[Allegro16.6以下] 飞思卡尔QorIQ P1010 RDB demo 板PCB和原理图SDK PDF等共享
查看8065 | 回复66 | 2020-10-5 00:25:22 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
BH1MOUNT_HOLE_MTG156_PTH_IC_0.05MMMOUNTING HOLEMTG156_PTH
BH2MOUNT_HOLE_MTG156_PTH_IC_0.05MMMOUNTING HOLEMTG156_PTH
BH3MOUNT_HOLE_MTG156_PTH_IC_0.05MMMOUNTING HOLEMTG156_PTH
BH4MOUNT_HOLE_MTG156_PTH_IC_0.05MMMOUNTING HOLEMTG156_PTH
BT1BATTERY_SKT_3V_SKT_BAT_225X886_WBA-3B2 USKT_BAT_225X886_3V
D1DIODE_SCHTKY_SOD523_IC_0.7MM_48RB521S-30SOD523
D2LED_0603LED_IC_0.85MM_370-76464GRN0603LED
D3LED_0603LED_IC_0.85MM_370-76464GRN0603LED
D4LED_0603LED_IC_0.85MM_370-76464GRN0603LED
D5DIODE_SOD123_A_IC_1.35MM_480-78CMHD3595SOD123_A
D6DIODE_SCHTKY_SMA_IC_2.3MM_480-7B330ASMA
D7DIODE_SCHTKY_SOD-123_IC_1.35MM_MBR0540T1GSOD-123
D8LED_0603LED_IC_0.85MM_370-76464GRN0603LED
D9LED_0603LED_IC_0.85MM_370-76464GRN0603LED
D10LED_0603LED_IC_0.85MM_370-76464GRN0603LED
D11DIODE_CASE403D_02_IC_2.3MM_480-ES1D-13-FCASE403D_02
D12DIODE_SCHTKY_SOD-123_IC_1.35MM_MBR0540T1GSOD-123
D13DIODE_CASE403A_03_IC_2.62MM_480MURS120T3CASE403A_03
D14DIODE_CASE403A_03_IC_2.62MM_480MURS120T3CASE403A_03
D15SDIODE_CASE403A_03_IC_2.65MM_48MBRS140CASE403A_03
D16DUALDIODE_CA_SOT23_SOT23_IC_1.1BAW56-7-FSOT23
F1FUSE_RESETTABLE_FUSE_6P6X3P2MM_3A/60VFUSE_6P6X3P2MM_SM
F2FUSE_RESETTABLE_FUSE_6P6X3P2MM_3A/60VFUSE_6P6X3P2MM_SM
F3FUSE_RESETTABLE_FUSE_6P6X3P2MM_3A/60VFUSE_6P6X3P2MM_SM
F4FUSE_RESETTABLE_FUSE_6P6X3P2MM_3A/60VFUSE_6P6X3P2MM_SM
J1USB_MINI_AB_RECEPTACLE_CON_USB_USB_TYPE_ABCON_USB_5F_0P65_SM_RA
J2USB_MINI_AB_RECEPTACLE_CON_USB_USB_TYPE_ABCON_USB_5F_0P65_SM_RA
J3CONN_ESATA_7P_CON_ESATA_7M_50_SCON eSATACON_ESATA_7M_50_SM_RA
J443202-6101_CON_PHRA_6_A_IO_11.5RJ11-6CON_PHRA_6_A
J5RJ45_2X8_CON_RJ45_X2_TH_25.65MMRJ45X2_LEDCON_RJ45_X2_TH
J6CONN_RJ45_STACKED_16P_CON_RJ45_5569381-1CON_RJ45_16F_50_TH_RA
J7HDR_SHRD_2X1_HDR102_9.45MM_210-HDR 1X2HDR102
J8SATA_PLUG7_CON_SATA_7M_50_TH_IOCON SATA 7CON_SATA_7M_50_TH
J9HEADER5X2_HDR_10M_100_SM_IO_10.HDR_2X5HDR_10M_100_SM
J10CONN_COAX_1P_F_CON_SMA_IO_9.53CON 1 SMACON_SMA
