查看: 2684|回复: 0
spb16.5里出矩形焊盘钻孔 方法
管理员
发表于 2012-9-4 00:55:10 | 显示全部楼层 |阅读模式
出了一些警告:
Processing route path data ...
% s' a
WARNING: No route path data was found for processing.
Processing slot hole data ...
WARNING: Can't find NC Route bit file (ncroutebits.txt)!1 a7 g! o* S+ m0 M/ d/ `- ~
          Using T01 to route ALL route cuts.
WARNING: No toolcode of a size smaller than 39.37 found for a RECTANGLE slot!
          Defaulting to T01 as toolname.
解决方法:建立个ncroutebits.txt文件,里面填上0.01 T01
导入到cam350时,对rou文件要在导入时设置一下,和钻孔时使用的参数一致就可以了。
OVAL      slots routed: 0
RECTANGLE slots routed: 3
