[Allegro16.6以下] 20层Freescale T4240QDS vxworks7.0 24核 PowerPC 开发板 PCB和原理图 da
查看13530 | 回复75 | 2019-4-14 21:03:04 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
BT1BATTERY_SKT_3V_SKT_BAT_225X886_WBA-3B2 USKT_BAT_225X886_3V
D29LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWLED_0603
D30LED_LED_0603_IC_0.9MM_370-75079REDLED_0603
D31LED_LED_0603_IC_0.8MM_370-75078BLUELED_0603
D32LED_LED_0603_IC_0.9MM_370-75079REDLED_0603
D33LED_LED_0603_IC_0.9MM_370-75079REDLED_0603
D55LED_LED_0603_IC_0.8MM_370-75077LED_GREENLED_0603
D56LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWLED_0603
D57LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWLED_0603
D58LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWLED_0603
D63LED_LED_0603_IC_0.9MM_370-75079REDLED_0603
D64DIODE_SCHTKY_SOD123_IC_1.45MM_4MBR0520LT1GSOD123
D65DIODE_SCHTKY_SOD123_IC_1.45MM_4MBR0520LT1GSOD123
D66DIODE_SCHTKY_SOD123_IC_1.45MM_4MBR0520LT1GSOD123
D67DIODE_SOD123_A_IC_1.35MM_480-78CMHD3595SOD123_A
D68DIODE_SOD123_A_IC_1.35MM_480-78CMHD3595SOD123_A
D69LED_LED_0603_IC_0.9MM_370-75079REDLED_0603
D70LED_LED_0603_IC_0.9MM_370-75079REDLED_0603
F25INDUCTOR_FERRITE_IND_0805_DISCR1000@100MHZIND_0805
F31BEAD_FERRITE_IND_0603A_DISCRETEBLM18KG121TN1IND_0603A
F32BEAD_FERRITE_IND_0603A_DISCRETEBLM18KG121TN1IND_0603A
F35IND_IND_0603_DISCRETE_1MM_180-760 OHM 100MHZIND_0603
F53BEAD_FERRITE_IND_0603A_DISCRETEBLM18KG121TN1IND_0603A
J2CONN_HDR_4X2_HDR2X4_2P54_TH_RA_PLUG 2X4 RAHDR2X4_2P54_TH_RA
J3PCIEXPRESS_MIDBUSPROBE_GEN_X16_CONN_PCIEX16_LAICONN_PCIEX16_LAI
J4PCIEXPRESS_MIDBUSPROBE_GEN_X16_CONN_PCIEX16_LAICONN_PCIEX16_LAI
J15CONN_HDR_3X1_HDR103_IO_9.45MM_2HDR_1X3HDR103
J22DDR3_240P_CON_240_DDR3_DIMM_SKTCON_240_DIMMCON_240_DDR3_DIMM_SKT
J23DDR3_240P_CON_240_DDR3_DIMM_SKTCON_240_DIMMCON_240_DDR3_DIMM_SKT
J24CON_SATA_PLUG7_CON_7_SATA_V_SM_HDR 1X7CON_7_SATA_V_SM
J25SIG_TIE_100X200_SIG_TIE_100X200PLANE SHORT TIESIG_TIE_100X200
J26CON_SATA_PLUG7_CON_7_SATA_V_SM_HDR 1X7CON_7_SATA_V_SM
J27ATX_12V_PWR_CONN8_CONN_2X4_165_CON 2X4CONN_2X4_165_TH
J30CONN_PWR_12X2_CON_ATXPWR_2X12_ACON_2X12_PWRCON_ATXPWR_2X12_A
J38CONN_HDR_5X2_HDR205_4W_IO_9.65MCON_2X5HDR205_4W
J40MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMA
