[Pads_VX.2x] 再发一个MTK6735 MT6735 智能手机板 PCB和原理图共享
查看6272 | 回复150 | 2022-10-31 11:41:33 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePart TypePCB DecalValue
ANT802ANT_P07-AB001F085ANT_P07-AB001F085_2013P07-AB001F085
ANT803ANT_P07-AB001F085ANT_P07-AB001F085_2013P07-AB001F085
ANT901ANT_P07-AB001F085ANT_P07-AB001F085_2013P07-AB001F085
ANT903ANT_P07-AB001F085ANT_P07-AB001F085_2013P07-AB001F085
D301DIODE_PSBD3D40V1HDIODE_SOD-323PSBD3D40V1H
D302DIO_PZ3D4V2HDIODE_UDZ5V6B_2011PZ3D4V2H
F801FILTER_TPRX_TPX205950MT-7110A1FILTER_SMD_TPX205950MT-7110A1TRPX / TPX205950MT-7110A1
J401BATT_B50-AB04F221BATT_B50-AB04F22A_1407_0818_M5BB50-AB04F221
J410CON_FPC_2PIN_LED_0.5X2.3CON2-2.3X0.5-P1.02PIN 1.0p 0.5*2.3
J501CON_FPC_2PIN_LED_0.5X2.3CON2-2.3X0.5-P1.02PIN 1.0p 0.5*2.3
J503CON_SIM_S80-0B12F16AS80-0B12F16AS80-0B12F16A
J504CON_TF_T08-BB08F230T08-BB08F230T08-BB08F230
J507CON_FPC_8PIN_0.8P_0.4X2.3CON_FPC_8PIN_0.8P_0.4X2.38PIN 0.8p 0.4x2..3
J601CON_AXT524124_24PINAXT524124AXT524124
J602CON_FPC_21PIN_0.4X2.3CON_FPC_21PIN_0.4X2.321PIN 0.4X2.5
J603CON_6PIN_046298706000883CONN_6PIN_(046298004000883)_201104 6298 706 000 883+
J604CON_PF030-O25B-C10-HPF030-O25B-C10-HPF030-O25B-C10-H
J701CON_FPC_6PIN_0.8P_0.4X2.2CON_FPC_6PIN_0.8P_0.4X2.26PIN 0.8p 0.4x2.2
J702CON_FPC_4PIN_0.8P_0.4X2.5CON_FPC_4PIN_0.8P_0.4X2.54PIN 0.8p 0.4x2.5
J703CON_AUDJACK_PH10-2B05F35APH10-2B05F35APH10-2B05F35A
J704CON_FPC_21PIN_0.4X2.5CON_FPC_21PIN_0.4X2.521PIN 0.4X2.5
J901CON_RF_C90P106-00004AHRF_C90P106-00004AHC90P106-00004AH
J1001CON_ANT_70369-001ECOAXLAL-81800015770369-001E
J1005CON_RF_C90P106-00004AHRF_C90P106-00004AHC90P106-00004AH
L304IND3X3_10UH_1.2MMIND3X310uH 1.2MM
L333IND-BLM15HD102SN1DBLM15B1000@100M_HD
L335IND-BLM15AX102SN1BLM15B1000@100M_AX
L402IND_WPN252012HR33MTL_LQM2HPN2R2MG0_20110.33uH
L404IND_WPN201610UR47MTL/IND/SMD/VLS201610E_14060.47uH 2016
L405IND_WPN201610UR47MTL/IND/SMD/VLS201610E_14060.47uH 2016
L407IND_WPN201610UR47MTL/IND/SMD/VLS201610E_14060.47uH 2016
L410IND_SPH252010L2R2MTL_LQM2HPN2R2MG0_20112.2uH 2520
L501RES0402_0R_5%RES04020
L601RES0402_0R_5%RES04020
L612RES0201_33R_5%RES020133
L613RES0201_33R_5%RES020133
L701IND-BLM15AX102SN1BLM15B1000@100M_AX
L702IND-BLM15AX102SN1BLM15B1000@100M_AX
L705IND-UPZ1005D221-R90TFBLM15B220@100M_AX
L706IND-UPZ1005D221-R90TFBLM15B220@100M_AX
L707IND-BLM15BD182SN1DBLM15B1800@100M_BD
L708IND-BLM15BD182SN1DBLM15B1800@100M_BD
L709IND-BLM15BD182SN1DBLM15B1800@100M_BD
L710IND-BLM15BD182SN1DBLM15B1800@100M_BD
L800IND-BLM15AX102SN1BLM15B1000@100M_AX
L801IND0201_NCIND0201IND0201 NC
