Bill of MaterialReport |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_TOL | COMP_CLASS | REFDES |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 18PF | | DISCRETE | C1 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C2 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C3 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C4 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C5 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 18PF | | DISCRETE | C6 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C7 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 0.01UF | | DISCRETE | C8 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 0.01UF | | DISCRETE | C9 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C10 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C11 |
CCE63X55 | CAP_POL_CCE63X55_DISCRETE_5.7MM | 100UF | | DISCRETE | C12 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C13 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C14 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C15 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.87 | 1000PF | | DISCRETE | C16 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C17 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C18 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C19 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C20 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C21 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 0.01UF | | DISCRETE | C22 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C23 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C24 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 18PF | | DISCRETE | C25 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 18PF | | DISCRETE | C26 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C27 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C28 |
CC3216 | CAP_POL_CC3216_DISCRETE_1.8MM_1 | 10UF | | DISCRETE | C29 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C30 |
CC3216 | CAP_POL_CC3216_DISCRETE_1.8MM_1 | 10UF | | DISCRETE | C31 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C32 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C33 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C34 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C35 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C36 |
CC3528-21 | CAP_POL_CC3528-21_DISCRETE_2.1M | 47UF | | DISCRETE | C37 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.87 | 1000PF | | DISCRETE | C38 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C39 |
CC3528-21 | CAP_POL_CC3528-21_DISCRETE_2._1 | 10UF | | DISCRETE | C40 |
CC3216 | CAP_POL_CC3216_DISCRETE_1.8MM_1 | 10UF | | DISCRETE | C41 |
CC3216 | CAP_POL_CC3216_DISCRETE_1.8MM_1 | 10UF | | DISCRETE | C42 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C43 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C44 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 3300pF | | DISCRETE | C45 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 3300pF | | DISCRETE | C46 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 3300pF | | DISCRETE | C47 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C48 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C49 |
CC3216 | CAP_POL_CC3216_DISCRETE_1.8MM_1 | 10UF | | DISCRETE | C50 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 18PF | | DISCRETE | C51 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C52 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C53 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C54 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 18PF | | DISCRETE | C55 |
CC3216 | CAP_POL_CC3216_DISCRETE_1.8MM_1 | 10UF | | DISCRETE | C56 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | | DISCRETE | C57 |
LED_0603_C1 | LED_LED_0603_C1_IC_1.0MM_370-76 | YEL | | IC | D1 |
LED_0603_C1 | LED_LED_0603_C1_IC_1.0MM_370-_1 | OR/RED | | IC | D2 |
0603LED_1A2C | LED_1A2C_0603LED_1A2C_IC_0.85MM | GRN | | IC | D3 |
0603LED_1A2C | LED_1A2C_0603LED_1A2C_IC_0.85MM | GRN | | IC | D4 |
LED_0603_C1 | LED_LED_0603_C1_IC_1.0MM_370-_1 | OR/RED | | IC | D5 |
0603LED_1A2C | LED_1A2C_0603LED_1A2C_IC_0.85MM | GRN | | IC | D6 |
LED_0603_C1 | LED_LED_0603_C1_IC_1.0MM_370-76 | YEL | | IC | D7 |
0603LED_1A2C | LED_1A2C_0603LED_1A2C_IC_0.85MM | GRN | | IC | D8 |
SMB_2P7X1P4 | DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7 | MSS1P3L | | IC | D9 |