J41MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMA
J49QTH-030-02-L-D-A_CON_60_QTH_0P5CONNECTOR_60PW/2GUIDECON_60_QTH_0P5_SM_2GUIDE
J51DSD9M_DUALDB-9MM_IO_31.75MM_2102XDB9DUALDB-9MM
J53CON_USB_8P_F_4SH_CON_USB_8F_TH_USB_TYPE_A_DUALCON_USB_8F_TH_RA
J54USB_MINI_AB_RECEPTACLE_CON_USB_USB_TYPE_ABCON_USB_5F_0P65_SM_RA
J55CONN_SDC013_19P_CON19_SDCARD_28CONN CRD 19CON19_SDCARD_28X16_SM
J60CONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20CONN2X20_20X7MM_PCI_EXT
J75QTH060_CON_120_0P5MM_SM_2GUIDE_CONNECTOR_120PW/2GUIDECON_120_0P5MM_SM_2GUIDE
J83CONN_PCI_EXPRESS_X8_A_CON_PCIE_CON 98 PCIE SMTCON_PCIE_98F_40_SM
J84CONN_PCI_EXPRESS_X8_A_CON_PCIE_CON 98 PCIE SMTCON_PCIE_98F_40_SM
J85CONN_PCI_EXPRESS_X8_A_CON_PCIE_CON 98 PCIE SMTCON_PCIE_98F_40_SM
J86CONN_PCI_EXPRESS_X8_A_CON_PCIE_CON 98 PCIE SMTCON_PCIE_98F_40_SM
J87PCI_EXPRESS_CONN16_A_CON_PCIE16W3GD-164AN63B52UWCON_PCIE164_1_SM
J88CONN_PCI_EXPRESS_X8_A_CON_PCIE_CON 98 PCIE SMTCON_PCIE_98F_40_SM
J89PCI_EXPRESS_CONN16_A_CON_PCIE16W3GD-164AN63B52UWCON_PCIE164_1_SM
J90CONN_PCI_EXPRESS_X8_A_CON_PCIE_CON 98 PCIE SMTCON_PCIE_98F_40_SM
J91CONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20CONN2X20_20X7MM_PCI_EXT
J92CONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20CONN2X20_20X7MM_PCI_EXT
J93CONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20CONN2X20_20X7MM_PCI_EXT
J94CONN_2X35_CON2X35_SKT_0P8_SM_IOCONN SKT 70CON2X35_SKT_0P8_SM
J95CONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20CONN2X20_20X7MM_PCI_EXT
J96CONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20CONN2X20_20X7MM_PCI_EXT
J97CONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20CONN2X20_20X7MM_PCI_EXT
J98CONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20CONN2X20_20X7MM_PCI_EXT
J101MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMA
J102MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMA
J103MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMA
J104MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMA
J105HDR_SHRD_2X1_HDR102_IO_9.45MM_2HDR 1X2HDR102
J107HDR_SHRD_2X1_HDR102_IO_9.45MM_2HDR 1X2HDR102
J110DDR3_240P_CON_240_DDR3_DIMM_SKTCON_240_DIMMCON_240_DDR3_DIMM_SKT
J111DDR3_240P_CON_240_DDR3_DIMM_SKTCON_240_DIMMCON_240_DDR3_DIMM_SKT
