REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
BP1 | SWITCH2_A06-H-E_138_SWITCH | Switch | A06-H-E_138 |
BP2 | SWITCH2_A06-H-E_138_SWITCH | Switch | A06-H-E_138 |
CON1 | SODIMM_3_CONN200_1612618-4 | 1612618-4 | CONN200 |
CON2 | RJ12_RJ6-RZ2_MJM0606GE06-H | MJM0606GE06-H | RJ6-RZ2 |
CON3 | RJ12_RJ6-RZ2_MJM0606GE06-H | MJM0606GE06-H | RJ6-RZ2 |
D1 | SCH_DUAL_SOT23_SOT23_BAT54CLT1G | BAT54CLT1G | SOT23 |
D2 | LED_D0805_RED | Red | D0805 |
D3 | MMBD3004S_SOT23_MMBD3004S-7-F | MMBD3004S-7-F | SOT23 |
D4 | TVB200SC-L_F6127_TB3100M-13-F | TB3100M-13-F | F6127 |
D5 | MMBD3004S_SOT23_MMBD3004S-7-F | MMBD3004S-7-F | SOT23 |
D6 | TVS_0_SOT23_LM4040BIM3-3.0+T | LM4040BIM3-3.0+T | SOT23 |
D7 | LED_D0805_RED | Red | D0805 |
D8 | LED_D0805_RED | Red | D0805 |
J1 | HD2X20_CONN40_HD2X20-HH | HD2X20-HH | CONN40 |
J2 | HD2X20_CONN40_HD2X20-HH | HD2X20-HH | CONN40 |
J3 | HD2X20_CONN40_HD2X20-HH | HD2X20-HH | CONN40 |
J4 | DC POWERJACK_CON_3_WDC001_575_ | DC POWER JACK | CON_3_WDC001_575 |
J5 | BATTERYHOLDER_PILE_KEYSTONE_300 | BatteryHolder | PILE_KEYSTONE_3000_DIA12MM0 |
J6 | PJS008-2110-0_MICRO_SD_PJS008_P | PJS008-2110-0 | MICRO_SD_PJS008 |
J7 | 7SDCN-X0-X101-F_7SDCN_7SDCN-B0- | 7SDCN-B0-0101-F | 7SDCN |
J8 | DSUB9_M_SUBD9M_DB9M_R | DB9M_R | SUBD9M |
J9 | HDR_2X10_TH_BR20_BR20-H | BR20-H | BR20 |
J10 | HE10_HR2X5_HD2X05 | HD2X05 | HR2X5 |
J11 | DSUB9_M_SUBD9M_DB9M_R | DB9M_R | SUBD9M |
J12 | DSUB9_M_SUBD9M_DB9M_R | DB9M_R | SUBD9M |
J13 | STEREOCMS_CON_JACK_KLBR-4J_STE | STEREO_3.5mm | CON_JACK_KLBR-4J |
J15 | STEREOCMS_CON_JACK_KLBR-4J_STE | STEREO_3.5mm | CON_JACK_KLBR-4J |
J16 | RJ12_RJ6-RZ2_MJM0606GE06-H | MJM0606GE06-H | RJ6-RZ2 |
J17 | J0026D21PULSE_0_RJ45_PULSE_J00 | J0026D21B | RJ45_PULSE |
J18 | J0026D21PULSE_0_RJ45_PULSE_J00 | J0026D21B | RJ45_PULSE |
J19 | CCUSBA-32002-30X_0_CON_8_USB_A_ | USB-A-D-S-W-TH-R | CON_8_USB_A_610 |
J20 | USB_MICROAB_USBCONN_5SM_315X217 | G3515-09010101-00 | USBCONN_5SM_315X217_118 |
J21 | TSW_2X15_DIP_RA_CONN30_ESW-115- | ESW-115-33-L-D | CONN30 |
J22 | BCS_2X20_DIP_RA_CONN40_ESW-120- | ESW-120-33-L-D | CONN40 |
JP1 | SIP3-DROIT_BAR3PTS02_SIP3 | SIP3 | BAR3PTS02 |
JP2 | SIP3-DROIT_BAR3PTS02_SIP3 | SIP3 | BAR3PTS02 |
JP3 | SIP3-DROIT_BAR3PTS02_SIP3 | SIP3 | BAR3PTS02 |