J11HDR_SHRD_2X1_HDR102_9.45MM_210-HDR 1X2HDR102
J12HDR_SHRD_2X1_HDR102_9.45MM_210-HDR 1X2HDR102
J13HDR_SHRD_2X1_HDR102_9.45MM_210-HDR 1X2HDR102
J14HDR_SHRD_2X1_HDR102_9.45MM_210-HDR 1X2HDR102
J15CONN_HDR_5X2_HDR205_SM_IO_9.65HDR_2X5HDR205_SM
J16CONN_HDR_3X1_HDR103_9.45MM_210-HDR_1X3HDR103
J17CONN_HDR_4X2_HDR204_TSM_SM_9.65HDR_2X4HDR204_TSM_SM
J19HDR_SHRD_2X1_HDR102_9.45MM_210-HDR 1X2HDR102
J20HDR_SHRD_2X1_HDR102_9.45MM_210-HDR 1X2HDR102
J22CONN_HDR_3X1_HDR103_9.45MM_210-HDR_1X3HDR103
J23CONN_HDR_4X2_HDR2X4_8.6MM_210-7HDR_2X4HDR2X4
J24HDR_SHRD_2X1_HDR102_9.45MM_210-HDR 1X2HDR102
J25ATXPWR_2X10VERT_ATXPWR_2X10_VERCON_2X10ATXPWR_2X10_VERT
J26HDR_SHRD_2X1_HDR102_9.45MM_210-HDR 1X2HDR102
J27HDR_SHRD_2X1_HDR102_9.45MM_210-HDR 1X2HDR102
J28CONN_HDR_3X1_HDR103_9.45MM_210-HDR_1X3HDR103
J29HTST-108-01-L-DV_HDR208_HTST_SMHTST-108-01-L-DVHDR208_HTST_SM
J30HDR_SHRD_2X1_HDR102_9.45MM_210-HDR 1X2HDR102
J31CONN_HDR_3X1_HDR103_9.45MM_210-HDR_1X3HDR103
J32CONN_HDR_3X1_HDR103_9.45MM_210-HDR_1X3HDR103
J33CONN_SDCARD_1X17_F_CON_SDCARD_1SDSN13CON_SDCARD_17F_49_SM_RA
J34CONN_HDR_3X1_HDR103_9.45MM_210-HDR_1X3HDR103
K1EA2-5NJ_DIP10_2P54_14P3X9P3_IC_TQ2-3VDIP10_2P54_14P3X9P3
L1DLW43_CHOKE_0805_DISCRETE_1MM_190OHMCHOKE_0805
L2DLW43_CHOKE_0805_DISCRETE_1MM_190OHMCHOKE_0805
L14INDUCTOR_IND_0402_DISCRETE_0.551000OHMIND_0402
L15BEAD_IND_0805_DISCRETE_1.05MM_160ohmIND_0805
L16INDUCTOR_IND_6363_DISCRETE_3MM_4.7UHIND_6363
L17COIL_IND_1210_DISCRETE_2.4MM_11 UHIND_1210
L18IND_IND_VLS252012_DISCRETE_1.2M4.7UHIND_VLS252012
L19INDUCTOR_IND_0402_DISCRETE_0._11000OHMIND_0402
L20INDUCTOR_IND_SLF7045_DISCRETE_4220UHIND_SLF7045
L21INDUCTOR_IND_SLF7045_DISCRETE_1100UHIND_SLF7045
L22INDUCTOR_IND_IHLP_DISCRETE_3MM0.68UHIND_IHLP
L23INDUCTOR_IND_IHLP_DISCRETE_3.01uHIND_IHLP
L24BEAD_IND_0805_DISCRETE_1.05MM_160ohmIND_0805
L25BEAD_FERRITE_IND_0603_DISCRETE_120OHMIND_0603
L39BEAD_FERRITE_IND_0603_DISCRETE_120OHMIND_0603
P1RJ45_LED_CON8_RJ45_JACK_LED_IO_RJ45-8CON8_RJ45_JACK_LED
P2RJ-11_RIGHT-ANGLE_PHONE_PLUG_CO2xRJ11-6CON_RJ11_12F_50_TH_RA
P3PCI EXPRESSX1_PCI_36_EXPRESS_CPCI EXPRESS 36PCI_36_EXPRESS_CONN_TH