J200DDR3_240P_CON_240_DDR3_DIMM_SKTCON_240_DIMMCON_240_DDR3_DIMM_SKT
J201DDR3_240P_CON_240_DDR3_DIMM_SKTCON_240_DIMMCON_240_DDR3_DIMM_SKT
J202MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMA
J203MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMA
J204HDR_SHRD_2X1_HDR102_IO_9.45MM_2HDR 1X2HDR102
J216CONN_HDR_8X2_HDR208_B_IO_9.86MMCON_2X8HDR208_B
J217CONN_HDR_8X2_HDR208_B_IO_9.86MMCON_2X8HDR208_B
J218HDR_1X3_HDR1X3_TH_IO_12.04MM_21HDR 1X3HDR1X3_TH
J221CONN_HDR_3X2_HDR203_IO_8.58MM_2HDR_2X3HDR203
J223HDR-1X8_JUMP1X8-6040_IO_8.382MHDR_1X8JUMP1X8-6040
J224CON_2X15_HDR_CON30_2P54_8P81X38SSW-115-02-F-D-RACON30_2P54_8P81X38P61MM_C
J225ATX_12V_PWR_CONN8_CONN_2X4_165_CON 2X4CONN_2X4_165_TH
J226MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMA
J229MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMA
J230HDR_SHRD_2X1_HDR102_IO_9.45MM_2HDR 1X2HDR102
J231MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMA
J232HDR_SHRD_2X1_HDR102_IO_9.45MM_2HDR 1X2HDR102
J233CONN_HDR_2X1_HDR102_STAG_SM_IO_HDR_1X2HDR102_STAG_SM
J234CONN_HDR_2X1_HDR102_STAG_SM_IO_HDR_1X2HDR102_STAG_SM
L1ETQP6F_2P_IND2_410X311_DISCRETE175nHIND2_410X311
L2ETQP6F_2P_IND2_410X311_DISCRETE175nHIND2_410X311
L3ETQP6F_2P_IND2_410X311_DISCRETE175nHIND2_410X311
L4ETQP6F_2P_IND2_410X311_DISCRETE175nHIND2_410X311
L6COIL_IND_IHLP-5050_DISCRETE_6.50.33uHIND_IHLP-5050
L40INDUCTOR_IND_2016A_DISCRETE_1.810UHIND_2016A
L41INDUCTOR_IND_2016A_DISCRETE_1.810UHIND_2016A
L42INDUCTOR_IND_2016_DISCRETE_1.6M2.2UHIND_2016
L43IND_IND_0603_DISCRETE_1MM_180-760 OHM 100MHZIND_0603
L44DLW43_CHOKE_0805_DISCRETE_1.4MM90OHMCHOKE_0805
L45IND_IND_0603_DISCRETE_1MM_180-760 OHM 100MHZIND_0603
L46IND_IND_0603_DISCRETE_1MM_180-760 OHM 100MHZIND_0603
L47DLW43_CHOKE_0805_DISCRETE_1.4MM90OHMCHOKE_0805
L82BEAD_FERRITE_IND_0603A_DISCRE_1BLM18KG121TN1IND_0603A
P4RJ45_MAG_2X1_LED_CON_RJ45_2X1_MRJ45 13X2PORTSCON_RJ45_2X1_MAG_LED
Q1TRANS_NMOS_3P_TDSON_0P65_3P4X3PBSZ060NE2LSTDSON_0P65_3P4X3P4
Q2TRANS_NMOS_5P_TDSON_1P27_5P35X6CSD17312Q5TDSON_1P27_5P35X6P35
Q3TRANS_NMOS_5P_TDSON_1P27_5P35X6CSD17312Q5TDSON_1P27_5P35X6P35
Q4TRANS_NMOS_3P_TDSON_0P65_3P4X3PBSZ060NE2LSTDSON_0P65_3P4X3P4
Q5TRANS_NMOS_5P_TDSON_1P27_5P35X6CSD17312Q5TDSON_1P27_5P35X6P35
