查看: 47412|回复: 293
[PADS9.5以下] 发个整套的机顶盒资料,PADS的,好东西啊,我都舍不得发
发表于 2012-8-23 13:56:16 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
发个整套的机顶盒资料,PADS的,好东西啊,我都舍不得发,有带电原有不带的,可以直接使用。
带电原PCB
带电原PCB
GSR-K101.B.M.rar (823 KB, 下载次数: 186)
****************以下信息由管理员 @老吴   编辑添加*******************
板子有以下封装,如有需要可以下载提取使用。
NameValuePCB DecalPart Type
A2HOLE-PAD0-1.4PAD
C1473CAP0603CAP
C20.1UFCAP0603CAP
C3270pFCAP0603CAP
C4270pFCAP0603CAP
C5270pFCAP0603CAP
C6104CAP0603CAP
C7104CAP0603CAP
C80.1UFCAP0603CAP
C9103pFCAP0603CAP
C100.1UFCAP0603CAP
C110.1UFCAP0603CAP
C120.1UFCAP0603CAP
C13100nFCAP0603CAP
C144.7ufCAP0805CAP
C154.7ufCAP0805CAP
C1610uFCAP0805CAP
C1710uFCAP0805CAP
C1810uFCAP0805CAP
C191nFCAP0603CAP
C200.1UFCAP0603CAP
C21104CAP0603CAP
C22104CAP0603CAP
C23104CAP0603CAP
C24104CAP0603CAP
C25104CAP0603CAP
C26104CAP0603CAP
C27104CAP0603CAP
C28104CAP0603CAP
C29104CAP0603CAP
C3027PCAP0603CAP
C3127PCAP0603CAP
C32104CAP0603CAP
C33102CAP0603CAP
C34104CAP0603CAP
C35102CAP0603CAP
C36104CAP0603CAP
C37104CAP0603CAP
C38104CAP0603CAP
C39270pFCAP0603CAP
C40104CAP0603CAP
C41104CAP0603CAP
C4210uFCAP0805CAP
C43104CAP0603CAP
C4410uFCAP0805CAP
C4510uFCAP0805CAP
C46104CAP0603CAP
C47104CAP0603CAP
C48104CAP0603CAP
C49104CAP0603CAP
C50104CAP0603CAP
C51100n,NICAP0603CAP
C52104CAP0603CAP
C53102CAP0603CAP
C54102CAP0603CAP
C55104CAP0603CAP
C56104CAP0603CAP
C57270pFCAP0603CAP
C58270pFCAP0603CAP
C5922PCAP0603CAP
C6010PCAP0603CAP
C61270pfCAP-CC-P5BCAP
C62100PCAP0603CAP
C63100nFCAP0603CAP
C64100nFCAP0603CAP
C65100nFCAP0603CAP
C66100nFCAP0603CAP
C67100nFCAP0603CAP
C68100nFCAP0603CAP
C694.7uFCAP0805CAP
C70104CAP0603CAP
C7110PCAP0603CAP
C72100nFCAP0603CAP
C7310PCAP0603CAP
C74100nFCAP0603CAP
C75270pfCAP-CC-P5BCAP
C80CAP0603CAP-SMD
C84390CAP0603CAP
C85390CAP0603CAP
C86270pfCAP-CC-P5BCAP
C871000PCAP0603CAP
C881000PCAP0603CAP
C91104pFCAP0603CAP
C92CAP0603CAP-SMD
C94CAP0603CAP-SMD
C95CAP0603CAP-SMD
C96CAP0603CAP-SMD
C97CAP0603CAP-SMD
C98270PCAP0603CAP
C10022PCAP0603CAP
C101270PCAP0603CAP
C102330PCAP0603CAP
C10322PCAP0603CAP
C104270PCAP0603CAP
C105330PCAP0603CAP
C10622PCAP0603CAP
C1090.1ufCAP0603CAP
C11110nFCAP0603CAP
C112100nFCAP0603CAP
C114104CAP0603CAP
C115104CAP0603CAP
C11747PCAP0603CAP
C11856PCAP0603CAP
C11956PCAP0603CAP
C12010nFCAP0603CAP
C121220PCAP0603CAP
