#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/errno.h>
#include <linux/slab.h>
#include <linux/i2c.h>
#include <linux/init.h>
#include <linux/idr.h>
#include <linux/mutex.h>
#include <linux/of_device.h>
#include <linux/completion.h>
#include <linux/hardirq.h>
#include <linux/irqflags.h>
#include <linux/rwsem.h>
#include <linux/pm_runtime.h>
#include <asm/uaccess.h>
#include "i2c-core.h"
/* core_lock protects i2c_adapter_idr, and guarantees
that device detection, deletion of detected devices, and attach_adapter
and detach_adapter calls are serialized */
static DEFINE_MUTEX(core_lock);
static DEFINE_IDR(i2c_adapter_idr);
static struct device_type i2c_client_type;
//static int i2c_check_addr(struct i2c_adapter *adapter, int addr);
static int i2c_check_addr_ex(struct i2c_adapter *adapter, int addr);
static int i2c_detect(struct i2c_adapter *adapter, struct i2c_driver *driver);
#ifdef CONFIG_I2C_DEV_RK29
extern struct completion i2c_dev_complete;
extern void i2c_dev_dump_start(struct i2c_adapter *adap, struct i2c_msg *msgs, int num);
extern void i2c_dev_dump_stop(struct i2c_adapter *adap, struct i2c_msg *msgs, int num, int ret);
#endif
static const struct i2c_device_id *i2c_match_id(const struct i2c_device_id *id,
const struct i2c_client *client)
while (id->name[0]) {
if (strcmp(client->name, id->name) == 0)
return id;
id++;
return NULL;
static int i2c_device_match(struct device *dev, struct device_driver *drv)
struct i2c_client *client = i2c_verify_client(dev);
struct i2c_driver *driver;
if (!client)
return 0;
/* Attempt an OF style match */
if (of_driver_match_device(dev, drv))
return 1;
driver = to_i2c_driver(drv);
/* match on an id table if there is one */
if (driver->id_table)
return i2c_match_id(driver->id_table, client) != NULL;
return 0;
#ifdef CONFIG_HOTPLUG
/* uevent helps with hotplug: modprobe -q $(MODALIAS) */
static int i2c_device_uevent(struct device *dev, struct kobj_uevent_env *env)
struct i2c_client *client = to_i2c_client(dev);
if (add_uevent_var(env, "MODALIAS=%s%s",
I2C_MODULE_PREFIX, client->name))
return -ENOMEM;
dev_dbg(dev, "uevent\n");
return 0;
#else
#define i2c_device_uevent NULL
#endif /* CONFIG_HOTPLUG */
static int i2c_device_probe(struct device *dev)
int status;
if (!client)
return 0;
driver = to_i2c_driver(dev->driver);
if (!driver->probe || !driver->id_table)
return -ENODEV;
client->driver = driver;
if (!device_can_wakeup(&client->dev))
device_init_wakeup(&client->dev,
client->flags & I2C_CLIENT_WAKE);
dev_dbg(dev, "probe\n");
status = driver->probe(client, i2c_match_id(driver->id_table, client));
if (status) {
client->driver = NULL;
i2c_set_clientdata(client, NULL);
return status;
static int i2c_device_remove(struct device *dev)
int status;
if (!client || !dev->driver)
return 0;
if (driver->remove) {
dev_dbg(dev, "remove\n");
status = driver->remove(client);
} else {
dev->driver = NULL;
status = 0;
if (status == 0) {
return status;
static void i2c_device_shutdown(struct device *dev)
return;
if (driver->shutdown)
driver->shutdown(client);
#ifdef CONFIG_PM_SLEEP
static int i2c_legacy_suspend(struct device *dev, pm_message_t mesg)
return 0;
if (!driver->suspend)
return 0;
return driver->suspend(client, mesg);
static int i2c_legacy_resume(struct device *dev)
return 0;
if (!driver->resume)
return 0;
return driver->resume(client);
static int i2c_device_pm_suspend(struct device *dev)
const struct dev_pm_ops *pm = dev->driver ? dev->driver->pm : NULL;
if (pm)
return pm_generic_suspend(dev);
else
return i2c_legacy_suspend(dev, PMSG_SUSPEND);
static int i2c_device_pm_resume(struct device *dev)
if (pm)
return pm_generic_resume(dev);
else
return i2c_legacy_resume(dev);
static int i2c_device_pm_freeze(struct device *dev)
if (pm)
return pm_generic_freeze(dev);
else
return i2c_legacy_suspend(dev, PMSG_FREEZE);
static int i2c_device_pm_thaw(struct device *dev)
if (pm)
return pm_generic_thaw(dev);
else
static int i2c_device_pm_poweroff(struct device *dev)
if (pm)
return pm_generic_poweroff(dev);
else
return i2c_legacy_suspend(dev, PMSG_HIBERNATE);
static int i2c_device_pm_restore(struct device *dev)
if (pm)
return pm_generic_restore(dev);
else
#else /* !CONFIG_PM_SLEEP */
#define i2c_device_pm_suspend NULL
#define i2c_device_pm_resume NULL
#define i2c_device_pm_freeze NULL
#define i2c_device_pm_thaw NULL
#define i2c_device_pm_poweroff NULL
#define i2c_device_pm_restore NULL
#endif /* !CONFIG_PM_SLEEP */
static void i2c_client_dev_release(struct device *dev)
kfree(to_i2c_client(dev));
static ssize_t
show_name(struct device *dev, struct device_attribute *attr, char *buf)
return sprintf(buf, "%s\n", dev->type == &i2c_client_type ?