Q6TRANS_NMOS_5P_TDSON_1P27_5P35X6CSD17312Q5TDSON_1P27_5P35X6P35
Q7TRANS_NMOS_3P_TDSON_0P65_3P4X3PBSZ060NE2LSTDSON_0P65_3P4X3P4
Q8TRANS_NMOS_5P_TDSON_1P27_5P35X6CSD17312Q5TDSON_1P27_5P35X6P35
Q9TRANS_NMOS_5P_TDSON_1P27_5P35X6CSD17312Q5TDSON_1P27_5P35X6P35
Q10TRANS_NMOS_3P_TDSON_0P65_3P4X3PBSZ060NE2LSTDSON_0P65_3P4X3P4
Q11TRANS_NMOS_5P_TDSON_1P27_5P35X6CSD17312Q5TDSON_1P27_5P35X6P35
Q12TRANS_NMOS_5P_TDSON_1P27_5P35X6CSD17312Q5TDSON_1P27_5P35X6P35
Q13MOSFET_N_8P_TDSON8_1P27_6X5MM_IBSC080N03MSGTDSON8_1P27_6X5MM
Q14MOSFET_N_8P_TDSON8_1P27_6X5MM_IBSC080N03MSGTDSON8_1P27_6X5MM
Q15MOSFET_N_8P_TDSON8_1P27_6X5MM_1BSC020N03MSGTDSON8_1P27_6X5MM
Q16MOSFET_N_8P_TDSON8_1P27_6X5MM_1BSC020N03MSGTDSON8_1P27_6X5MM
Q17NPN_SOT23_IC_1.12MM_480-75757_MMMBT3904SOT23
RT1THERMISTOR_NTC_RC0805_OV_DISCRE6.8KRC0805_OV
SW9SW_DIP_8_SW_DIP16_8POS_SM_IC_2.218-8LPSTSW_DIP16_8POS_SM
SW11SW_TACT-SPST-2_SM_6_22X6_38_SW_DTSMW-69R-V-T/R6_22X6_38_SW
SW12SW_TACT-SPST-2_SM_6_22X6_38_SW_DTSMW-69R-V-T/R6_22X6_38_SW
SW13SW_TACT-SPST-2_SM_6_22X6_38_SW_DTSMW-69R-V-T/R6_22X6_38_SW
U1T4240_BGA1932_1MM_45X45MM_IC_3.T4240PSE1T1ABGA1932_1MM_45X45MM
U2OSC3_XTLOSC4_5X7_5_IC_1.55MM_2366.666MHzXTLOSC4_5X7_5
U6INA220AIDGST_MSOP_10_0P5_3X3_ICINA220AIDGSTMSOP_10_0P5_3X3
U7INA220AIDGST_MSOP_10_0P5_3X3_ICINA220AIDGSTMSOP_10_0P5_3X3
U8INA220AIDGST_MSOP_10_0P5_3X3_ICINA220AIDGSTMSOP_10_0P5_3X3
U9INA220AIDGST_MSOP_10_0P5_3X3_ICINA220AIDGSTMSOP_10_0P5_3X3
U10INA220AIDGST_MSOP_10_0P5_3X3_ICINA220AIDGSTMSOP_10_0P5_3X3
U22CBTL02043ABQ_20P_DHVQFN20_0P5_2CBTL02043ADHVQFN20_0P5_2P6X4P6
U31TPS51200_QFN_10_0P5_3X3_IC_1.0TPS51200QFN_10_0P5_3X3
U56ZL6105_QFN_36P_QFN36_0P5_6X6_ICZL6105QFN36_0P5_6X6
U76MAX811_SOT143-25X60_IC_1.22MM_MAX811SOT143-25X60
U77IC_ISL8201_QFN_15P_QFN15_15X15_ISL8204MIRZQFN15_15X15
U781G125_SC-70_IC_1.1MM_312-75240_SN74LVC1G125DCKRSC-70
U79IC_ISL8201_QFN_15P_QFN15_15X15_ISL8204MIRZQFN15_15X15
U80INA220AIDGST_MSOP_10_0P5_3X3_ICINA220AIDGSTMSOP_10_0P5_3X3
U83IC_ISL8201_QFN_15P_QFN15_15X15_ISL8204MIRZQFN15_15X15
U84100201_SO_10_SC70-5_IC_1.1MM_31SN74CBTLV1G125DCKRSC70-5
U85ADG804_MSOP10_60X12_IC_1.10MM_3ADG804YRMMSOP10_60X12
U92IC_ISL8201_QFN_15P_QFN15_15X1_1ISL8201MIRZQFN15_15X15