P4MPCI_EXPRESS_CON52_0P8_SMT_FULLCONN PCI EXP 52CON52_0P8_SMT_FULL-HALF
Q1NPN_SOT23_IC_1.12MM_480-75173_MMBT3904LT1GSOT23
Q2MOSFET_P_SOT23_IC_1.11MM_480-75NTR4101SOT23
Q3NPN_SOT23_IC_1.12MM_480-75173_MMBT3904LT1GSOT23
Q4MOSFET_P_SOT23_IC_1.11MM_480-75NTR4101SOT23
Q5IRF7821_8P_SO_8_1P27_4X5_IC_1.7IRF7821PBFSO_8_1P27_4X5
Q6IRF7832_8P_SO_8_1P27_4X5_IC_1.7IRF7832SO_8_1P27_4X5
Q7MOSFET_IRLZ24_D2PAK_A_IC_4.83MMIRLZ24NSPBFD2PAK_A
Q8IRF7832_8P_SO_8_1P27_4X5_IC_1.7IRF7832SO_8_1P27_4X5
Q9IRF7821_8P_SO_8_1P27_4X5_IC_1.7IRF7821PBFSO_8_1P27_4X5
Q10NPN_SOT23_IC_1.12MM_480-75173_MMBT3904LT1GSOT23
Q11FDV301N_SOT23-40X40_IC_1.3MM_48FDV301NSOT23-40X40
Q12PNP_SOT23_IC_1.1MM_480-76358_MMMMBT2907ASOT23
R1RES_RC0805_OV_DISCRETE_470-75440RC0805_OV
SW1SW_DIP_8_SW_DIP16_8POS_SM_IC_2.218-8LPSTSW_DIP16_8POS_SM
SW2SW_DIP_8_SW_DIP16_8POS_SM_IC_2.218-8LPSTSW_DIP16_8POS_SM
SW3SW_DIP4_SW_DIP8_4POS_SM_IC_2.65SW_DIP-4/SMSW_DIP8_4POS_SM
SW4SW_DIP4_SW_DIP8_4POS_SM_IC_2.65SW_DIP-4/SMSW_DIP8_4POS_SM
SW5ELTSA-63K-H_SW_ELTSA6_TH_7.2MM_SPST PBSW_ELTSA6_TH
SW6SW_DIP4_SW_DIP8_4POS_SM_IC_2.65SW_DIP-4/SMSW_DIP8_4POS_SM
T1C8140_FLYBACK_XFRM_SOT_C8140_10C8140SOT_C8140_10P
TP1TESTPAD_TESTPOINT_35MIL_IC_0.135 MILTESTPOINT_35MIL
TP38TESTPAD_TESTPOINT_35MIL_IC_0.135 MILTESTPOINT_35MIL
U1RCCLAMP_SLP1616P6_IC_0.65MM_312RCLAMP0504P.TCTSLP1616P6
U2RCCLAMP_SLP1616P6_IC_0.65MM_312RCLAMP0504P.TCTSLP1616P6
U3NL17SZ00_SOT-553-5P_IC_0.6MM_31NL17SZ00XV5T2SOT-553-5P
U4MIC2506_SO8_IC_1.879MM_312-7609MIC2506YMSO8
U5PI3USB10ZEE_TDFN12_0P5_3X3P5_ICPI3USB10TDFN12_0P5_3X3P5
U6USB3300_QFN32_IC_1.0MM_312-7553USB3300QFN32
U7SP3232E_SSOP16_IC_1.99MM_312-77SP3232SSOP16
U8SP3232E_SSOP16_IC_1.99MM_312-77SP3232SSOP16
U9749020010_XFMR24_1P27_12X18_IC_24HSS1041-2 HFXFMR24_1P27_12X18
U10749020010_XFMR24_1P27_12X18_IC_24HSS1041-2 HFXFMR24_1P27_12X18
U11749020010_XFMR24_1P27_12X18_IC_24HSS1041-2 HFXFMR24_1P27_12X18
U12TISP61089H_SO8_1P27_4X5_IC_1.75TISP61089BSO8_1P27_4X5
U13TISP61089H_SO8_1P27_4X5_IC_1.75TISP61089BSO8_1P27_4X5
U14MP2365DN_SOIC8_1P27_4X5_IC_1.7MMP2365DNSOIC8_1P27_4X5
