[Pads_VX.2x] 工业海事用的一个主板PCB和原理图
查看9451 | 回复67 | 2019-10-29 17:07:29 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePart TypePCB DecalValue
AC1CAP_NP_4SMC0603330PF-0603
AC2CAP_NP_4SMC0603330PF-0603
AC3CAP_NP_4SMC0603330PF-0603
AD1DIODE_SCHOTTKY_11N5817-SMT1N5819-SMT
AD2DIODE_SCHOTTKY_11N5817-SMT1N5819-SMT
AR1R_7SMR060330K-0603
AR2R_7SMR060310K-0603
AR3R_7SMR060315K-0603
AR4R_7SMR060315K-0603
AR5R_7SMR060351K-0603
AR6R_7SMR060330K-0603
AU1LT1940DIP16-TSSOPLT1940
C1CAPACITOR_POLB-CASE47UF-10V-B
D1LED_3LED-SMTRED LED-SMT
D2LED_3LED-SMTRED LED-SMT£¨NC£©
D3DIODE_ZENER_1DIODE-589AD589JR-SOP8
D4DIODE_01N4148-SMT1N4148-SMT
D5DIODE_01N4148-SMT1N4148-SMT
D6DIODE_SCHOTTKY_11N5817-SMT1N5819-SMT
D7DIODE_01N4148-SMT1N4148-SMT(NC)
D8DIODE_01N4148-SMT1N4148-SMT(NC)
D9DIODE_01N4148-SMT1N4148-SMT(NC)
D10DIODE_01N4148-SMT1N4148-SMT(NC)
D11DIODE_0_21N5817-SMT1N4005-SMT(NC)
D20LED_4LED-SIP3RED-GREEN/D3
D26DIODE_SCHOTTKY_1SMCDIODEMMSZ4679T1
D27DIODE_SCHOTTKY_1SMCDIODEMMSZ4679T1
D28DIODE_01N4148-SMT1N4148-SMT
D29DIODE_01N4148-SMT1N4148-SMT
D31DIODE_SCHOTTKY_11N5817-SMT1N5819-SMT
D32DIODE_SCHOTTKY_11N5817-SMT1N5819-SMT
D33DIODE_SCHOTTKY_11N5817-SMT1N5819-SMT
D271DIODE_21SV2421SV242
D272DIODE_01N4148-SMT1N4148-SMT
D273DIODE_01N4148-SMT1N4148-SMT
D274DIODE_01N4148-SMT1N4148-SMT
D275DIODE_01N4148-SMT1N4148-SMT
D276DIODE_01N4148-SMT1N4148-SMT
D277DIODE_01N4148-SMT1N4148-SMT
D?DIODE_SCHOTTKY_11.5KE24A1N5408
D?DIODE_SCHOTTKY_11.5KE24ASB360
F1FUSE_2FUSE-SMTFUSE-2.0A-1812
F2FUSE_2FUSE-SMTFUSE-2.0A-1812
FIX1HEADER_4_1TP-100X200TP
FIX7HEADER_4_1TP-100X200TP
FIX8HEADER_4_1TP-100X200TP
J1RKJXM_1RKJXM-8SRKJXM
J2CON3PAD3-2.5CON3 NC
J3HEADER_4_1PAD2.0TP
J4HEADER_4ZIFF4-1.0-LFPC1.0S-6S-4PWB-UP
J19UP_CONN_2CON4-USB-SUSB
J26HEADER_4_1PAD2.0TP
J27HEADER_4_1PAD2.0TP
J33CON3_4CON-POWER-SCON3
J34HEADER_30_3ZIFF30-0.5MMZIFF30-0.5MM
J270CON3_7SIP6-2.0CON6  NC
J?RKJXM_1RKJXM-8SRKJXM
J?HEADER_4_10MINIRCAST001
J?CON3_4CON-POWER-SCON3
J?UP_CONN_2CON4-USB-SUSB
JCF1HEADER_30_7CF-CARD1ZIFF50-0.5MM
JP6HEADER_4_10MINIRCAST001
JP8HEADER_4_4LCDH4-1KHI1240-00B-040105
JP9HEADER_4_9MINIRCAST001
JP10HEADER_4_9MINIRCAST001
L1INDUCTORL-1206BEAD-1206
L3INDUCTORL-1206BEAD-1206
L4INDUCTORL-1206BEAD-1206
L7INDUCTORL-2P7\S22UH/SMTDRS0732-470M
L8INDUCTORL-2P7\S22UH/SMTDRS0732-470M
L9INDUCTORL-2P6.0SMTDRRI0402-220M(3L)
L14INDUCTORL-1206BEAD-1206
L15INDUCTORL-1206BEAD-1206
L16INDUCTORL-1206BEAD-1206
L17INDUCTORL-1206BEAD-1206
L18INDUCTORL-1206BEAD-1206
L24INDUCTOR_2L-1206BEAD-1206
L25INDUCTORL-2P7\S22UH/SMTDRS0732-470M
L28INDUCTOR_2L-1206BEAD-1206
L29INDUCTORL-1206BEAD-1206
L31INDUCTORL-1206BEAD-1206
L32INDUCTOR_233UH-4A33UH-4A
L101INDUCTOR_2LMH1.6mH-LMH(NC)
L268INDUCTORL-2P6.0SMTDRRI0402-220M(3L)
L269INDUCTORL-2P6.0SMTDRRI0402-220M(3L)
L270INDUCTORL-080547UH-0805/SMI-201212-470K
L271INDUCTORL-080533UH-0805/SMI-201212-330K