U93100201_SO_10_SC70-5_IC_1.1MM_31SN74CBTLV1G125DCKRSC70-5
U97PCA9547_24P_TSSOP24_0P65_7P9X4PPCA9547PWTSSOP24_0P65_7P9X4P5
U99ATMEL_SERIAL_EEPROM_64K-1_TSSOPAT24C02C-XHM-BTSSOP8
U101ATMEL_SERIAL_EEPROM_64K-1_TSSOPAT24C02C-XHM-BTSSOP8
U102DS3232S_SO20W_IC_2.67MM_315-767DS3232SO20W
U1031G125_SC-70_IC_1.1MM_312-75240_SN74LVC1G125DCKRSC-70
U104ADT7481_MSOP10_60X12_IC_1.10MM_ADT7481ARMZMSOP10_60X12
U1061G125_SC-70_IC_1.1MM_312-75240_SN74LVC1G125DCKRSC-70
U110SN74LVC_SOT-23-5_IC_1.45MM_312-SN74LVC1G86SOT-23-5
U111S29GL01GS_56P_TSOP56_IC_1.2MM_3S29GL01GS11TFI010TSOP56
U112CONN_HDR_25X2_CON_FTR-125-01-S-HDR_2X25CON_FTR-125-01-S-D
U113SN74LVC_SOT-23-5_IC_1.45MM_312-SN74LVC1G86SOT-23-5
U114SN74LVC_SOT-23-5_IC_1.45MM_312-SN74LVC1G86SOT-23-5
U115AT24CXX_TSSOP8_IC_1.2MM_334-756AT24C512C-XHD-BTSSOP8
U116AT24CXX_TSSOP8_IC_1.2MM_334-756AT24C512C-XHD-BTSSOP8
U120SN74CB3Q3253DGVR_TVSOP16_IC_1.2SN74CB3Q3253TVSOP16
U121SN74CB3Q3253DGVR_TVSOP16_IC_1.2SN74CB3Q3253TVSOP16
U138VSC8641_EP-100LQFP_LQFP100_0P4_VSC8641XKOLQFP100_0P4_12X12MM
U139VSC8641_EP-100LQFP_LQFP100_0P4_VSC8641XKOLQFP100_0P4_12X12MM
U230MT29F4G08ABBDAH4_VFBGA63_0P8_9XMT29F4G08ABBDAH4VFBGA63_0P8_9X11
U262A3PE1500-676P_FBGA676_1MM_27X27A3PE1500-FGG676FBGA676_1MM_27X27
U272IC_ISL8201_QFN_15P_QFN15_15X15_ISL8204MIRZQFN15_15X15
U274FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6P
U278SN74CB3Q3253DGVR_TVSOP16_IC_1.2SN74CB3Q3253TVSOP16
U279SN74CB3Q3253DGVR_TVSOP16_IC_1.2SN74CB3Q3253TVSOP16
U285SST25WF040_SO8_1P27_4X5_IC_1.75SST25WF040SO8_1P27_4X5
U287SN74CB3Q3257DGVR_TVSOP16_0P4_4XSN74CB3Q3257DGVRTVSOP16_0P4_4X3
U2928T49N222A_48P_QFN48_0P5_7X7_TAB8T49N222A-100NLGI8QFN48_0P5_7X7_TAB5P65
U293NC7WZ16_SC70-6_IC_0.95MM_312-75NC7WZ16SC70-6
U294NC7WZ16_SC70-6_IC_0.95MM_312-75NC7WZ16SC70-6
U295NC7WZ16_SC70-6_IC_0.95MM_312-75NC7WZ16SC70-6
U296FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6P
U297FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6P
U302PCA9521D_SO8_TSSOP8_A_IC_1.1MM_PCA9521DPTSSOP8_A
U303PCA9521D_SO8_TSSOP8_A_IC_1.1MM_PCA9521DPTSSOP8_A
U304NVT2003DP_TSSOP10_TSSOP10_0P5_3NVT2003DPTSSOP10_0P5_3X3MM
U305NVT2003DP_TSSOP10_TSSOP10_0P5_3NVT2003DPTSSOP10_0P5_3X3MM
U306NVT2003DP_TSSOP10_TSSOP10_0P5_3NVT2003DPTSSOP10_0P5_3X3MM
