[IC] SGM8904
查看48 | 回复0 | 2024-9-23 14:59:56 | 显示全部楼层 |阅读模式
圣邦威
SGM8904
● Capless Structure
Eliminates Pop/Clicks
Eliminates Output DC-Blocking Capacitors
Provides Flat Frequency Response from DC to 20kHz
● Low Noise and THD
Typical SNR = 114dB
Typical V N  = 5.4μVrms
Typical THD+N = 0.001% (f = 1kHz)
● 2Vrms Output Voltage into 2.5kΩ Load with 3.3V
Supply Voltage
● 3Vrms  Output  Voltage  into  2.5kΩ  Load  with  5V
Supply Voltage
● -40℃ to +85℃ Operating Temperature Range
● Available in the Green MSOP-10 Package
SGM8904.pdf
1.53 MB, 下载次数: 0, 下载积分: 金币 -1 枚
售价: 1 枚金币  [记录]  [购买]
