重要提示:PCB作品文件展下载说明
REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | CN1 | CONN_SATA_ATERI_22P | SATA_PLUG_7P+15P | CONN_SATA_ATERI_22P | CX48 | C0402H6 | 1uF | C0402H6 | D2 | D0603 | RED LED | D0603 | D4 | D0603 | RED LED | D0603 | D5 | USON-10-2_5X1_0X0_55 | TPD4E05U06DQAR | USON-10-2_5X1_0X0_55 | D10 | SOD-523 | 1PS79SB30 | SOD-523 | D13 | SOD-523 | 1PS79SB30 | SOD-523 | D17 | SMA_FL | MBRAF440 | SMA_FL | D18 | D0603 | RED LED | D0603 | D34 | B550C | B550C | B550C | D37 | SOD-523 | 1PS79SB30 | SOD-523 | D39 | SOD-523 | 1SS389 | SOD-523 | D40 | SOD-523 | 1SS389 | SOD-523 | D41 | SOD-523 | 1SS389 | SOD-523 | D42 | SOD-523 | 1SS389 | SOD-523 | D44 | B550C | B550C | B550C | D45 | SMA_FL | MBRAF440 | SMA_FL | D46 | SMA_FL | MBRAF440 | SMA_FL | D47 | SOD-523 | 1SS389 | SOD-523 | D48 | SMA_FL | MBRAF440 | SMA_FL | D59 | SOD-523 | 1PS79SB30 | SOD-523 | F14 | BGA152_14X18_1MM | Flash/BGA152/8CE | BGA152_14X18_1MM | F15 | F1206 | NC_FUSE | F1206 | IC1 | TFBGA288-12X12 | SM2246EN-AA-BGA288-4CH-8CE | TFBGA288-12X12 | IC2 | FBGA96-13X9 | DDR3_X16_96 | FBGA96-13X9 | IC3 | FBGA96-13X9 | DDR3_X16_96 | FBGA96-13X9 | J2 | SIP-4P-2_0 | SIP-4P | SIP-4P-2_0 | J3 | DIP3-2_54 | CON3 | DIP3-2_54 | JP1 | SIP-2P-50 | NC_SIP-2P | SIP-2P-50 | JP3 | R0603 | NC_SIP-2P | R0603 | L2 | L4012_A | 2.2uH | L4012_A | L3 | L6018 | 6.8uH | L6018 | L4 | L0603 | BEAD/120 Ohm | L0603 | L6 | L3025H5 | Power Inductor 2.2uH | L3025H5 | L7 | L0603 | BEAD/120/0603 | L0603 | L8 | L0603 | BEAD/120 Ohm | L0603 | L11 | L0603 | BEAD/33 Ohm | L0603 | L17 | L0603 | 0R | L0603 | L31 | L4012_A | 4.7uH | L4012_A | L33 | LPO3310 | Power Inductor 2.2uH | LPO3310 | L34 | L3025H5 | Power Inductor 2.2uH | L3025H5 | Q1 | SOT-723 | ACE1551AJM+H | SOT-723 | Q4 | SOT23_123H11 | MMBT3904 | SOT23_123H11 | Q22 | SOT23_123H11 | MMBT3904 | SOT23_123H11 | Q32 | SOT23_123H11 | ACE2302B | SOT23_123H11 | Q33 | SOT-723 | ACE1551AJM+H | SOT-723 | SD1 | SMA_FL | MBRAF440 | SMA_FL | SD2 | SMA_FL | MBRAF440 | SMA_FL | U1 | SOT-23-5H1 | RT8059GJ5 | SOT-23-5H1 | U2 | DFN8-0P65-3X3 | RT8065ZQW | DFN8-0P65-3X3 | U4 | DFN33_0P5_5P8X5P8 | msp430f2112 | DFN33_0P5_5P8X5P8 | U6 | QFN-19-0_45-3X4 | SY6402 | QFN-19-0_45-3X4 | U7 | SOT23-5 | RT9193 -33 | SOT23-5 | U8 | SOT-23-5H1 | RT8059GJ5 | SOT-23-5H1 | U11 | SOT-23-5H1 | RT8059GJ5 | SOT-23-5H1 | U12 | SOT23-5 | RT9193 -33 | SOT23-5 | U13 | DFN-10-0_5-3X3 | SY6875ADBC | DFN-10-0_5-3X3 | U14 | SOP-8-9-1P27-6X4P9 | RT8279GSP | SOP-8-9-1P27-6X4P9 | U15 | QFN16_0P45_3X3 | NC/SY6885BQDC | QFN16_0P45_3X3 | U16 | DFN8-0P65-3X3 | RT8070ZQW | DFN8-0P65-3X3 | U17 | DFN-10-0_5-3X3 | SY6875ADBC | DFN-10-0_5-3X3 | XC1 | C0402H6 | 10pF | C0402H6 | XC2 | C0402H6 | 10pF | C0402H6 | Y1 | XTAL-3225 | XTAL-50MHz/3225 | XTAL-3225 | ZD1 | DIODE-TSLP | ESD5V3U1U-02LRH | DIODE-TSLP | ZD3 | DIODE-TSLP | ESD5V3U1U-02LRH | DIODE-TSLP | ZD4 | DIODE-TSLP | ESD5V3U1U-02LRH | DIODE-TSLP | ZD5 | DIODE-TSLP | ESD5V3U1U-02LRH | DIODE-TSLP | ZD6 | DIODE-TSLP | ESD5V3U1U-02LRH | DIODE-TSLP | ZD7 | SOD323 | SD12 | SOD323 | ZD8 | DIODE-TSLP | ESD5V3U1U-02LRH | DIODE-TSLP | ZD9 | DIODE-TSLP | NC_ESD5V3U1U-02LRH | DIODE-TSLP | ZD10 | DIODE-TSLP | NC_ESD5V3U1U-02LRH | DIODE-TSLP | ZD11 | SOD323 | SD12 | SOD323 |
重要提示:PCB作品文件展下载说明
