[问题求助] 导入问题
查看1249 | 回复2 | 2015-4-3 09:27:23 | 显示全部楼层 |阅读模式
Reading file --  C:\PADS Projects\padsnet.asc
ERROR: Component name UP1. Decal  USB5P-A  has terminal names whereas corresponding parttype CNS-USBMINIAB-A has a pin map.
UP1     CNS-USBMINIAB-A@USB5P
pin map    terminal names  区别
拜访春天 | 2015-4-3 13:34:57 | 显示全部楼层
楼主应该阐述清楚一点。
xs19820727 | 2015-4-4 08:53:20 | 显示全部楼层