U307FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6P
U308FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6P
U315FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10P
U316FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10P
U317FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10P
U318TPS51200_QFN_10_0P5_3X3_IC_1.0TPS51200QFN_10_0P5_3X3
U320NC7SP08_SC70-5_A_IC_1.1MM_312-7NC7SP08SC70-5_A
U321LT3070_QFN28_4X5_EP_IC_0.8MM_31LT3070IUFDQFN28_4X5_EP
U322LT3070_QFN28_4X5_EP_IC_0.8MM_31LT3070IUFDQFN28_4X5_EP
U325IC_ISL8201_QFN_15P_QFN15_15X1_1ISL8201MIRZQFN15_15X15
U326100201_SO_10_SC70-5_IC_1.1MM_31SN74CBTLV1G125DCKRSC70-5
U327ISL8010X_DFN_10P_DFN10_0P5_3X3_ISL80103IRAJZDFN10_0P5_3X3
U333NC7WZ16_SC70-6_IC_0.95MM_312-75NC7WZ16SC70-6
U334NC7WZ16_SC70-6_IC_0.95MM_312-75NC7WZ16SC70-6
U3381G125_SC-70_IC_1.1MM_312-75240_SN74LVC1G125DCKRSC-70
U3391G125_SC-70_IC_1.1MM_312-75240_SN74LVC1G125DCKRSC-70
U340MAX4906ELB_0_DFN_10_0P4_2X2_MAXMAX4906FELB+DFN_10_0P4_2X2_MAXIM
U341TXS0206_BGA20_0P4_1P6X2_NSP_IC_TXS0206BGA20_0P4_1P6X2_NSP
U342TXS0206_BGA20_0P4_1P6X2_NSP_IC_TXS0206BGA20_0P4_1P6X2_NSP
U343LTC2912-2_TSOT23_8_0P65_2X1_IC_LTC2912CTS8-2TSOT23_8_0P65_2X1
U345LTC2912-2_TSOT23_8_0P65_2X1_IC_LTC2912CTS8-2TSOT23_8_0P65_2X1
U346LTC2912-2_TSOT23_8_0P65_2X1_IC_LTC2912CTS8-2TSOT23_8_0P65_2X1
U3516V31021NLGI8_MLF_20P_TQFN20_0P56V31021NLGI8TQFN20_0P5_4X4MM
U3526V31021NLGI8_MLF_20P_TQFN20_0P56V31021NLGI8TQFN20_0P5_4X4MM
U3536V31021NLGI8_MLF_20P_TQFN20_0P56V31021NLGI8TQFN20_0P5_4X4MM
U3546V31021NLGI8_MLF_20P_TQFN20_0P56V31021NLGI8TQFN20_0P5_4X4MM
U355PCA9547_24P_TSSOP24_0P65_7P9X4PPCA9547PWTSSOP24_0P65_7P9X4P5
U358IDT840NT4_48P_QFN48_0P5_7X7_TABIDT840NT4-01AKQFN48_0P5_7X7_TAB5P65
U359ISL6334IRZ_QFN_40P_QFN40_0P5_6PISL6334DCRZQFN40_0P5_6P1X6P1
U360ISL6620CR_DFN10_DFN10_0P5_3X3_IISL6620CRDFN10_0P5_3X3
U361ISL6620CR_DFN10_DFN10_0P5_3X3_IISL6620CRDFN10_0P5_3X3
U362ISL6620CR_DFN10_DFN10_0P5_3X3_IISL6620CRDFN10_0P5_3X3
U363ISL6620CR_DFN10_DFN10_0P5_3X3_IISL6620CRDFN10_0P5_3X3
U3648T49N222A_48P_QFN48_0P5_7X7_T_18T49N222A-101NLGI8QFN48_0P5_7X7_TAB5P65
U3658T49N222A_48P_QFN48_0P5_7X7_TAB8T49N222A-100NLGI8QFN48_0P5_7X7_TAB5P65
U3672-INPUT_OR_SC70-5_IC_1.1MM_312-NC7SZ32P5XSC70-5
