重要提示:PCB作品文件展下载说明
CCM4101_QFN48_40PIN_LCD_EVB_V1D0.7z
(289.99 KB, 下载次数: 10)
REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | D1 | ZENER DIODES_SOD123_BZT52C5V1 | BZT52C5V1 | SOD123 | D2 | DIODE TVS_SOD-523_ESD5Z6.0T1G-M | ESD5Z6.0T1G-MS | SOD-523 | D3 | DIODE TVS_SOD-523_ESD5Z6.0T1G-M | ESD5Z6.0T1G-MS | SOD-523 | ED1 | DIODE_TVS_ESD0402B_ESD5451N | ESD5451N | ESD0402B | ED18 | DIODE_TVS_ESD0402B_ESD5451N | ESD5451N | ESD0402B | HOLE1 | HOLE3MM_HOLE3MM_HOLE3MM | Hole3mm | HOLE3MM | HOLE2 | HOLE3MM_HOLE3MM_HOLE3MM | Hole3mm | HOLE3MM | HOLE3 | HOLE3MM_HOLE3MM_HOLE3MM | Hole3mm | HOLE3MM | HOLE4 | HOLE3MM_HOLE3MM_HOLE3MM | Hole3mm | HOLE3MM | J1 | JACK_JACK_JACK | JACK | JACK | J2 | JUMPER_SIP2_JUMPER | JUMPER | SIP2 | J3 | CON6_SIP6_SIP6 | SIP6 | SIP6 | J4 | TF_SCK_TF_SCK_TF_SCK | TF_SCK | TF_SCK | J5 | SIP4_SIP4_SIP4 | SIP4 | SIP4 | J6 | CON8_1_FPC_8_FPC_PIN8 | FPC_PIN8 | FPC_8 | J8 | SIP4_SIP4_SIP4 | SIP4 | SIP4 | J9 | SIP4_SIP4_SIP4 | SIP4 | SIP4 | J10 | CON4_2_SMD2_5_1X4P_SMD_CON4 | SMD_CON4 | SMD2_5_1X4P | J11 | SIP4_SIP4_SIP4 | SIP4 | SIP4 | J12 | SIP4_SIP4_SIP4 | SIP4 | SIP4 | J13 | SIP4_SIP4_SIP4 | SIP4 | SIP4 | J14 | SIP4_SIP4_SIP4 | SIP4 | SIP4 | J15 | SIP4_SIP4_SIP4 | SIP4 | SIP4 | J16 | SIP4_SIP4_SIP4 | SIP4 | SIP4 | J17 | CON42_1_FPC_40_CON42_1 | CON42_1 | FPC_40 | J18 | CON9_SIP9_SIP9 | SIP9 | SIP9 | J19 | CON9_SIP9_SIP9 | SIP9 | SIP9 | J20 | SIP4_SIP4_SIP4 | SIP4 | SIP4 | J21 | SIP4_SIP4_SIP4 | SIP4 | SIP4 | J22 | CON8_SIP8_SIP8 | SIP8 | SIP8 | J23 | CON8_SIP8_SIP8 | SIP8 | SIP8 | J24 | JUMPER_SIP2_JUMPER | JUMPER | SIP2 | J25 | JUMPER_SIP2_JUMPER | JUMPER | SIP2 | J26 | JUMPER_SIP2_JUMPER | JUMPER | SIP2 | J27 | CON8_SIP8_SIP8 | SIP8 | SIP8 | J28 | CON8_SIP8_SIP8 | SIP8 | SIP8 | J29 | TP_SIP1_TP | TP | SIP1 | J30 | JUMPER_SIP2_JUMPER | JUMPER | SIP2 | L1 | L_SMDL52_47_30_4.7UH/3.0A | 4.7uH/3.0A | SMDL52_47_30 | LED1 | LED0805_LED0805_LED_RED | LED_Red | LED0805 | LED2 | LED0805_LED0805_LED_RED | LED_Red | LED0805 | PZ1 | PIEZO BUZZER_0_BUZZER_BUZZER | BUZZER | BUZZER | Q1 | 2N7002_SOT23_2N7002 | 2N7002 | SOT23 | Q2 | 2N7002_SOT23_2N7002 | 2N7002 | SOT23 | Q3 | N_MOS_SOT23_2N7002 | 2N7002 | SOT23 | Q4 | SS8550_SOT23_SS8550 | SS8550 | SOT23 | SW1 | SW-P-5_SPDT_SW-P-5 | SW-P-5 | SPDT | U1 | W25Q128FVSIG_SOP8_150_WSON8_5X6 | PY25Q128HA-SUH-IT/NC | SOP8_150_WSON8_5X6 | U2 | CCM4101_QFN48_QFN48W6H6_0D4_TES | CCM4101_QFN48 | QFN48W6H6_0D4_TEST_SCK | U3 | MPS1497DJ_1_TSOT_26_AP62200 | AP62200 | TSOT_26 |
重要提示:PCB作品文件展下载说明