U15NCP1117_SOT223_IC_1.8MM_315-300NCP1117STAT3GSOT223
U16LE88266DLC_LQFP_80_IC_1.6MM_312Le88266DLCLQFP_80
U17VSC8221_TFBGA100_0P8_9X9_IC_1.1VSC8221XHHTFBGA100_0P8_9X9
U18VSC8221_TFBGA100_0P8_9X9_IC_1.1VSC8221XHHTFBGA100_0P8_9X9
U19SN74CBT16214D_TSSOP_56_TSSOP56_SN74CBT16214DGGRTSSOP56_0P5_14X6P1MM
U20ATMEL_SERIAL_EEPROM_64K-1_TSSOPAT24C01BTSSOP8
U21JS28F256M29EWL_TSOP56_0P5_18_4XJS28F256M29EWLTSOP56_0P5_18_4X14_IN
U22K9F5608U0D-PCB0_TSOP48_12X20_ICK9F5608U0D-PCB0TSOP48_12X20
U23MP2119DQ_QFN10_0P5_3X3_A_IC_1MMMP2119DQQFN10_0P5_3X3_A
U24IDT74CBTLV3257_TSSOP16_IC_1.2MMIDT74CBTLV3257PGGTSSOP16
U25MP2105DJ_TSOT-23_0P95_IC_1MM_31MP2105DJTSOT-23_0P95
U26IS24CXXMCP4921-ESNSO8_1P27_4X5
U27P1010E_TEPBGA425_0P8_19X19MM_ICP1010ETEPBGA425_0P8_19X19MM
U28LCMXO256_TQFP_100P_TQFP100_IC_1LCMXO256C-3TN100CTQFP100
U29ZL2006_QFN36_IC_1.0MM_312-7818ZL2006QFN36
U30M24256_TSSOP8_IC_1.2MM_334-7721M24256-BWDW6TPTSSOP8
U312G_DDR3_SDRAM_HX_FBGA78_0P8_9X1MT41J256M8HXFBGA78_0P8_9X11P5
U322G_DDR3_SDRAM_HX_FBGA78_0P8_9X1MT41J256M8HXFBGA78_0P8_9X11P5
U332G_DDR3_SDRAM_HX_FBGA78_0P8_9X1MT41J256M8HXFBGA78_0P8_9X11P5
U342G_DDR3_SDRAM_HX_FBGA78_0P8_9X1MT41J256M8HXFBGA78_0P8_9X11P5
U35MAX811_SOT143-25X60_IC_1.22MM_MAX811SOT143-25X60
U36TPS51116_TSSOP20_PWRPAD_IC_1.2MTPS51116TSSOP20_PWRPAD
U37PT7C433833_MSOP_8P_USOP-8_IC_1.PT7C4338USOP-8
U38ECLAMP2357N_QFN16_3X3MM_1P6_IC_ECLAMP2357N.TCTQFN16_3X3MM_1P6
U39SN65HVD230DR_S08_1P27_4X5_IC_1.SN65HVD230DS08_1P27_4X5
U40VSC8641_EP-100LQFP_LQFP100_0P4_VSC8641XKOLQFP100_0P4_12X12MM
U41SN65HVD230DR_S08_1P27_4X5_IC_1.SN65HVD230DS08_1P27_4X5
U42S25FL128P_WSON_8_IC_0.8MM_334-7S25FL128P0XNFI00WSON_8
U4674ALVT16373_48SSOP_IC_2.79MM_3174ALVT1637348SSOP
U47IDT74CBTLV3257_TSSOP16_IC_1.2MMIDT74CBTLV3257PGGTSSOP16
U481G125_SC-70_IC_1.1MM_312-75240_SN74LVC1G125DCKRSC-70
U49PI6C557_05LE_TSSOP_20P_TSSOP20_PI6C557-05TSSOP20
U71PCA9557PW_TSSOP16_1.1MM_312-752PCA9557PWTSSOP16
Y1XTAL_13Y_XTLOSC4_6P2X3P7MM_SM_I24MHZ CRYSTALXTLOSC4_6P2X3P7MM_SM
Y2XTAL4_SMB-751L_XTAL4_7P2X5P2_SM25MHzXTAL4_7P2X5P2_SMB-751L