C12222PCAP0603CAP
C123104CAP0603CAP
C124102CAP0603CAP
C1251PCAP0603ACAP
C1261uFCAP0603CAP
C127103CAP0603CAP
C128100PCAP0603CAP
C1291PCAP0603ACAP
C13010PCAP0603CAP
C13122PCAP0603CAP
C13210PCAP0603CAP
C13322PCAP0603CAP
C13410nFCAP0603CAP
C13510nFCAP0603CAP
C136104CAP0603CAP
C13710PCAP0603CAP
C13822PCAP0603CAP
C13910nFCAP0603CAP
C14022PCAP0603CAP
C14110PCAP0603CAP
C14210nFCAP0603CAP
C14310PCAP0603CAP
C14410PCAP0603CAP
C1454.7kCAP0603CAP
C1461nFCAP0603CAP
C1472.2nFCAP0603CAP
C14847PCAP0603ACAP
C14947PCAP0603ACAP
C1501nFCAP0603CAP
C1511nFCAP0603CAP
C153220nFCAP0603CAP
C15410nFCAP0603CAP
C170104CAP0603CAP
C171104CAP0603CAP
C172104CAP0603CAP
C1731uFCAP0603CAP
C174102CAP0603CAP
C201104CAP0603CAP
C301104CAP0603CAP
C302NC/1000PCAP0603CAP
C303100nFCAP0603CAP
C304330PCAP0603CAP
C30510u805CAP0805
C3074.7uFCAP0805CAP
C50347pFCAP0603CAP
CE6220uFCAPE/2.5/6CAPE
CE710uF/10VCAPE/2/5CAPE
CE847uFCAPE/2/5CAPE
CE9100uFCAPE/2/5CAPE
CE10100u/16VCAPE/2/5CAPE
CE13100u/16VCAPE/2/5CAPE
CE14100UFCAPE/2/5CAPE
CE2010U/50VCAPE/2.5/6CAPE
CE2410uF/16VCAPE/2/5CAPE
CE25220uFCAPE/2.5/6CAPE
CE27100uF/16VCAPE/2/5CAPE
CE39CE-D10-P5C-ECAP-V
CE60CE-D6.3-P2.5C-ECAP-V
CE61CE-D6.3-P2.5C-ECAP-V
CE76CE-D10-P5C-ECAP-V
CE79CE-D16-P7.5C-ECAP-V
CE80CE-D5-P2.5C-ECAP-V
CE81CE-D6.3-P2.5C-ECAP-V
CE82CE-D6.3-P2.5C-ECAP-V
CE83CE-D8-P3.5C-ECAP-V
CE89CE-D10-P5C-ECAP-V
CE97CE-D6.3-P2.5C-ECAP-V
CE501100uF/16VCAPE/2/5CAPE
CN1CON-8/2MMCON-8
CN3CON-2P-P7.6CON-2P-A
CX1CAP-X-P15-T8.5CAP-X
CY1CAP-Y-P10-T5CAP-Y
D1DIO-DO201ADV-P8DIODE-DO201AD/DO15
D2M2DIO-1210DIO
D3M2DIO-1210DIO
D4DIO-DO15H-P11DIODE-DO201AD/DO15
D5DIO-DO41H-P10DIODE-DO41/DO35
D61608/8BAR63-03
D7DIO-DO41V-P3DIODE-DO41/DO35
D8DIO-DO41H-P10DIODE-DO41/DO35
D9DIO-DO41H-P10DIODE-DO41/DO35
D10DIO-DO41V-P4ADIODE-DO41/DO35
D11M2DIO-31N4001
D12FR104DIO-31N4001
D13DIO-DO41V-P4ADIODE-DO41/DO35
D14DIO-DO41H-P10DIODE-DO41/DO35
D15DIO-DO201ADV-P8DIODE-DO201AD/DO15
D16M2DIO-31N4001
D17M2DIO-31N4001
D18M2DIO-1210DIO
D19M2DIO-31N4001
E1NCRES0603RES
E2NCRES0603RES
F1FUS-3X10-LEAD-2P-V7.5FUSE-2P
H1HOLE(F)NHHOLE(F)
H2HOLE(F)NHHOLE(F)
H3HOLE(F)NHHOLE(F)
H7HOLE(F)NHHOLE(F)
I1HOLE(5.0)HOLE
I9HOLE-PAD0-4HOLE
I10HOLE-PAD0-4HOLE
IC205XS3045BSOP-8XS3045B
J1RFINJACK-CABLEX4PJACK-CABLEX4P
J2RFOUTJACK-CABLEX4PJACK-CABLEX4P
J3SCART-SCART-1_PBSCART-1_PB