SOT-23 | BAT721B_SOT-23_IC_1.3MM_480-779 | BAT54C | | IC | D10 |
CON164_1MM_FINGER | PCI_EXPRESSX16_CON164_1MM_FINGE | PCI EXPRESS 164 TWRSYS PRIMARY | | IO | J1 |
HDR203_M20 | CONN_HDR_3X2_HDR203_M20_IO_8.64 | HDR 2X3 | | IO | J2 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.6MM_21 | HDR TH 1X3 | | IO | J3 |
HDR102 | CONN_HDR_1X2_HDR102_IO_8.6MM_21 | HDR 1X2 TH | | IO | J4 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.6MM_21 | HDR TH 1X3 | | IO | J5 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.6MM_21 | HDR TH 1X3 | | IO | J6 |
HDR208 | CONN_HDR_8X2_HDR208_IO_8.79MM_2 | HDR_2X8 | | IO | J7 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.6MM_21 | HDR TH 1X3 | | IO | J8 |
HDR205 | CONN_HDR_5X2_HDR205_IO_8.6MM_21 | HDR 2X5 | | IO | J9 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.6MM_21 | HDR TH 1X3 | | IO | J10 |
HDR202_100_TH | CONN_HDR_2X2_HDR202_100_TH_IO_8 | HDR 2X2 | | IO | J11 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.6MM_21 | HDR TH 1X3 | | IO | J12 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.6MM_21 | HDR TH 1X3 | | IO | J13 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.6MM_21 | HDR TH 1X3 | | IO | J14 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.6MM_21 | HDR TH 1X3 | | IO | J15 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.6MM_21 | HDR TH 1X3 | | IO | J16 |
CON5_MUSB_AB_0P8_RA_SMT | USB_MINI_B_SKT_CON5_MUSB_AB_0P8 | USB_MINI_B 5 | | IO | J17 |
HDR213_A | CONN_HDR_13X2_HDR213_A_IO_8.9M | HDR_2X13 | | IO | J18 |
CON164_1MM_FINGER | PCI_EXPRESSX16_CON164_1MM_FINGE | PCI EXPRESS 164 TWRSYS PRIMARY | | IO | J19 |
HDR102 | CONN_HDR_1X2_HDR102_IO_8.6MM_21 | HDR 1X2 TH | | IO | J20 |
HDR102 | CONN_HDR_1X2_HDR102_IO_8.6MM_21 | HDR 1X2 TH | | IO | J21 |
IND_0603 | IND_IND_0603_DISCRETE_0.8MM_180 | 100MHZ | | DISCRETE | L1 |
IND_0603 | IND_IND_0603_DISCRETE_0.8MM_180 | 100MHZ | | DISCRETE | L2 |
IND_1206A | BEAD_IND_1206A_DISCRETE_1.3MM_1 | 26OHM | | DISCRETE | L3 |
IND_1206A | BEAD_IND_1206A_DISCRETE_1.3MM_1 | 26OHM | | DISCRETE | L4 |
IND_0603 | IND_IND_0603_DISCRETE_0.8MM_180 | 100MHZ | | DISCRETE | L5 |
IND_0603 | IND_IND_0603_DISCRETE_0.8MM_180 | 100MHZ | | DISCRETE | L6 |
IND_0603 | BEAD_IND_0603_DISCRETE_0.95MM_1 | 10 OHM | | DISCRETE | L7 |
IND_0603 | IND_IND_0603_DISCRETE_0.8MM_180 | 100MHZ | | DISCRETE | L8 |
SOT-23 | NPN_SOT-23_IC_1.14MM_480-77945_ | MMBT3904K | | IC | Q1 |
SOT-23 | TRAN_NPN_RES_SOT-23_IC_1.3MM_48 | PDTC115T | | IC | Q2 |
SOT-23 | TRAN_NPN_RES_SOT-23_IC_1.3MM_48 | PDTC115T | | IC | Q3 |
SOT-23 | TRAN_NPN_RES_SOT-23_IC_1.3MM_48 | PDTC115T | | IC | Q4 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R1 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 33 | | DISCRETE | R2 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 33 | | DISCRETE | R3 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 33 | | DISCRETE | R4 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 33 | | DISCRETE | R5 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 33 | | DISCRETE | R6 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 33 | | DISCRETE | R7 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_5 | 1.0M | | DISCRETE | R8 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R9 |
POT3_3352W | POT_POT3_3352W_DISCRETE_470-799 | 10K | | DISCRETE | R10 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R11 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7584 | 10 | | DISCRETE | R12 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R13 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7545 | 330 | | DISCRETE | R14 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7555 | 10M | | DISCRETE | R15 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7545 | 330 | | DISCRETE | R16 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7545 | 330 | | DISCRETE | R17 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7584 | 10 | | DISCRETE | R18 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7545 | 330 | | DISCRETE | R19 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7545 | 330 | | DISCRETE | R20 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R21 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R22 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R23 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7545 | 330 | | DISCRETE | R24 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R25 