REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
D1200 | DIODEBI_DIR TRIG_ESD0402_ESD5451N | ESD5451N | ESD0402 |
D1500 | DIODEBI_DIR TRIG_ESD0402_ESD5451N | ESD5451N | ESD0402 |
D2000 | DIODE_DO_214AC_SS32 | SS32 | DO_214AC |
D2500 | DIODEBI_DIR TRIG_ESD0402_ESD5341N | ESD5341N | ESD0402 |
D4207 | DIODEBI_DIR TRIG_ESD0402_ESD5451N | ESD5451N | ESD0402 |
D5000 | DIODE_SOD_323_B5819WS | B5819WS | SOD_323 |
D5001 | DIODE_SOD_123_B5819W | B5819W | SOD_123 |
D6800 | BA301N_3_SMB_F_BS3500NCF | BS3500NCF | SMB_F |
D6801 | BA301N_3_SMB_F_BS3500NCF | BS3500NCF | SMB_F |
D6802 | BA301N_3_SMB_F_BS3500NCF | BS3500NCF | SMB_F |
D6803 | BA301N_3_SMB_F_BS3500NCF | BS3500NCF | SMB_F |
D7600 | DIODEBI_DIR TRIG_ESD0402_ESD5341N | ESD5341N | ESD0402 |
DJ7600 | GP1FD310TP1_0_DLT2160A_DLT2160A | DLT2160A | DLT2160A |
ED5000 | DIODEBI_DIR TRIG_ESD0402_ESD5341N | ESD5341N | ESD0402 |
ED5001 | DIODEBI_DIR TRIG_ESD0402_ESD5341N | ESD5341N | ESD0402 |
ED5002 | DIODEBI_DIR TRIG_ESD0402_ESD5341N | ESD5341N | ESD0402 |
ED5003 | DIODEBI_DIR TRIG_ESD0402_ESD5341N | ESD5341N | ESD0402 |
ED6800 | DIODEBI_DIR TRIG_SOD_323_UDD32C03L01 | UDD32C03L01 | SOD_323 |
ED6801 | DIODEBI_DIR TRIG_SOD_323_UDD32C03L01 | UDD32C03L01 | SOD_323 |
ED6802 | DIODEBI_DIR TRIG_SOD_323_UDD32C03L01 | UDD32C03L01 | SOD_323 |
ED6803 | DIODEBI_DIR TRIG_SOD_323_UDD32C03L01 | UDD32C03L01 | SOD_323 |
F2000 | FUSE_R1206_0R | 0R | R1206 |
FB2100 | BEAD_L0603_180R-100M | 180R-100M | L0603 |
FB2101 | BEAD_L0603_180R-100M | 180R-100M | L0603 |
FB6800 | BEAD_L0603_120R-100MHZ | 120R-100MHz | L0603 |
H9900 | HOLE_HOLE_C3R20_C6R00_HOLE_3R20 | HOLE_3R20 | HOLE_C3R20_C6R00 |
H9901 | HOLE_HOLE_C3R20_C6R00_HOLE_3R20 | HOLE_3R20 | HOLE_C3R20_C6R00 |
H9902 | HOLE_HOLE_C3R20_C6R00_HOLE_3R20 | HOLE_3R20 | HOLE_C3R20_C6R00 |
H9903 | HOLE_HOLE_C3R20_C6R00_HOLE_3R20 | HOLE_3R20 | HOLE_C3R20_C6R00 |
J2000 | DCJACK_3P_DC3_DC_0007_5P_DC-0007-5P | DC-0007-5P | DC3_DC_0007_5P |
J2500 | J_USB20_AF-13R7_USB20_AF-13R7 | USB20_AF-13R7 | USB20_AF-13R7 |
J2501 | USB30_TYPE_A_V_2_USB30A9_25R70X7R32X13R85_USB30_A_V | USB30_A_V | USB30A9_25R70X7R32X13R85 |
J2502 | J_USB20_AF-13R7_USB20_AF-13R7 | USB20_AF-13R7 | USB20_AF-13R7 |
J2503 | J_USB20_AF-13R7_USB20_AF-13R7 | USB20_AF-13R7 | USB20_AF-13R7 |
J4200 | TFCARD_SOCKET_TF9_TFP09-2-12B_TFP09-2-12B | TFP09-2-12B | TF9_TFP09-2-12B |
J4700 | 24FPC_CNN24_1R00_FP05SL_V_MIPI_CSI_RX | MIPI_CSI_RX | CNN24_1R00_FP05SL_V |