Y3XTAL4_SMB-751L_XTAL4_7P2X5P2_SM25MHzXTAL4_7P2X5P2_SMB-751L
Y5CLKGEN-SM_XTLOSC4_5X7_5_IC_1.5566.666MHzXTLOSC4_5X7_5
Y6O4-0_OSC4_2P5X2P0_SM_IC_0.8MM_224 MHzOSC4_2P5X2P0_SM
Y7OSC_6P_ECS-VXO_XO6_2P54_7X5MM_I50MHZXO6_2P54_7X5MM
Y8CLKGEN-SM_XTLOSC4_2P54_3P3X2P6_32.768KHzXTLOSC4_2P54_3P3X2P6
Y9CLKGEN-SM_XTAL4_7P2X5P2_SMB-7512.048MHzXTAL4_7P2X5P2_SMB-751L
Y10XTAL_XTL2_ECS_SM_IC_2.25MM_230-32.768KHzXTL2_ECS_SM
Y11CRYSTAL_JXS63_XTLOSC4_5X3MM_SM_CSX3-AB-18-25XTLOSC4_5X3MM_SM
Y12CRYSTAL_JXS63_XTLOSC4_5X3MM_SM_CSX3-AB-18-25XTLOSC4_5X3MM_SM
重要提示:PCB作品文件展下载说明
老吴 | 2020-10-5 00:35:57 | 显示全部楼层
资料有点大。比较多。是否完整不知道。SDK 有没有问题,也不保证。有需要的下载参考。
P1010RDB.7z
40.17 MB, 下载次数: 17, 下载积分: 金币 -5 枚
P1010RDB-PB.7z
14.23 MB, 下载次数: 6, 下载积分: 金币 -5 枚
SDK1.7--2.01.7z
89.78 MB, 下载次数: 2, 下载积分: 金币 -5 枚
Technical Presentations.7z
3.07 MB, 下载次数: 2, 下载积分: 金币 -5 枚
20140708.rar
17 MB, 下载次数: 1, 下载积分: 金币 -5 枚
P1010.rar
8.66 MB, 下载次数: 0, 下载积分: 金币 -5 枚
P1010_uboot_ppt等.zip
36.94 MB, 下载次数: 1, 下载积分: 金币 -5 枚
16242_P1010_P1014_Qual_Report_F.pdf
254 KB, 下载次数: 0, 下载积分: 金币 -5 枚
AN4039---DDR3.pdf
335 KB, 下载次数: 0, 下载积分: 金币 -5 枚
AN4534--Design checklist.pdf
257 KB, 下载次数: 0, 下载积分: 金币 -5 枚
AN4938.pdf
118 KB, 下载次数: 0, 下载积分: 金币 -5 枚
P1010 Errata.pdf
324 KB, 下载次数: 0, 下载积分: 金币 -5 枚
P1010_Benchmarks.pdf
326 KB, 下载次数: 0, 下载积分: 金币 -5 枚
P1010APPBRF.pdf
588 KB, 下载次数: 0, 下载积分: 金币 -5 枚
P1010CE_RevP.pdf
406 KB, 下载次数: 0, 下载积分: 金币 -5 枚
P1010CE_RevQ.pdf
415 KB, 下载次数: 0, 下载积分: 金币 -5 枚
P1010EC.pdf
830 KB, 下载次数: 0, 下载积分: 金币 -5 枚
P1010RDBPBUG.pdf
666 KB, 下载次数: 0, 下载积分: 金币 -5 枚
P1010RM.pdf
9.12 MB, 下载次数: 0, 下载积分: 金币 -5 枚
P1014EC (1).pdf
803 KB, 下载次数: 0, 下载积分: 金币 -5 枚
P1014EC.pdf
800 KB, 下载次数: 0, 下载积分: 金币 -5 枚
P1014RM.pdf
8.44 MB, 下载次数: 0, 下载积分: 金币 -5 枚
QP1010FS.pdf
203 KB, 下载次数: 2, 下载积分: 金币 -5 枚
清心如水 | 2020-10-5 06:44:27 | 显示全部楼层
kanxue_nmg | 2020-10-5 06:46:54 | 显示全部楼层
shuszhao | 2020-10-5 08:44:25 | 显示全部楼层
小鑫鑫 | 2020-10-5 08:45:51 | 显示全部楼层
sekisan | 2020-10-5 08:53:38 | 显示全部楼层
yaodaoji | 2020-10-5 08:58:28 | 显示全部楼层
bidinghong | 2020-10-5 08:59:35 | 显示全部楼层
单枪舞九州 | 2020-10-5 09:00:22 | 显示全部楼层