U368NC7SZ14_SC70-5_A_IC_1.1MM_312-NC7SZ14SC70-5_A
U3692-INPUT_OR_SC70-5_IC_1.1MM_312-NC7SZ32P5XSC70-5
U3712-INPUT_OR_SC70-5_IC_1.1MM_312-NC7SZ32P5XSC70-5
U3722-INPUT_OR_SC70-5_IC_1.1MM_312-NC7SZ32P5XSC70-5
U37374-16210_48P_TVSOP48_IC_1.2MM_3SN74CB3Q16210DGVRTVSOP48
U37474-3245_20P_TSSOP20_IC_1.2MM_374CB3Q3245TSSOP20
U37574-16210_48P_TVSOP48_IC_1.2MM_3SN74CB3Q16210DGVRTVSOP48
U37674-16210_48P_TVSOP48_IC_1.2MM_3SN74CB3Q16210DGVRTVSOP48
U381ICS557_08_TSSOP16_IC_1.2MM_312-6V31023PGGI8TSSOP16
U382LTC2804_SSOP16_SSOP16_4P8X3P8MMLTC2804-1SSOP16_4P8X3P8MM
U383LTC2804_SSOP16_SSOP16_4P8X3P8MMLTC2804-1SSOP16_4P8X3P8MM
U384NC7SZ14_SC70-5_A_IC_1.1MM_312-NC7SZ14SC70-5_A
U3852076_2_8P_SOP8-1_IC_1.73MM_312-MIC2076-1YMSOP8-1
U386RCCLAMP_SLP1616P6_IC_0.65MM_312RCLAMP0504P.TCTSLP1616P6
U387RCCLAMP_SLP1616P6_IC_0.65MM_312RCLAMP0504P.TCTSLP1616P6
U388VSC3316XJK_196P_BGA196_1P0_15X1VSC3316XYPBGA196_1P0_15X15_C019
U389VSC3316XJK_196P_BGA196_1P0_15X1VSC3316XYPBGA196_1P0_15X15_C019
U390840NT4_48P_QFN48_0P5_7X7_TAB5P6IDT840NT4QFN48_0P5_7X7_TAB5P65
U391FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6P
U392NC7WZ16_SC70-6_IC_0.95MM_312-75NC7WZ16SC70-6
U395FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10P
U396FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10P
U397FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10P
U398FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10P
U399FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10P
U400FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10P
U4018535_31_TSSOP_20P_TSSOP20_IC_1.8535AGI-31LFTTSSOP20
U4028535_31_TSSOP_20P_TSSOP20_IC_1.8535AGI-31LFTTSSOP20
U4038T49N222A_48P_QFN48_0P5_7X7_T_18T49N222A-101NLGI8QFN48_0P5_7X7_TAB5P65
U404871S1022EK_QFN32_QFN32_S134EP_I871S1022EKLFTQFN32_S134EP
U405AT24CXX_TSSOP8_IC_1.2MM_334-756AT24C512C-XHD-BTSSOP8
U406TXB0104PWRG4_TSSOP14_IC_1.2MM_3TXB0104PWRG4TSSOP14
U407TXB0104PWRG4_TSSOP14_IC_1.2MM_3TXB0104PWRG4TSSOP14
U408FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6P
U409FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6P
U410NC7SB3157_6P_MICROPAK_6P_IC_0.5NC7SB3157L6XMICROPAK_6P
U411MTFC4GGQDQ_LBGA_100P_LBGA100_1MN2M400FDB311A3CFLBGA100_1MM_14X18
