[AD格式] 2层-NUCLEO-F091RC官网PCB文件+原理图(STM32F103CBT6+STM32F091RC
查看3355 | 回复8 | 2018-11-26 11:33:20 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
游客,如果您要查看本帖隐藏内容请回复
2层PCB设计,600Pins
FootprintCommentLibRefDesignatorDescriptionQuantity
PB10USER (Blue)SW PUSHBUTTONB1SE PUSHBUTTON1
PB10TD-0341 [RESET/Black]SW PUSHBUTTONB2SE PUSHBUTTON1
0603C100nFCapacitor_ST, Capacitor_ST, Capacitor_ST, Capacitor_ST,Capacitor_ST, Capacitor_ST, Capacitor_ST, CAP, CAP, Capacitor_ST,Capacitor_ST, Cap, Cap, Cap, Cap, CapC1, C4, C5, C6, C7, C11, C12,C14, C15, C19, C20, C23, C24, C27, C28, C30Capacitor 0402 / 0603 / 0805,Capacitor 0402 / 0603 / 0805, Capacitor 0402 / 0603 / 0805, Capacitor 0402 /0603 / 0805, Capacitor 0402 / 0603 / 0805, Capacitor 0402 / 0603 / 0805,Capacitor 0402 / 0603 / 0805, Capacitor, Capacitor, Capacitor 0402 / 0603 /0805, Capacitor 0402 / 0603 / 0805, Capacitor, Capacitor, Capacitor,Capacitor, Capacitor16
0603C1uF_X5R_0603CAP SMD 0603  X5R 1礔 25V10%C2, C13, C18,C21, C290603 X5R 1礔5
0603C20pFCapacitor_STC3, C8Capacitor 0402 / 0603 / 08052
0603C10nF_X7R_0603CAP SMD 0603  X7R10000PF 50V 10%C90603 X7R 10NF1
0603C20pF[N/A]Capacitor_ST, CAP, CAPC10, C33, C34Capacitor 0402 / 0603 / 0805,Capacitor, Capacitor3
TAN-B10uF(25V)Cap Pol1C16Polarized Capacitor (Radial)1
TAN-A10uFCap Pol1C17Polarized Capacitor (Radial)1
TAN-A2.2uFCap_2.2uF_X7R_10%_0805C22, C25, C26Capacitor,2.2uF,16V,X7R,10%,0805,YAGEO3
0603C10pF[N/A]CAPC31, C32Capacitor2
USB-MINI-B-SMD5075BMR-05-SMUSB-MINI-typeB connectorCN1USB-MINI-typeB connector1
1*4Header 4Header 4CN2Header, 4-Pin, Single row1
SIP2/2.54 JP2CN3, CN11, CN12,JP1, JP4, JP6 6
1*6PHeader 6X1Header 6X1CN4Header, 6-Pin, Single row1
1*10P_FEMALEHeader 10X1_FemaleHeader 10X1_FemaleCN5Header, 10-Pin, Single row,female1
1*8P_FEMALEHeader 8X1_FemaleHeader 8X1_FemaleCN6, CN9Header, 8-Pin, Single row,female2
2*19PHeader 19X2Header 19X2CN7, CN10Header, 19-Pin, Dual row2
1*6P_FEMALEHeader 6X1_FemaleHeader 6X1_FemaleCN8Header, 6-Pin, Single row,female1
SOD323/ABAT60JFILMBAT60JFILMD1, D2, D3BAT60JFILM3
SMASTPS2L30ASTPS2L30AD4STPS2L30A1
SIP3 Jumper3JP5 1
0603LBEADInductorL1Inductor1
HSMF-A201LD_BICOLOR_CMSLD_BICOLOR_CMSLD1Bicolor Led1
0603DGreenLED2LD2Typical RED, GREEN, YELLOW, AMBERGaAs LED1
0603DREDPHOTOLD3 1
0603R10KResistor_ST, Resistor_ST, Res1, res1R1, R3, R12, R33Resistor 0402 / 0603 / 0805, Resistor0402 / 0603 / 0805, Resistor, Resistor4