to_i2c_client(dev)->name : to_i2c_adapter(dev)->name);
static ssize_t
show_modalias(struct device *dev, struct device_attribute *attr, char *buf)
return sprintf(buf, "%s%s\n", I2C_MODULE_PREFIX, client->name);
static DEVICE_ATTR(name, S_IRUGO, show_name, NULL);
static DEVICE_ATTR(modalias, S_IRUGO, show_modalias, NULL);
static struct attribute *i2c_dev_attrs[] = {
&dev_attr_name.attr,
/* modalias helps coldplug: modprobe $(cat .../modalias) */
&dev_attr_modalias.attr,
NULL
static struct attribute_group i2c_dev_attr_group = {
.attrs = i2c_dev_attrs,
static const struct attribute_group *i2c_dev_attr_groups[] = {
&i2c_dev_attr_group,
NULL
static const struct dev_pm_ops i2c_device_pm_ops = {
.suspend = i2c_device_pm_suspend,
.resume = i2c_device_pm_resume,
.freeze = i2c_device_pm_freeze,
.thaw = i2c_device_pm_thaw,
.poweroff = i2c_device_pm_poweroff,
.restore = i2c_device_pm_restore,
SET_RUNTIME_PM_OPS(
pm_generic_runtime_suspend,
pm_generic_runtime_resume,
pm_generic_runtime_idle
struct bus_type i2c_bus_type = {
.name = "i2c",
.match = i2c_device_match,
.probe = i2c_device_probe,
.remove = i2c_device_remove,
.shutdown = i2c_device_shutdown,
.pm = &i2c_device_pm_ops,
EXPORT_SYMBOL_GPL(i2c_bus_type);
static struct device_type i2c_client_type = {
.groups = i2c_dev_attr_groups,
.uevent = i2c_device_uevent,
.release = i2c_client_dev_release,
* i2c_verify_client - return parameter as i2c_client, or NULL
* @dev: device, probably from some driver model iterator
* When traversing the driver model tree, perhaps using driver model
* iterators like @device_for_each_child(), you can't assume very much
* about the nodes you find. Use this function to avoid oopses caused
* by wrongly treating some non-I2C device as an i2c_client.
struct i2c_client *i2c_verify_client(struct device *dev)
return (dev->type == &i2c_client_type)
? to_i2c_client(dev)
: NULL;
EXPORT_SYMBOL(i2c_verify_client);
/* This is a permissive address validity check, I2C address map constraints
* are purposely not enforced, except for the general call address. */
static int i2c_check_client_addr_validity(const struct i2c_client *client)
if (client->flags & I2C_CLIENT_TEN) {
/* 10-bit address, all values are valid */
if (client->addr > 0x3ff)
return -EINVAL;
} else {
/* 7-bit address, reject the general call address */
if (client->addr == 0x00 || client->addr > 0x7f)
return -EINVAL;
return 0;
/* And this is a strict address validity check, used when probing. If a
* device uses a reserved address, then it shouldn't be probed. 7-bit
* addressing is assumed, 10-bit address devices are rare and should be
* explicitly enumerated. */
static int i2c_check_addr_validity(unsigned short addr)
* Reserved addresses per I2C specification:
* 0x00 General call address / START byte
* 0x01 CBUS address
* 0x02 Reserved for different bus format
* 0x03 Reserved for future purposes
* 0x04-0x07 Hs-mode master code
* 0x78-0x7b 10-bit slave addressing
* 0x7c-0x7f Reserved for future purposes
if (addr < 0x08 || addr > 0x77)
return -EINVAL;
return 0;
static int __i2c_check_addr_busy(struct device *dev, void *addrp)
int addr = *(int *)addrp;
if (client && client->addr == addr)
return -EBUSY;
return 0;
/* walk up mux tree */
static int i2c_check_mux_parents(struct i2c_adapter *adapter, int addr)
struct i2c_adapter *parent = i2c_parent_is_i2c_adapter(adapter);
int result;
result = device_for_each_child(&adapter->dev, &addr,
__i2c_check_addr_busy);
if (!result && parent)
result = i2c_check_mux_parents(parent, addr);
return result;
/* recurse down mux tree */
static int i2c_check_mux_children(struct device *dev, void *addrp)
int result;
if (dev->type == &i2c_adapter_type)
