****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
[table=952,#ffffff,,0]NamePart TypePCB DecalValueANT1201ANTENNAANT/1P/SMD/818000378/ECTANT/1P/SMD/818000378/ECTAU_SPKR_P1TEST_POINT_DIP0.61PIN-1.2X2TEST POINTBEAD412BEADBEAD/SMD/0603BLM18BD252SN1C1819SMALL_CAPC060310uF/10V/X5RC1820C_/_2200_/_NF_/_0402C04021uF/16V/X5RC1821CAP_NP_0C04020.1uF/16V/X5RCON402OV7645FB_3BBL1MM0.23MMW0.4MMPH10PINWisky camera connectorCON403CXJC-PJ2_1J301T05GAGZL2PJ-S3142CON803OV7645FB_13BBL1MM0.23MMW0.4MMPH30PIN-ZMAIN CAMERA CONNECTORCON804SUB_CAMBBL1MM0.23MMW0.4MMPH24PINSUB CAMERA CONNECTORCON807OV7645FB_13_2H3/SMD/P1.25/1.25A-WTT-3P/ZHENGHE1.25A-WTT-3P(JD1)H1.85CON904IPEX-20455-040E_4LCD_40_0.5P_2.8H_HJ080NA-04F40P-0.5PITCH, BOTTOMCON1001CAR_KIT_/_MM8430-2610BMM8430-2600BMM8430-2610BCON110233PIN_2ZIF_H51/SMD/P0.3-ZAXT340124CON1402MMC_CONN_0CAF11-08173-1514/9PIN/1.7HMG716- SD-cardCON1713HEADER_1CON20X2/SMD/M/AXT440124AXT440124D4DIODE_SCHOTTKY_6RB551V-30(UMD2)RB551V-30D7RCLAMP0524PRCLAMP0524P/10P/SMDRclamp0524PD9DIODE_DIACESD0603/SMDESD0603/SMD/NCD11BAT54SSOT23BAT54SD13DIODE_SCHOTTKY_25819B5819WD300DIODE_SCHOTTKY_6RB551V-30(UMD2)BAT54WSD303DIODE/ZENERDIODE/SMD/MMSZ5221BMMSZ5231BT1GD401PG05BSESC_0SOD923/SMDESD9L5.0ST5GD402DIODE_SCHOTTKY_0D/SMD/UMD2UDZV 5.6BD1602DIODE_SCHOTTKY_6SOD-323/SMD/RB551V-30RB551V-30EMI801EMIX21A390FNPE_0FILTER/SMD/ICVE10184E150R101FRICVE10184E070R100FRF201BL1608-05K2450_0DIPLEXER/6P/SMD/DP1608DIPLEXER/6P/SMD/DP1608GND2TEST_POINT_DIP0.6TP/SMD/D0.6TEST POINTH1301SCREW_HOLE_3_0.5MMDH1_6MMNTOOLING_HOLE/4MM/NCH1302SCREW_HOLE_3_0.5MMDH1_6MMNHOLE/NPTH/D2.2/WS1962/NCJ300PORT_HDMI_TYPE-AHDMI/SMD/CON/AHDMI_TYPE-A/NCJ301PORT_HDMI_TYPE-AMICROHDMI/19P/SMD/ATOMO10130010031HDMI_TYPE-DL4INDUCTORL/IND/SMD/LVS252010-2R2VLS252010T-4R7M (4.7uH)L214INDUCTORBEAD/SMD/0402BLM15AG601SN1L305INDUCTORL/IND/SMD/2520VLS252010ET-R68NL402BEADBEAD/SMD/0603LQW18ANR10G00L802INDUCTOR_1L/IND/SMD/LVS-S3016LQH44PN4R7MPOL(4.7uH)L1005L_/_39_/_NH_/_0402R0201NCL1006L_/_27_/_NH_/_0201L040282 nHL1008L_/_8.2_/_NH_/_0402L04025.6nHL1009INDUCTOR_3L0402100 nH/NCL1201FERRITE_BEAD_SMD_0402L/IND/SMD/0603560nH/MLF1608DR56JL1203INDUCTOR_1L/IND/SMD/LVS252010-2R2LQH2HPN4R7MG0L L1601INDUCTORL/IND/SMD/LVS252010-2R2LQH2HPN4R7MG0L (4.7uH)LED304DIODE_10LED/4P/SMD/19-237ASMLP36RGB1WMIC1+TEST_POINT_DIP0_4.61PIN-1.2X2TEST POINTMIC1-TEST_POINT_DIP0_4.61PIN-1.2X2TEST