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_2 | 1K | | DISCRETE | R26 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_2 | 1K | | DISCRETE | R27 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R31 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R32 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7539 | 22 | | DISCRETE | R33 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R34 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R35 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R36 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R39 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R40 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 33 | | DISCRETE | R41 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R42 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R43 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 33 | | DISCRETE | R44 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 33 | | DISCRETE | R45 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7999 | 1.8K | | DISCRETE | R46 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_2 | 1K | | DISCRETE | R47 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_2 | 1K | | DISCRETE | R48 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7539 | 22 | | DISCRETE | R49 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_2 | 1K | | DISCRETE | R50 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_2 | 1K | | DISCRETE | R51 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R52 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_2 | 1K | | DISCRETE | R53 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R54 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R55 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R56 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R57 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R58 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R59 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_3 | 2.2K | | DISCRETE | R60 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R61 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_4 | 4.7K | | DISCRETE | R62 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_4 | 4.7K | | DISCRETE | R63 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R64 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 33 | | DISCRETE | R65 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R66 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7555 | 10M | | DISCRETE | R67 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 33 | | DISCRETE | R68 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R69 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R70 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R71 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R72 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | | DISCRETE | R73 |
RNET_4_8 | RESISTOR_ARRAY_RNET_4_8_DISCRET | 10k | | DISCRETE | RN1 |
RNET_4_8 | RESISTOR_ARRAY_RNET_4_8_DISCRET | 10k | | DISCRETE | RN2 |
SH0402 | RES_SHORT-2_SH0402_DISCRETE_470 | 0 | | DISCRETE | SH1 |
SW_SPST_TH | SW_PSHBT_SPST_2_SW_SPST_TH_IC_7 | LIGHT TOUCH PUSHBUTTON | | IC | SW1 |
DIP-SMT4 | SW_DIP-4_SM_DIP-SMT4_IC_3.82MM | 219-6LPST-P | | IC | SW2 |
SW_SPST_TH | SW_PSHBT_SPST_2_SW_SPST_TH_IC_7 | LIGHT TOUCH PUSHBUTTON | | IC | SW3 |
SW_SPST_TH | SW_PSHBT_SPST_2_SW_SPST_TH_IC_7 | LIGHT TOUCH PUSHBUTTON | | IC | SW4 |
TP_075_045MIL | TESTLOOP_TP_075_045MIL_IO_5.0MM | 999-60-110045 | | IO | TP1 |
TP_075_045MIL | TESTLOOP_TP_075_045MIL_IO_5.0MM | 999-60-110045 | | IO | TP2 |
TP_075_045MIL | TESTLOOP_TP_075_045MIL_IO_5.0MM | 999-60-110045 | | IO | TP3 |
TQFP144 | MCF52259_TQFP144_IC_1.6MM_312-7 | MCF52259 | | IC | U2 |
LGA14_0P80_3X5_SH | MMA7360L_LGA14_0P80_3X5_SH_IC_1 | MMA7361LCT | | IC | U3 |
SO8 | MIC2526_8P_SO8_IC_1.73MM_312-75 | MIC2026-1YM | | IC | U4 |
SOT223 | LM1117_SOT223_IC_1.9MM_315-788 | LD1117-3.3 | | IC | U5 |
TSSOP14 | 74LVC125_TSSOP14_IC_1.2MM_312-7 | 74LVC125 | | IC | U6 |
TQFP44 | MC9S08JM60CLD_TQFP44_IC_1.60MM | MC9S08JM60CLD | | IC | U7 |
TSSOP20 | SN74ACT573PWR_TSSOP20_IC_1.2MM_ | SN74ACT573 | | IC | U8 |
TSSOP16 | ICL3232_TSSOP16_IC_1.1MM_312-7 | ICL3232 | | IC | U9 |
XTL2_ECS_CSM7_SM | XTAL_XTL2_ECS_CSM7_SM_IC_4.2MM_ | 4MHz | | IC | X1 |
XTLOSC_4P_6P2X3P9 | XTAL_13Y_XTLOSC_4P_6P2X3P9_IC_1 | 48MHZ | | IC | Y1 |
XTL2_ECS_SM | XTAL_XTL2_ECS_SM_IC_2.25MM_230- | 32.768KHz | | IC | Y2 |