result = device_for_each_child(dev, addrp,
i2c_check_mux_children);
else
result = __i2c_check_addr_busy(dev, addrp);
return result;
static int i2c_check_addr_busy(struct i2c_adapter *adapter, int addr)
int result = 0;
if (parent)
if (!result)
return result;
* i2c_lock_adapter - Get exclusive access to an I2C bus segment
* @adapter: Target I2C bus segment
void i2c_lock_adapter(struct i2c_adapter *adapter)
if (parent)
i2c_lock_adapter(parent);
else
rt_mutex_lock(&adapter->bus_lock);
EXPORT_SYMBOL_GPL(i2c_lock_adapter);
* i2c_trylock_adapter - Try to get exclusive access to an I2C bus segment
static int i2c_trylock_adapter(struct i2c_adapter *adapter)
if (parent)
return i2c_trylock_adapter(parent);
else
return rt_mutex_trylock(&adapter->bus_lock);
* i2c_unlock_adapter - Release exclusive access to an I2C bus segment
void i2c_unlock_adapter(struct i2c_adapter *adapter)
if (parent)
i2c_unlock_adapter(parent);
else
rt_mutex_unlock(&adapter->bus_lock);
EXPORT_SYMBOL_GPL(i2c_unlock_adapter);
* i2c_new_device - instantiate an i2c device
* @adap: the adapter managing the device
* @info: describes one I2C device; bus_num is ignored
* Context: can sleep
* Create an i2c device. Binding is handled through driver model
* probe()/remove() methods. A driver may be bound to this device when we
* return from this function, or any later moment (e.g. maybe hotplugging will
* load the driver module). This call is not appropriate for use by mainboard
* initialization logic, which usually runs during an arch_initcall() long
* before any i2c_adapter could exist.
* This returns the new i2c client, which may be saved for later use with
* i2c_unregister_device(); or NULL to indicate an error.
struct i2c_client *
i2c_new_device(struct i2c_adapter *adap, struct i2c_board_info const *info)
struct i2c_client *client;
int status;
client = kzalloc(sizeof *client, GFP_KERNEL);
if (!client)
return NULL;
client->adapter = adap;
client->dev.platform_data = info->platform_data;
if (info->archdata)
client->dev.archdata = *info->archdata;
client->flags = info->flags;
client->addr = info->addr;
client->irq = info->irq;
client->udelay = info->udelay; // add by kfx
strlcpy(client->name, info->type, sizeof(client->name));
/* Check for address validity */
status = i2c_check_client_addr_validity(client);
if (status) {
dev_err(&adap->dev, "Invalid %d-bit I2C address 0x%02hx\n",
client->flags & I2C_CLIENT_TEN ? 10 : 7, client->addr);
goto out_err_silent;
/* Check for address business */
#if 0
status = i2c_check_addr_busy(adap, client->addr);
if (status)
goto out_err;
#else
/* ddl@rock-chips.com : Devices which have some i2c addr can work in same i2c bus,
if devices havn't work at the same time.*/
status = i2c_check_addr_ex(adap, client->addr);
if (status != 0)
dev_err(&adap->dev, "%d i2c clients have been registered at 0x%02x",
status, client->addr);
#endif
client->dev.parent = &client->adapter->dev;
client->dev.bus = &i2c_bus_type;
client->dev.type = &i2c_client_type;
client->dev.of_node = info->of_node;
#if 0
dev_set_name(&client->dev, "%d-%04x", i2c_adapter_id(adap),
client->addr);
#else
if (status == 0)
client->addr);
else
dev_set_name(&client->dev, "%d-%04x-%01x", i2c_adapter_id(adap),
client->addr,status);
#endif
status = device_register(&client->dev);
if (status)
goto out_err;
dev_dbg(&adap->dev, "client [%s] registered with bus id %s\n",
client->name, dev_name(&client->dev));
return client;
out_err:
dev_err(&adap->dev, "Failed to register i2c client %s at 0x%02x "
"(%d)\n", client->name, client->addr, status);
out_err_silent:
kfree(client);
return NULL;
EXPORT_SYMBOL_GPL(i2c_new_device);