J5000 | HDMI_TYPE_A_0_HDMIA19_HDMI_01A_HDMI_TYPE_A | HDMI_TYPE_A | HDMIA19_HDMI_01A |
J6800 | RJSAE5F8002_0_RJ45_5812-10P8C-A_RJ45_5812-10P8C-A_TAB-DOWN | RJ45_5812-10P8C-A_Tab-Down | RJ45_5812-10P8C-A |
J9101 | USB20_MINI_USB20MIN5_USB_M5_03_002_USB20_MINI | USB20_mini | USB20MIN5_USB_M5_03_002 |
L1701 | INDUCTORCOM_RP2_0405_NC | NC | RP2_0405 |
L2000 | INDUCTORSOF FERRITE_IND_606045_6.8UH | 6.8uH | IND_606045 |
L2001 | INDUCTORSOF FERRITE_IND_404026_2.2UH | 2.2uH | IND_404026 |
L2100 | INDUCTORSOF FERRITE_IND_404026_2.2UH | 2.2uH | IND_404026 |
L2101 | INDUCTORSOF FERRITE_IND_404030_1.0UH | 1.0uH | IND_404030 |
L2102 | INDUCTORSOF FERRITE_IND_404030_1.0UH | 1.0uH | IND_404030 |
L2500 | INDUCTORCOM_RP2_0405_NC | NC | RP2_0405 |
L2501 | INDUCTORCOM_RP2_0405_NC | NC | RP2_0405 |
L4500 | INDUCTORSOF FERRITE_IND_404026_2.2UH | 2.2uH | IND_404026 |
L6800 | INDUCTORSOF FERRITE_IND_303015_2.2UH | 2.2uH | IND_303015 |
LED2000 | LED_LED0603_LED_GREEN | LED_GREEN | LED0603 |
LED2001 | LED_LED0603_LED_BLUE | LED_BLUE | LED0603 |
LED6801 | LED_LED0603_LED_YELLOW | LED_Yellow | LED0603 |
LED6802 | LED_LED0603_LED_GREEN | LED_GREEN | LED0603 |
LED9100 | LED_LED0603_LED_RED | LED_RED | LED0603 |
M9900 | MARK_MARK_MARK | MARK | MARK |
M9901 | MARK_MARK_MARK | MARK | MARK |
M9902 | MARK_MARK_MARK | MARK | MARK |
M9903 | MARK_MARK_MARK | MARK | MARK |
M9904 | MARK_MARK_MARK | MARK | MARK |
M9905 | MARK_MARK_MARK | MARK | MARK |
Q2100 | MOSFETP_SOT_23_WPM3407-3/TR | WPM3407-3/TR | SOT_23 |
Q2101 | NPN_SOT_23_S8050 | S8050 | SOT_23 |
Q4200 | MOSFETP_SOT_23_WPM2015-3/TR | WPM2015-3/TR | SOT_23 |
Q4201 | NPN_SOT_23_S8050 | S8050 | SOT_23 |
Q5000 | MOSFETN_SOT_323_2SK3018 | 2SK3018 | SOT_323 |
Q5001 | MOSFETN_SOT_323_2SK3018 | 2SK3018 | SOT_323 |
Q5002 | MOSFETN_SOT_323_2SK3018 | 2SK3018 | SOT_323 |
SW1200 | KEY_4PIN_SW4_6R50X7R00X7R10_TS-1138V1 | TS-1138V1 | SW4_6R50X7R00X7R10 |
SW1500 | KEY_4PIN_SW4_6R50X7R00X7R10_TS-1138V1 | TS-1138V1 | SW4_6R50X7R00X7R10 |
TP1200 | TP_TP_0R70_TP_0.7 | TP_0.7 | TP_0R70 |
TP1300 | TP_TP_0R70_EMMC_D0/FLASH_D0 | eMMC_D0/FLASH_D0 | TP_0R70 |
TP1301 | TP_TP_0R70_GND | GND | TP_0R70 |
TP1501 | TP_TP_0R70_TP_0.7 | TP_0.7 | TP_0R70 |
U1000 | SOC_RK3566_BGA565_15R50X14R40X0R90_RK3566 | RK3566 | BGA565_15R50X14R40X0R90 |
U1200 | VOLTAGE_DETECTOR_CE8809_SOT_23_TCS9819 | TCS9819 | SOT_23 |