L1159IND0201P_2.7NHIND02012.7nH
M901RES0201_0R_5%RES02010
M903RES0201_0R_5%RES0201NC
M904RES0201_0R_5%RES0201NC
MARK1MARK_TBMARK_TB
MARK2MARK_TBMARK_TB
MOTORFPC_2PIN_1.1X2.0_P2.1FPC_2PIN_1.1X2.0_P2.12PIN 1.1X2.0 P2.1
Q401MOS-SSM3K35MFV2-1L1B/SMD/SSM3K35MFVSSM3K35MFV
REC1FPC_2PIN_1.1X2.0_P2.1FPC_2PIN_1.1X2.0_P2.12PIN 1.1X2.0 P2.1
REC2FPC_2PIN_1.1X2.0_P2.1FPC_2PIN_1.1X2.0_P2.12PIN 1.1X2.0 P2.1
T514ESD9L5.0ST5G_SOD-923ESD_SOD-923SOD923   ESD9L5.0ST5G
T515ESD9L5.0ST5G_SOD-923ESD_SOD-923SOD923   ESD9L5.0ST5G
T517SDV1005E090C800NPTFVR04029V 80pf
T610TVS-ESD9M5.0ST5G_ESD_SOD-923ESD_SOD-923ESD9M5.0ST5G
T611TVS-ESD9M5.0ST5G_ESD_SOD-923ESD_SOD-923ESD9M5.0ST5G
T612TVS-ESD9M5.0ST5G_ESD_SOD-923ESD_SOD-923ESD9M5.0ST5G
T613TVS-ESD9M5.0ST5G_ESD_SOD-923ESD_SOD-923ESD9M5.0ST5G
T614TVS-ESD9M5.0ST5G_ESD_SOD-923ESD_SOD-923ESD9M5.0ST5G
T701ESD_ESDBVD5V0Y1ESD_04021.5pF 5V
T702ESD_ESDBVD5V0Y1ESD_04021.5pF 5V
T703TVS-ESD9M5.0ST5G_ESD_SOD-923ESD_SOD-923ESD9M5.0ST5G
T704TVS-ESD9M5.0ST5G_ESD_SOD-923ESD_SOD-923ESD9M5.0ST5G
T705TVS-ESD9M5.0ST5G_ESD_SOD-923ESD_SOD-923ESD9M5.0ST5G
T706TVS-ESD9M5.0ST5G_ESD_SOD-923ESD_SOD-923ESD9M5.0ST5G
T707TVS-ESD9M5.0ST5G_ESD_SOD-923ESD_SOD-923ESD9M5.0ST5G
T708TVS-ESD9M5.0ST5G_ESD_SOD-923ESD_SOD-923ESD9M5.0ST5G
T709ESD_ESDBVD5V0Y1ESD_04021.5pF 5V
T710ESD_ESDBVD5V0Y1ESD_04021.5pF 5V
T711ESD_ESDBVD5V0Y1ESD_04021.5pF 5V
T712ESD_ESDBVD5V0Y1ESD_04021.5pF 5V
T713ESD_ESDBVD5V0Y1ESD_04021.5pF 5V
T714ESD_ESDBVD5V0Y1ESD_04021.5pF 5V
T715TVS-ESD9M5.0ST5G_ESD_SOD-923ESD_SOD-923ESD9M5.0ST5G
T716ESD9L5.0ST5G_SOD-923ESD_SOD-923SOD923   ESD9L5.0ST5G
T717ESD9L5.0ST5G_SOD-923ESD_SOD-923SOD923   ESD9L5.0ST5G
T719ESD9L5.0ST5G_SOD-923ESD_SOD-923SOD923   ESD9L5.0ST5G
T720ESD_ESDBVD5V0Y1ESD_04021.5pF 5V
T721ESD_ESDBVD5V0Y1ESD_04021.5pF 5V
T728ESD_ESDBVD5V0Y1ESD_04021.5pF 5V
T800ESD_ESDPSA0402V05ESD_0402NC
TVS515TVS-ESD9M5.0ST5G_ESD_SOD-923ESD_SOD-923ESD9M5.0ST5G
TVS518TVS-ESD9M5.0ST5G_ESD_SOD-923ESD_SOD-923ESD9M5.0ST5G
U101IC-MT6735-LP3-E1-SBS_MAP0827AMT6735/VFBGA641/P0.4/B0.25/12.6X12.6MT6735
U300IC/MT6328-E1/XXXMM_41_205BALL_1503MT6328/VFBGA205/P0.4/B0.25/6.6X6.6_1503MT6328E1
U405SGM3726YTD16G/TR_TDFN-2X2-6LSGM3726YTD16G/TR_TDFN-2X2-6LSGM3726
U406CAP0805_47UFCAP080547uF
U407STT818B_SOT23-6LSOT23-6L(PT236T30E2/STT818B)_2011STT818B
U410TDFN10_SMD_P0.5_SGM3141BTDFN10_SMD_P0.5_SGM3141BSGM3141B
U501KXTJ2_1009KXTJ2_1.0_2013KXTJ2-1009
U502ET4003YD18_2013ET4003YD_0.9MM_20140123ET4003YD18
U503LDO_SGM2030_2.5VSGM2030SGM2030-2.5YUDG4G/TR
U600EXC14CE900UEXC14CE900UEXC14CE900U