J4SMART_CARDSMARTCARD
J5AV4-8.4-10JACK-AV4
J7BLM21P221SGUSB-A-03BUSB2
J8CON2X7CON-2X7
J9CON2X7-FEMALCON-2X7
L11.2uHIND-0805IND
L22.7uHIND-0805IND
L31.8uHIND-0805IND
L4RES-1/2WV-P4IND
L5FBIND-0805IND
L6FBIND-0805IND
L72.7uHIND-0805IND
L8IND-D6-P5IND
L9FBIND-0805IND
L1033uHIND-0805IND
L11IND-D6-P5IND
L121.8uHIND-0805IND
L141.2uHIND-0805IND
L154.7nHIND-0603AIND
L171.0uHIND-0805IND
L241.0uHIND-0805IND
L281.0uHIND-0805IND
LEM1CHO-4P-UU9.8-P8X7CHO-COMMON-4P
MARK1MARKMARK
MARK2MARKMARK
MARK3MARKMARK
MARK4MARKMARK
MARK8MARKMARK
MARK9MARKMARK
N1ZL10039ZL10039
P1HOLE(2.0)HOLE
P2HOLE(2.0)HOLE
P3HOLE(2.0)HOLE
P4HOLE(2.0)HOLE
P11HOLE(0.5)HOLE
PA1HOLE(0.5)HOLE
PA2HOLE(0.5)HOLE
PA3HOLE(0.5)HOLE
PA4HOLE(0.5)HOLE
PA5HOLE(0.5)HOLE
PA6HOLE(0.5)HOLE
PA7HOLE(0.5)HOLE
PA8HOLE(0.5)HOLE
Q1TO-92(EBC)BC858CLT1
Q2SOT-232N5551
Q3TO-220-3P-123-P2.54Q-MOSFET
Q4SOT-232N5551
Q5SOT-232N5551
Q6SOT-232N5551
Q7SOT-232N5551
Q8SOT-232N5551
Q9TO-92ABST100
Q10SOT-232N5551
Q11SOT-232N5401
Q12SOT-232N5401
Q162SC1815SOT-232N5551
Q18TO-92(EBC)BC858CLT1
Q20SOT-232N5551
Q282SC1815SOT-232N5551
R14.7kRES0603RES
R24.7kRES0603RES
R310K,NCRES0603RES
R410kRES0603RES
R5100KRES0603RES
R61kRES0603RES
R70RES0603RES
R80RES0603RES
R90RES0603RES
R100RES0603RES
R114.7KRES0603RES
R122k2RES0603RES
R1312KRES0603RES
R143.3KRES0603RES
R1520KRES0603RES
R1620KRES0603RES
R17RES-1WV-P5RES-1W---10W
R1810kRES0603RES
R194k7RES0603RES
R200RES0603RES
R21RES0805RES-SMD
R2233RES0603RES
R2333RES0603RES
R244.7KRES0603RES
R251MRES0603RES
R264k7RES0603RES
R2733RES0603RES
R2833RES0603RES
R29220RRES0603RES
R30NIRES0603RES
R310RES0603RES
R32RES0603RES-SMD
R33805RES-SMD
R3433RES0603RES
R3533RES0603RES
R361KRES0603RES
R3710KRES0603RES
R386.04K 1%RES0603RES
R3910KRES0603RES
R40RES0603RES-SMD
R41RES0603RES-SMD
R42RES0603RES-SMD
R43RES0603RES-SMD
R44RES0603RES-SMD
R452K2RES0603RES
R462K2RES0603RES
R47RES0603RES-SMD
R48RES0603RES-SMD
R491KRES0603RES
R5033RES0603RES
R5133RES0603RES
R521k8RES0805RES
R534.7KRES0603RES
R5447RRES0603RES
R5510KRES0603RES
R5610KRES0603RES
R574k7RES0603RES
R58RES0603RES-SMD
R59RES0603RES-SMD
R60RES0603RES-SMD
R61RES0603RES-SMD
R62RES0603RES-SMD
R63RES0603RES-SMD
R64RES0805RES-SMD
R65RES0805RES-SMD
R6633RES0603RES
R6733RES0603RES
R68RES0805RES-SMD
R69RES0805RES-SMD