#ifdef CONFIG_PLAT_RK
#define RK610_KEY "rk610"
static int __i2c_client_print(struct device *dev, void *param)
if(client)
printk(KERN_WARNING "client: %s, addr: 0x%x\n", client->name, client->addr);
return 0;
static int __i2c_check_rk610_ex(struct device *dev, void *ex)
if(!client)
return 0;
if(strstr(client->name, RK610_KEY) != NULL)
*(int *)ex += 1 << 8;
else
*(int *)ex += 1;
return 0;
int i2c_check_rk610_ex(int nr)
int ex = 0, rk610_ex = 0, oth_ex = 0;
struct i2c_adapter *adap = i2c_get_adapter(nr);
if(!adap){
printk(KERN_ERR "%s: adap(%d) is not exist\n", __func__, nr);
return -EINVAL;
device_for_each_child(&adap->dev, &ex, __i2c_check_rk610_ex);
if(ex & (1 << 8))
rk610_ex = 1;
oth_ex = ex & 0xff;
if(rk610_ex && oth_ex){
ex = 1;
printk(KERN_WARNING "******************* WARNING ********************\n");
dev_warn(&adap->dev, "%s is exist, clients:\n", RK610_KEY);
device_for_each_child(&adap->dev, NULL, __i2c_client_print);
printk(KERN_WARNING "************************************************\n");
else
ex = 0;
return ex;
#else
return 0;
#endif //end of CONFIG_PLAT_RK
EXPORT_SYMBOL_GPL(i2c_check_rk610_ex);
#ifdef CONFIG_I2C_RK30
int i2c_add_device(int nr, struct i2c_board_info const *info)
int status;
if(!adap){
return -EINVAL;
if (!client){
dev_err(&adap->dev, "no memory for client\n");
return -ENOMEM;
if (info->archdata)
if (status) {
if (status){
status = -EEXIST;
dev_warn(&adap->dev, "i2c clients have been registered at 0x%02x\n", client->addr);
int i;
for (i = 0; i < count; i++)
crc = crc8((crc ^ p) << 8);
return crc;
/* Assume a 7-bit address, which is reasonable for SMBus */
static u8 i2c_smbus_msg_pec(u8 pec, struct i2c_msg *msg)
/* The address will be sent first */
u8 addr = (msg->addr << 1) | !!(msg->flags & I2C_M_RD);
pec = i2c_smbus_pec(pec, &addr, 1);
/* The data buffer follows */
return i2c_smbus_pec(pec, msg->buf, msg->len);
/* Used for write only transactions */
static inline void i2c_smbus_add_pec(struct i2c_msg *msg)
msg->buf[msg->len] = i2c_smbus_msg_pec(0, msg);
msg->len++;
/* Return <0 on CRC error
If there was a write before this read (most cases) we need to take the
partial CRC from the write part into account.
Note that this function does modify the message (we need to decrease the
message length to hide the CRC byte from the caller). */
static int i2c_smbus_check_pec(u8 cpec, struct i2c_msg *msg)
u8 rpec = msg->buf[--msg->len];
cpec = i2c_smbus_msg_pec(cpec, msg);
if (rpec != cpec) {
pr_debug("i2c-core: Bad PEC 0x%02x vs. 0x%02x\n",
rpec, cpec);
return -EBADMSG;
return 0;
* i2c_smbus_read_byte - SMBus "receive byte" protocol
* @client: Handle to slave device
* This executes the SMBus "receive byte" protocol, returning negative errno
* else the byte received from the device.
s32 i2c_smbus_read_byte(const struct i2c_client *client)
union i2c_smbus_data data;
int status;
status = i2c_smbus_xfer(client->adapter, client->addr, client->flags,
I2C_SMBUS_READ, 0,
I2C_SMBUS_BYTE, &data);
return (status < 0) ? status : data.byte;
EXPORT_SYMBOL(i2c_smbus_read_byte);
* i2c_smbus_write_byte - SMBus "send byte" protocol
* @value: Byte to be sent
* This executes the SMBus "send byte" protocol, returning negative errno
* else zero on success.
s32 i2c_smbus_write_byte(const struct i2c_client *client, u8 value)
return i2c_smbus_xfer(client->adapter, client->addr, client->flags,
I2C_SMBUS_WRITE, value, I2C_SMBUS_BYTE, NULL);
EXPORT_SYMBOL(i2c_smbus_write_byte);
* i2c_smbus_read_byte_data - SMBus "read byte" protocol
* @command: Byte interpreted by slave
* This executes the SMBus "read byte" protocol, returning negative errno
* else a data byte received from the device.
s |