L272XC6383A501PR_1L/CP-4LBK5S-4.8UH+->12%(3L)
L?INDUCTOR_233UH-4A33UH-4A
L?INDUCTORSL1012T-151K-B
LA1INDUCTOR_2L-1206BEAD-1206(NC)
LA2INDUCTOR_2L-1206BEAD-1206(NC)
LA3INDUCTOR_2L-1206BEAD-1206(NC)
LA4HEADER_4_1ANTNNATP1(NC)
LA5INDUCTOR_2L06033.6nH(NC)
LA6INDUCTOR_2L060322nH(NC)
LA7INDUCTOR_2L-1206BEAD-1206
LA8INDUCTOR_2L-1206BEAD-1206
LA9INDUCTOR_2L-1206SMB-321609-F1-500P
LA10INDUCTOR_2L-1206BEAD-1206
LA11INDUCTOR_2L-1206SMB-321609-F1-500P
LD1INDUCTORL2P-SMD10UH10UH/SMD-453232-100K
LD2INDUCTORL-1206BEAD-1206
LD3HEADER_4_1FI-10TP
LD4HEADER_4_1FI-10TP
LS1CON3_5SIP2-2.0CON3/NC
LS2CON3_5SIP2-2.0A1500WV-2P
LS20SPEAKER_2A1500WV-2PFM0040-022-0-1W
MK?MICROPHONEMICROPHONE
Q1MOSFET_N_0_22N70022N7002
Q2HEADER_4_1REFTP
Q4MOSFET_N_0_22N70022N7002
Q5MOSFET_P_4SOT-89XP162A12A6PR
Q6LM7805CT_10SOT-8978L05-SOT89
Q7MOSFET_N_0_22N70022N7002
Q8MOSFET_N_0_22N70022N7002
Q10HEADER_4_1REFTP
Q11HEADER_4_1REFTP
Q18MOSFET_P_7XP162A12A6PR
Q19MOSFET_N_0_22N7002
Q20MOSFET_N_0_22N7002
Q270MOSFET_N_0_22N70022N7002
Q271MOSFET_N_0_22N70022N7002
Q272PNP_02N3906-SMT2N3906-SMT
Q273NPN_02N3904-SMT2N3904-SMT
Q274NPN_02N3904-SMT2N3904-SMT
Q?MOSFET_N_0TO-252FDB6030L
Q?MOSFET_N_0_22N7002
S2SW_PUSHBUTTON_0TD-06XA-YTD-06XA-Z
U1EP9312EP9312EP9312
U228F800CV_T_0SMT-SOP2-56E28F320J3A-110
U3SDRAM_1SMT-SOP2-54HY57V561620T-HI
U4SDRAM_1SMT-SOP2-54HY57V561620T-HI
U528F800CV_T_0SMT-SOP2-56E28F320J3A-110
U9CS4202CS4202CS4202
U1374HCT04_0DIP14-MTCSN74LCX14MTCX
U14XC6383A501PR_2SOT23-5XC6366B103MR
U16NJM2073SOP8\225NJM2073
U17NFR2401NRF2401NFR2401(NC)
U19IR3Y31MCC48\PQFPIR3Y31M-PQFP
U20QFP-64_0LQFP64PVI-1004D/PQFP
U21LM833MSOP8LM8272-MSOP
U22ELM9827AA_0SOT23-3LM3480IM3-3.3
U25AIC1563SOP8\225AIC1563-SOP
U221AIC1563_1NC7SPU04NC7SPU04P5X(NC)
U270NFR2401_2TQFP32ATMegaL8
U290AIC1563_0SOP8\225MAX708CSA
U29114053_1SOP16\22574HC4053-SOP
U292XC6383A501PR_4SOT23-5BU4S81-SOT23
U29314053_1SOP16\22574HC4053-SOP
U?AIC1563AIC1563-SOP
U?BIT3105_1BIT3107LM5005MH
U?DIODE_SCHOTTKY_11N5819-SMT
UD1ADV7120DIP48-PQFPADV7120KST30
US2SP385A-SSOPDIP20-SOPSP385A-SSOP
VR1R_2SMR060310K-0603
VR2R_7SMR06030-0603
X1CRYSTALXP24.576MHZ
Y1CRYSTAL_2XP14.7456MHz
Y2CRYSTAL_2XP-3232.768kHz-1
Y271CRYSTAL_2XP3.579545MHz-1-U3B
Y272CRYSTAL_2XP4.433619MHz-1-U3B
Y273CRYSTAL_2XP4MHz
YA1CRYSTAL_0SMT-5X3.216MHz-5X3.2(NC)
ZIR1HEADER_3IRM-3438IRM-3438
ZR1R_5SMR060310K-0603(NC)
重要提示:PCB作品文件展下载说明
armclub | 2019-10-29 17:08:43 | 显示全部楼层
PCB 和原理图。很多个版本一起打包。
回复可见下载。
游客,如果您要查看本帖隐藏内容请回复
jeeson196 | 2019-10-29 17:24:23 | 显示全部楼层
yhgwork | 2019-10-29 19:53:01 | 显示全部楼层
shuszhao | 2019-10-29 20:37:35 | 显示全部楼层
yjqaii | 2019-10-29 20:45:38 | 显示全部楼层
zgh393484673 | 2019-10-29 20:54:04 | 显示全部楼层
a1090953707 | 2019-10-29 23:52:26 | 显示全部楼层
单枪舞九州 | 2019-10-30 07:09:52 | 显示全部楼层
东风导弹 | 2019-10-30 08:02:46 | 显示全部楼层
早上好呀,过来学习一下,设计得很好呀
终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
