TDA7388+TDA7719+MC9S08DZ60_pcb_sch.7z
(1.31 MB, 下载次数: 49)
Name | Part Type | PCB Decal | Value | ANT1 | CON_MM9329-2700 | CON_MM9329-2700 | NC | ANT2 | CON_14-2500-0001-00 | ANT-2P-846 | | ANT3 | GPS_ANT | CON-2017.01.2510.00 | GTA-1.6CF(70) | BPZ1 | BPZ | BPZ | | CN3 | B_TO_B_84PIN | B_TO_B_80PIN_MALE | IMSA-9828B-60Y921 | CW2 | PAD-POINT | PAD-POINT-0.8MMBAAABCAAAA | | D1 | DD | SDSMC2723BAA | NC | D2 | DIODE4148 | SD0805 | 1N4148 | D3 | DIODE4148 | SD0805 | 1N4148 | D4 | SMA-SMB | SMA | IN4007 | D8 | SMA-SMB | SMA | SMA_B340A | D9 | DIODE4148 | SD0805 | 1N4148 | D10 | DIODE4148 | SD0805A | 1N4148 | D11 | DIODE_ZENER | SOD-80 | 15V | D12 | DD | SDSMC2723 | 1-5SMC24AT3 | D13 | SCHOTTKY | SMA | SMA_B340A | D14 | DIODE4148 | SD0805 | 1N4148 | D16 | DIODE4148 | SD0805A | 1N4148 | DD1 | PNP_2 | TO-252-TAA | STPS15H100CB | DL1 | TDKZJYS81 | DLW21S_SQ | ACM2012-121-2P-T001 | ESD1 | ESD2 | ESD | ESD | F1 | FUSE1206 | SF1206A | SMD1812P260TF/12 | F2 | FUSE0805 | FU0805 | 100MA/12V | F3 | FUSE1206 | SF1206 | 500MA/12V | F5 | FUSE1206 | SF1206 | 500MA/12V | FB1 | L | 0603/R-3 | FB120R | FB2 | INDUCTOR_0 | 0805/FB | FB31R | IC1 | IC_TDA7719 | IC_TDA7719 | TDA7719 | IC7 | XC6209B332MR | SOT-23-5 | XC6228D332VR | IC19 | IC_IVT_BLUESOLEIL_I50E | IC_IVT_BLUESOLEIL_I38EA | IVT_BlueSoleil_i50e | ISO28P1 | ISO28P | ISO28PAAAAAAA | | J1 | HEADER_3X2 | DZ60_DEBUG | | J3 | CON60 | CN-SMD60P-H-0.5-A | CON-60PIN-0.5-DOWN(HannStar TFT) | JP1 | CON9 | HOLE118-8STARA | CON9 | JP2 | CON9 | HOLE118-8STAR | CON9 | JP3 | CON9 | HOLE118-8STAR | CON9 | JP4 | CON9 | HOLE118-8STAR | CON9 | L1 | INDUCTOR_2 | 0805/L | 1.8UH | L2 | INDUCTOR_3 | 1206/FB | FB121 | L3 | INDUCTOR_3 | 1206/FB | FB121 | L4 | CAP_FEED | NFE31PT | NFE31PT222Z1E9D_6A | L5 | INDUCTOR_1 | L-CD75 | 2.2mH | L8 | INDUCTOR2 | L1608-330 | 330UH | L9 | INDUCTOR | 1206/FB | 215nH | L10 | FB_S_2 | 0805/FB | 270nH | L12 | INDUCTOR_3 | 1206/FB | 3.3uH | L14 | INDUCTOR_3 | 1206/FB | 3.3uH | L16 | FB_S_2 | 1206/L | 1uH | L17 | FB_S_2 | 1206/L | 1uH | L18 | FB_S | 0805/FB | 270nH | L19 | L | CDR7D28MN | 10uH | L20 | L | CDR7D28MN | 10uH | L21 | INDUCTOR_0 | 0805/FB | FB31R | L22 | INDUCTOR_0 | 0805/FB | FB31R | L25 | L | CDR7D28MN | 10uH | L26 | L | CDR7D28MN | 10uH | L30 | INDUCTOR_2 | 0805/LA | 27nH | L31 | EMIFIL | NFM21C | NFM21CC471R1H3 | L32 | L2 | 0603/L | 15NH | L34 | L_3 | CDR7D28MN | 10uH | L35 | L_3 | 0805/FB | FB31R | L36 | L_3 | CDR7D28MN | 10uH | MU1 | IC_JN3.B3A2.LR | IC_JN3.B3A2.LR | NEO-6M | Q1 | PNP_2 | TO-252-T | _2SA2072TLQ | Q2 | NPN3 | SOT-23 | PMBT3904 | Q3 | NPN | SOT23A | MMBT3904 | Q4 | DTC_114 | SOT-323 | DTC114EUA | Q5 | PMOS | SOT23-MOS | MI3407 | Q6 | PNP | SOT89 | BCX53-16 | Q8 | PNP_2 | TO-252-T | _2SA2072TLQ | Q9 | DTC_114 | SOT-323 | DTC114EUA | Q11 | DTC_114 | SOT-323 | NC | Q12 | DTC_114 | SOT-323 | DTC114EUA | Q21 | NPN3 | SOT-23 | PMBT3904 | U1 | PCM5102A | PCM5102AA | S U4 | U2 | 78LXX | SOT-89 | 78L18 | U4 | NXP665X | HVQFN32-5X5 | TEF6686 | U5 | VOLTREG | SOT1117-223 | TLV1117LV33DLYR-3.3 | U6 | LM22670 | SO8 | LM9076BMA-3.3 | U7 | VOLTREG | SOT1117-223 | TLV1117LV33DLYR-3.3 | U8 | TPS54386-Q1 | SO-G14 | TPS54386PWPRQ1 | U10 | TPS2543 | S-PWQFN-N16A | TPS2543 | U13 | MC9S08DZ60 | SQFP10X10-64AA | S9S08DZ60MLH_DZMCU | U15 | MIC811 | SOT-143 | TC1270ASVRCTR | U16 | TPS54386-Q1 | SO-G14 | TPS54386PWPRQ1 | U20 | 7388 | FLEXIWAT25/TDA7386 | TDA7388 | U24 | BA14741 | SO14 | BA14741F | U25 | LT1931 | SSOP5 | LT1931ES5 | Y1 | XTAL | SMHF-49B | 4MHz_SMHF-49B | Y2 | XTAL_2 | SMHF-49B | 4MHz |