R70RES0805RES-SMD
R71RES0805RES-SMD
R72RES0805RES-SMD
R73RES0805RES-SMD
R74RES0603RES-SMD
R75100RES0603RES
R76RES0603RES-SMD
R77RES0603RES-SMD
R78RES0805RES-SMD
R79270KRES0603RES
R80270KRES0603RES
R8115KRES0603RES
R8215KRES0603RES
R834K7RES0603RES
R844K7RES0603RES
R8520KRES0603RES
R8620KRES0603RES
R8751KRES0603RES
R8851KRES0603RES
R8975RES0603RES
R9075RES0603RES
R91RES0805RES-SMD
R92RES0603RES-SMD
R95RES0603RES-SMD
R96RES0805RES-SMD
R991kRES0603RES
R100510RES0603RES
R101510RES0603RES
R1022K2RES0603RES
R1032k2RES0603RES
R1044K7RES0603RES
R1052K2RES0603RES
R10647KRES0603RES
R10747KRES0603RES
R1084K7RES0603RES
R10910KRES0603RES
R11015RES0805RES
R1112K2RES0603RES
R158200RRES0603RES
R159200RRES0603RES
R160200RRES0603RES
R16310KRES0603RES
R16447RRES0603RES
R1681KRES0603RES
R1691KRES0603RES
R170300RES0603RES
R17110KRES0603RES
R17210KRES0603RES
R1754K7RES0603RES
R1764k7RES0603RES
R177220RES0603RES
R179150RES0603RES
R1808.2KRES0603RES
R1818.2KRES0603RES
R182MBW1608-121RES0603RES
R183MBW1608-121RES0603RES
R18451RRES0603RES
R18551RRES0603RES
R18651RRES0603RES
R18751RRES0603RES
R188100RRES0603RES
R189100RRES0603RES
R190MBW1608-121RES0603RES
R2201kRES0603RES
R221100RES0603RES
R30210KRES0603RES
R30610KRES0603RES
R30733RES0603RES
R331NCRES0603RES
R50120KRES0603RES
R50220KRES0603RES
R52075R\NCRES0603RES
R5352.2KRES0603RES
RN133RN4RN4
RV1VAR-D10-P7.5VARISTOR
T2TRAN-P10-4X20TRAN-10P-5P
THR1NTC-D8-P5THR
U1DPAKALD1117-1V8
U2SO28TDA8024
U3TO-92-123IC-TL431
U4FP128M5GACT216S-Z
U5SOP8-300S25FL004/008/016
U6TO-92-123IC-TL431
U7DIP4-P8.89AIC-PC817-AB
U8JRC4558DIP8\SOJRC4558
U9DIP8-P7.62IC-8P-FSDM0365RN
U10SOT-223LD1117A
U15SDRAM54HY57V641620HG-B
X127MHzXTALXTAL1
XS110.111MHzXTALXTAL
ZD1DIO-1206ZENER
ZD2DIO-1206ZENER
评分
参与人数 2威望 +6 收起 理由
mfkiwl + 1 哪家的方案呢
2dmin + 5
查看全部评分
重要提示:PCB作品文件展下载说明
M
管理员
发表于 2012-8-23 15:46:44 | 显示全部楼层
支持一下。 奖励奖励
社区居民
发表于 2012-8-23 21:12:14 | 显示全部楼层
没有权限下载啊,郁闷啊。怎么到二级啊
管理员
发表于 2012-8-23 21:19:30 | 显示全部楼层
发表于 2012-8-23 21:47:28 | 显示全部楼层
好好挣钱   努力学习~~~~~
发表于 2012-8-23 22:45:58 | 显示全部楼层
想下来完玩,正在努力学多层板,没权限[s:6]
发表于 2012-8-24 08:20:21 | 显示全部楼层
头像被屏蔽
社区居民忠实会员终身成就奖特殊贡献奖宣传大使奖社区明星
发表于 2012-8-24 08:48:16 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2012-8-30 13:04:13 | 显示全部楼层
发表于 2012-8-30 17:45:51 | 显示全部楼层
学习一下,字数补丁。