0603R10K[N/A]Resistor_STR2Resistor 0402 / 0603 / 08051
0603R4K7Res1, Resistor_ST, Resistor_ST, Res1, res1R4, R23, R27, R28, R30Resistor, Resistor 0402 / 0603 /0805, Resistor 0402 / 0603 / 0805, Resistor, Resistor5
0603R22Resistor_STR5, R8, R13, R22Resistor 0402 / 0603 / 08054
0603R100KResistor_STR6, R14, R15Resistor 0402 / 0603 / 08053
0603R2K7Res1R7Resistor1
0603R100[N/A]Resistor_STR9Resistor 0402 / 0603 / 08051
0603R36KRes1R10Resistor1
0603R100Resistor_ST, Resistor_ST, Resistor_ST, Resistor_ST,Resistor_ST, Res1R11, R20, R21, R24, R25, R29Resistor 0402 / 0603 / 0805, Resistor0402 / 0603 / 0805, Resistor 0402 / 0603 / 0805, Resistor 0402 / 0603 / 0805,Resistor 0402 / 0603 / 0805, Resistor6
0603R1K5Resistor_STR16Resistor 0402 / 0603 / 08051
0603R0Resistor_STR17, R18, R19Resistor 0402 / 0603 / 08053
0603R[N/A]Res1R26, R34, R35,R36, R37Resistor5
0603R510Res1R31Resistor1
0603R1KResistor_STR32Resistor 0402 / 0603 / 08051
JP2_SMDCircuit BreakerCircuit BreakerSB1, SB2, SB3, SB4, SB5, SB6,SB7, SB8, SB9, SB10, SB11, SB12, SB13, SB14, SB15, SB16, SB17, SB18, SB19,SB20, SB21, SB22, SB23, SB24, SB25, SB26, SB27, SB28, SB29, SB30, SB31, SB32,SB33, SB34, SB35, SB36, SB37, SB38, SB39, SB40, SB41, SB42, SB43, SB44, SB45,SB46, SB47, SB48, SB49, SB50, SB51, SB52, SB53, SB54, SB55, SB56, SB57, SB58,SB59, SB60, SB61, SB62, SB63, SB64, SB65Circuit Breaker65
SOT-239013NPNT1NPN Bipolar Transistor1
SO8STS7PF30LSTS7PF30LT2 1
SOT-23-5LLD3985M33RLD3985M33RU1Ultra low drop-low noise BiCMOSvoltage, regulators low ESR capacitors compatible1
QFP48 7X7STM32F103CBT6STM32F103CBT6U2Medium-density performance lineARM-based 32-bit MCU with 64KB Flash1
SOT-223LD1117S50TRLD1117U3 1
DFN6(3X3)LD39050PU33RLD39050PU4 1
LQFP64MCU_LQFP64MCU_LQFP64U5 1
XTAL18MHz(12pF)XTALX1Crystal Oscillator1
XTAL_4SM_8X3R832.768K[N/A]MC306X2 1
XTAL18MHz(16pF)[N/A]CRYSTALX3Crystal1
     172
重要提示:PCB作品文件展下载说明
BLOG:https://blog.csdn.net/Pieces_thinking
洛洛123456 | 2019-1-22 21:22:17 | 显示全部楼层
cybi1861 | 2019-1-23 07:47:10 | 显示全部楼层
vj08gh | 2019-1-24 08:58:29 | 显示全部楼层
丁响820425 | 2019-1-24 09:00:52 | 显示全部楼层
o桃花岛主o | 2019-4-27 22:16:06 | 显示全部楼层
lcfmax | 2019-4-28 08:08:23 | 显示全部楼层
匿名 here | 2019-11-14 18:21:41 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
123478288 | 2021-7-11 15:44:43 | 显示全部楼层
