, P4, P5,P6, P7, P8, P9, P10, P11, P12, P13, P14 | CP6.3 | T | 14 | 8050 | 三极管 | Q1, Q2, Q3, Q4, Q5,Q6, Q7 | SOT23-EBC | NPN | 7 | 8550 | | Q8 | SOT23-EBC | PNP | 1 | 360 | Resistor | R1, R21, R32, R40,R48 | 1206- | RES2 | 5 | 220 | Resistor | R2, R22, R33, R41,R49 | 0805N | RES2 | 5 | 3.3K | Resistor | R3, R23, R34, R42,R50 | 0805N | RES2 | 5 | 330 | Resistor | R4, R24, R35, R44,R53 | 1206- | RES2 | 5 | 1K | Resistor, 电阻 | R5, R6, R7, R8, R9,R10, R11, R12, R13, R14, R15, R25, R30, R31, R37, R39, R45, R51, R54, R55,R62, R63, R64, R65, R66, R69, R71, R72 | 0805N | RES2 | 28 | 10K | Resistor | R16, R17, R18, R19,R20, R26, R27, R28, R29, R36, R38, R43, R70 | 0805N | RES2 | 13 | 1.2k | Resistor | R46, R47 | 0805N | RES2 | 2 | 4k | Resistor | R52, R56 | 0805N | RES2 | 2 | 1.5k | Resistor | R57, R58 | 0805N | RES2 | 2 | 1.3k | Resistor | R59, R60, R61 | 0805N | RES2 | 3 | 0 | Resistor | R67, R68 | 0805N | RES2 | 2 | 20/2W | Resistor | RZ1, RZ2, RZ4, RZ6,RZ7 | 1206- | RES2 | 5 | 2/1W 5.6 | 电阻 | RZ3 | 2512- | Res2 | 1 | 100K/1W | | RZ5 | 1206- | RES1 | 1 | KEY | | S1 | SW-7 | KEY | 1 | FAN | DC FAN | SR1 | TO90 | FAN | 1 | MJD122 | NPN BipolarTransistor | T1, T2, T3, T4, T5 | TO-252 | NPN | 5 | BTA41-600B | Silicon BidirectionalTriode Thyristor | T6, T7 | BTA4 | Triac | 2 | BT137S | Silicon BidirectionalTriode Thyristor | T8, T10, T11 | SOT-428 | Triac | 3 | MJD122 | NPN BipolarTransistor | T9 | TO-252-2L | NPN | 1 | Trans3 | Three-windingTransformer (Non-Ideal) | TR1 | CON4-4.1MM | Trans3 | 1 | 3021 | Opto-Triac | U1, U2, U4, U5, U6 | SOP6 | Opto TRIAC | 5 | STM32F103RBT6 | STM32 ARM-based32-bit MCU with 128 Kbytes Flash, 64-pin LQFP, Industrial Temperature | U3 | LQFP64 | STM32F103RBT6 | 1 | MPX5700 | | U7 | MPX5500 | Component_1 | 1 | LM2596S-5.0 | | U8 | TO-263 | LM2596 | 1 | LM1117 3.3 | | U9 | TO-252AA | AMS1117 | 1 | 8M | Crystal Oscillator | Y1 | XTAL2 | XTAL | 1 |
重要提示:PCB作品文件展下载说明