JP13 | SIP2_BAR2PTS02_SIP2 | SIP2 | BAR2PTS02 |
JP14 | SIP3-DROIT_BAR3PTS02_SIP3 | SIP3 | BAR3PTS02 |
L9 | BEAD_FERRITE_R0805_220OHM AT 1 | 220ohm at 100MHz | R0805 |
L10 | BEAD_FERRITE_R0805_2200R | 2200R | R0805 |
L11 | BEAD_FERRITE_R0805_2200R | 2200R | R0805 |
L21 | BEAD_FERRITE_R0805_220OHM AT 1 | 220ohm at 100MHz | R0805 |
MN1 | ZEN056V130A24LS_ZEN056V130A24LS | ZEN056V230A16LS | ZEN056V130A24LS |
MN2 | BNX002-01_0_CONN6-EMI_BNX002-01 | BNX002-01 | CONN6-EMI |
MN3 | RT9018A_1_SOP_8__50_154X193_69_ | RT9018A | SOP_8__50_154X193_69 |
MN4 | ADM3312EARU_SOP24-26-173_ADM331 | ADM3312EARU | SOP24-26-173 |
MN5 | SN65HVD234_SOP8-50-150A_SN65HVD | SN65HVD234DR | SOP8-50-150A |
MN6 | SN65HVD234_SOP8-50-150A_SN65HVD | SN65HVD234DR | SOP8-50-150A |
MN8 | ADM3222_SOP18-50-300_ADM3222ARW | ADM3222ARW | SOP18-50-300 |
MN9 | ADM3312EARU_SOP24-26-173_ADM331 | ADM3312EARU | SOP24-26-173 |
MN10 | WM8731_0_SSOP_28_026_220X400_78 | WM8731SEDS | SSOP_28_026_220X400_78 |
MN11 | CX20548-11Z_QFN16_CX20548-11Z | CX20548-11Z | QFN16 |
MN12 | DM9161AE_0_JEDEC_MS026_BBC_LQFP | DM9161AEP | JEDEC_MS026_BBC_LQFP7X7_48 |
MN13 | DM9161AE_0_JEDEC_MS026_BBC_LQFP | DM9161AEP | JEDEC_MS026_BBC_LQFP7X7_48 |
MN14 | SP2526A-SO8_SOP8_244_0500_069_A | AIC1526-0GS | SOP8_244_0500_069 |
MN15 | SP2526A-SO8_SOP8_244_0500_069_A | AIC1526-0GS | SOP8_244_0500_069 |
MN16 | DS2431_SOP6-50-150_DS2431P | DS2431P | SOP6-50-150 |
MN17 | 74AC244SC_74AC244SC_74AC244SC | 74AC244SC | 74AC244SC |
MN18 | SN74AVC8T245PWR_0_SN74AVC8T245P | SN74AVC8T245PWR | SN74AVC8T245PWR |
MN19 | SN74LVC1G126DBV_SN74LVC1G126_SN | SN74LVC1G126DBV | SN74LVC1G126 |
Q1 | SI1563EDH_SOT-363_SI1563EDH | Si1563EDH | SOT-363 |
Q2 | MMBAT42_1_SOT23_MMBAT42 | MMBAT42 | SOT23 |
Q3 | MMBAT42_0_SOT23_MMBAT42 | MMBAT42 | SOT23 |
Q4 | MMBAT42_2_SOT23_MMBAT42 | MMBAT42 | SOT23 |
Q5 | MMBAT42_3_SOT23_MMBAT42 | MMBAT42 | SOT23 |
Q6 | NMOS_SOT23T02_IRLML2402 | IRLML2402 | SOT23T02 |
RR18 | RN0402_RN0402_22R | 22R | RN0402 |
TX1 | LAN0061-00_0_LAN0019_LAN0066-50 | LAN0066-50 | LAN0019 |
Y1 | OSCILLATOR_OSC4SM_126X98_039_50 | 50MHz | OSC4SM_126X98_039 |
Y2 | OSCILLATOR_OSC4SM_126X98_039_50 | 50MHz | OSC4SM_126X98_039 |
Y3 | CRYSTAL_4PIN_7B12200028_12.288M | 12.288MHz | 7B12200028 |