U601EXC14CE900UEXC14CE900UEXC14CE900U
U602EXC14CE900UEXC14CE900UEXC14CE900U
U603EXC14CE900UEXC14CE900UEXC14CE900U
U604EXC14CE900UEXC14CE900UEXC14CE900U
U605LDO_SGM2030SGM2030NC
U606EXC14CE900UEXC14CE900UEXC14CE900U
U608EXC14CE900UEXC14CE900UEXC14CE900U
U610EXC14CE900UEXC14CE900UEXC14CE900U
U611EXC14CE900UEXC14CE900UEXC14CE900U
U612LP_DDR3_FBGA221_P0.5/B0.27/11.5X13FBGA221_P0.5/B0.27/11.5X13/SAMSUNGLPDDR3+eMMC
U613EXC14CE900UEXC14CE900UEXC14CE900U
U614EXC14CE900UEXC14CE900UEXC14CE900U
U615EXC14CE900UEXC14CE900UEXC14CE900U
U616EXC14CE900UEXC14CE900UEXC14CE900U
U701AW8736FCRAW8736FCRAW8736FCR
U801SAW_SAFEA2G45MC0F0ASAW1411_2015SAFEA2G45MC0F0A
U802MT6625L_QFN40MT6625_SQFN40/SMD/P0.4/5X5QFN40/MT6625L
U803SAW_SF14-1575F5UUA1_2011SAW1411_2015SF14-1575F5UUA1
U804BGU7005DALLAS/MAX2659_2011BGU7005
U901SAW-SAFFB2G35AA0F0ASAW1109/B1/2/3/5/7/17/39/2GEGSM_DRX_1404SAFFB2G35AA0F0A
U902LDM152G4910QC032TEMPBALUN/LDM152G4910QC032TEMP_1404LDM152G4910QC032TEMP
U903LDM152G4910QC032TEMPBALUN/LDM152G4910QC032TEMP_1404LDM152G4910QC032TEMP
U904SAW-SAFFB2G60AA1F0ASAW1109/B1/2/3/5/7/17/39/2GEGSM_DRX_1404SAFFB2G60AA1F0A
U906MT6169/VFBGA175/P0.4/B0.25/6.2X5.4MT6169/VFBGA175/P0.4/B0.25/6.2X5.4MT6169
U908KT2520F26000DCW28QAKTCXO/SMD/2.5X2.0/KT2520FKT2520F26000DCW28QAK
U909SPDT_/_SKYWORKS_/_SKY13373SKY13373SKY13373
U910SAW-SAFFB1G90FB0F0ASAW1109/B1/2/3/5/7/17/39/2GEGSM_DRX_1404SAFFB1G90FB0F0A
U1000PA_/_SKY77824-11SKY77824SKY77824-11
U1001SAW_SAFEA2G60MA0F0ASAW1411_2015SAFEA2G60MA0F0A
U1002SAW_SAFEA2G35MF0F0ASAW1411_2015SAFEA2G35MF0F0A
U1004LF1608-B2R5KCBRF_LPF_DEA162690LT_1404LF1608-B2R5KCB
U1011SAW_SAWEN1G84CW0F00R14SAW/SMD/SAWEN881MCY0F00R14SAWEN1G84CW0F00R14
U1102SAW-SAWEN881MCY0F00R14SAW-SAWEN881MCY0F00R14SAWEN881MCY0F00R14
U1103SAW-SAWFD1G90BK0F0ASAW-SAWFD1G90BK0F0ASAWFD1G90BK0F0A
U1104LDM152G4910QC032TEMPBALUN/LDM152G4910QC032TEMP_1404LDM152G4910QC032TEMP
U1107SKY77910-11SKY77910SKY77910-11
X401CRYSTAL_FC135_32.768_2011CRYSTAL_FC135_32.768_201132.768K
Y801KT2520P26000ACW28TAA_6620_2011KT2520P26000ACW28TAA_6620_2011KT2520P26000ACW28TAA
重要提示:PCB作品文件展下载说明
老吴 | 2022-10-31 11:42:58 | 显示全部楼层
PCB 原理图都是PADS格式。回复可见下载
游客,如果您要查看本帖隐藏内容请回复
renjiawu | 2022-10-31 11:50:58 | 显示全部楼层
weiziushi | 2022-10-31 12:42:07 | 显示全部楼层
cookoko | 2022-10-31 13:39:46 | 显示全部楼层
li1011 | 2022-10-31 14:36:36 | 显示全部楼层
翻身的闲鱼 | 2022-10-31 14:43:13 | 显示全部楼层
ntpcb3356619 | 2022-10-31 15:03:18 | 显示全部楼层
神话2013 | 2022-10-31 15:39:01 | 显示全部楼层
回 老吴 的帖子
老吴:PCB 原理图都是PADS格式。回复可见下载
[内容隐藏]
 (2022-10-31 11:42)
谢谢分享!
cctv1 | 2022-10-31 15:40:14 | 显示全部楼层
