(orcad 2 pads2007)的网络表时,却出现以下的问题,各位请问应该怎么解决呢?谢谢!!!6 ]( j7 B- I/ Q' x* g, P4 H& @
Reading file --F:\adsl.asc
*Unspecified or unsupported version of ASCII file# [% ~0 Q% io# |6 I7 O7 p8 _
*PADS2000*
Bad part mirror value -1
C12 DIP-CAP,470PF - 5KV - Y2
*Bad *PART* ascii data line format
C24 0603,0.1UF 10%
*Bad *PART* ascii data line format; P& M2 S5 u, u5 l0 o2 l" w
C25 0603,0.1UF 10%. ]- U: f. {x
*Bad *PART* ascii data line format6 F+ ^|3 [/ i' O{
C26 0603,0.1UF 10%1 p' b8 k6 {) k- d* x& |. V
*Bad *PART* ascii data line format_+ I& k* M8 `- ^5 T' N5 Z' m* C
C73 0603,CAP NP7 U8 X! s& ZR
*Bad *PART* ascii data line format& M1 l' V9 T: l5 u6 ~
C75 0603,CAP NP; o% C7 [5 L* D: ~
C9 DIP-CAP,470PF - 5KV - Y2# N" O% V8 L* a; x: M/ w4 S" U
R39 0603,24K 5%/ l7 m# q- y7 v8 w+ A0 L
SW1 SW-8,SW SLIDE-DP3T& U5 @# ^+ _$ }: T/ T/ I
*Bad *PART* ascii data line format3 J* b# p/ e" c( m& G5 e+ ^
SW2 SIP-3P,SW SLIDE-SPDT7 U* u" U4 Q# `# {
*Bad *PART* ascii data line format- r% `8 a4 z3 t& j# U
SW3 SIP-3P,SW SLIDE-SPDT8 p6 U- [& x! a6 D
SW4 SIP-3P,SW SLIDE-SPDT
*Part name not found C26
U2.4 C26.1 C23.2. U- y& J9 cb/ J& m3 K
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N253543& I" Z1 G% }5 r
*Part name not found SW4
SW4.3 R113.1
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N18179952 ?0 G7 J1 ~0 x5 @3 L
*Part name not found SW3
SW3.3 U10.3
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N18421635 H* EG; ], D9 i0 U% f' U; f
R112.1 SW4.15 |' FC9 x/ ~7 h# p& Q2 A
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N1800505
*Part name not found SW1
SW1.5 RV3.1 D12.1
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N10263) O/ J! W/ X# X! H2 [
*Part name not found SW1+ n8 l2 _6 n7 _1 r. h0 ]) N
SW1.6 J7.17 l: q1 Z3 {6 w+ L
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N09585- ~) J( m# D! N
*Part name not found C75
U11.8 U13.1 C75.1
*Part name not found SW2- m2 B" Z$ ]; k3 }1 {0 @
SW2.2 U12.13
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N31703188 U8 m$ h$ X( N0 S
*Part name not found SW3# A( H' M8 {( }4 n# S9 h
SW3.2 U12.12
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N3170741
*Part name not found C126 S8 z; M% v# w; G. }* c+ _/ k) C
C12.1 RV2.1 RV1.2 T1.9 J1.4
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N1509421 ?# @# ]+ w2 H
*Part name not found C9
C9.2 C12.2 J1.10 J1.9 J3.37 J3.36 J3.35 J3.34
*Part name not found R390 lU8 M5 NV' V
U2.51 U2.43 R39.2 C26.2 C24.2 C29.2 C31.2 C32.2" xZ& p1 N8 t, W9 o3 r8 T: F
*Part name not found C25
U1.57 U1.48 U1.21 C6.2 C13.2 C25.2 C30.2 C33.2
*Part name not found C73
C72.2 U11.7 C73.2 U12.7 U10.7 U13.8( w. ?: l( U# D9 G) g4 F
U2.5 C25.1 C23.1
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N253227
*Part name not found C24
U2.6 C24.1
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N252913
*Part name not found R39. mI; B7 k4 |1 q9 ?
U2.24 R39.17 ]$ Y0 k+ `4 y4 N1 l
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N252601! a7 D* P- S+ }1 }- l
T1.16 C9.1 RV1.1 RV2.2 J1.3
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N150517/ h3 z! I$ _( ?9 HZ, u7 X
*Part name not found SW2Z5 e6 P- Z* o3 K; E- ^
U1.76 D8.2 SW2.3+ }& E, G6 Y2 Z$ D9 Y# {
SW3.1 SW2.1
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N1889636
*Part name not found C73$ n6 P" G' C2 ^" W# n5 t3 t7 E. P
U11.2 C73.1 SW4.2
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N1800965
U11.12 U11.13 R116.2 C75.2* w% H% l* ^$ N; g# R
Warning: deleting signal N253543u0 |1 O/ p( {9 {" q' X
Warning: deleting signal N1817995
Warning: deleting signal N1842163( m+ F" ^" a3 Q+ S% f
Warning: deleting signal N1800505
Warning: deleting signal N102638 k- `# _* C% k: Y
Warning: deleting signal N09585m/ q* K2 P' n
Warning: deleting signal N31703182 X2 e' b9 [) y2 m
Warning: deleting signal N3170741* T0 _b/ r& e
Warning: deleting signal N1509423 f: k' l" f$ X; w% a4 {! l
Warning: deleting signal N253227) X+ g8 P5 c6 jH8 {# e( K# }* e
Warning: deleting signal N252913# J6 Z3 i" ?; I3 ^0 ?7 n
Warning: deleting signal N252601
Warning: deleting signal N150517
Warning: deleting signal N1889636
Warning: deleting signal N1800965$ t, Q5 o8 E) g/ |' i6 o6 ~& R
**INPUT WARNINGS FOUND**4 n; w0 @' l# G3 f: Q
如果不带value出网络表则没有问题;出网络表的设置如图所示8 s; l) e9 b6 {0 x& n
- [/ z# U0 U3 P; ^
[ 本帖最后由 panhaojie 于 2008-12-7 13:48 编辑 ]
(92.97 KB, 下载次数: 2)
2008-12-7 13:48 上传
点击文件名下载附件 |
