[Allegro16.6以下] IMX6Q 挂4个DDR3 小系统板PCB和原理图
查看13240 | 回复151 | 2020-10-3 00:25:45 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
D3BAV99_0_A_LED_3X1MM_KB_LED_BLUELED_BlueA_LED_3X1MM_KB
D10DIODE_SCHTKY_SOD323_IC_NSR0320NSR0320SOD323
D12DIODE_8_SOD123_ROHMRB060M-30/NROHM RB060M-30/NCSOD123
D38BAT54S_0_SOT23-132_AZC199-02S/NAZC199-02S/NCSOT23-132
D39DIODE_0_A_DO50_SM_SMAJ58CASMAJ58CAA_DO50_SM
D40DIODE_0_A_DO_214AA_S3ABS3ABA_DO_214AA
D504DIODE_SOD323_IC_BAT54HT1BAT54HT1SOD323
D505BR81D_SOD106_4P_CDNBS04-B08200CDNBS04-B08200SOD106_4P
D506BR81D_SOD106_4P_CDNBS04-B08200CDNBS04-B08200SOD106_4P
F6FS-A_0_FUSE1206_6V500MA6V500mAFUSE1206
FB21FERBD,0805,100OHM_100MHZ,4A_A_FFB_0805A_FB0805
FB34FERBD,0805,100OHM_100MHZ,4A_A_3FB_0603A_FB0603
FJ10MOUNTINGHOLE_0_HOLE230D87_PTH0PTH01HOLE230D87
GNDTEST_POINT_ANT_1P_TEST_POINT_?_TEST_POINTANT_1P
HOLE1TEST_POINT_HOLE25X50_TEST_POINTTEST_POINTHOLE25X50
HOLE2TEST_POINT_HOLE25X50_TEST_POINTTEST_POINTHOLE25X50
J3USB-B_1_A_HEADER4_HEADER4Header4A_HEADER4
J4AUDIOJACK_0_AUDIO_6P_B_AUDIO JAudio Jack_6AUDIO_6P_B
J5IPEXCON_RF3_BL_RT5370RM2_IPEXIPEX CONRF3_BL_RT5370RM2
J86140024800G_1_A_CON_HDMI_HDMI-AHDMI-AA_CON_HDMI
J13RJ45-101110FD2H2M440ZA_2_LAN_LEUDE RB1-125BHQ1ALAN_LED_WN
J14USB_A_0_MINI_USB_PTH065_5P_MICRMicro_USB-BMINI_USB_PTH065_5P
J23HEADER_1X6_A_HEADER6_HEADER_1X6HEADER_1X6A_HEADER6
J24HEADER_0_A_HEADER9_HEADER_1X9HEADER_1X9A_HEADER9
JP5HEADER3_5_A_HEADER3_HEADER3HEADER3A_HEADER3
JP6HEADER3_5_A_HEADER3_HEADER3HEADER3A_HEADER3
JP7HEADER3_5_A_HEADER3_HEADER3HEADER3A_HEADER3
L2INDUCTOR_COIL_SI54H_A_2.2UH_SD42.2uH_SD43COIL_SI54H_A
L3INDUCTOR_COIL_SI54H_A_2.2UH_SD42.2uH_SD43COIL_SI54H_A
L4INDUCTOR_COIL_SI54H_A_2.2UH_SD42.2uH_SD43COIL_SI54H_A
L6INDUCTOR_COIL_SD32_SD322.2UHSD32 2.2uHCOIL_SD32
L8TMP_202406_A_FB0805_4P_90_100MH90_100MHZA_FB0805_4P
L13BEAD_0_A_FB0603_DISCRETE_120OHM120OHMA_FB0603
L16BEAD_0_A_FB0603_DISCRETE_120OHM120OHMA_FB0603
L18BEAD_0_A_FB0603_DISCRETE_120OHM120OHMA_FB0603
L21INDUCTOR_COIL_SI54H_A_4.7UH_SD44.7uH_SD43COIL_SI54H_A
L380805USB-421ML_A_FB0805_4P_42R_142R_100MHzA_FB0805_4P
L390805USB-421ML_A_FB0805_4P_42R_142R_100MHzA_FB0805_4P
LB17FB-0805_L0806_2.2UH/NC2.2uH/NCL0806
MC509CAP_POL_0_CAP_SMD_W7X7_PMA_22_1220uF/6.3VCAP_SMD_W7X7_PMA
MD51DIODE_8_A_DO323_SM_RB551V-30RB551V-30A_DO323_SM
MD52DIODE_8_A_DO323_SM_RB551V-30RB551V-30A_DO323_SM
MFS1FUSE_FUSE1206_SMD1206P050TFSMD1206P050TFFUSE1206
PT1MOUNTINGHOLE_0_HOLE230D87_PTH0PTH01HOLE230D87
PT2MOUNTINGHOLE_0_HOLE230D87_PTH0PTH01HOLE230D87
PT3MOUNTINGHOLE_0_HOLE230D87_PTH0PTH01HOLE230D87
Q42020002300_4_SOT323N_2SK3541_SO2SK3541_SOT323SOT323N
Q62020002300_4_SOT323N_2SK3541_SO2SK3541_SOT323SOT323N
Q14MOS-N_5_SOT23-GDS_FDV301NFDV301NSOT23-GDS
Q15MOS-N_5_SOT23-GDS_FDV301NFDV301NSOT23-GDS
Q172020002300_4_SOT323N_2SK3541_SO2SK3541_SOT323SOT323N
Q20APM2301AAC-TR_2_SOT23-GDS_AO341AO3413_SOT23SOT23-GDS