POINTNC18NC_PAD_1206_SMDNC/MMD/L2/4MILNC PADQ80140852_4SOT233904Q802P_DGS_1SOT23SI2305Q80340852_4SOT233904Q1601MOSFET_P_SMD_2SOT23MI2301Q1602TRANSISTOR_NPN_SMD(B-C-E)_0SOT23LMBT3904LT1GRD4R0603_3R020142.2_1%SHIELD1TP_/_30MIL_1SH/SMD/35X41.35/MT8127/MMDSHIELDSW1201KEY_1KEY_RESETPOWERSW1302KEY_0DSWDPOWERTP77T_POINT_FTP20MILNC_TP30MILTP202TEST_POINT_SMD1.0TP/SMD/0.5MMTEST POINTTP216TEST_POINT_SMD1.0TP/SMD/D0.6TEST POINTTP252T_POINT_STP30MILTPTP340TEST_POINT_DIP0.6TP0.3MMTEST POINTTP1346TEST_POINT_DIP0.6TP/SMD/D0.6TEST POINTTP1411TEST_POINT_DIP0.6TP/SMD/0.5MMTEST POINTU1R1172X_1SOT23/5P/SMDSY8089AACU2MT6611_SMD_WLCSP-61_0MT6627-NS/MQFN40/SMD/P0.4/5X5MT6627_IPD_QFN40U3R1172X_1SOT23/5P/SMDSY8088AAC/NCU5IC_DDR3_X16_FBGA-96FBGA96/SMD/P0.8/10X14/DDR3L/16BIC DDR3 x16 FBGA-96U6IC_DDR3_X16_FBGA-96FBGA96/SMD/P0.8/10X14/DDR3L/16BIC DDR3 x16 FBGA-96U12APL5151_0SOT23-6/SMDSY7200AU13SY7208_2SOT23-6/SMDSY7208U17EPC1_0DFN8/SMD/P1.0/OTS0800DOTS080CD(NC)U22AM29PL160C_3TSOP48/SMDNAND08GW3B2CN6E/NCU201MT8127E1_DDR316_0916_RMNCMT8127/TFBGA393/P0.5/B0.27/12.1X12.6MT8127U301FDG6303_2SOT-6STT818BU302MT6323_E1_4MT6323L/TFBGA158/P0.5/B0.27/7.6X7.6MT6323LU303MOSFET_N_22-1L1B/SMD/SSM3K35MFVSSM3K35MFVU406TEA1206T_0SOT23-6/SMDMicro Power-SGM3110U502169_BALL_EMMCBGA169/THGBM1GXDXEBAI/TOSHIBASamsung KLM2G1HE3F-B001U901FILTER_EXC24CE_2FILTER_EXC24CE_1Filter_EXC24CEU1005TCXO_RAKON_SMD_4P_3TCXO/SMD/2.5X2.0/IT2205BEMT6627 QVL TCXO/NCU1006SAFEB1G57KA0F00SAW/SMD/1.05X1.35SAFEB1G57KE0F00U1010NJG1107HB3_0TSLP6/SMD/P0.4/BGA725L6/SBGA725L6U1101GT800_0QFN52/SMD/P0.4/GT911/SGT911U1201MT3301-140_SMD_PBGA-140_0MT6605/MQFN32/SMD/P0.4/4X4/SMT6605 QFN (32 Pins, 0.4mm pitch)U1208HALL_IC_AH1883HALL_IC_AH1883BU52011HFV/NCU1601SY7208_2SOT23-6/SMDSY7208U1602ADXL345_4WLCSP8/SMD/P0.4/B0.25/AK09911_AK0991U1604ADXL345_5LGA12/SMD/P0.5/BMA250EBMA250EU1607CM3623_2ALS_APDS9930APDS-9930U160974ALVC74PW_2QFN24/SMD/P0.4/MPU-6880_MPU-6880U1901TMP103AYFFTDSBGA4/SMD/P0.4/B0.25/TMP103TMP103AYFFTU1902TMP103AYFFT_0WLCSP6/SMD/P0.4/B0.23/NB3L03NB3L03/NCU1905LED_DRIVER_SY8006SOT23-5/SMDSY8006AACVBAT1TEST_POINT_DIP0.6TP/SMD/D0.6TEST POINTVIB_GND1TEST_POINT_DIP0_4.6ANT-1.5-2.5TEST POINTVR303VR0402R0402EZJZ0V500AAWIFI_BT_GPS_ANTCAR_KIT_/_MM8430-2610B_0PAD_3PINPAD_3PINX302CRYSTAL_1CRYS/SMD/MS3V-T1R32K (MS3V-T1R)X601TCXO_RAKON_SMD_4P_3TCXO/SMD/2.5X2.0/IT2205BEMT6627 QVL TCXOX1201QUARTZ_IQX0_1CRYS/SMD/FA-128QUARTZ 27.12 Mhz |
