Electrical(电气规则) 8 F0 b; h) V% L; S) w
Clearance(安全间距规则)
short-circuit(短路规则) 2 I1 G/ f; C6 w9 L
Unrouted Net(未布线网络规则)
Unconnected Pin(未连线引脚规则) , D6 `. w: N$ b( k; K# k
Routing(走线规则) ' _. q) B; q+ }1 Z( w+ v9 T# F/ g
Width(走线宽度规则)
Routing Topology(走线拓扑布局规则) 0 ^, y, y. ^3 b7 f: `
Routing Priority(布线优先级规则)
Routing Layers(板层布线规则) ; p# o0 p) _$ d5 l# k
Routing Corners(导线转角规则)
Routing Via Style(布线过孔形式规则) . G) m5 OO0 b# N& |+ j7 e9 ^* {
Fanout Control(布线扇出控制规则) ; \: ~) k: ?3 ~& E1 |
SMT(表贴焊盘规则) % T4 O+ B2 @$ a' \v
SMD To Corner(SMD焊盘与导线拐角处最小间距规则)
SMD To Plane(SMD焊盘与电源层过孔最小间距规则) # B8 h( S9 N3 Q( Q5 g% `
SMD Neck-Down(SMD焊盘颈缩率规则)
Mask(阻焊层规则) ; w6 \" I" n- t' f! ?! K' P5 j
Solder Mask Expansion(阻焊层收缩量规则) ' {- C% d- O" n& B! ^- X3 A
Paste Mask Expansion(助焊层收缩量规则) 6 M9 v9 X6 U" Q- w; m' d1 L; O
Plane(电源层规则) - }3 ^5 i; K) P0 k. q) r
Power Plane Connect(电源层连接类型规则) " \5 R: t- X" j1 X7 ^3 j0 U
Power Plane Clearance(电源层安全间距规则) N6 J( g3 f; E1 ~
Polygon Connect Style(焊盘与覆铜连接类型规则) 9 Q# U5 Z' ]) u* D: f
Testpoint(测试点规则)
Testpoint Style(测试点样式规则) ; T$ `7 k1 z; x8 Z9 oP* k
Testpoint Usage(测试点使用规则) # U% B, _2 ]$ {8 ]# bn, j! y
Manufacturing(电路板制作规则)
Minimum Annular Ring(最小包环限制规则) 8 L8 e% g+ L, x: u1 @
Acute Angle Constraint(锐角限制规则)
Hole Size(孔径大小设计规则) % s* l; [5 c/ w# B, w
Layer Pairs(板层对设计规则) ' m" w7 Q. {; Y+ _% _3 |
Highspeed(高频电路规则)
Parallel Segment(平行铜膜线段间距限制规则)
Length(网络长度限制规则) ) o% ^% W5 L6 dd7 w: z
Matched Net Lengths(网络长度匹配规则)
Daisy Chain Stub Length (菊花状布线分支长度限制规则) $ l! S4 C' fv, E9 B+ q3 \$ p
Vias Under SMD(SMD焊盘下过孔限制规则)
Maximum Via Count(最大过孔数目限制规则) 3 ~# Q, k" G4 _- `/ g+ J
Placement(元件布置规则) * r! ~3 E: f: L& s7 q
Room Definition(元件集合定义规则)
Component Clearance(元件间距限制规则)
Component Orientations(元件布置方向规则)
Permitted Layers(允许元件布置板层规则)\7 C0 L6 a- u( E4 D9 m$ Y2 V6 `
Nets To Ignore(网络忽略规则)
Hight(高度规则)
Signal Integrity(信号完整性规则) 1 W* }$ g' p2 l# O8 [9 f0 g
Signal Stimulus(激励信号规则)
Overshoot-Failing Edge(负超调量限制规则)
Overshoot-Rising Edge(正超调量限制规则)
Undershoot-Falling Edge(负下冲超调量限制规则)
Undershoot-Rising Edge(正下冲超调量限制规则) * f! u* Y: f( `2 B
Impedance(阻抗限制规则)
Signal Top Value(高电平信号规则) 4 z# B1 a+ d" M
Signal Base Value(低电平信号规则)
Flight Time-Rising Edge(上升飞行时间规则) $ v5 r/ R3 d% a3 T. H1 u$ s( \
Flight Time-Falling Edge(下降飞行时间规则) : p& p9 kR5 [. s& f
Slope-Rising Edge(上升沿时间规则)
Slope-Falling Edge(下降沿时间规则)
Supply Nets(电源网络规则) J3 d( I7 B4 i
更多资源与交流尽在电子工程师社区,电子工程师社区欢迎您的光临! |