Q21MOS-N_5_SOT23-GDS_FDV301NFDV301NSOT23-GDS
Q22APM2301AAC-TR_2_SOT23-GDS_AO341AO3413_SOT23SOT23-GDS
Q232020002300_4_SOT323N_2SK3541_SO2SK3541_SOT323SOT323N
Q242020002300_4_SOT323N_2SK3541_SO2SK3541_SOT323SOT323N
Q252020002300_4_SOT323N_2SK3541_SO2SK3541_SOT323SOT323N
Q272020002300_4_SOT323N_2SK3541_SO2SK3541_SOT323SOT323N
Q99XSTR,2SK3541,FET,NCH,VMT3_1_A_S2N7002_SOT23A_SOT23
Q100XSTR,2SK3541,FET,NCH,VMT3_1_A_S2N7002_SOT23A_SOT23
Q5012020002300_4_SOT323N_2SK3541_SO2SK3541_SOT323SOT323N
QZ500XTAL_XTAL2-3P2X1P5-SM_IC_32.76832.768KHZXTAL2-3P2X1P5-SM
RX1RES_A_RES0402_DISCRETE_1M1MA_RES0402
RX2RES_A_RES0402_DISCRETE_1M1MA_RES0402
SW25030002100_0_SW2_MTA2_WNCQTR_PSPSONSWSW2_MTA2_WNCQTR
T8TESTLOOP_TPAD_015_IO_TPAD_015TPAD_015TPAD_015
T9TESTLOOP_TPAD_015_IO_TPAD_015TPAD_015TPAD_015
T10TESTLOOP_TPAD_015_IO_TPAD_015TPAD_015TPAD_015
U1PCIMX6Q6VV1A_BGA624_0P8_21X21_IiMX6QBGA624_0P8_21X21
U22G_DDR3_SDRAM_128MX16_96P_BGA96MT41J128M16HA-15EBGA96_0P8_9P15X14P15
U32G_DDR3_SDRAM_128MX16_96P_BGA96MT41J128M16HA-15EBGA96_0P8_9P15X14P15
U42G_DDR3_SDRAM_128MX16_96P_BGA96MT41J128M16HA-15EBGA96_0P8_9P15X14P15
U52G_DDR3_SDRAM_128MX16_96P_BGA96MT41J128M16HA-15EBGA96_0P8_9P15X14P15
U8EUP3420JIR1_2_TDFN10_PT05_W3X3_AT7174TDFN10_PT05_W3X3
U9RTL8169S_0_QFN32_PT05_W5X5_RTL8RTL8201F-VC-CGQFN32_PT05_W5X5
U11WIFI_0_WIFI-BL8188-2F_BL-8188-2BL-8188-2FWIFI-BL8188-2F
U12EUP3420JIR1_2_TDFN10_PT05_W3X3_AT7174TDFN10_PT05_W3X3
U13EUP3420JIR1_2_TDFN10_PT05_W3X3_AT7174TDFN10_PT05_W3X3
U14M25P32_A_SO8_IC_M25P32-VMW6TG/NM25P32-VMW6TG/NCA_SO8
U16AUR9705_3_A_TSOT23_5P_AT7151AT7151A_TSOT23_5P
U21EN25P16-50HCP_SOIC8-50X288_MX25MX25L1606ESOIC8-50X288
U28MX25L12835EMI-10G_0_A_TSSOP16_IISL3232 TSSOPA_TSSOP16
U33TPS3808G33_0_SOT23_6P_TPS3808G0TPS3808G01/NCSOT23_6P
U37AX3102_SOP8L_7_PSOP-8L_AT7284-SAT7284-SF8RPSOP-8L
U63IC,PRTR5V0U2X,ESD,SOT143_SOT143CM1293A-02SR/NCSOT143B
U82CONNW25P80AOZ8804ADI/NCDFN10_PT05_W1X2_5
U83CONNW25P80AOZ8804ADI/NCDFN10_PT05_W1X2_5
U84CONNW25P80AOZ8804ADI/NCDFN10_PT05_W1X2_5
U85CONN, IC, FLASH,W25X80T_2_DFN1AOZ8804ADI/NCDFN10_PT05_W1X2_5
U512SDIN5C2_TFBGA_169P_BGA169_0P5_1THGBM4G6D2HBAIRBGA169_0P5_12X16
U5131G125_A_SOT353_5P_IC_NC7SP125P5NC7SP125P5XA_SOT353_5P
U33A3EUP7917-25NIR1_A_TSOT23_5P_AT52AT5231-1.2KER/NCA_TSOT23_5P
UM1HDR_1_AG9182M_AG9821MAG9821MAG9182M
USB2UJACK_0_A_USB1_UJACKUJACKA_USB1
Y1XTAL_13Y_A_XTAL4_SX_3225_IC_24M24MHzXTAL4_SX_3225
Y2XTAL_13Y_A_XTAL4_5_7X3_3_IC_25M25M_CX5MXTAL4_5_7X3_3
重要提示:PCB作品文件展下载说明
老吴 | 2020-10-3 00:27:03 | 显示全部楼层
PCB 原理图一起打包。PS:原理图没校对,不知道和PCB是否一致。
游客,如果您要查看本帖隐藏内容请回复
kanxue_nmg | 2020-10-3 03:05:12 | 显示全部楼层
longxuekai | 2020-10-3 06:14:11 | 显示全部楼层
清心如水 | 2020-10-3 07:01:25 | 显示全部楼层
gyj82117 | 2020-10-3 07:20:13 | 显示全部楼层
wangy2000 | 2020-10-3 07:50:09 | 显示全部楼层
nj20044 | 2020-10-3 08:03:25 | 显示全部楼层
yangxf0120 | 2020-10-3 08:07:19 | 显示全部楼层
谢谢分享IMX6Q小系统板PCB和原理图
luchonghui74 | 2020-10-3 08:17:52 | 显示全部楼层