U412TXB0104PWRG4_TSSOP14_IC_1.2MM_3TXB0104PWRG4TSSOP14
U413SN74CB3Q3257DGVR_TVSOP16_0P4_4XSN74CB3Q3257DGVRTVSOP16_0P4_4X3
U414FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6P
U415FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6P
U4181G125_SC-70_IC_1.1MM_312-75240_SN74LVC1G125DCKRSC-70
U419LT3070_QFN28_4X5_EP_IC_0.8MM_31LT3070IUFDQFN28_4X5_EP
U420LT3070_QFN28_4X5_EP_IC_0.8MM_31LT3070IUFDQFN28_4X5_EP
U421NL17SZ126_SC-70_IC_1.1MM_312-80NC7SV126SC-70
U422NL17SZ126_SC-70_IC_1.1MM_312-80NC7SV126SC-70
U4231G125_SC-70_IC_1.1MM_312-75240_SN74LVC1G125DCKRSC-70
VDD_CORE_PL1TESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT REDTEST_LOOP
XU1N25Q512A11GSF40X_SO16W_IC_2.65MN25Q512A11GSF40FSO16W
XU2EN25S64_8P_SO8_W_IC_1MM_342-005EN25S64SO8_W
Y1XTAL_HC49SDLF_IC_4.5MM_230-778720.1416MHZHC49SDLF
Y2XTAL_HC49SDLF_IC_4.5MM_230-778720.1416MHZHC49SDLF
Y3XTAL_HC49SDLF_IC_4.5MM_230-778720.1416MHZHC49SDLF
Y4CRYSTAL_JXS63_XTLOSC4_5X3MM_SM_25MHZXTLOSC4_5X3MM_SM
Y9XTAL_13Y_XTAL_4_7P2X5P2_IC_1.3M25MHZXTAL_4_7P2X5P2
重要提示:PCB作品文件展下载说明
老吴 | 2019-4-14 21:09:06 | 显示全部楼层
PCB 原理图一起打包,5个金币。
Layout_Sche.7z (15.37 MB, 下载次数: 93)
T4240PB.pdf
999 KB, 下载次数: 2, 下载积分: 金币 -5 枚
T4240QDS QIXIS FPGA HDL Code (NDA Required).zip
214 KB, 下载次数: 2, 下载积分: 金币 -5 枚
T4240QDS Reference Manual V8.9_130225.pdf
2.78 MB, 下载次数: 2, 下载积分: 金币 -5 枚
T4240QDS_disclaimer_Proto3_121016.pdf
32 KB, 下载次数: 0, 下载积分: 金币 -5 枚
T4240QDS_disclaimer_Proto4_1212.pdf
37 KB, 下载次数: 0, 下载积分: 金币 -5 枚
T4240QDS_Packing_List_130313.pdf
18 KB, 下载次数: 0, 下载积分: 金币 -5 枚
T4240QDS_QSG_Proto4_r1.4_121203.pdf
1.35 MB, 下载次数: 0, 下载积分: 金币 -5 枚
T4240QDS_RM_V9.1_130604.pdf
2.82 MB, 下载次数: 0, 下载积分: 金币 -5 枚
T4240QDSFS.pdf
437 KB, 下载次数: 0, 下载积分: 金币 -5 枚
T4240QDSQSG.pdf
4.11 MB, 下载次数: 0, 下载积分: 金币 -5 枚
T4240RDBQS.pdf
2.27 MB, 下载次数: 0, 下载积分: 金币 -5 枚
T4240T4160FS.pdf
310 KB, 下载次数: 0, 下载积分: 金币 -5 枚
shyoung | 2019-4-14 21:12:50 | 显示全部楼层
Re:20层Freescale T4240QDS vxworks7.0 24核 PowerPC 开发板 PCB和原理图
老吴太猛了!那个Vxwork7能不能共享一下?
地沟油 | 2019-4-14 21:30:11 | 显示全部楼层
yhgwork | 2019-4-14 22:02:17 | 显示全部楼层
tylh | 2019-4-14 22:04:24 | 显示全部楼层
zhifang88 | 2019-4-14 22:42:09 | 显示全部楼层
单枪舞九州 | 2019-4-15 07:30:52 | 显示全部楼层
十月的皮皮 | 2019-4-15 07:47:36 | 显示全部楼层
longxuekai | 2019-4-15 08:07:26 | 显示全部楼层
学习学习哦,好东西