U2000 | DCDC_SY8113_SOT_23_6_SY8113B/SM8103ADC | SY8113B/SM8103ADC | SOT_23_6 |
U2001 | DCDC_SY8088_SOT_23_5_ETA3409/SY8089AAC | ETA3409/SY8089AAC | SOT_23_5 |
U2100 | LDO_LP3983S_SOT_23_5_LP3983S | LP3983S | SOT_23_5 |
U2101 | DCDC_SY8088_SOT_23_5_ETA3409/SY8089AAC | ETA3409/SY8089AAC | SOT_23_5 |
U2102 | DCDC_SY8088_SOT_23_5_ETA3446 | ETA3446 | SOT_23_5 |
U2103 | DCDC_SY8088_SOT_23_5_ETA3446 | ETA3446 | SOT_23_5 |
U2104 | LDO_PT5108_SOT_23_5_PT5108E23E-18 | PT5108E23E-18 | SOT_23_5 |
U2105 | LDO_PT5108_SOT_23_5_PT5108E23E-18 | PT5108E23E-18 | SOT_23_5 |
U2300 | LDO_PT5108_SOT_23_5_PT5108E23E-18 | PT5108E23E-18 | SOT_23_5 |
U2500 | SWITCH_SY6280_SOT_23_5_SY6280AAC | SY6280AAC | SOT_23_5 |
U2501 | SWITCH_SY6280_SOT_23_5_SY6280AAC | SY6280AAC | SOT_23_5 |
U2502 | SWITCH_SY6280_SOT_23_5_SY6280AAC | SY6280AAC | SOT_23_5 |
U3600 | DDR4_0_FBGA78_15R50X9R00X1R20_DDR4_8BIT | DDR4_8bit | FBGA78_15R50X9R00X1R20 |
U3601 | DDR4_0_FBGA78_15R50X9R00X1R20_DDR4_8BIT | DDR4_8bit | FBGA78_15R50X9R00X1R20 |
U3602 | DDR4_0_FBGA78_15R50X9R00X1R20_DDR4_8BIT | DDR4_8bit | FBGA78_15R50X9R00X1R20 |
U3603 | DDR4_0_FBGA78_15R50X9R00X1R20_DDR4_8BIT | DDR4_8bit | FBGA78_15R50X9R00X1R20 |
U3604 | LDO_PT5108_SOT_23_5_PT5108E23E-25 | PT5108E23E-25 | SOT_23_5 |
U4000 | INAND_EMMC_153_2L_BGA153_13RX11R5X0R9_2L_EMMC_B153_2L | EMMC_B153_2L | BGA153_13RX11R5X0R9_2L |
U4100 | NANDFLASH_TSOP48_TSOP48_18R40X12R10X1R20_NAND_FLASH | NAND_FLASH | TSOP48_18R40X12R10X1R20 |
U4200 | LDO_LP3983S_SOT_23_5_LP3983S | LP3983S | SOT_23_5 |
U4500 | DCDC_SY8088_SOT_23_5_SY8089AAC | SY8089AAC | SOT_23_5 |
U4501 | LDO_LP3983S_SOT_23_5_LP3983S | LP3983S | SOT_23_5 |
U4502 | LDO_PT5108_SOT_23_5_PT5108E23E-18 | PT5108E23E-18 | SOT_23_5 |
U4503 | LDO_PT5108_SOT_23_5_PT5108E23E-28 | PT5108E23E-28 | SOT_23_5 |
U5000 | ESD_ESD5304D_SON10_2R50X1R00X0R50_ESD5304D | ESD5304D | SON10_2R50X1R00X0R50 |
U5001 | ESD_ESD5304D_SON10_2R50X1R00X0R50_ESD5304D | ESD5304D | SON10_2R50X1R00X0R50 |
U6800 | ETHERNET_H5007_SOIC24_15R10X7R10X4R75_G2406S/QT24A29 | G2406S/QT24A29 | SOIC24_15R10X7R10X4R75 |
U6801 | ETHERNET_RTL8211F_QFN40_5R00X5R00X0R90_T_RTL8211F-CG | RTL8211F-CG | QFN40_5R00X5R00X0R90_T |
U9100 | INTERFACE_FT232RL_SSOP28_10R20X5R30X2R00_FT232RL | FT232RL | SSOP28_10R20X5R30X2R00 |
Y1200 | CRYSTAL_4P_CRY4_3R20X2R50X0R80_24MHZ | 24MHz | CRY4_3R20X2R50X0R80 |
Y6800 | CRYSTAL_4P_CRY4_3R20X2R50X0R80_25MHZ | 25MHz | CRY4_3R20X2R50X0R80 |
