TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 20878
Name | PCB Decal | Value | Part Type | CB1 | C0603 | 0.1u/NC | CAP_NP_0 | CB2 | C0603 | 0.1u/NC | CAP_NP_2 | CN1 | VGAS-3 | VGA | VGA | CN2 | PHONEJACK2 | PHONE_JACK_STEREO_SW | PHONEJACK_STEREO_SW_0 | CN3 | CN4-20A | 4P_2.0mm | CON4_2 | CN4 | HDMI19P | CONHDMI | SMD_HDMI_CON-HDMI | CN7 | SCART | SCART/NC | SCART | CN8 | CN8-20A | CON8_2.0 | HEADER_15_1 | CN102 | POWER | DC-005/NC | DC_JACK_0 | CON1 | CON18X2-2.0 | DIP-36(2*18) | DIP-36(2_18) | CON5 | CN10-20A | CON10_2.0/CON6_2.0 | CON10 | CON6 | FPC50P-0.5 | NC/FPC50 | HEADER_20X2_0 | CON7 | CN4-20A | CON4_2.0 | CON9_0_2 | CON10 | CN2-20A | CON2-2.0/NC | CON4_0 | CON16 | CN9-20A | CON9_2.0/NC | CON9 | D1 | SOT-23 | BAT54C | BAS70-04/SOT_0 | D5 | D4148 | C33V1 | DIODE_ZENER1 | D6 | D4148 | 1N4148 | DIODE | D10 | SOT-23 | BAV99 | BAV99_3 | D11 | D4148 | 8.2V | DIODE_SCHOTTKY | D66 | D4148 | BA277 | DIODE | D98 | 1N4001 | 1N4001 | DIODE_2 | D100 | SK34A | SK34A/NC | DIODE_SCHOTTKY_1 | D101 | SK34A | SK34A | DIODE_SCHOTTKY_3 | F100 | FUSEA125 | 5A/105V/JUMPER/NC | FUSE_0 | FB1 | L0603 | 600R | SMD_BEAD_FB0603 | FB2 | L0603 | 600R | SMD_BEAD_FB0603 | FB4 | L0603 | 600R | SMD_BEAD_FB0603 | FB5 | L0603 | 600R | SMD_BEAD_FB0603 | FB6 | L0603 | 600R | SMD_BEAD_FB0603 | FB7 | L0603 | 600R | SMD_BEAD_FB0603 | L1 | L0603 | FB/10uH/NC | INDUCTOR_4 | L7 | L-POWER | 15uH/NC | INDUCTOR_IRON_1 | L8 | L-POWER | 15uH | INDUCTOR_IRON_1 | L16 | L1206 | FB | INDUCTOR | L18 | R7.5MM | 200uH | INDUCTOR | L22 | L0603 | FB/NC | INDUCTOR_4 | L29 | L0603 | 0 | INDUCTOR_4 | L34 | L1210 | FB/1206 | INDUCTOR/SM | L83 | L1206 | FB/220_500MA | INDUCTOR | L100 | L-1210-W | FB/1210/NC | INDUCTOR_6 | L104 | R-1206 | 0ohm/1206 | INDUCTOR_6 | L105 | R-1206 | 0ohm/1206/NC | INDUCTOR_6 | L505 | L0603 | FB/NC | INDUCTOR/SM | L506 | L0603 | FB | INDUCTOR/SM | L507 | L0603 | FB/NC | INDUCTOR/SM | L508 | L0603 | FB | INDUCTOR/SM | M1 | SOT-23GSD | 2N7002/NC | SMD_NMOS_SOT-23DGS | P2 | AV-3 | RCA_3 | AVIN_7 | P4 | PHONE4 | PJ-325B | PHONEJACK_STEREO_SW_0 | P6 | SVIDEO | S-VIDEO-Jack | S-JACK_3 | P7 | RCA | RCA_AV | CON-AV | P8 | RCA | RCA_AV | CON-AV | P9 | RCA | RCA_AV | CON-AV | Q1 | SOT-23 | 2N3904 | SMD_NPNBJT_SOT-23A | Q12 | SOT-23 | 3904 | NPN(BEC)_0 | Q13 | TO-92E | 3904 | 2SC1815 | Q15 | SOT-23 | 3904 | NPN(BEC)_0 | Q17 | SOT-23 | 3904/NC | NPN(BEC)_0 | Q18 | SOT-23 | 3904 | NPN(BEC)_0 | Q19 | SOT-23 | 3906/NC | PNP(BEC)_0 | Q20 | SOT-23 | 3904/NC | 2N1070_0 | Q25 | SOT-23 | 3906 | PNP(BEC)_0 | Q26 | SOT-23 | 2N3904 | SMD_NPNBJT_SOT-23A | Q27 | SOT-23 | BT3904 | NPN(BEC)_0 | Q28 | SOT-23 | 3904/NC | NPN(BEC)_0 | Q29 | SOT-23 | 3904/NC | NPN(BEC)_0 | Q30 | SOT-23 | 3904 | 2N1070_1 | Q31 | SOT-23 | 2N3904 | SMD_NPNBJT_SOT-23A | Q32 | SOT-23 | 3906/NC | PNP(BEC)_0 | Q44 | SOT-23 | 3904 | 2N1070_0 | Q208 | SOT-23 | AO3401 | MOSFET_P_GSD_8 | Q601 | SOT-23 | 3904 | 2SC1815_0 | RP1 | RES-4 | 33R | SMD_RESISTOR_ARRAY_1 | RP10 | RES-4 | 33R | SMD_RESISTOR_ARRAY_1 | RP12 | RES-4 | NC | SMD_RESISTOR_ARRAY_1 | T12 | TP | TP-0_8MM | TP-0_8MM | U1 | TSSOP16-225-0.65 | P15V330/NC | P15V330_0 | U2 | SOP8-225-50 | AT24C04 | AT24C21 | U3 | SOP8-225-50 | 24C04 | SMD_EEPROM_SO8 | U7 | TUNER-2 | TUNER_IF | TUNER_IF_3 | U8 | TO-263/3 | AP1084-ADJ | TO-220_0 | U16 | QFP128-1420-0.5 | MST719 | MST719 | U17 | SOP8-225-50 | 24C32 | SMD_EEPROM_SO8 | U18 | SOP8-225-50 | EN25F40_100GCP | SMD_SPIFLASH_8P_SOPL-200 | U19 | SOP8-225-50 | 24C04/NC | 24C08 | U22 | SOP16-225-50 | 74HC4052/NC | 74HC4052 | U23 | SOIC8 | CS4334 | 24CXX_1 | U24 | SOP28-375-50 | R2S15908 | R2S15900_0 | U25 | SAWFB1 | D9650H | AD9630/SO_1 | U26 | SOIP_24 | R2S10407 | R2S10401_IF | U27 | TO252_LM7805 | LM7805_TO252_1.5A | TO-220_0_2 | U29 | SAWFB1 | K3953D | AD9630/SO_5 | U100 | SOP-8 | IRF7314/NC | SI9433_0 | U102 | SOP-8 | EC9410CNF/NC | M24CXX_0 | U103 | SOP-8 | EC9410CNF | M24CXX_2 | U601 | TPA1517-TI | TDA1517P or BL6217 | TDA1517-1_0 | U604 | QFP44-1010-0.8 | MSP34X5/NC | MSP34X5_10 | Y3 | XTAL\HC49\F | 12MHZ | CRYSTAL_0 | Y4 | XTAL\HC49\F | 18.432MHZ/NC | CRYSTAL_0 | Y5 | XTAL\HC49\F | 4MHz | CRYSTAL_1 | ZD20 | L0603 | EZJZ1V80010 | SMD_CDS2C5HDMI_L0402 | ZD21 | L0603 | EZJZ1V80010 | SMD_CDS2C5HDMI_L0402 | ZD22 | L0603 | EZJZ1V80010 | SMD_CDS2C5HDMI_L0402 | ZD23 | L0603 | ESD/NC | SMD_CDS2C5HDMI_L0402 | ZD24 | D0603 | EZJZ1V270RA | HDMI_DIODE_ZENER_0 | ZD25 | D0603 | ESD/NC | HDMI_DIODE_ZENER_0 | ZD26 | D0603 | EZJZ1V270RA | HDMI_DIODE_ZENER_0 | ZD27 | D0603 | EZJZ1V270RA | HDMI_DIODE_ZENER_0 | ZD28 | D0603 | EZJZ1V270RA | HDMI_DIODE_ZENER_0 | ZD29 | D0603 | EZJZ1V270RA | HDMI_DIODE_ZENER_0 | ZD31 | D0603 | EZJZ1V270RA | HDMI_DIODE_ZENER_0 | ZD32 | D4148 | 5.6V/NC | SMD_ZENER_DIODE_D-SOD87 | ZD34 | L0603 | EZJZ1V270RA | SMD_CDS2C5HDMI_L0402 | ZD35 | L0603 | EZJZ1V270RA | SMD_CDS2C5HDMI_L0402 | ZD36 | L0603 | EZJZ1V270RA | SMD_CDS2C5HDMI_L0402 | ZD37 | L0603 | EZJZ1V270RA | SMD_CDS2C5HDMI_L0402 | ZD38 | L0603 | ESD/NC | SMD_CDS2C5HDMI_L0402 | ZD39 | L0603 | EZJZ1V270RA | SMD_CDS2C5HDMI_L0402 |
